GT8-2428SC(70)
GT8-2428SC(70)
    HRS(广濑)
    CONN SKT CRIMP 22-28AWG TIN
GT8-2428SC(70) 数据手册
GT 13 GT 5 Connections of the Various Units and Device Interiors PO5G GT 16 GT8 Series GT 11 — High-Pressure Connectors — GT 7 Features GT 9 GT 8 GT 15 GT 18W GT 10 Crimp Terminals U  se of an air-tight dimple construction at the contact portion serves to prevent oxidation of the contact portion. F Connector Housing T  erminal number markings appear in a large size in consideration of insertion processing. F  orm designed to prevent erroneous insertion. M Connectors D  esigned with escape holes for washing liquid to escape so that secondary soiling may be prevented when the board has been washed. T  he surrounding wall of the terminal has been constructed higher than the terminal so as to prevent terminal bending. The others T  he F connector housing fits entirely inside of the M connector to prevent incomplete insertion and prevents twisting and other problems. The F connector is guarded so that there is no slanting nor contact movement, and the connector is resistant to vibration. T  he color of the F connector housing and the M connector have been changed to prevent incomplete insertion. M Connectors (SMT Product) I nstead of using screws for board fastening, a lead reflow type of reinforced fitting is used that permits soldering at the time of reflow. GT 25 GT 22 Connections of the Various Units and Device Interiors GT 6W GT 3 GT 27 GT 26 GT 19 GT 17 200 Applications Internal connections of mobile units and industrial equipments. GT8 Series F Connectors 1.5 1.7 GT 13 Terminals GT 5 6.2 GT 16 PO5G GT 11 Material Phosphor bronze Phosphor bronze Phosphor bronze Phosphor bronze Finish Tin plating Tin plating Tin plating Tin plating Packaging 10,000 pcs/reel 10,000 pcs/reel 10,000 pcs/reel 10,000 pcs/reel Applicable housing RoHS GT8-*DS-2C, GT8A-*DS-2C, GT8Z-*DS-2C YES GT8E-*S-2C, GT8E-*DS-2C, GT8E-*S-HU, GT8E-*DS-HU Note : GT8-2428SC(70) loose terminals for hand tools are also available. There are 100 pieces per package. GT 26 A GT 27 6.2 Housing (Without Flange) 8 GT 3 Housing (With Flange) RoHS YES 6.2 8.4 B A GT 10 GT 18W GT 15 Number of positions A dimension Specifications Packaging 14 15.8 1piece 20 21.8 1piece 24 25.8 1piece 20 21.8 1piece Without lock 24 25.8 1piece GT 7 HRS No. Material Color 758-0018-0 758-0003-3 758-0005-9 PBT Dark Gray 758-0011-1 758-0012-4 3 GT 9 8 GT 8 Note : This product mates with GT8- or GT8A-*DP-2DSA(70). Number of positions A dimension 14 15.8 20 21.8 24 25.8 B dimension 22 28 32 Packaging 1piece 1piece 1piece RoHS YES GT 22 HRS No. Material Color 758-0009-0 758-0007-4 PBT Dark Gray 758-0008-7 GT 25 Part Number GT8Z-14DS-2C GT8Z-20DS-2C GT8Z-24DS-2C 201 Connections of the Various Units and Device Interiors Part Number GT8-14DS-2C GT8-20DS-2C GT8-24DS-2C GT8A-20DS-2C GT8A-24DS-2C Terminal No. GT 6W Lock Lock GT 19 HRS No. 758-0001-8-70 758-0026-9 758-0033-4 758-0055-7 GT 17 Part Number GT8-2428SCF(70) GT8-2022SCF GT8E-2022SCF GT8E-2428SCF GT8E Series F Connectors Single low Housing Part Number GT8E-2S-2C GT8E-8S-2C Applicable AWG #20-22 AWG #24-28 Applicable conductor GT8E-2022SCF GT8B-2428SCF HRS No. Material Color 758-0030-6 PBT Black 758-0029-7 Number of positions A dimension±0.15 2 7.1 8 16.6 Packaging 1piece 1piece Note 1: Applicable terminal is GT8E-2022PCF. Note 2: Use this in combination with GT8EW-4P-R, GT8EW-4P/S-BR, GT8EW-4P/S-BHS. Note 3: Applicable housing is GT8E-W-4S-HU. GT 15 GT 18W GT 10 GT 7 Single low Housing GT 8 GT 9 GT 25 GT 22 Connections of the Various Units and Device Interiors Plug GT8E *S-2C GT 6W GT 3 GT 27 GT 26 GT 19 GT 17 GT 11 PO5G GT 16 GT 13 GT 5 GT8 Series 202 Plug GT8E-8DS-2C Applicable AWG #20-22 AWG #24-28 Part Number GT8E-8DS-2C HRS No. 758-0027-1 Applicable conductor GT8E-2022SCF GT8B-2428SCF Material PBT Color Black Note 1: Applicable terminal is GT8E-2022SCF, GT8B-2428SCF(70). Note 2: Applicable housing is GT8E-*S-HU. Number of positions 8 Packaging 1piece RoHS YES RoHS YES GT8 Series GT 5 Housing (3 to 10 pos./single row) GT 13 GT 16 PO5G GT 11 GT 17 Applicable Applicable conductor AWG #20-22 