NEW
1 mm Pitch Double Rows Low Profile Board-to-Cable Connectors
DF20 series
Cable
5.4
Socket
DF20A**DS-1C
DF20F(G)**DP-1V
5.8
Pin
Header
PCB
Cable
6.2
DF20F
**DP-1H
Pin
Header
5.5
DF20A**DS-1C
Socket
PCB
■Features
Narrower external width and length
1. Contact Pitch
1 mm contact pitch allows reliable solder and cable
termination.
2. Low profile
Total mating height above the board is 5.8 mm for the
straight type and 5.5 mm for the right angle type.
3. Reliable electrical connection wipe
Effective electrical connection is assured with a 1mm wipe of
mating contacts.
4. Narrower external width and length
Redesigned metal fittings decreased the overall length of the
board- mount receptacle and permit end-to-end mounting of
several connectors.
Metal fitting
5. Automatic equipment board placement
Straight type pin headers are supplied with a 5.4 mm X 4.6mm
flat platform to allow vacuum pick-up and placement on the
board.
6. Product variations
(1) Available with 10, 20, 30, 40, and 50 contacts.
(2) Pin headers are available in two types: with or without
board positioning bosses.
(3) Depending on specific application pin headers can be
ordered in straight or right angle types.
DF20F-****SCFA
Contact
■Applications
DF20F(G)-**DP-1V
Pin Header
1
Notebook PC, small office automation equipment, small
consumer devices, portable devices.
Any application requiring low profile reliable board-to-cable
connection with a AWG #28, AWG#30, AWG#32 conductors.
DF20A-**DS-1C
Socket
1mm Pitch, Double Rows
2002.5
1
■Product Specifications
AWG#28 : 1A
Operating temperature range -35°C to 85°C (Note 1,2) Storage temperature range -10°C to 60°C (Note 2)
AWG#30 : 0.9A
AWG#32 : 0.7A
Storage humidity range -40% to 70%
Rated voltage
Operating humidity range
-20% to 80%
100V AC
Rated current
Rating
Item
Specifications
1.Insulation resistance
Conditions
Measured at 100V DC
500Mø min.
2.Withstanding voltage No flashover or insulation breakdown
Conduction of 300V AC applied for 1 minute
3.Contact resistance
Measure at 100mA.
30mø max.
4.Insertion-Extraction force
Min. 0.2 N (20 gf), Max. 2 N (200 gf)
4.(per contact)
Measured with a steel pin of 0.2 ±0.005 thickness
5.Vibration
No electrical discontinuity of 1µs min.
Frequency of 10 to 55 Hz, single amplitude of 0.75 mm, in 3 directions for 2hours
6.Humidity
Contact resistance of 30mø max., insulation resistance of 100Mø min. Temperature of 40±2ç, humidity of 90% to 95%, left standing for 96 hours
7.Temperature cycle
Contact resistance of 30mø max,insulation resistance of 500Mø min.
(-55ç:30min / 5ç to 35ç: 2 to 3min / 85ç:30min / 5ç to 35ç:2 to 3min ) for 5 cycles
8.Mechanical operation Contact resistance of 30mø max.
50 cycles
9.Resistance to
Soldering heat
Reflow: At the recommended temperature profile, manual
solder: Soldering iron temperature of 300°C for 3 seconds
No deformation of the insulator parts that will
affect performance
Note1: Includes temperature rise caused by current flow.
Note2: The term “storage” refers to products stored for long periods of time prior to mounting and use.
Note2: Operating temperature range and Humidity range covers non-conducting conditions of installed connectors in storage,
Note2: shipment or transportation.
■Materials
Item
Part
Socket
Socket contact
Pin header
Material
Finish
Remarks
Insulator
Polyamide
Color : Beige
UL94V-0
Contact
Phosphor bronze
Gold plating
Insulator
Polyamide
Color : Beige
UL94V-0
Contact
Phosphor bronze
Gold plating
Metal Fitting
Brass
V type: Solder plating
H type: Tin-Copper plating (Pb free)
■Ordering Information
●Connectors
DF 20 # - * DS - 1 C
1
2
3
4
5
1 Series name : DF
2 Series No. : 20
3 Boss Type
■Pin header
■F: Without boss
■G: With boss
■Crimp socket: A
4 Number of contacts: 10, 20, 30, 40, 50
●Contacts
7
5 Connector type
DS: Double-row socket
DP: Double-row pin header
6 Contact pitch: 1 mm
7 Type of housing, header
7 C: Crimp housing
V: Straight SMT header
H: Right angle SMT header
DF20 F - 2830 SCF A
1
1 F
2 Applicable wire size
2830: AWG #28 to 30
3032: AWG #30 to 32
2
6
2
3
4
3 Contact & packaging type
SCF: Socket contact reel
4 Plating type
A: Gold plating
5
5 Packaging Specifications
Blank: 1 reel = 10,000 pieces
41: 1 reel = 20,000 pieces
■Double Row Socket
Contact No. *
Contact No. 2
Contact No. *-1
Contact No. 1
5th contact marking
Contact No. 1 mark
Shown with terminated and installed contacts
Unit: mm
B
Product No.
