FFSD-15-01-N
FFSD-15-01-N
    SAMTEC(申泰)
    P=1.27mm
FFSD-15-01-N 数据手册
REVISION AU NOTES: 1. HIDDEN LINES ARE USED TO SHOW POLARIZATION WHEN USING -N OPTION. 2. C REPRESENTS A CRITICAL DIMENSION. 3. FFSD CABLE ASSEMBLIES ARE LEAD FREE. 4. ALL ASSEMBLIES TO BE 100% ELECTRICALLY TESTED FOR SHORTS AND OPENS. C 5. ALL ASSEMBLIES TO BE 100% HI-POT TESTED AT 630V. 6. STRAIN RELIEF TO WITHSTAND 5LB[22N] STRAIGHT PULL. No OF POSITIONS 7. NOTE DELETED. -02 THRU -25 8. WHEN CUTTING CABLE TO LENGTH, CONDUCTORS SHOULD NOT EXTEND (PER ROW) PAST THE CABLE INSULATION, EXTENDING LESS THAN 25% OF CABLE END ASSEMBLY THICKNESS ON CONSECUTIVE AND LESS THAN 50% OF CABLE THICKNESS ON NON-CONSECUTIVE STRANDS IS CONSIDERED A PROCESS INDICATOR. -S: SINGLE END 9. REFERENCE FFSD-XX-XX-X-N-XXX FOR CONNECTOR ASSEMBLY -D: DOUBLE END DIMENSIONS AND ITS REQUIREMENTS. C 10. COLORED WIRE MUST MATCH FIRST POSITION INDICATOR ASSEMBLY LENGTH ON THE FIRST CONNECTOR FOR ALL OPTIONS WITH THE (INCLUDES ADDED OPTION LENGTHS) EXCEPTION OF -RW. ALL OPTIONS THAT USE -D"XX": 4.00 [101.6] MINIMUM 11. FOR LENGTHS LESS THAN 12.5", TOLERANCE SHALL BE +/-.125, ALL OTHER OPTIONS: 1.00 [25.4] MINIMUM ALL OTHER LENGTHS SHALL BE +/-1%. FFSD-XX-X-XX.XX-01-X-X-XXX DO NOT SCALE FROM THIS PRINT OPTION -RW: REVERSE WIRING (NOT AVAILABLE WITH -RN1 OR -RN2) -D"XX": DAISY CHAIN (MINIMUM 2.00[50.8], 1.00[25.4] INCREMENTS) -R: REVERSED (-D"XX" OPTIONAL) (NOT AVAILABLE WITH -M OR -O) -RN1: REVERSE POLARIZATION NOTCH (NOT AVAILABLE WITH -RW OR -RN2) -RN2: REVERSE POLARIZATION NOTCH (NOT AVAILABLE WITH -RW OR -RN1) -M: MIDDLE REVERSE (REQUIRES -D"XX") (NOT AVAILABLE WITH -R OR -O) -O: OUTSIDE REVERSE (REQUIRES -D"XX") (NOT AVAILABLE WITH -R OR -M) -SR: STRAIN RELIEF (NOT AVAILABLE WITH -O, -M, -R, OR -D"XX") (SOLD AS ASSEMBLIES ONLY) LEAD STYLE PLATING OPTIONS - LEAVE BLANK FOR STANDARD, USE C-67-L: 10µ" GOLD IN CONTACT AREA TIN IN IDC AREA -S: USE C-67-S: 30µ" GOLD IN CONTACT AREA TIN IN IDC AREA -F: USE C-67-F: 3µ" GOLD IN CONTACT AREA TIN IN IDC AREA C XX.XX[XX.X x 25.4]±1% (SEE NOTE 8 & 11) STANDARD POLARIZATION NOTCH -N: POLARIZATION NOTCH (NOT AVAILABLE IN -02 THRU -04) (LEAVE BLANK FOR -02, -03, -04) .075 1.91 REF .120 3.05 REF C (No OF POS x .050[1.27]) + .165[4.19] .006 0.15 MAX +.006 XX.XX[XX.X x 25.4]±1% (SEE NOTE 8 & 11) FLUSH TO .010 0.25 MAX CABLE OVERHANG (SEE NOTE 8) 2 RED WIRE TO SIDE OF FIRST POS INDICATOR -N OPTION +0.15 C .200 - .003 5.08 - 0.08 -N OPTION 1 .040 1.02 REF FIG 2 (FFSD-10-S-XX.XX-01-X-N SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) NOTCH DENOTES FIRST POSITION FIG 1 (FFSD-10-D-XX.XX-01-X-N SHOWN) RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR THIS DOCUMENT CONTAINS CONFIDENTIAL AND TOLERANCES ARE: MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS