1.25mm Pitch Miniature Crimping Connector (UL Listed)
DF13 Series
Straight Type
Right Angle Type
Dec.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Type
Mounting Height(h)
Mounting Type
DIP
5.3mm
SMT
5.8mm
DIP
3.6mm
SMT
■Features
Correspond to Automatic Mounting
1. Miniature Size
Secure the automatic plain area for the absorption
type automatic mounting machine.
Designed in the low profile at mounting height 5.8mm.
(SMT mounting straight type)
(For DIP type, the mounting height is to 5.3mm to the
straight and 3.6mm at the right angle)
Straight Type
Absorption area
2. Multi-contact
The double row type achieves the multi-contact up to 40
contacts, and secures 30% higher density in the mounting
area, compared with the single row type.
3. Correspond to Automatic Mounting
The header provides the grade with the vacuum absorption
area, and secures automatic mounting by the embossed
tape packaging.
In addition, the tube packaging can be selected. (Fig.1)
4. Integral Basic Function Despite Miniature Size
The header is designed in a scoop-proof box structure, and
completely prevents mis-insertion.
In addition, the surface mounting (SMT) header is equipped
with the metal fitting to prevent solder peeling. (Fig.1)
Metal fitting
Right Angle Type
Absorption area
5. UL Certifled
6. Glow wire compliance (Compliant with IEC 60695-2-11)
■Applications
Note PC, mobile terminal, miniature type business equipment,
and other various consumer equipment, including video
camera
B242
Fig.1
DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed)
■Product Specifications
Specification
1A
UL
Specification AC 150V
Voltage rating
UL
AC/DC 29.9V
Current rating
Rating
Item
Operating Temperature Range : -35 to +85ç (Note 1) Storage Temperature Range : -10 to +60ç (Note 2)
Operating Moisture Range : 20 to 80% (Note 3)
Storage Moisture Range : 40 to 70% (Note 2)
Specification
Condition
1.Insulation Resistance
500Mø min.
100V DC
2.Withstanding voltage
No flashover or insulation breakdown.
500V AC/1 minute
3.Contact Resistance
30mø max.
100mA
4.Single Insertion/Extraction Force 0.3N (30gf) min., 3N (300gf) max.
Measured at the square steel pin of 0.35±0.002mm
No electrical discontinuity of 1μs or more
5.Vibration
Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
6.Humidity (Steady state) Contact resistance : 30mø max. Insulation resistance : 500Mø min.
96 hours at temperature of 40ç and humidity of 90% to 95%
7.Temperature Cycle
(-55ç : 30 minutes➝ 5 to 35ç : 10 minutes➝ 85ç : 30 minutes➝ 5 to 35ç : 10 minutes) 5 cycles
8.Durability (Mating/un-mating) Contact resistance : 30mø max.
Tin plating : 30 cycles
Gold plating : 50 cycles
No deformation of components affecting performance.
9.Resistance to Soldering heat
Flow : 250ç for 10 seconds
Manual soldering : 300ç for 3 seconds
Reflow : At the recommended temperature profile
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3 : Use without condensation on parts.
■UL File No. and Recognition No. UL : E52653
■Materials/Finish
Product
Crimping Socket
Crimping Contact for Socket
Pin Header (Through hole)
Pin Header (SMT Single row)
Pin Header (SMT Double row)
Part
Insulator
Contact
Insulator
Contact
Insulator
Contact
Metal Fitting
Insulator
Contact
Metal Fitting
Material
Polyamide
Phosphor copper
Polyamide
Brass
Polyamide
Brass
Phosphor copper
Polyamide
Brass
Phosphor copper
Finish
Beige
Tin plated or gold plated
Beige
Tin plated
Beige
Tin plated
Beige
Tin-copper plated or gold plated
Tin plated
Remarks
UL94V-0
UL94V-0
UL94V-0
UL94V-0
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Connector
DF13
q
# - * S - 1.25 C
w
e
r
t
y
q Series Name
: DF13
e Number of Contacts
t Contact Pitch: 1.25mm
w Style Symbol
: Blank : With boss
r Single row : 2 to 12, 14, 15
y Connection Form / Contact Style.