CL No.
Number of Contacts
A
DF20A-10DS-1C
686-0020-3
10
17.2
14.0
DF20A-20DS-1C
686-0021-6
19.0
DF20A-30DS-1C
686-0022-9
30
17.2
14.0
DF20A-40DS-1C
686-0023-1
40
22.2
19.0
DF20A-50DS-1C
686-0024-4
50
27.2
24.0
[Specifications number]-*, (**)
(59): Gold plating, embossed tape
packaging
Note: Sales quantities are by the package unit (containing 100 pieces). Please order by package unit.
■Socket Crimp Contacts
Product No.
DF20F-2830SCFA(**)
DF20F-3032SCFA(**)
CL No.
686-0042-6-**
686-0043-9-**
Type of contacts
Quantity
Plating type
Reel contacts
See specifications number column
Gold plating
[Specifications number] -*, (**)
Blank 1 reel
: 10,000 pieces
41 1 reel
: 20,000 pieces
1.45
0.7
●Applicable Wire (Tin plated solid soft conductor)
Applicable Wire Size (Stranded wire conductor)
Jacket diameter
0.5mm to 0.6 mm
AWG #30 (7/0.1 mm)
2
AWG #32 (7/0.08 mm)
0.9
3.3
AWG #28 (7/0.127 mm)
●Strip length
●1.2 to 1.9 mm
0.5
●Recommended wire
●UL1571
Note: When using other than the recommended wire,
contact your nearest Hirose representative.
●Applicable Crimping Tools
Type
CL No.
Product No.
Applicator
901-4572-6
AP105-DF20-2830S
Press
901-0005-4
CM-105
Manual crimping tool 901-4540-6
HT302/DF20B-2830S
Note 1: Hirose Electric will not be responsible for any
problems caused by use of tools other than specified.
Note 2: The manual crimping tool can be also used for
cutting-off individual contacts from the reel.
Note 3: Customers that already have DF13 Series Hirose’s
press units and applicators will be able to use them
for DF20 Series crimp terminations by replacing of
only crimper and anvil.
Note4: The crimping tool for the DF20F-3032SCFA can
also be used with the DF20F-2830SCFA.
■Replacement Parts List for Applicator
Type
Product No.
CL No.
Insulation crimper
AP105-DF20-2830S(61)
901-4572-6-61
Wire crimper
AP105-DF20-2830S(62)
901-4572-6-62
Insulation anvil and wire anvil AP105-DF20-2830S(63)
901-4572-6-63
3
■ Double Row Straight Pin header
B
A
Contact No.3
P=1
Contact No.1
Contact No. **-1
Indication of number
of contacts
Contact No. **
6.4
Contact No.2
0.2
0.7
4.6
5.4
Ø0.5
1.9
C
D
A
0.2
BPCB Footprints
A ±0.05
P=1±0.03
Contact No. 1 marking
0.9±0.05
0.85±0.1
4±0.1
D±0.05
.1
+0 0
.7
Ø0
1.9±0.05
7.2 ±0.1
1.8 ±0.1
0.5±0.05
0.6±0.05
Note 1:Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations.
Note 2: Required only for pin headers supplied with the positioning boss.
Unit: mm
Product No.
CL No.
Number of contacts
A
B
C
D
DF20F-10DP-1V ( * * )
CL686-0032-2- * *
10
14.0
17.3
15.7
DF20F-20DP-1V ( * * )
CL686-0033-5- * *
12.3
10.7
DF20F-30DP-1V ( * * )
CL686-0034-8- * *
30
14.0
17.3
15.7
DF20F-40DP-1V ( * * )
CL686-0035-0- * *
40
19.0
22.3
20.7
DF20F-50DP-1V ( * * )
CL686-0036-3- * *
50
24.0
27.3
25.7
DF20G-10DP-1V ( * * )
CL686-0037-6- * *
10
14.0
17.3
16.6
15.7
DF20G-20DP-1V ( * * )
CL686-0038-9- * *
12.3
11.6
10.7
DF20G-30DP-1V ( * * )
CL686-0039-1- * *
30
14.0
17.3
16.6
15.7
DF20G-40DP-1V ( * * )
CL686-0040-0- * *
40
19.0
22.3
21.6
20.7
DF20G-50DP-1V ( * * )
CL686-0041-3- * *
50
24.0
27.3
26.6
Note1: Order embossed tape packaging items by the reel. (1 reel contains 1,000 pieces)
Note2: Vacuum pick-up platforms are included with embossed tape packaged connectors.
