DF38-40P-0.3SD
DF38-40P-0.3SD
    HRS(广濑)
    CONN PLUG 0.3MM 40POS
DF38-40P-0.3SD 数据手册
0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors DF38 Series High contact reliability – Effective mating length of 0.4 mm 1.5 ±0.15 (Mated height) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.7±0.15 (0.4) Effective mating length ■Features 1. Small mated height and board occupied space Enhanced shielding Small pitch (0.3mm) and mated height (1.5mm) allows use in space-restricted areas. Plug’s height of 1.3mm and width of 2.38mm allow its passage through narrow openings in smalldiameter hinge applications. 2. Enhanced shielding and ground connections Metal shells on the plug and receptacle connect to each other with a reliable multi-point ground contacts, assuring reliable ground connection and EMC protection. 3. Reliable lock Fully mated condition is assured with reliable locks at 4 locations, confirming it with a distinct tactile click. 4. Reliable electrical and mechanical connection Despite its small mated height, unique contact configuration assures highly reliable connection, with effective mating length of 0.4mm. Multi-point ground contacts 4-point lock: 2 points at each end 5. Solder wicking prevention Nickel barriers prevent solder wicking in the critical contact areas. 6. Durable plug construction Formed metal shells on the top and side surfaces form a strong and rigid assembly. 7. RoHS, Halogen-free* *As defined by IEC61249-2-21 Br-900 ppm maximum,Cl-900 ppm maximum, Cl+Br combined-1,500 ppm maximum Distinct tactile click ■Connector for conductivity tests We have a line-up of connectors for inspection, usable for electrical testing of both plug and receptacle connectors. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2014.3w 1 DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors ■Specifications Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ratings AWG #42: 0.15 A Current rating Wire size AWG #44: 0.1 A (Note.3) AWG #46: 0.1 A Operating temperature range Operating humidity range -35 to +85°C (Note 1) RH 20% to 80% Voltage rating Storage temperature range Storage humidity range -10 to +60°C (Note 2) RH 40% to 70% (Note 2) 30 V AC Item 1.Insulation resistance 50Mø min Specification 100V DC Conditions 2.Withstanding voltage No flashover or insulation breakdown 100 V AC / 1 minute 3.Contact resistance Signal: 80mø max., Ground: 80mø max. 100mA (DC or 1,000Hz) 4.Vibration No electrical discontinuity of 1 µs or longer Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 3 directions, 2 hours 5.Humidity Contact resistance (change from initial value) 50 mø max. Insulation resistance: 25 Mø min. 96 hours at of 40 ±2°C, and humidity of 90 to 95% 6.Temperature cycle Contact resistance (change from initial value) 50 mø max. Insulation resistance: 50 Mø min. -55°C ➝ 5 to 35°C ➝ 85°C ➝ 5 to 35°C Time: 30 min. ➝ 2 to 3 min. ➝ 30 min. ➝ 2 to 3 min. 5 cycles 7.Durability Contact resistance (change from initial value) 50 mø max. 30 cycles 8.Resistance to soldering heat No deformation of affecting performance Reflow: At the recommended temperature profile Manual soldering: 350°C for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for a long period prior to mounting and use. The operating temperature and humidity range covers the non-conducting condition of connectors after board mounting and the temporary storage conditions of transportation, etc. Note 3: With only the connector portion at an elevated temperature level, the rated current value is set. ■Material Product Receptacle Plug 2 Part Insulator Contacts Metal cover Vacuum cap Insulator Contacts Metal cover Material LCP Phosphor bronze Polyamide LCP Phosphor bronze Finish Color: Black Gold