DF36-45P-0.4SD(72)
DF36-45P-0.4SD(72)
    HRS(广濑)
    CONN PLUG 0.4MM 45POS SHLD AU
DF36-45P-0.4SD(72) 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. 0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors DF36 Series 1.5±0.15 (Mated height) High contact reliability – Effective mating length of 0.4 mm (0.4) (Effective mating length) Enhanced shielding (standard type) Plug ■Features 1. Small mated height and board occupied space Small pitch (0.4mm) and mated height (1.5mm) allows use in space-restricted areas. Standard type: mated height 1.5 mm, depth 4.4 mm Saving space type: mated height 1.5 mm, depth 2.8 mm Plug : Height 1.33 mm, depth 2.8 mm 2. Enhanced shielding and ground connections Metal covers on the plug and receptacle connect to each other with a reliable multi-point ground contacts, assuring reliable ground connection and EMC protection. Receptacle Ground contacts Fully mated Multi-point contacts Enhanced shielding (Space - Saving type) 3. Reliable lock Fully mated condition is assured with reliable locks at 4 locations, confirming it with a distinct tactile click. 4. Reliable electrical and mechanical connection Despite it’s small mated height, unique contact configuration assures highly reliable connection, with effective mating length of 0.4 mm. 5. Solder wicking prevention Nickel barriers prevent solder wicking in the critical contact areas. 6. Durable plug construction Formed metal shells on the top and side surfaces form a strong and rigid assembly. Fully mated 4-point lock: 2 points at each end ■Receptacle for conductivity tests We have a line-up of connectors for inspection, usable for electrical testing of both standard type and space saving type. Distinct tactile click 2010.9 1 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Product Specifications Current rating 0.25A(AWG#42) 0.25A(AWG#44) (Note3) 0.1A(AWG#46) Voltage rating 30 V AC Ratings Item 1.Insulation resistance 2.Withstanding voltage 3.Contact resistance 4.Vibration 5.Humidity Operating temperature range Operating humidity range -35 to +85°C (Note 1) 20 to 80% Storage temperature range Storage humidity range -10 to +60°C (Note 2) 40 to 70% (Note 2) Specification 50 Mø min No flashover or insulation breakdown Signal: 80 mø max., Ground: 80 mø max. No electrical discontinuity of 1 µs or longer No damage, cracks or parts dislocation. Contact resistance (Change from initial value) 50 mø max. Insulation resistance: 25 Mø min. No damage, cracks or parts dislocation. Conditions 100 V DC 100 V AC / one minute 100 mA (DC or 1,000 Hz) Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 10 cycles in each of the 3 axial directions 96 hours at 40 ±2°C, and humidity of 90 to 95% 6.Temperature cycle Contact resistance (Change from initial value) 50 mø max. Temperature: -55°C / 5 to 35°C / 85°C / 5 to 35°C Insulation resistance: 25 Mø min. Time: 30 min. / 2 to 3 min. / 30 min. / 2 to 3 min. No damage, cracks or parts dislocation. 5 cycles 7.Durability Contact resistance (Change from initial value) 50 mø max. 30 cycles No damage, cracks or parts dislocation. 