HCSD-08-01-N
HCSD-08-01-N
    SAMTEC(申泰)
    P=2.54mm
HCSD-08-01-N 数据手册
REVISION AE HCSD-XX-X-XX.XX-01-XXX-XXX XX.XX (SEE NOTE 10) OPTION #2 (SEE FIG 3 THRU FIG 19 FOR AVAILABLE OPTIONS) OPTION #1 (SEE FIG 3 THRU FIG 19 FOR AVAILABLE OPTIONS) LEAD STYLE No OF POSITIONS -02 THRU -36 (STANDARD COLOR CODED CABLE) (-32 & -36 ONLY AVAILABLE WITH -G OPTION) (POSITIONS 21-36: EXISTING CUSTOMERS ONLY) DO NOT SCALE FROM THIS PRINT CB-XX-28-7/36-050-G ASSEMBLY LENGTH (2 INCH MINIMUM) END ASSEMBLY -S: SINGLE END -D: DOUBLE END FIG 3 -G: GRAY CABLE (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG1) FIG 2 -T: BRIGHT ACID TIN ON ENTIRE PIN (USE HCSD-XX-01-TX) LEAVE BLANK FOR 10µ" SELECTIVE GOLD IN CONTACT AREA, BRIGHT ACID TIN ON TAIL. HCSD-08-S-XX.XX-01 SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG1) FIG 4 C XX.XX (SEE NOTE 10) .200 5.08 REF -T: TIN PLATING 01 02 (NO OF POS x .100[2.54] + .180[4.57] REF .150 3.81 REF BROWN OR RED WIRE INDICATES POS #1 CB-XX-28-7/36-050-C FLUSH TO .010[0.25] MAX CABLE OVERHANG (TYP)(SEE NOTE 9) HCSD-XX-01-N .050 1.27 REF FIG 5 .375 9.53 REF (SEE NOTE 5) HCSD-XX-01-X FIG 1 HCSD-08-D-XX.XX-01 SHOWN -N: NOTCH (NOT AVAILABLE ON -02 POSITION) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG1) NOTCH DENOTES FIRST POSITION (SEE NOTE 8) NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. HIDDEN LINES ARE USED TO SHOW POLARIZATION WHEN USING -N OPTION. C 3. ALL ASSEMBLIES TO BE 100% ELECTRICALLY TESTED FOR SHORTS AND OPENS 4. ALL ASSEMBLIES TO BE 100% HI-POT TESTED AT 1000V. 5. HCSD-XX-01-X TO BE PRESSED TOGETHER WITH NO GAPS BETWEEN CABLE & BODIES. 6. CONDUCTORS SHALL BE CONSISTENT IN APPEARANCE, SOLDER MUST MAINTAIN C CABLE STRANDS WITHIN THE MAX DIA. TOLERANCE. 7. NOTE DELETED. 8. FOR R OR RW OPTION, CABLE RIB ORIENTATION CAN BE EITHER TOWARDS OR AWAY FROM THE CAP. 9. WHEN CUTTING CABLE TO LENGTH, CONDUCTORS SHOULD NOT EXTEND PAST THE CABLE INSULATION, EXTENDING LESS THAN 25% OF CABLE THICKNESS ON CONSECUTIVE AND LESS THAN 50% OF THE CABLE THICKNESS ON NON-CONSECUTIVE STRANDS IS CONSIDERED A PROCESS INDICATOR. 10. FOR LENGTHS LESS THAN 12.5", TOLERANCE SHALL BE ±.125[3.18], ALL OTHER LENGTHS SHALL BE ±1%. 11. PACKAGE -STX USING SKIN PACKAGING PER THE PACKAGING MANUAL. FOLLOW THE IDC FLOW CHART IN THE MANUAL FOR ALL OTHER OPTIONS. 12. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW. SAMTEC .COM. F:\DWG\MISC\MKTG\HCSD-XX-X-XX.XX-01-XXX-XXX-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 1 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:2 INSULATOR: LCP, UL 94 VO, COLOR: BLACK CONTACT: PHOS BRONZE CABLE: COLOR-CODED OR GRAY PVC/TIN PLATED COPPER 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .100 CL MOLD TO POS DOUBLE ROW FEMALE ASSEMBLY HCSD-XX-X-XX.XX-01-XXX-XXX BY: KOLB 08/03/1990 SHEET 1 OF 4 REVISION AE BROWN OR RED WIRE LENGTH ±.0625[1.588] .030[0.76] MAX (AFTER STRIPPED AND TINNED) SEE NOTES 6 & 7 .0625[1.588] MAX FLAT WIRE ALLOWED XX (SEE NOTE 10) MIN 2.00[50.80] FIRST POSITION INDICATOR FIG 7 -ST"X": STRIPPED