APPLICABLE STANDARD
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
OPERATING
TEMPERATURE RANGE
-55 C
VOLTAGE
TO
125 V
STORAGE
TEMPERATURE RANGE
OPERATING HUMIDITY
RANGE
STORAGE HUMIDITY
RANGE
APPLICABLE CABLE
(AWG SIZE)
85 C (1)
AC
RATING
CURRENT
0.5A
APPLICABLE CABLE
(OUTER DIAMETER)
φ0.8 TO 1.0 mm
-10 C
TO
60 C (2)
40 % TO 80 %
40 % TO 70 % (2)
AWG28
SPECIFICATIONS
ITEM
CONSTRUCTION
TEST METHOD
REQUIREMENTS
GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
QT AT
30 mΩ MAX .
30 mΩ MAX .
1000 MΩ MIN.
NO FLASHOVER OR BREAKDOWN.
ACCORDING TO DRAWING.
ELECTRIC CHARACTERISTICS
CONTACT RESISTANCE
CONTACT RESISTANCE
MILLIVOLT LEVEL
METHOD
INSULATION
RESISTANCE
VOLTAGE PROOF
100 mA (DC or 1000 Hz).
20 mV MAX,
1 mA(DC OR 1000Hz)
250 V DC.
300 V AC FOR 1 min.
MECHANICAL CHARACTERISTICS
CONTACT INSERTION
AND EXTRACTION
FORCES
MECHANICAL
OPERATION
□0.5±0.002 BY STEEL GAUGE.
INSERTION FORCE: 2.9 N MAX.
EXTRACTION FORCE: 0.3 N MIN.
500 TIMES INSERTIONS AND EXTRACTIONS.
VIBRATION
FREQUENCY 10 TO 55 Hz,
AMPLITUDE : 0.76 mm,
AT 2 h FOR 3 DIRECTION.
①CONTACT RESISTANCE: 30 m MAX.
②NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
①NO ELECTRICAL DISCONTINUITY OF
1 s.
OF PARTS.
②INSULATION RESISTANCE:1000 M MIN.
③NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
②NO HEAVY CORROSION.
490 m/s2 , DURATION OF PULSE 11 ms
AT 3 TIMES FOR 3 DIRECTIONS.
SHOCK
ENVIRONMENTAL CHARACTERISTICS
DAMP HEAT
(STEADY STATE)
RAPID CHANGE OF
TEMPERATURE
EXPOSED AT
40±2 C,
90 ~ 95 %,
96
h.
TEMPERATURE -55 → +85 C
TIME
30 →
30
min.
UNDER
5 CYCLES.
(RELOCATION TIME TO CHAMBER:WITHIN 2~3 MIN)
CORROSION SALT MIST EXPOSED IN
5 % SALT WATER SPRAY FOR
48 h.
HYDROGEN SULPHIDE EXPOSED IN
3
PPM FOR 120 h.
(TEST STANDARD:JEIDA 38)
COUNT
REMARK
(1)
(2)
DESCRIPTION OF REVISIONS
DESIGNED
TEMPERATURE RISE INCLUDED WHEN ENERGIZED.
THIS STORAGE INDICATES A LONG-TERM STORAGE STATE
FOR THE UNUSED PRODUCT BEFORE THE BOARD MOUNTED.
Unless otherwise specified, refer to MIL-STD-1344.
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
CHECKED
APPROVED
HS.OKAWA
15.08.21
CHECKED
HT.YAMAGUCHI
15.08.21
DESIGNED
TH.SANO
15.08.21
DRAWN
HR.NAGAYASU
15.08.21
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
DATE
ELC-365749-00-00
HIF6-**D-1.27R(20)
CL630
0 1/1
很抱歉,暂时无法提供与“HIF6-20D-1.27R(20)”相匹配的价格&库存,您可以联系我们找货