8.Resistance to soldering heat No deformation of components affecting performance. Reflow: At the recommended temperature profile Manual soldering: 350°C for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for a long period prior to mounting and use. The operating temperature and humidity range covers the non-conducting condition of connectors after board mounting and the temporary storage conditions of transportation, etc. Note 3: With only the connector portion at an elevated temperature level, the rated current value is set. Note 4: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials Item Receptacle (Standard) Plug (Standard) Item Receptacle (Space-saving) Plug (Space-saving) 2 Part Insulator Contacts Metal cover Insulator Contacts Metal shell Material LCP Phosphor bronze Phosphor bronze LCP Phosphor bronze Phosphor bronze Finish Color: Black Gold plated Tin plated Color: Natural (Beige), Black Gold plated Tin plated Remarks UL94V-0 ------------UL94V-0 ------------- Part Insulator Contacts Metal cover Insulator Contacts Metal shell Material LCP Phosphor bronze Phosphor bronze LCP Phosphor bronze Phosphor bronze Finish Color: Black Gold plated Gold plated Color: Natural (Beige), Black Gold plated Gold plated Remarks UL94V-0 ------------UL94V-0 ------------- The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Ordering information ●Connector DF 36 A J – * S – 0.4 V (**) 1 2 3 4 5 6 7 8 9 DF 36 A J – * P – SHL 1 1 2 3 2 3 4 5 6 10 4 Series name : DF Series No. : 36 Connector style Receptacle/shell A : Standard Blank : Space-saving Plug Blank : Standard 5 Insulator type J : Receptacles for conductivity tests Blank : Standard or space-saving P : Single-row plug Number of contacts Standard : 15 to 50 Space-saving : 15 to 25 Receptacles for conductivity tests : 15 to 50 6 7 8 9 10 Connector style S : Single-row receptacle P : Single-row plug Contact pitch: 0.4 mm Termination type V : Straight SMT SD : Fine coaxial cable plug Packaging (51) : Embossed tape packaging Installation item (separate) SHL : Metal cover ■Combinations ●Standard use DF36(A)-*S-0.4V(**) + DF36(A)-*P-ASSY ( DF36-*P-0.4SD(**) ) DF36(A)-*P-SHL Note: The product specification of the above combination is shown on page 2. ●Receptacle test DF36(A)-*S-0.4V(**) + DF36(A)J-*P-ASSY • • Note DF36-*P-0.4SD(**) ( DF36(A)J-*P-SHL ) Note: This harness item is only usable for the receptacle test. For the product specification of the above combination, please contact our sales department. ●Plug test DF38(A)J-*S-0.4V(**) • • Note + DF36(A)-*P-ASSY ( DF36-*P-0.4SD(**) DF36(A)-*P-SHL ) Note: This harness item is only usable for the plug test. For the product specification of the above combination, please contact our sales department. π: ASSY means a harness item. 3 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Receptacles - Standard, with metal cover B±0.2 A±0.15 P=0.4±0.1 0.15±0.05 CAV No. (0.95) Vacuum pick-up area (C) Lot No. 4.4±0.2 1.5±0.15 (0.87) Contact No.1 All dimensions: mm Part Number CL No. Number of Contacts A B C DF36A-15S-0.4V(**) 662-4509-5-** 15 9.6 13.66 2.6 DF36A-25S-0.4V(**) 662-4011-4-** 25 9.6 13.66 2.6 DF36A-30S-0.4V(**) 662-4017-0-** 30 11.6 15.66 3.0 DF36A-40S-0.4V(**) 662-4003-6-** 40 15.6 19.66 3.0 DF36A-45S-0.4V(**) 662-4008-0-** 45 17.6 21.66 3.0 DF36A-50S-0.4V(**) 662-4043-0-** 50 17.6 21.66 3.0 [Specifications number] - * *, (* *) (51) : Embossed tape packaging (4,000 pieces per reel) Note 1: Tape and reel packaging (4,000 pieces/reel). Order by number of reels. Note 2: The 15 pos. does not have a lot stamp. ■Recommended PCB mounting pattern 0.15±0.1 1.7±0.05 6.7±0.05 11.09±0.05 13.47±0.05 1.3±0.05 6±0.05 7.09±0.05 9.47±0.05 C 0. 