EF1-38RA-1SCA(30)
EF1-38RA-1SCA(30)
    HRS(广濑)
    CONN RCPT 1POS PNL MNT A KEY RED
EF1-38RA-1SCA(30) 数据手册
EF1 Series Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Simple Assembly In-Line Power Connectors for up to 160A Dec. 2020 ⑥ EF1 Series/Simple Assembly In-Line Power Connectors for up to 160A Features 1. Connection by simply inserting the ring terminal into the case Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Connection is completed with only a few labor steps by simply crimping the contact to the power cable and inserting to the housing. 2. Quick snap- in lock, no screw retightening The snap- in mating design reduces the number of cable routing steps. Since the connector does not use screws, there is no risk of loosening. 3. Rated Current of 160A when using 38mm2 cable The conductor diameter of 5. 5, 8, 14 and 22mm2 cables can be converted to 38mm2 by using a sleeve. 4. Choice of two mounting options: DIN rail attachment or panel This connector is versatile enough to be used in a wide range of mounting applications. 5. Simplified crimp termination No special tools are required. 6. Equipped with guide keys Guide keys are used to prevent incorrect wiring. 7. TÜ V, UL certified 8. RoHS compliant 2 EF1 Series/Simple Assembly In-Line Power Connectors for up to 160A Product Specifications Rated Current (Note 1) Rated Voltage Rated Current (Note 1) Rated Voltage Note 1 : Note 2 : -25 ~ +105℃ 160A Storage Temperature Range -10 ~ +60℃ 2 AWG, 38mm2 4 AWG, 22mm2 6 AWG, 14mm2 8 AWG, 8mm2 10 AWG, 5.5mm2 Operating Temperature (Note 2) -25 ~ +105℃ 130A 94A 70A 50A 40A Storage Temperature Range -10 ~ +60℃ AC/DC 600V 2 AWG, 38mm2 4 AWG, 22mm2 6 AWG, 14mm2 8 AWG, 8mm2 10 AWG, 5.5mm2 Operating Temperature (Note 2) -25 ~ +105℃ 130A 94A 70A 50A 40A Storage Temperature Range -10 ~ +60℃ AC/DC 600V The rated current value varies depending on the ambient temperature in which the connector is used. It is recommended to use the product within the derating curve zone (dashed lines). When using a UL or TÜV approved product, please use the product within the specified range as well as the derating curve area. Includes the temperature rise due to current flow. Items Specifications Conditions Contact Resistance 0.5m Ω Max. Measured with 1A DC Insulation Resistance 1,000M Ω Min. Measured with 500V DC Withstanding Voltage No flashover or breakdown 3310V AC for 1 min. Mating Durability Contact Resistance : 1m Ω Max. Inserting and Extracting Force : 150N Max. 30 mating cycles Temperature Cycles Insulation Resistance : 1,000M Ω Min. -55℃ : 30 minutes → Room temperature : 2 to 3 minutes → 105℃ : 30 minutes → Room temperature : 2 to 3 minutes 5 cycles Salt Water Spray No functional problems Left for 48 hours in 5% concentration of salt water Humidity Resistance (Steady State) Insulation Resistance : 10M Ω Min. (in high humidity) 100M Ω Min. (dry) Temperature 40℃ , humidity 90 to 95%, 96 hours [Reference] Derating Curve and Temperature Rise Curve [Derating Curve] 250 Basic Curve Derating Curve [Temperature Rise Curve] 250 200 Current [A] 200 Current [A] Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Rated Voltage TÜV Operating Temperature (Note 2) AC/DC 1000V Rated Current (Note 1) UL 2 AWG, 38mm2 150 100 150 100 50 50 0 0 Ambient Temperature [℃] Note 1 : Note 2 :                Ambient Temperature [℃] The derating curve is derived from the basic curve multiplied by the derating factor of 0.8. The derating curve and temperature rise curve are measured under the following conditions: • Product unused prior to testing • Cable conductor cross-sectional area : 38mm2 (2 AWG) • Measured with power supplied in stationary state 3 EF1 Series/Simple Assembly In-Line Power Connectors for up to 160A Material / Finish Component Material Insulator Finish Remarks PBT Resin Black, Red or Blue UL94V-0 Copper Alloy Tin Plated - Contact Spring Contact Sleeve Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Connector EF 1 - 38 R A - 1 S C A (##) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❾ ■ Sleeve EF 1 - 38 - 22 (##) ❶ ❷  ❾ ❶ Series Name EF1 ❻ Connector Design S : Spring Contact Side P : Non-spring Contact Side ❷ Contact Size 38 : 38-5 size contact ❼ Contact Termination Method C : Crimp