A : Without boss
r Double row : 10, 20, 30, 40
C : Crimping socket / DSA : Straight through hole
C : Without boss
r Connector Type
DS : Right angle through hole / V : Straight SMT
t S : Single row socket / P : Single row pin header
H : Right angle SMT
t DS : Double row socket / DP : Double row pin header
●Contact
DF13 # - 2630 SCF A
q
w
e
r
q Style Symbol
Blank: Standard
e Packaging Type SCF : Socket Contact/Reel
G: Low insertion / extraction r Plating Type
w Applicable Cable Size 2630 : 26 to 30 AWG
Blank : Tin plated
A : Gold plated
3032 : 30 to 32 AWG
B243
■Single Row Socket
Photo: Contact insertion
Part No.
HRS No. No. of Contacts
536-0001-4
DF13-2S-1.25C
2
536-0002-7
DF13-3S-1.25C
3
536-0003-0
DF13-4S-1.25C
4
536-0004-2
DF13-5S-1.25C
5
536-0005-5
DF13-6S-1.25C
6
536-0006-8
DF13-7S-1.25C
7
536-0007-0
DF13-8S-1.25C
8
Note 1. The quantity is delivered per bag (100
A
1.25
2.50
3.75
5.00
6.25
7.50
8.75
pcs.).
B
RoHS
Part No.
4.15
536-0008-3
DF13- 9S-1.25C
9
536-0009-6
5.40
DF13-10S-1.25C
10
6.65
536-0010-5
DF13-11S-1.25C
11
Yes
7.90
536-0011-8
DF13-12S-1.25C
12
9.15
536-0012-0
DF13-13S-1.25C
13
10.40
536-0013-3
DF13-14S-1.25C
14
11.65
536-0014-6
DF13-15S-1.25C
15
If needed, please select and order the products per bag.
■Double Row Socket
Photo: Contact insertion state
Part No.
DF13-10DS-1.25C
DF13-20DS-1.25C
DF13-30DS-1.25C
DF13-40DS-1.25C
Note : The quantity
B244
Unit : mm
A
B
RoHS
536-0550-2
10
10.40
5.00
536-0555-6
11.25
Yes
536-0560-6
30
22.90
17.50
536-0565-0
40
29.15
23.75
is delivered per bag (100pcs). If needed, please select and order the products per bag.
A
10.00
11.25
12.50
13.75
15.00
16.25
17.50
Unit : mm
B
RoHS
12.90
14.15
15.40
16.65 Yes
17.90
19.15
20.40
■Single Row Straight Pin Header (Through hole)
[Specific No.] (**), **
Blank : Tin plated
(20) : Tin plated, tube packaging
BTube Dimensions
10
5
●Board Through-hole Diameter:Ø0.6±0.03
Unit: mm
Part No.
HRS No. No. of Contacts A
B Tube Packaging Quantity RoHS
Part No.
115
37
DF13-2P-1.25DSA(**) 536-0101-9 **
2
1.25 4.15
DF13- 9P-1.25DSA(**) 536-0108-8 **
9
10.00 12.90
89
34
DF13-3P-1.25DSA(**) 536-0102-1 **
3
2.50 5.40
DF13-10P-1.25DSA(**) 536-0109-0 **
10
11.25 14.15
72
31
DF13-4P-1.25DSA(**) 536-0103-4 **
4
3.75 6.65
DF13-11P-1.25DSA(**) 536-0110-0 **
11
12.50 15.40
61
29
Yes DF13-12P-1.25DSA(**) 536-0111-2 **
Yes
DF13-5P-1.25DSA(**) 536-0104-7 **
5
5.00 7.90
12
13.75 16.65
52
27
DF13-6P-1.25DSA(**) 536-0105-0 **
6
6.25 9.15
DF13-13P-1.25DSA(**) 536-0112-5 **
13
15.00 17.90
46
25
DF13-7P-1.25DSA(**) 536-0106-2 **
7
7.50 10.40
DF13-14P-1.25DSA(**) 536-0113-8 **
14
16.25 19.15
41
23
DF13-8P-1.25DSA(**) 536-0107-5 **
8
8.75 11.65
DF13-15P-1.25DSA(**) 536-0114-0 **
15
17.50 20.40
Note 1. The quantity at the specific No."None" is delivered per bag (100 pcs.). If needed, please select and order the products per bag.