25 ± 0. 05 Contact No.1 15.47±0.05 13.09±0.05 11.5±0.05 6.5±0.05 2.5±0.05 Contact No.30 Ground connecting areas 0.25±0.02 1.7±0.05 6.7±0.05 11.6±0.02 13.09±0.05 15.47±0.05 0.15±0.1 3.85±0.05 3.2±0.05 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 0.4±0.05 1.05±0.05 ●30 pos. 4 Contact No.1 13.47±0.05 11.09±0.05 10±0.05 9.6±0.02 5.6±0.05 2.2±0.05 P=0.4±0.02 P=0.4±0.02 0.25±0.02 Contact No.25 0.15±0.1 0.4±0.02 0.25±0.02 Contact No.15 3.85±0.05 3.2±0.05 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 1.05±0.05 Contact No.1 ●25 pos. 9.47±0.05 7.09±0.05 6±0.05 5.6±0.02 3.85±0.05 3.2±0.05 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 0.4±0.05 1.05±0.05 ●15 pos. The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Recommended PCB mounting patterns ●40 pos. Contact No.1 15.6±0.02 11±0.05 7±0.05 2±0.05 P=0.4±0.02 0.25±0.02 Contact No.40 0.15±0.1 3.2±0.05 3.85±0.05 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 0.4±0.05 1.05±0.05 19.47±0.05 17.09±0.05 16±0.05 Ground connecting areas 1.7±0.05 6.4±0.05 10.4±0.05 15.1±0.05 17.09±0.05 19.47±0.05 Contact No.1 21.47±0.05 19.09±0.05 18±0.05 17.6±0.02 13.4±0.05 10±0.05 5.6±0.05 2.2±0.05 P=0.4±0.02 0.25±0.02 Contact No.45 0.15±0.1 3.2±0.05 3.85±0.05 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 0.4±0.05 1.05±0.05 ●45 pos. Ground connecting areas 1.7±0.05 6.7±0.05 12.1±0.05 17.1±0.05 19.09±0.05 21.47±0.05 ●50 pos. P=0.4±0.02 0.25±0.05 Contact No.50 0.15±0.1 3.85±0.05 3.2±0.05 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 0.4±0.05 1.05±0.05 Contact No.1 23.47±0.05 21.09±0.05 20±0.05 19.6±0.02 16±0.05 12.8±0.05 8.8±0.05 5.6±0.05 1.6±0.05 1.7±0.05 6.7±0.05 14.1±0.05 19.1±0.05 21.09±0.05 23.47±0.05 Ground connecting areas 5 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Receptacles - Space-saving B±0.2 A±0.15 P=0.4±0.1 0.15±0.05 (2.8) (0.87) Contact No.1 CAV No. Lot No. (C) 1.5±0.15 (0.95) Vacuum pick-up area All dimensions: mm CL No. Number of Contacts A B C D DF36-15S-0.4V(**) 662-4031-1-** 15 5.6 9.66 2.6 8.28 DF36-20S-0.4V(**) 662-4039-3-** 20 7.6 11.66 2.6 10.28 DF36-25S-0.4V(**) 662-4005-1-** 25 9.6 13.66 2.6 12.28 Part Number [Specifications number] - * *, (* *) (51) : Embossed tape packaging (5,000 pieces per reel) Note 1: Tape and reel packaging (5,000 pieces/reel). Order by number of reels. Contact No.1 P=0.4±0.02 0.15±0.1 0.3±0.05 0.7±0.05 A±0.02 3.1±0.05 2.1±0.05 ■Recommended PCB mounting pattern 0.25±0.02 1.19±0.05 D±0.05 Ground connecting areas 6 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Plug ●Separate metal cover required 2.8±0.15 A±0.15 Contact No.1 * CAV No. P=0.4±0.1 B±0.15 All dimensions: mm CL No. Number of Contacts A B C D Packing DF36-15P-0.4SD(**) Part Number 662-4510-4-** 15 10.6 5.6 6.6 7.5 5,000 pcs./reel DF36-20P-0.4SD(**) 662-4040-2-** 20 12.6 7.6 8.6 9.5 5,000 pcs./reel DF36-25P-0.4SD(**) 662-4006-4-** 25 14.6 9.6 10.6 11.5 5,000 pcs./reel DF36-30P-0.4SD(**) 662-4018-3-** 30 16.6 11.6 12.6 13.5 5,000 pcs./reel DF36-40P-0.4SD(**) 662-4002-3-** 40 20.6 15.6 16.6 17.5 5,000 pcs./reel DF36-45P-0.4SD(**) 662-4009-2-** 45 22.6 17.6 18.6 19.5 5,000 pcs./reel DF36-50P-0.4SD(**) 662-4044-3-** 50 24.6 19.6 20.6 21.5 5,000 pcs./reel Note 