565-290-721P60
565-290-721P60
    565-290-721P60
565-290-721P60 数据手册
Water-Proof Product Line Connect with Us…Experience the Difference Your Connection to www.EDAC.net Quality & Service Features and Benefits Simple crimp and poke application Interface seals designed and tested to IP67 and SAE USCAR-2 standards Easy Terminal Extraction and Insertion Compatible with UL 28-14 AWG cable No need for individual wire seals for 565 and 566 series Housing seals and individual seals for 567, 568 & 570 Series Wide range of power and signal applications Various Pitch and Voltage/Current versions available Waterproof caps available to seal unused cavities in 565 & 566 Series Custom pre-assembled cable assemblies available Connect with Us…Experience the Difference. Your Connection to www.EDAC.net Quality & Service Applications Medical Patient Monitoring Ultrasound Industrial Outdoor Lighting Processing Equipment Vending Food Service Drink Dispenser Automotive OEM Aftermarket Recreation Marine Snowmobiles ATV Outdoor Hot Tubs Pools Connect with Us…Experience the Difference. Your Connection to www.EDAC.net Quality & Service 565 Series Housing: PBT (94V-0) Integral Wire Seal Wire to Wire and Wire to Board 2, 3 and 5 Position versions 2.5mm pitch Rated Current: 3A Max . Rated Voltage: 250V Wire sizes: 20-28 AWG Temperature range: -40c to 105c PCB thickness: 1.6mm Connect with Us…Experience the Difference Your Connection to www.EDAC.net Quality & Service 566 Series Housing: PBT (94V-0) Integral Wire Seals Tested & Certified to IP67 Wire to Wire 2, 3, 4 Positions Wire to Board 2, 3 Positions 2.0mm pitch Rated Current: 2A Max. Rated Voltage: 250V Wire sizes: 22-28 AWG Temperature range: -40c to 105c Connect with Us…Experience the Difference Your Connection to www.EDAC.net Quality & Service 567 Series Housing: PBT (94V-0) Wire to Wire 1,2,3,4,6 and 9 Position versions 5.0 X 5.9 mm pitch Rated Current: 8A Max Rated Voltage: 300V Separate Wire Seals Wire sizes: 14 - 22 AWG Insulation Diameter: 1.7mm – 3.1mm Temperature range: -40c to 105c Connect with Us…Experience the Difference Your Connection to www.EDAC.net Quality & Service 568 Series Housing: PBT (94V-0) Wire to Wire Separate Wire Seals Tested & Certified to IP67 1 Position Rated Current: 12A Max Rated Voltage: 300V Wire Size: 14 – 22 AWG Insulation Diameter: 1.7mm – 3.1mm Temperature range: -40c to 105c Connect with Us…Experience the Difference Your Connection to www.EDAC.net Quality & Service 570 Series Housing: PBT (94V-0) Wire to Wire and Wire to Board Separate Wire Seals Tested & Certified to IP67 1, 2 and 3 Position versions 5.8mm pitch Rated Current: 10A Max Rated Voltage: 300V Wire Sizes: 14 - 22 AWG Insulation Diameter: 1.7mm – 3.1mm Temperature range: -40c to 105c PCB Thickness: 1.6mm Connect with Us…Experience the Difference Your Connection to www.EDAC.net Quality & Service Tooling Auto Crimp Machines Applicators available for all Series Bench Mount type Quick Change Applicators 110V 50/60 Hz One-Touch Applicators Quick Change Applicators available for all contacts Fits most Universal Automatic machines Quick Set-up Retainer Insertion Tool Inserts the retainer into the connector housing Ensures Water Tight Seal Used on High Volume production Connect with Us…Experience the Difference Your Connection to www.EDAC.net Quality & Service Tooling Hand tool crimper Manual hand crimp tools Cuts contacts from Carrier Strips Extraction and Insertion Tools Easy Insertion and Removal of contacts Low Cost Field Repairs Connect with Us…Experience the Difference Your Connection to www.EDAC.net Quality & Service Thank You Connect with Us…Experience the Difference Your Connection to www.EDAC.net Quality & Service
565-290-721P60 价格&库存
很抱歉,暂时无法提供与“565-290-721P60”相匹配的价格&库存,您可以联系我们找货
565-290-721P60
