EF1-38R-1SCA
EF1-38R-1SCA
    HRS(广濑)
    CONN RCPT 1POS DIN A KEY BLACK
EF1-38R-1SCA 数据手册
MKT-E-12014F EF1 Series Simple Assembly In-Line Power Connector Up to 130 Amps DIN Rail Mount Type  Features Panel Mount Type 1. Crimp contact turns into a connector by just inserting into  Dimensions the housing 2. Quick and secure snap-in lock, no retightening of screw (DIN Rail Mount Type) 3. Supports 130 Amps by using 38 mm2 conductor size cable 4. Selectable mounting type; Attachable to DIN rail or panel 32 5. Easy crimp termination with market commodity tool 6. 4 types of mating keys available DIN Rail 7. Will be TÜV, UL certified 8. RoHS compliant  Specifications 130 A (38mm2 wire conductor size cable) Rated Coltage AC 600 V, DC 600 V Operating Temperature Range - 25 ˚C to + 105 ˚C Contact Resistance 0.5 m MAX. [DC 1 A] Insulation Resistance 1000 M MIN. [DC 500 V] Withstanding Voltage AC 3310 V for 1 minute Durability 30 times 85 Rated Current 50 (Panel Mount Type)  High Current Capability 56.5 EF1 軽減曲線(ディレーティングカーブ) 23.6 [Derating Curve (Typical)] [ディレーティングカーブ (Typical)] 250.00 150.00 100.00 72.8 通Current 電 電 流 [ (A) A] 200.00 50.00 0.00 0 20 40 60 80 100 Ambient 周囲温度[℃] Temperature (˚C) 120 NOTE: Crimp contact is attached to each housing as a set. 37.9 All the dimensions in millimeters Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities. © 2013 HIROSE ELECTRIC CO., LTD. All rights reserved. Issued: Mar. 5, 2013
EF1-38R-1SCA 价格&库存
很抱歉,暂时无法提供与“EF1-38R-1SCA”相匹配的价格&库存,您可以联系我们找货