plating Tin plating Color: Black Color: Natural, Black Gold plating Tin plating Remarks UL94-V0 ----------------------------UL94-HB UL94-V0 ----------------------------- DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors ■Ordering information ●Connector DF 38 A J – * S – 0.3 V (**) 1 2 3 4 5 6 7 8 9 DF 38 J – * P – SHL 1 2 4 5 6 10 1 Series name : DF 2 Series No. 6 Connector type : 38 S : Receptacle Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3 Insulator typestyle P : Plug Receptacle A : Standard 7 Contact pitch : 0.3mm Plug Blank : Standard 8 Termination type 4 Connector style V : Straight SMT Receptacle/Shell SD : Fine coaxial cable plug 9 Packaging J : Receptacle for conductivity tests (51) : Embossed tape packaging Blank : Standard 5 Number of positions : 30, 32, 40 10 Installation item (separate) SHL : Metal cover ■Combinations ●Standard use DF38A-*S-0.3V(**) + DF38-*P-ASSY ( DF38-*P-0.3SD(**) DF38-*P-SHL ) Note: The product specification of the above combination is shown on page 2. ●Receptacle conductivity test DF38A-*S-0.3V(**) + DF38J-*P-ASSY ··· (Note) ( DF38-*P-0.3SD(**) DF38J-*P-SHL ) Note: This harness item is only usable for the receptacle test. For the product specification of the above combination, please contact our sales department. ●Plug conductivity test DF38AJ-*S-0.3V(**) ··· (Note) + DF38-*P-ASSY ( DF38-*P-0.3SD(**) DF38-*P-SHL ) Note: This harness item is only usable for the plug test. For the product specification of the above combination, please contact our sales department. * : ASSY means a harness item. 3 DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors ■Receptacles B±0.2 A±0.15 P=0.3±0.1 0.1±0.05 3.7±0.15 Contact No.2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.5±0.15 Contact No.1 ■Recommended PCB mounting pattern D±0.05 C±0.05 A±0.02 P=0.3±0.02 0.58±0.05 1.2±0.05 1.75±0.05 2.35±0.05 (0.46 ) 0.92±0.05 1.94±0.05 G±0.05 F±0.05 1.8±0.05 J±0.05 H±0.05 1.28±0.05 Contact No.2 1 Contact No.1 F±0.05 G±0.05 H±0.05 J±0.05 0.3±0.02 Ground areas C±0.05 Refer to User Recommendation page (Para. 3) for the recommended metal mask dimensions and open area ratios. E±0.05 Note 1 : Area indicated must be free of conductive traces or the conductive traces must be covered by resist film. [Specifications number] - * *, (* *) (51) : Embossed tape packaging (5,000 pieces per reel) All dimensions: mm Part Number CL No. Number of Contacts A B DF38A-30S-0.3V(**) 662-4505-4-** DF38A-32S-0.3V(**) 662-4028-7-** 30 8.7 32 9.3 DF38A-40S-0.3V(**) 662-4501-3-** 40 11.7 Note 1: Tape and reel packaging (5,000 pieces/reel). Order by number of reels. 4 C D E F G H J 13.1 9.6 12.8 13.7 0.95 1.25 2.95 3.25 13.7 10.2 13.4 14.3 1.25 0.95 3.25 2.95 16.1 12.6 15.8 16.7 1.25 0.95 3.85 3.55 DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors ■Plug - separate metal cover required A±0.15 B±0.15 2.38±0.15 P=0.3±0.1 [Specifications number] - * *, (* *) (51) : Embossed tape packaging (5,000 pieces per reel) All dimensions: mm Part Number CL No. Number of Contacts A B C DF38B-30P-0.3SD(**) 662-4515-8-** 30 14.0 8.7 9.55 DF38-32P-0.3SD(**) 662-4027-4-** 32 14.6 9.3 10.15 DF38-40P-0.3SD(**) 662-4502-6-** 40 17.0 11.7 12.55 Note 1: Tape and reel packaging (5,000 pieces/reel). Order by number of reels. Note 2: The metal cover is required for fine coaxial cable termination. ■Recommended Fine Coaxial Cable Preparation C±0.1 P=0.3±0.07 Inner conductor (Pre-soldering required) 0.2 MAX (Insulator) Outer shield (NO protrusion) 0.2±0.05 1.3±0.05 B±0.15 Ø0.3 MAX (Jacket) 0.45 +0.08 0 (5) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No.1 0.46 MAX (Ground bar) Laminated tape Note 1: Contact Hirose for Termination Procedures. 