1: Tape and reel packaging(5,000 pieces / reel) order by number of reels. Note 2: The metal cover is required for fine coaxial cable termination. B±0.15 Pitch maintaining tape Note 1 Laminated tape D MAX 0.5 +0.1 0 2.5 MIN 0.2 MAX(Insulator) 5 MIN C±0.1 Inner conductor (Pre-Ł soldering required) Note 2 0.3±0.05 4 MIN 1.27±0.05(Cut dimension) 3 MIN 10±3 P=0.4±0.07 0.05 MAX Outer shield (for individual conductor) ■Recommended Fine Coaxial Cable Preparation 0.33 MAX(Jacket) 0.47±0.03 (Ground bar) Note 1: The pitch maintaining tape can be left in place during the termination process. Use high quality tape. Note 2: Contact Hirose for Termination Procedures. 7 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Metal cover - Required for assembly and termination of the Plug 0.25±0.1 2.8±0.1 A±0.15 [ Standard ] All dimensions: mm Part Number Part Number DF36A-15P-SHL Plating Number of Contacts A CL662-4511-7 15 9.92 DF36A-20P-SHL CL662-4042-8 20 11.92 DF36A-25P-SHL CL662-4007-7 25 13.92 DF36A-30P-SHL CL662-4019-6 30 15.92 DF36A-40P-SHL CL662-4013-0 40 19.92 DF36A-45P-SHL CL662-4010-1 45 21.92 DF36A-50P-SHL CL662-4045-6 50 23.92 Tin Note 1: Tape and reel packaging (10,000 pieces/reel). Order by number of reels. [ Space-saving ] Part Number All dimensions: mm Part Number DF36-15P-SHL CL662-4026-1 DF36-20P-SHL CL662-4041-5 DF36-25P-SHL CL662-4012-7 Plating Gold Note 1: Tape and reel packaging (10,000 pieces/reel). Order by number of reels. 8 Number of Contacts A 15 9.92 20 11.92 25 13.92 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Packaging Specification +0 0 .1 .5 8±0.1 4±0.1 Ø1 (1.135) (Vacuum pick-up area center) 1.75±0.1 ●Embossed Carrier Tape Dimensions – Standard Receptacle (2.3) +0 0 .1 .75 Unreeling direction R0 0.2±0.05 B±0.1 A±0.3 C±0.1 2±0.15 ●Reel Dimensions Part Number Label Ø21±0.8 0.2 (Ø80) 2± 0.5 Ø380±2 Ø13± D +20 E MAX All dimensions: mm CL No. Number of Contacts A B C D E DF36A-15S-0.4V(51) Part Number 662-4509-5-51 15 32 28.4 14.2 32.4 38.4 DF36A-20S-0.4V(51) 662-4037-8-51 20 32 28.4 14.2 32.4 38.4 DF36A-25S-0.4V(51) 662-4011-4-51 25 32 28.4 14.2 32.4 38.4 DF36A-30S-0.4V(51) 662-4017-0-51 30 32 28.4 14.2 32.4 38.4 DF36A-40S-0.4V(51) 662-4003-6-51 40 44 40.4 20.2 44.4 50.4 DF36A-45S-0.4V(51) 662-4008-0-51 45 44 40.4 20.2 44.4 50.4 DF36A-50S-0.4V(51) 662-4043-0-51 50 44 40.4 20.2 44.4 50.4 Note 1: Tape and reel packaging (4,000 pieces/reel). 9 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Packaging Specification Ø1 0 .1 0.2±0.05 R0 .7 5 +0 B±0.1 A±0.3 2±0.15 (1.85) C±0.1 + 0 0 .1 8±0.1 4±0.1 .5 (0.835) (Vacuum pick-up area center) 1.75±0.1 ●Embossed Carrier Tape Dimensions – Space saving Receptacle Unreeling direction ●Reel Dimensions Part Number Label Ø21±0.8 0.2 (Ø80) 2± 0 .5 Ø380±2 Ø13± D +20 E MAX All dimensions: mm CL No. Number of Contacts A B C D E DF36-15S-0.4V(51) CL662-4031-1-51 15 32 28.4 14.2 32.4 38.4 DF36-20S-0.4V(51) CL662-4039-3-51 20 32 28.4 14.2 32.4 38.4 DF36-25S-0.4V(51) CL662-4005-1-51 25 32 28.4 14.2 32.4 38.4 Part Number Note 1: Tape and reel packaging (5,000 pieces/reel). 