SWT25X-URTC-S01-UU-UU
    SULLINS
    CONN SOCKET CRIMP 20-26AWG TIN
SWT25X-URTC-S01-UU-UU 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2237 INITIAL RELEASE 05/24/2011 LH F F 9.80 .386 E B A E 1.90±0.15 .075±.006 2.20 .087 2.10 .083 D B A D 0.20±0.03 .008±.001 SECTION A-A C 2.00 .079 1.50 .059 1.80 .071 C 3.10±0.20 .122±.008 1.80 .071 0.60±0.15 .024±.006 1.30 .051 GOLD AREA B A SECTION B-B 3.40 .134 B NOTES: 1. MATERIAL: SEE PART NUMBER CODING. 2. PLATING: SEE PART NUMBER CODING. 3. WIRE RANGE: AWG #20 - #26. 4. INSULATION O.D.: 1.35mm ~ 1.90mm. 5. QUANTITY PER REEL = 10,000 PIECES. 6. USED IN SWH25X SERIES HOUSING. 7. PLATING BEFORE STAMPING/FORMING. 8 7 DRAWN Pb UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] TOLERANCES: ANGULAR: .X= 0.3 [.01] .XX= 0.30 [.012] RoHS COMPLIANT 6 5 4 INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 05/24/2011 LH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C SWT25X-U_ _C-S01-UU-UU CAGE CODE 54453 SCALE: 12:1 2 A CRIMP TERMINAL - SWH25X DWG. NO. 11631 SHEET 1 OF 1 1 REV A FILE NAME: Z:\COMPONENTS\Taiwan\TAiPEI-CALIFORNIA\TO CALIFORNIA (JEN)\WAFER ECO 2235,2236,2237\2237, WAFER 25X WST\11631, SWT25X-UR_C-S01-UU-UU PRINT: 8/26/2011
SWT25X-URTC-S01-UU-UU 价格&库存
很抱歉,暂时无法提供与“SWT25X-URTC-S01-UU-UU”相匹配的价格&库存,您可以联系我们找货
