SFH213-PPPN-D06-ID-BK-M181
    SULLINS
    CONNHEADER.079"12POS
SFH213-PPPN-D06-ID-BK-M181 数据手册
Headers .079” [2.00 mm]Contact Centers, IDC Sockets, Insulation Displacement With or Without Strain Relief- SFH Series Mates with SBH21 series (See opposite page) SPECIFICATIONS • Centered Polarizing Key Optional • Operating Temperature: -45°C to +105°C • UL Flammability Rating: 94V-0 • Current Rating: 1 Amp • Dielectric Withstanding: 500 VAC • Insulation Resistance: 1000 Megohms PART NUMBER OPTIONS SFH21 - P P P N - D 10 - ID - BK - M181 SERIES SFH21 = IDC Socket Without Strain Relief, .079” [2.00 mm] Contact Centers by .079” [2.00 mm] Row Spacing SFH213 = IDC Socket With Strain Relief, .079” [2.00 mm] Contact Centers by .079” [2.00 mm] Row Spacing INSULATOR MATERIAL P = PBT CONTACT MATERIAL P = Phosphor Bronze MODIFICATION (Omit for Standard) M181 = Without Centered Polarizing Key COLOR BK = Black TERMINATION TYPE ID = Insulation Displacement NUMBER OF CONTACT POSITIONS 03 thru 13, 15, 17, 20, 22, 25, 30, 34 (SFH21) 05 thru 13, 15, 17, 20, 22, 25 (SFH213) NUMBER OF ROWS D = Dual Row CONTACT CENTERS N = .079” [2.00 mm] CONTACT FINISH - RoHS Compliant P = Gold Flash Overall V = Gold Flash on Contact Surface, Nickel on Termination DIMENSIONS For complete drawings, go to www.sullinscorp.com or e-mail techsupport@sullinscorp.com Dimensions in [ ] are in millimeters, all others are in inches. Headers .163 [4.15] .134 [3.40] .039 [1.00] .348 [8.85] .031 [0.80] .075 [1.90] .215 [5.45] .163 [4.15] .187 [4.75] INSULATION DISPLACEMENT (ID) without Strain Relief, requires SFH21 Example P/N: SFH21-PPPN-D20-ID-BK -M181 Modification (No Centered Polarizing Key) Centered Polarizing Key Optional, Requires -M181 Modification to Remove .079 [2.00] .079 [2.00] .432 [10.98] .134 [3.40] .039 [1.00] .348 [8.85] .031 [0.80] .215 [5.45] .075 [1.90] .187 [4.75] .163 [4.15] Centered Polarizing Key Optional, Requires -M181 Modification to Remove INSULATION DISPLACEMENT (ID) with Strain Relief, requires SFH213 Example P/N: SFH213-PPPN-D20-ID-BK -M181 Modification (No Centered Polarizing Key) .079 [2.00] .079 [2.00] www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 107
物料型号:SFH21系列和SFH213系列,具有不同的配置选项。
器件简介:这些是带或不带张力释放的绝缘位移(IDC)插座,与SBH21系列配对。
引脚分配:提供03至34个接触位置的选项,具体取决于系列。
参数特性: - 操作温度:-45°C至+105°C - UL阻燃等级:94V-0 - 电流等级:1安培 - 介质耐压:500 VAC - 绝缘电阻:1000兆欧
功能详解:文档提供了极化键的可选性,以及是否需要-M181修改以去除中心极化键。
应用信息:适用于需要IDC插座的应用,具体应用场景未在文档中详述。
封装信息:提供了详细的尺寸信息,包括接触中心间距、行间距等,具体图纸可在Sullins公司网站获取。
SFH213-PPPN-D06-ID-BK-M181 价格&库存
很抱歉,暂时无法提供与“SFH213-PPPN-D06-ID-BK-M181”相匹配的价格&库存,您可以联系我们找货
