REVISION AK
DO NOT
SCALE FROM
THIS PRINT
TCSD-XX-X-XX.XX-01-XXX-XXX
NOTES:
1. HIDDEN LINES ARE USED TO SHOW POLARIZATION
WHEN USING -N OPTION.
2. C REPRESENTS A CRITICAL DIMENSION.
3. AS OF REV 'C' ON TCB-50 CABLE
ASSEMBLIES WILL BE LEAD FREE.
4. ALL ASSEMBLIES TO BE 100% ELECTRICALLY TESTED
FOR SHORTS AND OPENS.
5. ALL ASSEMBLIES TO BE 100% HI-POT TESTED AT 800V.
6. STRAIN RELIEF TO WITHSTAND 5LB STRAIGHT PULL.
7.WHEN CUTTING CABLE TO LENGTH, CONDUCTORS MAY NOT EXTEND PAST THE CABLE INSULATION. AK
OPTIONS #1
SEE OPTIONS BELOW
LEAD STYLE
END ASSEMBY
-S: SINGLE
-D: DOUBLE
-D: (DOUBLE END)
C1
OPTIONS #2
SEE OPTIONS BELOW
No OF POSITIONS
03, 04, 05, 07, 08, 10, 12,
13, 15, 17, 20, 22, 25
NOTE: OTHER POSITIONS
AVAILABLE AS ASO. TOOL
IS CAPABLE OF POSITIONS 2-25
ASSEMBLY LENGTH
(2 INCH MINIMUM)
XX.XX[XX INCHES x 25.4] ±.125[3.175]
(SEE NOTE 7) AK
-S (SINGLE END)
C1
(SAME AS -D UNLESS OTHERWISE STATED)
(SEE NOTE 7)
AK
.125 3.18 REF
.158 4.00 REF
(No. OF POS. x .07874[2.0000]) + .15748[4.0000] REF
C2
.200±.010 5.08±0.254
COLORED WIRE TO SIDE
OF FIRST POS. INDICATOR
* COLORED WIRE MAY BE
BLACK, BLUE, OR RED.
.010 0.25 MAX
CABLE OVERHANG (TYP)
(SEE NOTE 7) AK
2
-N OPTION
-N OPTION
-RN1 OPTION
1
.040 1.02
REF
-RN2 OPTION
-N: NOTCH POLARIZATION
(USE TCSD-XX-XX-N)
(AVAILABLE ON POS 04 THRU 25)
02
-RW: REVERSE WIRING
(NOT AVAILABLE WITH -RN1 OR -RN2 OPTIONS)
COLORED WIRE TO OPPOSITE
SIDE OF FIRST POS. INDICATOR
01
.040 1.02
REF
NOTCH DENOTES
FIRST POSITION
.125 3.18
REF
F:\DWG\MISC\MKTG\TCSD-XX-X-XX.XX-01-XXX-XXX-MKT.SLDDRW
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
MATERIAL:
DO NOT SCALE DRAWING
INSULATOR: BLACK PBT
CONTACT: HEAT TREATED BeCu
STRAIN RELIEF: BLACK PBT
PLATING:
-L: .000015 GOLD ON CONTACT AREA, TIN ON REMAINDER
-F: .000003 GOLD ON CONTACT AREA, TIN ON REMAINDER
(STANDARD PLATING IS .000030 GOLD ON CONTACT AREA,
TIN ON REMAINDER)
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
2MM DOUBLE ROW FEMALE IDC ASSEMBLY
DWG. NO.
BY: B RAY
11/20/2007
SHEET 1 OF 3
-M: MIDDLE REVERSED
-O: OUTSIDE REVERSED
REVISION AK
-P"XX": POLARIZED MATING
01
03
02
02
01
03
01
NOTE: THE SAME POSITION WILL BE
POLARIZED ON BOTH ENDS (USE PK-07-N)
01
02
01
01
01
02
01
XX±.125[3.18]
(MIN 2")
XX±.125[3.18]
(MIN 2")
-RN1 OR -RN2
(REVERSE POLARIZATION NOTCH)
TCSD-05-D-XX-01-RN2 SHOWN
MIDDLE SOCKET REVERSED WHEN DAISY CHAINED
OUTSIDE SOCKET REVERSED WHEN DAISY CHAINED
-R: REVERSE CONNECTOR
-D"XX": DAISY CHAINED
(NOT AVAILABLE WITH -RN1 OR -RN2 OPTION)
(2" MIN LENGTH, 1" INCREMENTS ONLY)
FIRST CONNECTOR
SECOND CONNECTOR
TCSD-05-D-XX-01-RN1 SHOWN
01
01
01
01
02
02
01
01
XX±.125[3.18] 6.70
(MIN 2")
XX±.125[3.18] 6.70
(MIN 2")
PROPRIETARY NOTE
NOTE:
-RN1 = REVERSE NOTCH ON 1ST CONNECTOR ONLY
AVAILABLE FOR POSITIONS 4 OR GREATER
(NOT AVAILABLE WITH -R OR -RW OPTIONS)
-RN2 = REVERSE NOTCH ON 2ND CONNECTOR ONLY
(REVERSE NOTCH NOT AVAILABLE WITH DAISY CHAIN OPTIONS)
BOTH SOCKETS REVERSED WHEN DAISY CHAINED
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
BY: B RAY
11/20/2007
SHEET 2 OF 3
REVISION AK
-SR: STRAIN RELIEF
(NOT AVAILABLE WITH -O, -M, -R, -D"XX" OR -B"XX")
(SAME AS -D, UNLESS OTHERWISE STATED)
(SOLD IN ASSEMBLIES ONLY)
(MUST USE HEAT BEND/STRAIN RELIEF TOOL ON POSITIONS 20-25)
-B"XX": BREAKOUT OPTION
6
XX
(No. OF POS.) x .07874[2.0000] + .31000[7.8740] REF
2
5.000[127.00] MAX
2.000[50.80] MIN
.039 1.00
REF
4
.310±.010 7.87±0.25
5
"XX" = NO. OF CONDUCTORS BROKEN
OUT FROM THE FIRST POSITION.
3
IN-PROCESS 2
IN-PROCESS 1
(-SR ONLY)
(-SR ONLY)
3
3
(XX.XX[XX INCHES x 25.4]+.5[19.1]) ±.125[3.175]
(XX.XX[XX INCHES x 25.4] ±.125[3.175]
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
BY: B RAY
11/20/2007
SHEET 3 OF 3
很抱歉,暂时无法提供与“TCSD-07-01”相匹配的价格&库存,您可以联系我们找货
