High Performance Ribbon Cable Connector
HIF3A Series
■Features
1. Two-Point Contact Structure
This connector is designed in the two-point contact structure with high
reliability.
2. Compatibility with HIF3 Series
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
This connector is compatible with HIF3B series products compliant with
MIL standard and other HIF series headers.(Except HIF3B-60 pos.)
3. Applicable Cable AWG#28
The applicable cable is UL2651 AWG#28 flat cable
(7 cores./0.127mm, jacket dia 0.9±0.1mm).
■Applications
Computers, terminal equipment, PPC, various kinds of electronic
equipment, and office automation machines
■Product Specifications
Current rating : 1A
Rating
Operating Temperature Range : –55 to +85ç (Note 1) Storage Temperature Range : –10 to +60ç (Note 2)
Voltage rating : 200V AC Operating Moisture Range : 40 to 80%
Item
Storage Humidity Range
Specification
: 40 to 70% (Note 2)
Condition
1000M ohms min
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
3. Contact Resistance
15m ohms max
0.1A
4. Vibration
No electrical discontinuity of 1μs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
1. Insulation Resistance
5. Humidity (Steady state) Insulation resistance: 1000M ohms min.
6. Temperature Cycle
96 hours at temperature of 40ç and humidity of 90% to 95%
(-55ç: 30 minutes ➝ 15 to 35ç: 5 minutes max.
No damage, cracks, or parts looseness.
125ç: 30 minutes ➝ 15 to 35ç: 5 minutes max.) 5 cycles
7. Durability (Mating/un-mating) Contact resistance: 15m ohms max.
500 cycles
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Material
Part
Material
Finish
Remarks
Insulator
PBT
Black
UL94V-0
Contact
Beryllium copper
Gold plated over nickel underplated
■Ordering Information
HIF3A - * D - 2.54 R
q
w
e
q Series Name
: HIF3A
w Number of Contacts : 16, 20, 26, 30, 34, 40, 50, 60
e Contact alignment
: D : Double
r
t
r Contact Pitch
t Connection type R
: 2.54mm
: ID type
B13
HIF3A Series●High Performance Ribbon Cable Connector
■Socket Type
Body
Protector
Clamp
Note1: The 50 contact and 60 contact connectors
contain convex area at two points.
Note2: The 60 contact connector indicates 5.6.
The applicable pin header is HIF3BAF type.
Unit:mm
B14
Part Number
CL No.
Number of Contacts
A
B
C
D
E
HIF3A-10D-2.54R
562-0057-5
10
17.27 10.16 11.43 17.27 17.27
HIF3A-16D-2.54R
562-0058-8
16
24.89 17.78 19.05 24.89 24.89
HIF3A-20D-2.54R
562-0059-0
29.97 22.86 24.13 29.97 29.97
HIF3A-26D-2.54R
562-0060-0
26
37.59 30.48 31.75 37.59 37.59
HIF3A-30D-2.54R
562-0055-0
30
42.67 35.56 36.83 42.67 42.67
HIF3A-34D-2.54R
562-0061-2
34
47.75 40.64 41.91 47.75 47.75
HIF3A-40D-2.54R
562-0062-5
40
55.37 48.26 49.53 55.37 55.37
HIF3A-50D-2.54R
562-0063-8
50
68.07 60.96 62.23 68.07 68.07
HIF3A-60D-2.54R
562-0056-2
60
80.77 73.66 74.93 80.77 80.77
RoHS
YES
很抱歉,暂时无法提供与“HIF3A-40D-2.54R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+82.31936
- 10+61.01318
- 40+56.96324