5 DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors ■Metal cover - Required for assembly of the Plug 1.22±0.15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.28±0.1 A±0.15 All dimensions: mm Part Number CL No. Number of Contacts A DF38-30P-SHL 662-4507-0 30 12.15 DF38-32P-SHL 662-4029-0 32 12.75 DF38-40P-SHL 662-4503-9 40 15.15 Note 1: Reel packaging (10,000 pieces/reel). Order by number of reels. 6 DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors ■Embossed Carrier Tape Dimensions (JIS C 0806) (1.7) (Vacuum pick-up area center) 8±0.1 4±0.1 2±0.1 F F-F (2.1) (1.8) (1) +0.1 0 5 0.2±0.05 G R0.7 F G Unreeling direction G-G (4) ●Reel Dimensions Part Number Label Unreeling direction Ø21±0.8 2 (Ø79) Ø382 MAX ±0. Ø13 2± 0.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B±0.1 A±0.3 C±0.1 Ø 1 0. + 0 5 1. 1.75±0.1 ●Receptacle D+20 E MAX All dimensions: mm Part Number CL No. Number of Contacts A B C D E DF38A-30S-0.3V(51) 662-4505-4-51 30 32 28.4 14.2 32.4 38.4 DF38A-32S-0.3V(51) 662-4028-7-51 32 32 28.4 14.2 32.4 38.4 DF38A-40S-0.3V(51) 662-4501-3-51 40 32 28.4 14.2 32.4 38.4 7 DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors ■Embossed Carrier Tape Dimensions (JIS C 0806) (1.7) (Vacuum pick-up area center) 8±0.1 4±0.1 (1.8) F-F (1.5) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B±0.1 A±0.3 C±0.1 Ø1. 5 +0 . 0 1 2±0.1 F 1.75±0.1 ●Plug G R0 F .1 +00 .75 0.2±0.05 G Unreeling direction G-G (2.7) ●Reel Dimensions Part Number Label Ø21±0.8 2 (Ø79) 2± 0.5 Ø382 MAX ±0. Ø13 D+20 E MAX All dimensions: mm 8 Part Number CL No. Number of Contacts A B C D E DF38-30P-0.3SD(51) 662-4506-7-51 30 32 28.4 14.2 32.4 38.4 DF38-32P-0.3SD(51) 662-4027-4-51 32 32 28.4 14.2 32.4 38.4 DF38-40P-0.3SD(51) 662-4502-6-51 40 32 28.4 14.2 32.4 38.4 DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors ■Extraction tool For details about the extraction tool, please contact your Hirose sales representative. ■Usage Recommendations 1. Recommended temperature profile Temperature (ç) 250 250ç 220ç 200 60sec. 180ç Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. max. 150 150ç 90 to 120sec. 100 50 Room temperature 50 100 150 200 250 300 Time (sec.) Solder composition: Paste, 96.5%Sn/3.0%Ag/0.5%Cu Note 1: Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2: The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2.Recommended manual soldering Manual soldering: 350ç for 3 seconds Do NOT use flux compound when manual soldering. 3.Recommended screen thickness and open area ratio (Pattern area ratio) 4.Board warpage Thickness: 0.1 mm Open area ratio: Lead terminal: 80% Ground terminal: 100% 5.Cleaning conditions 6.Precautions Refer to “Nylon Connector Use Handbook”. Maximum of 0.02mm at the connector center, with both ends of the connector as reference points. * Mating and un-mating of the connectors when not soldered on the boards is not recommended as this may cause deformation of the terminals, damage to the contacts or insulators. * When mating/un-mating do not twist or lift by the corners. Apply the forces evenly across the entire length and width of the connectors taking care NOT to damage or deform soldered terminations. * Slight discoloration on the insulating materials will not affect form, fit or function of the connectors. 