Note 2. Order the tube packaging product, multiplying the tube packaging quantity.
■Single Row Right Angle Pin Header (Through hole)
(20) : Tin plated tube packaging
BTube Dimensions
Part No.
Part No.
2
1.25 4.15
115
DF13-2P-1.25DS(20) 536-0151-7 20
DF13- 9P-1.25DS(20)
3
2.50 5.40
89
DF13-3P-1.25DS(20) 536-0152-0 20
DF13-10P-1.25DS(20)
4
3.75 6.65
72
DF13-4P-1.25DS(20) 536-0153-2 20
DF13-11P-1.25DS(20)
Yes DF13-12P-1.25DS(20)
5
5.00 7.90
61
DF13-5P-1.25DS(20) 536-0154-5 20
6
6.25 9.15
52
DF13-6P-1.25DS(20) 536-0155-8 20
DF13-14P-1.25DS(20)
7
7.50 10.40
46
DF13-7P-1.25DS(20) 536-0156-0 20
DF13-15P-1.25DS(20)
8
8.75 11.65
41
DF13-8P-1.25DS(20) 536-0157-3 20
Note 1.Order the tube packaging product, multiplying the tube packaging quantity.
9
536-0158-6 20
10
536-0159-9 20
11
536-0160-8 20
12
536-0161-0 20
14
536-0163-6 20
15
536-0164-9 20
Unit : mm
A
10.00 12.90
37
11.25 14.15
34
12.50 15.40
31
Yes
13.75 16.65
29
16.25 19.15
25
17.50 20.40
23
B245
■Single Row Straight Pin Header (SMT)
■(Three-Wall/Correspond to Vacuum Absorption)
1.8
BPCB mounting pattern
B246
Note 1.Shaded area must be free of any
electrically conductive traces to
avoid contact with soldered pin
header terminations.
This pin header is a three-wall type, header has sufficiently large flat areas to allow
pick-up with vacuum nozzles of automatic placement equipment.
(21) : Tin plated embossed tape packaging
(51) : Gold plated embossed tape packaging
Unit : mm
Part No.
HRS No.
No. of Contacts
A
1.25
2
536-0401-2 **
DF13C- 2P-1.25V(**)
2.50
3
536-0402-5 **
DF13C- 3P-1.25V(**)
3.75
4
536-0403-8 **
DF13C- 4P-1.25V(**)
5.00
5
536-0404-0 **
DF13C- 5P-1.25V(**)
6.25
6
536-0405-3 **
DF13C- 6P-1.25V(**)
7.50
7
536-0406-6 **
DF13C- 7P-1.25V(**)
8.75
8
536-0407-9 **
DF13C- 8P-1.25V(**)
10.00
9
536-0408-1 **
DF13C- 9P-1.25V(**)
11.25
10
536-0409-4 **
DF13C-10P-1.25V(**)
12.50
11
536-0410-3 **
DF13C-11P-1.25V(**)
13.75
12
536-0411-6 **
DF13C-12P-1.25V(**)
16.25
14
536-0413-1 **
DF13C-14P-1.25V(**)
17.50
15
536-0414-4 **
DF13C-15P-1.25V(**)
Note 1.Please order the embossed tape packaging product according
B
C
D
E
F
4.15
5.40
6.65
7.90
9.15
10.40
11.65
12.90
14.15
15.40
16.65
19.15
20.40
7.15
8.40
9.65
10.90
12.15
13.40
14.65
15.90
17.15
18.40
19.65
22.15
23.40
5.65
6.90
8.15
9.40
10.65
11.90
13.15
14.40
15.65
16.90
18.15
20.65
21.90
1.95
3.20
4.45
5.70
6.95
8.20
9.45
10.70
11.95
13.20
14.45
16.95
18.20
2.20
3.45
3.10
4.35
5.60
6.85
8.10
9.35
10.60
11.85
13.10
15.60
16.85
to reel number. (1000pcs/reel)
Emboss
Width
16
16
24
24
24
24
24
24
24
32
32
32
44
RoHS
Yes
■Single Row Right Angle Pin Header (SMT)
■(Four-Wall/Correspond to Vacuum Absorption)
1.8
Unit : mm
Part No.
