SFH210-PPEC-D07-ID-BK
    SULLINS
    CONNHEADER.100"14POS
SFH210-PPEC-D07-ID-BK 数据手册
Headers .100” [2.54 mm] Contact Centers, IDC Socket, Insulation Displacement- SFH Series With or Without Strain Relief Mates with SBH11 series SPECIFICATIONS • • • • • • • Centered Polarizing Key Optional Operating Temperature: -40°C to +105°C UL Flammability Rating: 94V-0 Current Rating: 1 Amp Dielectric Withstanding: 500 VAC Insulation Resistance: 3,000 Megohms For .050” [1.27 mm] Pitch AWG 26-28 Flat Ribbon Cable PART NUMBER OPTIONS SFH210 - P P P C - D 10 - ID - BK - Mxxx MODIFICATION (Omit for Standard) M181 = Without Centered Polarizing Key M207 = With Polarizing Key, With Mylar in Tape & Reel (only for SFH210) M208 = Without Polarizing Key, With Mylar in Tape and Reel (only for SFH210) COLOR BK = Black TERMINATION TYPE ID = Insulation Displacement NUMBER OF CONTACT POSITIONS 03 thru 13, 15, 17, 20, 25, 30, 32 *M208 and M207 not available in 30 or 32 NUMBER OF ROWS D = Dual Row CONTACT CENTERS C = .100” [2.54 mm] SERIES SFH210 = IDC Socket, Without Strain Relief SFH213 = IDC Socket, With Strain Relief INSULATOR MATERIAL P = PBT CONTACT MATERIAL P = Phosphor Bronze Headers CONTACT FINISH - RoHS Compliant P = Gold Flash Overall E = .000100” Pure Tin, Matte, Overall V = Gold Flash on Contact Surface, Nickel on Termination J = .000015” Gold on Contact Surface, Gold Flash on Termination K = .000015” Gold on Contact Surface, Nickel on Termination DIMENSIONS For complete drawings, go to www.sullinscorp.com or e-mail techsupport@sullinscorp.com Dimensions in [ ] are in millimeters, all others are in inches. .234 [5.95] .413 [10.50] .118 [3.00] .050 [1.27] -M181 Modification (No Centered Polarizing Key) .274 [6.95] .094 [2.40] Centered Polarizing Key Optional, Requires -M181 Modification to Remove .274 [6.95] INSULATION DISPLACEMENT (ID) without Strain Relief requires SFH210 Example P/N: SFH210-PPPC-D03-ID-BK .140 [3.55] .234 [5.95] .100 [2.54] .100 [2.54] .236 [6.00] .197 [5.00] .148 [3.75] .234 [5.95] .140 [3.55] .413 [10.50] .118 [3.00] .274 [6.95] .094 [2.40] Example P/N: SFH213-PPPC-D03-ID-BK 124 .234 [5.95] Centered Polarizing Key Optional, Requires -M181 Modification to Remove .274 [6.95] INSULATION DISPLACEMENT (ID) with Strain Relief requires SFH213 .050 [1.27] -M181 Modification (No Centered Polarizing Key) .100 [2.54] .100 [2.54] www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
1. 物料型号:SFH210系列,有带和不带张力释放的选项。 2. 器件简介:IDC插座,绝缘位移(ID)连接方式,可与SBH11系列配对。 3. 引脚分配:提供03至13、15、17、20、25、30和32个接触位置的选项,但M208和M207型号不提供30或32个接触位置。 4. 参数特性: - 工作温度:-40°C至+105°C - UL阻燃等级:94V-0 - 电流等级:1安培 - 介质耐压:500 VAC - 绝缘电阻:3000兆欧 - 适用于0.050英寸(1.27毫米)间距的AWG 26-28扁平电缆 5. 功能详解:提供中心极化键的选项,可选的张力释放。 6. 应用信息:适用于扁平电缆连接。 7. 封装信息:提供了详细的尺寸信息,包括接触中心间距、整体尺寸等,单位有英寸和毫米。
SFH210-PPEC-D07-ID-BK 价格&库存
很抱歉,暂时无法提供与“SFH210-PPEC-D07-ID-BK”相匹配的价格&库存,您可以联系我们找货
