MKT-E-12014F
EF1 Series
Simple Assembly In-Line Power
Connector Up to 130 Amps
DIN Rail Mount Type
Features
Panel Mount Type
1. Crimp contact turns into a connector by just inserting into
Dimensions
the housing
2. Quick and secure snap-in lock, no retightening of screw
(DIN Rail Mount Type)
3. Supports 130 Amps by using 38 mm2 conductor size cable
4. Selectable mounting type; Attachable to DIN rail or panel
32
5. Easy crimp termination with market commodity tool
6. 4 types of mating keys available
DIN Rail
7. Will be TÜV, UL certified
8. RoHS compliant
Specifications
130 A
(38mm2 wire conductor size cable)
Rated Coltage
AC 600 V, DC 600 V
Operating Temperature Range
- 25 ˚C to + 105 ˚C
Contact Resistance
0.5 m MAX. [DC 1 A]
Insulation Resistance
1000 M MIN. [DC 500 V]
Withstanding Voltage
AC 3310 V for 1 minute
Durability
30 times
85
Rated Current
50
(Panel Mount Type)
High Current Capability
56.5
EF1 軽減曲線(ディレーティングカーブ)
23.6
[Derating
Curve (Typical)]
[ディレーティングカーブ
(Typical)]
250.00
150.00
100.00
72.8
通Current
電 電 流 [ (A)
A]
200.00
50.00
0.00
60
80
100
Ambient 周囲温度[℃]
Temperature (˚C)
120
NOTE: Crimp contact is attached
to each housing as a set.
37.9
All the dimensions in millimeters
Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities.
© 2013 HIROSE ELECTRIC CO., LTD. All rights reserved.
Issued: Mar. 5, 2013
很抱歉,暂时无法提供与“EF1-38RA-1SCD”相匹配的价格&库存,您可以联系我们找货