4
Remarks
Without boss
With boss
25.7
packaging
■Double Row Right angle Pin header
Contact No.1
Contact No.**-1
Contact No.3
Contact No.1
marking
Contact No.**
Contact No.2
B
A
5
5.5
Indication of
number of
contacts
P= 1
0.2
A
0.2
6.2
C
1.4
+0.1
2.75 ±0.05
3.8 ±0.05
1.4
+0.1
BPCB Footprints
0.6 ±0.05
P= 1 ±0.03
A ±0.05
0.75 ±0.1
C ±0.1
Note : Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations.
Unit: mm
Product No.
HRS No.
Number of contacts
A
B
C
DF20F -10DP-1H ( * * )
686-0027-2 ( * * )
10
24.0
27.5
26.2
DF20F -20DP-1H ( * * )
686-0028-5 ( * * )
12.5
11.2
DF20F -30DP-1H ( * * )
686-0029-8 ( * * )
30
14.0
17.5
16.2
DF20F -40DP-1H ( * * ) Reserved for product expansion
40
19.0
22.5
21.2
DF20F -50DP-1H ( * * ) Reserved for product expansion
50
24.0
27.5
26.2
Remarks
Without boss
(59): Gold plating,
Note:Order embossed tape packaging items by the reel. (1 reel contains 1,000 pieces)
5
BEmbossed Carrier Tape Dimensions
●Straight pin header
Ø1
12 ±0.1
+0
0 .1
0.2±0.05
A ±0.3
R0.
7
5
1.7 +0.15
B ±0.1
C ±0.1
.5
1.75±0.1
2 ±0.1
4 ±0.1
1.5
0.4
+0.1
Unreeling direction
7.9
2±0.1
12±0.1
4±0.1
0.2±0.05
A ±0.3
R0
.75
1.7 +0.15
B ±0.1
C ±0.1
.1
+0
Ø1
1.75 ±0.1
●Right angle pin header
0.4
1.5 +0.1
Unreeling direction
●Reel dimensions
D
17.5
16.4
DF20F(G)-20DP-1V
11.5
24.4
DF20F(G)-30DP-1V
30
32
28.4
14.2
32.4
DF20F(G)-40DP-1V
40
44
40.4
20.2
44.4
DF20F(G)-50DP-1V
50
44
40.4
20.2
44.4
DF20F-10DP-1H
10
16
17.5
16.4
DF20F-20DP-1H
11.5
24.4
DF20F-30DP-1H
30
32
28.4
14.2
32.4
DF20F-40DP-1H
40
44
40.4
20.2
44.4
DF20F-50DP-1H
50
44
40.4
20.2
44.4
* Reserved for product expansion
6
2 ±0.5
Product name
label
Ø1.5 mm diameter
feed hole depth
Ø21 ±
0.8
Ø380 ±2
C
16
(Ø80)
B
10
.2
A
DF20F(G)-10DP-1V
±0
Number of
Contacts
Ø1
3
Product No.
2 ±0.5
D
+2
BUsage recommendation
1. Recommended Soldering
Temperature Profile for IR Reflow.
Temperature
IR Reflow
Preheating: 150°C for 60 sec. to 120 sec.
Soldering: 235°C±5°C for 10 sec. max.
... Maximum 240°C 220°C min.
10s to 30s ... 220°C
Preheating
Maximum 240°C
220°C
Soldering
Note 1: Up to 2 cycles of reflow soldering are possible under the same conditions, provided
that there is a return to normal temperature between the first and second cycle.
Note 2: The temperature indicates the board surface temperature at the points of contacts
with the connector terminals.
2.Recommended Manual Soldering Conditions
Soldering temperature: 290°C ±10°C, Soldering time: within 3 sec.
3. Recommended Solder Screen Thickness
0.15mm
4. Board Warping
Maximum of 0.03 mm at the connector center section, with both ends of the connector as reference points.
5. Cleaning Conditions
Refer to "Nylon Connector Use Handbook."
6. Wiring Termination Conditions
Crimp contacts should be handled with care as not to cause any deformation or damage
affecting the performance or termination.
7. Mating / un-mating precautions
Excessive twisting and pulling on wires during mating/un-mating should be avoided as it
may cause damage to connectors.
7
很抱歉,暂时无法提供与“DF20F-3032SCFA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.30264
- 10000+0.25152
- 20000+0.20746
- 国内价格
- 1+0.24790
- 500+0.22540
- 1000+0.20290