AND TINNED (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG1) (NOT AVAILABLE IN 28 POS AND UP) FIG 6 FIG 8 -D"XX": DAISY CHAIN DOUBLE (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG1) (2 INCH MIN WITH 1 INCH INCREMENTS) -RW: REVERSE WIRING (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG1) BOTH SOCKETS REVERSED WHEN DAISY CHAINED HCSS-XX-01-X MIDDLE SINGLE TO TERMINATE TO CONDUCTOR #1 02 04 FIRST POSITION INDICATOR FIRST POSITION INDICATOR FIG 11 XX (SEE NOTE 10) MIN 2.00[50.80] FIG 9 -R: REVERSE CONNECTOR (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG1) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. FIG 10 -W"XX": WIRING REVERSED (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG1) F:\DWG\MISC\MKTG\HCSD-XX-X-XX.XX-01-XXX-XXX-MKT.SLDDRW 01 03 -P"XX": POLARIZED MATING (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG1) XX = POSITION NO INSERT POLARIZING KEY PART NO PK-06-N INTO SPECIFIED POSITION -XX (BOTH ENDS) END SINGLE TO TERMINATE TO CONDUCTOR #2 XX (SEE NOTE 10) MIN 2.00[50.80] 02 04 01 03 DO NOT SCALE DRAWING SHEET SCALE: 3:2 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100 CL MOLD TO POS DOUBLE ROW FEMALE ASSEMBLY DWG. NO. HCSD-XX-X-XX.XX-01-XXX-XXX BY: KOLB 08/03/1990 SHEET 2 OF 4 REVISION AE END SINGLE TO TERMINATE TO CONDUCTOR #2 FIRST POSITION INDICATOR FIRST POSITION INDICATOR MIDDLE SINGLE TO TERMINATE TO CONDUCTOR #1 FIRST POSITION INDICATOR HCSS-XX-01-X HCSS-XX-01-X HCSS-XX-01-X XX (SEE NOTE 10) MIN 2.00[50.80] FIG 13 FIG 14 -W"XX"-M: MIDDLE REVERSED (SAME AS FIG 1, DIFFERENT AS SHOWN) -S"XX"-M: MIDDLE REVERSED (SAME AS FIG 1, DIFFERENT AS SHOWN) FIG 12 -S"XX": DAISY CHAIN SINGLE (SAME AS FIG 1, DIFFERENT AS SHOWN) (2 INCH MIN WITH 1 INCH INCREMENTS) SCALE: 3:2 FIRST POSITION INDICATOR FIRST POSITION INDICATOR FIRST POSITION INDICATOR HCSS-XX-01-X "XX" FIG 17 -D"XX"-M: MIDDLE REVERSED (SAME AS FIG 1, DIFFERENT AS SHOWN) FIG 16 -S"XX"-O: OUTSIDE REVERSED (SAME AS FIG 1, DIFFERENT AS SHOWN) 5.000[127.00] MAX 2.000[50.80] MIN FIG 15 -BXX: BREAKOUT OPTION (SAME AS FIG 1, DIFFERENT AS SHOWN) "XX" = NO OF CONDUCTORS BROKEN OUT FROM THE FIRST POSITION (HCSD-08-XX.XX-01-N-B04 SHOWN) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 F:\DWG\MISC\MKTG\HCSD-XX-X-XX.XX-01-XXX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100 CL MOLD TO POS DOUBLE ROW FEMALE ASSEMBLY DWG. NO. HCSD-XX-X-XX.XX-01-XXX-XXX BY: KOLB 08/03/1990 SHEET 3 OF 4 REVISION AE FIRST POSITION INDICATOR HCSS-XX-01-X FIRST POSITION INDICATOR FIG 18 -W"XX"-O: OUTSIDE REVERSED (SAME AS FIG 1, DIFFERENT AS SHOWN) FIG 19 -D"XX"-O: OUTSIDE REVERSED (SAME AS FIG 1, DIFFERENT AS SHOWN) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 F:\DWG\MISC\MKTG\HCSD-XX-X-XX.XX-01-XXX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100 CL MOLD TO POS DOUBLE ROW FEMALE ASSEMBLY DWG. NO. HCSD-XX-X-XX.XX-01-XXX-XXX BY: KOLB 08/03/1990 SHEET 4 OF 4
HCSD-08-01-N 价格&库存
很抱歉,暂时无法提供与“HCSD-08-01-N”相匹配的价格&库存,您可以联系我们找货
HCSD-08-01-N
  • 1+29.279801+3.77945