HRS No.
No. of Contacts
A
1.25
2
536-0301-8 **
DF13A- 2P-1.25H(**)
2.50
3
536-0302-0 **
DF13A- 3P-1.25H(**)
3.75
4
536-0303-3 **
DF13A- 4P-1.25H(**)
5.00
5
536-0304-6 **
DF13A- 5P-1.25H(**)
6.25
6
536-0305-9 **
DF13A- 6P-1.25H(**)
7.50
7
536-0306-1 **
DF13A- 7P-1.25H(**)
8.75
536-0307-4 **
8
DF13A- 8P-1.25H(**)
10.00
9
536-0308-7 **
DF13A- 9P-1.25H(**)
11.25
10
536-0309-0 **
DF13A-10P-1.25H(**)
12.50
11
536-0310-9 **
DF13A-11P-1.25H(**)
13.75
12
536-0311-1 **
DF13A-12P-1.25H(**)
16.25
14
536-0313-7 **
DF13A-14P-1.25H(**)
17.50
15
536-0314-0 **
DF13A-15P-1.25H(**)
B
4.15
5.40
6.65
7.90
9.15
10.40
11.65
12.90
14.15
15.40
16.65
19.15
20.40
to reel
C
D
Emboss
Width
7.15 5.65
16
8.40 6.90
16
9.65 8.15
24
10.90 9.40
24
12.15 10.65
24
13.40 11.90
24
14.65 13.15
24
15.90 14.40
24
17.15 15.65
24
18.40 16.90
32
19.65 18.15
32
22.15 20.65
32
23.40 21.90
44
RoHS
Yes
B247
■Double Row Straight Pin Header (SMT)
Note 1. Shaded area must be free of any electrically
conductive traces to avoid contact with soldered
pin header terminations.
(21) : Tin-copper plated embossed tape packaging
Unit: mm
Spec No. Spec No. Emboss
Part No.
HRS No.
No. of Contacts
A
B
C
DF13EA-10DP-1.25V(**)
536-0570-0
10
12.10
5.00
DF13EA-20DP-1.25V(**)
536-0571-0
(51)
Width
8.70
24
18.35 11.25 14.95
32
44
44
DF13EA-30DP-1.25V(**)
536-0572-0
30
24.60 17.50 21.20
DF13EA-40DP-1.25V(**)
536-0573-0
40
30.85 23.75 27.45
Note 1. Please order the embossed tape packaging product according to reel number. (1000pcs/reel)
Note 2. The absorption cap is attached to the embossed tape packaging product.