Termination ❸ Connector Type P : Plug R : Receptacle None : Sleeve ❽ Mating Guide Display 4 different keying options available from A to D ❹ Serial Symbol ❺ No. of Pos. ❾ 1  Other specification differences are noted with (01), (02)... to distinguish certain variations. Supported Cables 22 : Supports a cable with conductor crosssectional area equivalent to 22mm2 14 : Supports a cable with conductor cross-sectional area equivalent to 14mm2 8 : Supports a cable with conductor crosssectional area equivalent to    5.5 and 8mm2 4 EF1 Series/Simple Assembly In-Line Power Connectors for up to 160A Receptacle (DIN Rail Mount Type) 67.2 Mating Key Mark A Unit : mm Part No. HRS No. EF1-38R-1SCA(20) CL0142-0001-3-20 EF1-38R-1SCB(20) CL0142-0009-5-20 EF1-38R-1SCC(20) CL0142-0011-7-20 EF1-38R-1SCD(20) CL0142-0013-2-20 Purchase Unit Remarks 10pcs per bag - Receptacle (Panel Mount Type) 37.9 65.8 9.3 .5 φ4 2× Mating Key Mark 72.8 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 46.7 31.6 A Unit : mm Part No. HRS No. Purchase Unit Remarks EF1-38RA-1SCA(20) CL0142-0003-9-20 - EF1-38RA-1SCA(30) CL0142-0003-9-30 Color : Red EF1-38RA-1SCB(20) CL0142-0004-1-20 - EF1-38RA-1SCB(31) CL0142-0004-1-31 EF1-38RA-1SCC(20) CL0142-0015-8-20 - EF1-38RA-1SCD(20) CL0142-0016-0-20 - EF1-38RA-1SCD(30) CL0142-0016-0-30 Color : Red 10pcs per bag 5 Color : Blue EF1 Series/Simple Assembly In-Line Power Connectors for up to 160A Plug 25.4 38-5 Unit : mm Part No. HRS No. Purchase Unit Remarks EF1-38P-1PCA CL0142-0002-6-00 - EF1-38P-1PCA(10) CL0142-0002-6-10 Color : Red EF1-38P-1PCB CL0142-0005-4-00 EF1-38P-1PCC CL0142-0010-4-00 - EF1-38P-1PCD CL0142-0012-0-00 - 10pcs per bag - Sleeve 12 φ9.2 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 28.3 53 Unit : mm Part No. EF1-38-22 HRS No. Purchase Conductor Cross-Sectional Area of Applicable Cable Rated Current Unit CL0142-0006-7-00 EF1-38-8 CL0142-0007-0-00 EF1-38-14 CL0142-0008-2-00 100pcs per bag 6 22mm2 94A ① 8mm2, ② 5.5mm2 ① 50A, ② 40A 14mm2 70A EF1 Series/Simple Assembly In-Line Power Connectors for up to 160A Panel Cut-Out Dimensions from Receptacle Mounted Side Single Mounting Dual Mounting +0.1 2×φ4 + 15.55+0.1 0 20.05 0 .5 0.1 +0.1 15.55 +0.1 0 36.1±0.1 20.05 0 0 .5 +0.1 0 .5 7.8±0.1 42.2 +0.2 0 R0 4× 61.8±0.1 7.8±0.1 61.8±0.1 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 42.2+0.2 0 R0 4× 4.5 4×φ Recommended Crimp Tools Type Manual Hydraulic Type Crimp Tool Electric Hydraulic Type Crimp Tool Part No. HT111/9H-60 HT112/REC-150F HRS No. CL0902-1515-2-00 CL0902-1516-5-00 Remarks Equivalent Product : 9H-60 made by Maxell Izumi Co., Ltd. Equivalent Product : REC-150F made by Maxell Izumi Co., Ltd. Note : Please perform regular maintenance on the crimp tool based on the instruction manual. Safety Precautions Warning ● Do not touch the exposed conductor while it is energized, failing to follow this warning may cause an electric shock   and injury. ● The power should be in the OFF position when inserting or extracting this connector. ● To check for correct connector mating, lightly pull on the cable and make sure the connector does not come off.   Incomplete mating may result in significant danger such as disconnection or contact failure. Caution ●   ●   This connector was designed to be used in a stable and stationary environment, do not try to operate this connector where vibration will occur. Please use only Hirose approved contacts. Use of a a non- specified contact may lower product performance and result in serious accident. Please contact your Hirose representative for additional information. 7 EF1 Series/Simple Assembly In-Line Power Connectors for up to 160A Mechanical Strength (EF1-38R-1SC#) ( 1) Cable Routing When wiring, fasten the cables in order to prevent a load to the connector. Avoid surpassing the specified values shown in the cable routing direction diagram below in order to prevent connector breakage. Tolerable Mechanical Stress to Cables ( Reference) ① , ③ , ④ , ⑥ , ⑦ , ⑧ direction : 20N Max. ② direction : 150N Max. ⑤ direction : 200N Max. Note : The mechanical stress varies depending on cable types. When using a hard type cable in particular, make sure not to break the lock arm. ⑦ (100) (100) ③ ① DIN Rail Rail stopper DIN Rail Rail stopper (100) (100) Lock arm Cable ⑥ ④ ⑧ ⑤ ( 2) After Wiring Stabilize the cable with cable ties, etc. to prevent direct vibration and shock to the connector. Securing the cables within 100mm distance from the connector body is recommended. Fixing the cables 100 Max. 100 Max. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ② Fixing the cables 8 EF1 Series/Simple Assembly In-Line Power Connectors for up to 160A While taking in consideration Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the " Drawing" and " Product Specifications" sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given. Please consult with your Hirose sales representative if you are planning to use the product for any of the following applications. ( Automotive, medical, public infrastructure, aerospace/ defense, etc. ) Hirose will consider the validity of the warranty depending on the conditions. 9 EF1 Series/Simple Assembly In-Line Power Connectors for up to 160A [ JAPAN ] [ GERMANY ] Headquarters GERMAN Branch / STUTTGART Office HIROSE ELECTRIC CO., LTD HIROSE ELECTRIC EUROPE B.V. Phone : +81-3-3491-7675 http://www.hirose.com Phone : +49-711-456002-1 http://www.hirose.com/eu/ YOKOHAMA Center NUREMBERG Office HIROSE ELECTRIC CO., LTD HIROSE ELECTRIC EUROPE B.V. Phone : +81-45-620-3491 http://www.hirose.com Phone : +49-911-326889-63 http://www.hirose.com/eu/ [ TAIWAN ] TAIWAN Office HIROSE ELECTRIC (TAIWAN) CO., LTD. Phone : +886-2-2555-7377 http://www.hirose.com/tw/ [ KOREA ] KOREA Office HIROSE KOREA CO.,LTD. HANOVER Office [ USA ] Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. U.S Headquarters / CHICAGO Office HIROSE ELECTRIC EUROPE B.V. Phone : +49-511-978261-30 http://www.hirose.com/eu/ HIROSE ELECTRIC ( U.S.A.), INC. Phone : +1-630-282-6700 http://www.hirose.com/us/ SAN JOSE Office [ SINGAPORE ] [ FRANCE ] SINGAPORE Office HIROSE ELECTRIC PARIS Office HIROSE ELECTRIC ( U.S.A.), INC. HIROSE ELECTRIC EUROPE B.V. Phone : +1-408-253-9640 http://www.hirose.com/us/ Phone : +33-1-85764886 http://www.hirose.com/eu/ DETROIT Office (AUTOMOTIVE) HIROSE ELECTRIC ( U.S.A.), INC. Phone : +1-734-542-9963 http://www.hirose.com/us/ HIROSE ELECTRIC ( U.S.A.), INC. SINGAPORE PTE. LTD. Phone : +65-6324-6113 http://www.hirose.com/sg/ [ THAILAND ] [ ITALY ] BANGKOK Liaison Office MILAN Office HIROSE ELECTRIC EUROPE B.V. BOSTON Office Phone : +82-31-496-7000 http://www.hirose.co.kr/ Phone : +39-02-36636350 http://www.hirose.com/eu/ HIROSE ELECTRIC SINGAPORE PTE. LTD. Phone : +66-2-686-1255 http://www.hirose.com/sg/ Phone : +1-978-655-9850 http://www.hirose.com/us/ [ CHINA ] DALLAS Office HIROSE ELECTRIC ( U.S.A.), INC. Phone : +1-972-324-3370 http://www.hirose.com/us/ IRVINE Office HIROSE ELECTRIC ( U.S.A.), INC. Phone : +1-949-930-3750 http://www.hirose.com/us/ CHINA Headquarters / SHANGHAI Branch HIROSE ELECTRIC ( CHINA ) CO., LTD. PENANG Representative Office Phone : +86-21-6391-3355 http://www.hirose.com/cn/ SINGAPORE PTE. LTD. EU Headquarters / AMSTERDAM OFFICE HIROSE ELECTRIC Phone : +60-4-648-5536 http://www.hirose.com/sg/ SHENZHEN Branch HIROSE ELECTRIC ( CHINA ) CO., LTD. Phone : +86-755-8207-0851 http://www.hirose.com/cn/ [ INDIA ] BANGALORE Office BEIJING Branch [ THE NETHERLANDS ] [ MALAYSIA ] HIROSE ELECTRIC ( CHINA ) CO.,LTD. Phone : +86-10-5165-9332 Fhttp://www.hirose.com/cn/ HIROSE ELECTRIC INDIA PVT. LTD. Phone : +91-80-4120-1907 http://www.hirose.com/sg/ HIROSE ELECTRIC EUROPE B.V. Phone : +31-20-6557460 http://www.hirose.com/eu/ DELHI Office [ HONG KONG ] HONG KONG Office [ UNITED KINGDOM ] HIROSE ELECTRIC HONGKONG TRADING CO., LTD. UK Branch Phone : +852-2803-5338 http://www.hirose.com/hk/ HIROSE ELECTRIC EUROPE B.V. HIROSE ELECTRIC INDIA PVT. LTD. Phone : +91-120-660-8018 http://www.hirose.com/sg/ Phone : +44-1908-202050 http://www.hirose.com/eu/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com https://www.hirose-connectors.com ※ The contents of this catalog are current as of date of 12/ 2020. Contents are subject to change without notice for the purpose of improvements. 10 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. M E M O Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. M E M O
EF1-38RA-1SCA(30) 价格&库存
很抱歉,暂时无法提供与“EF1-38RA-1SCA(30)”相匹配的价格&库存,您可以联系我们找货