10 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Packaging Specification +0 0 .1 Ø1 .5 8±0.1 4±0.1 1.75±0.1 ●Plug (1.8) A±0.3 +0 0 .1 .75 Unreeling direction R0 0.2±0.05 B±0.1 C±0.1 2±0.15 ●Reel Dimensions Part Number Label Ø21±0.8 0.2 (Ø80) 2± 0.5 Ø380±2 Ø13± D +20 E MAX All dimensions: mm CL No. Number of Contacts A B C D DF36-15P-0.4SD(51) Part Number 662-4510-4-51 15 32 28.4 14.2 32.4 DF36-20P-0.4SD(51) 662-4040-2-51 20 32 28.4 14.2 32.4 DF36-25P-0.4SD(51) 662-4006-4-51 25 32 28.4 14.2 32.4 DF36-30P-0.4SD(51) 662-4006-4-51 30 32 28.4 14.2 32.4 DF36-40P-0.4SD(51) 662-4002-3-51 40 44 40.4 20.2 44.4 DF36-45P-0.4SD(51) 662-4009-2-51 45 44 40.4 20.2 44.4 DF36-50P-0.4SD(51) 662-4044-3-51 50 44 40.4 20.2 44.4 Note 1: Tape and reel packaging (5,000 pieces/reel). 11 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Extraction tool For details about the extraction tool, please contact your Hirose sales representative. ■Usage Recommendations 1.Recommended temperature profile Temperature (ç) 250ç 250 220ç 200 60sec max 180ç 150 150ç 90 to 120sec 100 50 Room temperature 0 50 100 150 200 250 300 Time (sec.) Solder composition: Paste, 96.5%Sn/3.0%Ag/0.5%Cu Note 1: Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2: The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2.Recommended manual soldering 3.Recommended screen thickness and open area ratio (Pattern area ratio) 12 Manual soldering: 350ç for 3 seconds Do NOT use flux compound when manual soldering. Standard Thickness: 0.1 mm Open area ratios: Lead terminal: 90% Ground terminal: 100% Space-saving Thickness: 0.1 mm Open area ratios: Lead terminal: 90% Ground terminal: 90% 4.Board warpage Maximum of 0.02 mm at the connector center, with both ends of the connector as reference points. 5.Cleaning conditions Refer to “Nylon Connector Use Handbook”. The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF36 Series●0.4 mm Pitch, 1.5 mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Precautions Precautions · Mating / un-mating [ Standard ] Mate the plug with the receptacle by pressing straight against the entire plug surface. Do NOT mate the plug while holding by the terminated cable. Use a dedicated extraction tool to un-mate the plug. Insert the tool under either end of the plug (clearance) and pull straight up as illustrated below. Please refrain from removing by holding the electrical cable, otherwise this may result in cable disconnection, connector breakage and so on. Extraction tool Plug End side (clearance) [ Space-saving ] Mate the plug with the receptacle by pressing straight against the entire plug surface, the same as the standard. Use a dedicated extraction tool to un-mate the plug. Insert the tool under the plug at the front side (clearance) and pull straight up, as illustrated below. Do NOT mate / un-mate the connectors when receptacle is not mounted on the board. Please refrain from removing by holding the electrical cable, otherwise this may result in cable disconnection, connector breakage and so on. Extraction tool Extraction tool Plug Front side End side (clearance) · Do not mate / un-mate the connectors when receptacle is not mounted on the board. · In the manual soldering process, don't carry out the flux coating which will cause a flux blister on the connector. · Different production lots may exhibit different shades of the insulator materials. No affect on form, fit or function of the connectors. · Excessive scoop insertion or extraction may result in damage. 13
DF36-45P-0.4SD(72) 价格&库存
很抱歉,暂时无法提供与“DF36-45P-0.4SD(72)”相匹配的价格&库存,您可以联系我们找货