B248
RoHS
Yes
■Crimping Contact
wire
HRS No. UL styleRecommended
Wire size Wire conductor Jacket diameter Packaging Finish RoHS
26AWG 7pieces/φ0.16mm
1061 28AWG 7pieces/φ0.127mm φ0.56 to
DF13-2630SCF
536-0300-5
1571 30AWG 7pieces/φ0.1mm φ1.0mm 10,000pcs/reel Tin plating
1061 30AWG 7pieces/φ0.1mm φ0.52 to
DF13-3032SCF
536-0299-8
1571 32AWG 7pieces/φ0.08mm φ0.8mm
1061 26AWG 7pieces/φ0.16mm
to
DF13-2630SCFA(04) 536-0298-5 04 1571 28AWG 7pieces/φ0.127mm φ0.56
φ1.0mm
10,000pcs/reel Gold plating Yes
1061
φ0.52 to
DF13-3032SCFA
536-0641-6 00 1571 30AWG 7pieces/φ0.1mm φ0.8mm
1061 26AWG 7pieces/φ0.16mm φ0.56 to
DF13G-2630SCF
536-0643-1
Tin plating
1571 28AWG 7pieces/φ0.127mm φ1.0mm
10,000pcs/reel
1061 26AWG 7pieces/φ0.16mm φ0.56 to (Low insertion/extraction)
DF13G-2630SCFA 536-0642-9
Gold plating
Note 1. Contact extraction tool : DF-C-PO(B)
Note 2. Material used as a conductor of recommended wire is annealed tinned
copper wire.
Note 3. Please contact your local Hirose sales REP if you plan on using wires other
than those listed above.
Part No.
KDF13G
1
1.5
0.15
BApplicable Crimping Tool
Part No.
HRS No.
AP105-DF13-2630S
901-4531-9
AP105-DF13-3032S
Press Main Unit
CM-105C
Manual Crimping Tool DF13-TB2630HC
901-4552-9
901-0001-0
550-0256-1
0.8
Type
0.5
2
0.9
3.7
3.3
Applicator
7.2
Extraction Tool
DF-C-PO(B)
550-0179-2
Applicable Contact
DF13-2630SCF/SCFA
DF13G-2630SCF/SCFA
DF13-3032SCF/SCFA
--------------DF13-2630SCF
DF13-2630SCF/SCFA
DF13G-2630SCF/SCFA
DF13-3032SCF/SCFA
Note 1. If a trouble has occurred due to other tools, which are not designated by Hirose,
Hirose won't guarantee any product.
Note 2. The manual crimping tool is used to sequentially cut the reel contact with carrier.
Note 3. Please conduct crimping work according to the "Crimping quality standard" and
"Crimping condition table".
BApplication Pattern
Through hole
(Single Row Product)
SMT
(Double Row Product)
Right Angle
SMT
Straight
KDF13
B249
■Crimp contact with cable
B250
DF13-2630SF 1571 - 26 A 9 - 300
1
2
3
4
5
3 Wire size
1 Part No. of adopted crimping contact
5 Wire color
26 : 26AWG
DF13-2630SF : DF13-2630SCF
DF13-2630SFA : DF13-2630SCFA(04)
9 : White
4 Crimp position / End processing
A : Both end crimped
2 Wire type
1571 : UL1571
6
B : One side crimped without end processing
0 : Black
6 Wire length
300 : 300mm
S : One side crimped with striped end processing
Part No.
DF13-2630SF1571-26A9-300
DF13-2630SFA15711-26A9-300
HRS No.
Quantity
Finish
536-9001-0 00
100pcs/Pack
Tin plating
Under development
100pcs/Pack
Gold plating
Note 1. Bag packaging (100pcs/pack). Order by number of packs.
Note 2. Please contact your local sales rep if you plan on using specification other than those listed above.
BEmbossed Carrier Tape Dimensions
5.2±0.15
A−A
(1.4)
C±0.1
Product name label
Ø370±2
B±0.1
A±0.3
Ø21±0.8
A
A
+2
D 0
(D+6)MAX
A
DIRECTION OF UNREELING
0.2
A−A
(1.1)
2±0.5
3±
4.1±0.15
0.3±0.1
Ø1
Ø21±
(Ø80)
A
C±0.1
B±0.1
A±0.3
Product name label
Ø330±2
2±0.1(A