9 DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors ■Precautions Precautions ■Mating Mate the plug with the receptacle by pressing straight against the entire plug surface. Do NOT un-mate the plug while holding by the terminated cable. Plug Lock areas Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Lock areas Receptacle ■Un-mating Use a dedicated extraction tool to un-mate the plug. Insert the tool under either end of the plug (clearance) and pull straight up as illustrated. Do NOT un-mate the plug while holding by the terminated cable. Extraction tool End side (clearance) ■Routing of the fine coaxial cable after termination Allow sufficient clearance between the plug and the fine coaxial cable to avoid sharp bend, excessive twist or pull forces applied to the connector. No pulling ■Other · Do NOT mate / un-mate the connectors when receptacle is not mounted on the board. · Different production lots may exhibit different shades of the insulator materials. No affect on form, fit or function of the connectors. · Rework of the soldered terminations on the board-mounted receptacles is not possible. · Sides of the metal cover protrude over the termination areas. · Do not mate / un-mate the connectors when receptacle is not mounted on the board. 10 DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO : 11 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF38 Series●0.3 mm Pitch, 1.5 mm Mated Height, Board- to-Fine Coaxial Cable Connectors USA: HIROSE ELECTRIC (U.S.A.), INC. Headquarters 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : +1-805-522-7958 Fax : +1-805-522-3217 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. San Jose Office 3255 Scott Boulevard, Building 7, Suite 101 Santa Clara, CA 95054 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. Detroit Office (Automotive) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hiroseusa.com THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hiroseeurope.com GERMANY: HIROSE ELECTRIC EUROPE B.V. German Branch Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : +49-711-4560-02-1 Fax : +49-711-4560-02-299 http://www.hirose.de UNITED KINGDOM: HIROSE ELECTRIC EUROPE B.V. UK Branch 22 Vincent Avenue, Crownhill Business Centre, Crownhill, Milton Keynes, MK8 0AB Phone : +44-1908-305750 Fax : +44-1908-305768 http://www.hirose.co.uk CHINA: HIROSE ELECTRIC TRADING (SHANGHAI) CO., LTD. 1601,Henderson Metropolitan,NO.300 ,East Nanjing Road,Huangpu District, Shanghai,China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC TRADING (SHANGHAI) CO., LTD. Beijing Branch A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, Chao Yang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre 5002, ShenNanDong Road, ShenZhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose-china.com.cn HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose-hongkong.com.hk TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose-taiwan.com.tw KOREA: HIROSE KOREA CO., LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, Kyunggi-Do 429-450 Phone : +82-31-496-7000,7124 Fax : +82-31-496-7100 http://www.hirose.co.kr SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. Bangalore Liaison office HIROSE ELECTRIC SINGAPORE PTE. LTD. 10 Anson Road #26-1 International Plaza Unit No.03, Ground Floor, Explorer Building International Tech Park Whitefield Road, Bangalore 560066 Karnataka, India 079903 Phone : +65-6324-6113 Phone : +65-6324-6113 Fax : +65-6324-6123 Fax : +65-6324-6123 http://www.hirose-singapore.com.sg http://www.hirose-singapore.com.sg INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD Delhi Liaison Office Suite No. 606 5th Floor SB Tower 1A/1 Sector 16 A Filmcity Noida 201301 Uttar Pradesh-India Phone : +91-120-4804917 Fax : +91-120-4804949 http://www.hirose.com/sg/ MALAYSIA: HIROSE ELECTRIC SINGAPORE PTE. LTD (Representative office) 1-10-07, Suntech @ Penang Cybercity (1164),Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ ® 12 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 3/2014. Contents are subject to change without notice for the purpose of improvements.
DF38-40P-0.3SD 价格&库存
很抱歉,暂时无法提供与“DF38-40P-0.3SD”相匹配的价格&库存,您可以联系我们找货