DECIMALS ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: FIG 11 (FFSD-10-X-XX.XX-01-X-N-RW SHOWN) F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW PROPRIETARY NOTE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. * * PROPRIETARY INFORMATION AND ALL DESIGN, AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 INSULATORS: PBT UL94V-0, COLOR: BLACK CONTACT: BeCu WIRE: 30 AWG, 7/38, TINNED, STRANDED WITH GRAY PVC INSULATOR PLATING: .000010 GOLD OVER .000050 NICKEL REMAINDER: .000200 REF TIN OVER .000050 NICKEL DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 1 OF 5 REVISION AU FIRST CONNECTOR, FIRST POSITION INDICATOR SECOND CONNECTOR, FIRST POSITION INDICATOR 03 01 02 FIRST POSITION INDICATOR (FFSD-10-S-XX.XX-01-X-N-RN1 SHOWN) (SAME AS FIG 2, DIFFERENT AS SHOWN) SECOND CONNECTOR, FIRST POSITION INDICATOR FIRST CONNECTOR, FIRST POSITION INDICATOR (FFSD-10-D-XX.XX-01-X-N-RN2 SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (FFSD-10-D-XX.XX-01-X-N-RN1 SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) FIG 3 (FFSD-10-X-XX.XX-01-X-N-RNX SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (REVERSE NOTCH NOT AVAILABLE WITH -RW OR ANY DAISY CHAIN OPTIONS) -RN1 = REVERSE NOTCH ON 1ST CONNECTOR ONLY (NOT AVAILABLE WITH -R OPTION) -RN2 = REVERSE NOTCH ON 2ND CONNECTOR ONLY (NOT AVAILABLE WITH -R OPTION) * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 2 OF 5 REVISION AU WITH -RW OPTION ONLY: RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR WITH -RW OPTION ONLY: RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") FIRST POSITION INDICATOR FIRST POSITION INDICATOR XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") MIDDLE CONNECTOR REVERSED WHEN DAISY CHAINED OUTSIDE CONNECTOR REVERSED WHEN DAISY CHAINED FIG 4 (FFSD-10-D-XX.XX-01-X-N-DXX-O SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) FIG 5 (FFSD-10-D-XX.XX-01-X-N-DXX-M SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) WITH -RW OPTION ONLY: RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR WITH -RW OPTION ONLY: RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR FIRST POSITION INDICATOR XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") FIRST POSITION INDICATOR XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") FIG 7 (FFSD-10-D-XX.XX-01-X-N-DXX SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, BOTH CONNECTORS REVERSED WHEN DAISY CHAINED INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY FIG 6 OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. (FFSD-10-D-XX.XX-01-X-N-DXX-R SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (NOT AVAILABLE WITH -RN1 OR -RN2 OPTION) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 3 OF 5 WITH -RW OPTION ONLY: RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR REVISION AU (No OF POS x .050[1.27]) C + .315[8.00] REF XX.XX[XX.X x 25.4] + .4375[11.113]±.125[3.18] IN-PROCESS 1 (2-15 POS -SR ONLY FOR DOUBLE END) 4 .039 0.99 .335±.010 8.51±0.25 3 C (XX.XX[XX.XX x 25.4] ± .13[3.2]) C (XX.XX[XX.XX x 25.4] .13[3.2] FIG 9 IN-PROCESS 2 STRAIN RELIEF OPTION (POS 2-15 ONLY) (FFSD-10-D-XX.XX-01-X-N-SR SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2-15 POS -SR ONLY FOR DOUBLE END) XX.XX[XX.XX x 25.4] +.4375[11.113] .125[3.18] IN-PROCESS 1 (16-25 POS -SR ONLY FOR DOUBLE END) C XX.XX[XX.XX x 25.4] .13[3.2] IN-PROCESS 2 +0.05 .0228+-.002 .000 0.58 0.00 (16-25 POS -SR ONLY FOR DOUBLE END) DETAIL 'A' SCALE 8 : 1 6 IN-PROCESS 3 (16-25 POS -SR ONLY FOR DOUBLE END) * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, 'A' MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS 5 WRITTEN CONSENT OF SAMTEC, INC. FIG 10 STRAIN RELIEF OPTION (POS 16-25 ONLY) (FFSD-25-D-XX.XX-01-X-N-SR SHOWN) (SAME AS FIG 9, DIFFERENT AS SHOWN) SCALE 1 : 1 DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 4 OF 5 REVISION AU (XX.XX[XX.XX x 25.4] ± .125[3.18]) XX.XX[XX.XX x 25.4] +.4375[11.113] .125[3.18] IN-PROCESS 1 IN-PROCESS 1 (FFSD-XX-S-XX.XX-01-X-N-RW ONLY) (16-25 POS -SR ONLY FOR SINGLE END) XX.XX[XX.XX x 25.4] .125[3.18] C XX.XX[XX.X x 25.4] + .4375[11.113]±.125[3.18] IN-PROCESS 1 IN-PROCESS 2 (2-15 POS -SR ONLY FOR SINGLE END) (16-25 POS -SR ONLY FOR SINGLE END) IN-PROCESS 3 (16-25 POS -SR ONLY FOR SINGLE END) (XX.XX[XX.XX x 25.4] ± .125[3.18]) C * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS IN-PROCESS 2 AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE (2-15 POS -SR ONLY FOR SINGLE END) 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2.5:1 F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 5 OF 5
FFSD-15-01-N
1. 物料型号:文档中提到了多种型号,例如FFSD-XX-01-X-N-XX,CB-XX-30-7/38-025-GR等。 2. 器件简介:文档中没有直接提供器件简介,但根据上下文推测,这可能是关于某种电缆组件或连接器的规格说明。 3. 引脚分配:文档中提到了不同配置的引脚分配,例如“-02 THRU -25 (PER ROW)”和“RED WIRE TO SIDE OF FIRST POS INDICATOR”。 4. 参数特性:文档中列出了多个参数,例如电缆长度、引脚间距、绝缘材料规格等。例如,电缆长度的公差为“±1%”,绝缘材料为“PBT UL94V-0, COLOR: BLACK”。 5. 功能详解:文档中描述了多种功能选项,如“-RW: REVERSE WIRING”,“-R: REVERSED”,“-SR: STRAIN RELIEF”等。 6. 应用信息:文档中提到了应用信息,如电缆组件需要承受的拉力“5LB[22N] STRAIGHT PULL”,以及电气测试要求“100% ELECTRICALLY TESTED FOR SHORTS AND OPENS”。 7. 封装信息:文档中提供了封装的详细尺寸和材料信息,例如“.050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY”。
FFSD-15-01-N 价格&库存
很抱歉,暂时无法提供与“FFSD-15-01-N”相匹配的价格&库存,您可以联系我们找货
FFSD-15-01-N
  • 25+56.83981
  • 50+49.37966
  • 100+42.52406
  • 500+38.31639
  • 1000+34.54400
  • 2500+28.12368
  • 4175+23.83137
库存:200
FFSD-15-01-N
  • 1+67.229561+8.74170
  • 25+58.2676025+7.57640
  • 50+50.6217650+6.58223
  • 100+43.59103100+5.66804
  • 500+39.28500500+5.10814
  • 1000+39.218731000+5.09952
库存:281