GT8E-2022SCF GT8E-*S-HU AWG #24-28 GT8B-2428SCF HRS No. 758-0061-0 758-0047-9 758-0062-2 758-0048-1 758-0063-5 758-0049-4 758-0050-3 Material PBT PBT PBT PBT PBT PBT PBT Color Black Black Black Black Black Black Black Note 1: Applicable terminal is GT8E-2022SCF, GT8B-2428SCF. Note 2: This product mates with GT8E-*P-DS. Number of positions A dimension 3 7.9 0.5 4 8.6 0.5 5 12 0.5 6 12.6 0.5 7 15.6 0.5 8 16.6 0.5 10 20.6 0.7 B dimension C dimension 7.9 0.5 4 0.15 8.6 0.5 6 0.15 7.1 0.5 8 0.15 7.1 0.5 10 0.15 7.1 0.5 12 0.15 7.1 0.5 14 0.15 7.1 0.5 18 0.15 Number of positions A dimension 12 16.6 0.5 16 21.85 0.7 20 24.6 0.7 24 28.6 0.7 B dimension 14 0.15 18 0.15 22 0.15 26 0.15 + + + + + + + - + + + + + + + - + + + + + + + - Packaging 1piece 1piece 1piece 1piece 1piece 1piece 1piece RoHS YES GT 3 Part Number GT8E-3S-HU GT8E-4S-HU GT8E-5S-HU GT8E-6S-HU GT8E-7S-HU GT8E-8S-HU GT8E-10S-HU GT 27 GT 26 Plug GT 19 GT 6W Howsing (Double row) GT 7 GT 10 GT 18W GT 15 GT 8 Plug HRS No. CL758-0051-6 CL758-0064-8 CL758-0052-9 CL758-0054-4 Material PBT PBT PBT PBT Color Black Black Black Black Note 1: Applicable terminal is GT8E-2022SCF, GT8B-2428SCF. Note 2: This product mates with GT8E-*DP-DS. + + + + - + + + + - Packaging 1piece 1piece 1piece 1piece RoHS YES GT 22 Part Number GT8E-12DS-HU GT8E-16DS-HU GT8E-20DS-HU GT8E-24DS-HU Applicable conductor GT8E-2022SCF GT8B-2428SCF GT 25 Applicable AWG #20-22 AWG #24-28 GT 9 GT8E-*DS-HU 203 Connections of the Various Units and Device Interiors M connector Board type(Vertical Dip type) BRecommended Board Mounting Pattern GT 27 GT 26 GT 19 GT 17 GT 11 PO5G GT 16 GT 13 GT 5 GT8 Series GT 7 GT 15 GT 18W GT 10 GT 8 GT 9 GT 25 GT 22 Connections of the Various Units and Device Interiors GT 6W GT 3 BFully Mated connector assemblies 204 Part Number GT8E-4P-DSA GT8E-7P-DSA HRS No. 758-0065-0 758-0066-3 Number of positions 4 7 A dimension 11.98 0.2 18.98 0.2 + + - B dimension 6 0.15 12 0.15 + + - C dimension 14.4 0.3 21.4 0.3 + + - D dimension E dimension 6 0.5 11.98 0.15 12 0.5 18.98 0.15 + + - + + - Packaging 1piece 1piece GT8 Series GT 5 BFully Mated connector assemblies Board type(S.M.T. 8pos) GT 13 GT 16 PO5G GT 11 GT 17 BRecommended Board Mounting Pattern Packaging GT 19 400pcs/reel GT 26 Color/Finish Part Number HRS No. Material PPS(Housing) Black GT8E-8DP-2H(70) 758-0028-4-70 Brass(Contact) Tin plated Brass(Reinforced fitting) Tin plated Note 1: Applicable housing is GT8E-8DS-2C. GT 27 GT 3 BFully Mated connector assemblies Board type(Small-size S.M.T.) GT 6W GT 7 GT 10 GT 18W GT 15 GT 8 Note 1: Applicable housing is GT8E-*S-HU. Color/Finish Black Tin plated Tin plated Packaging RoHS 500pcs/reel 400pcs/reel YES 400pcs/reel GT 22 Material PBT(Housing) Brass(Contact) Brass(Metal fitting) + + + - GT 25 + + + - GT 9 Number of positions A dimension B dimension C dimension D dimension E dimension F dimension HRS No. Part Number GT8E-2P-2H(70) 758-0032-1-70 2 13 0.15 9.15 0.15 2 10.58 2 10.58 GT8E-3P-2H 758-0096-4 3 13.7 0.3 9.85 0.3 4 11.28 4 11.28 GT8E-4P-2H 758-0079-5 4 14.4 0.3 10.55 0.3 6 11.98 6 11.98 205 Connections of the Various Units and Device Interiors BRecommended Board Mounting Pattern Board type(Small-size 8/2pos) BRecommended Board Mounting Pattern GT 17 GT 11 PO5G GT 16 GT 13 GT 5 GT8 Series GT 27 GT 26 GT 19 BFully Mated connector assemblies Finish Black Tin plated Tin plated Packaging RoHS 500pcs/reel YES Note 1: Applicable housing is GT8E-8S-2C. Board type(8/5pos) GT 7 BFully Mated connector assemblies BRecommended Board Mounting Pattern GT 8 GT 15 GT 18W GT 10 Material PPS(Housing) Brass(Contact) Brass(Metal fitting) GT 9 GT 25 GT 22 Connections of the Various Units and Device Interiors GT 6W GT 3 Part Number HRS No. GT8E-8/2P-2H(70) 758-0031-9-70 206 Part Number GT8E-8/5P-2H HRS No. 758-0073-9 Material PPS(Housing) Brass(Contact) Brass(Metal fitting) Note 1: Applicable housing is GT8E-5S-HU, GT8E-8S-2C. Finish Black Tin plated Tin plated Packaging 500pcs/reel GT8 Series BFully Mated connector assemblies GT 5 Board type(Single raw DIP type) GT 13 GT 16 PO5G BRecommended PCB Mounting Pattern GT 11 Number of potions 2 3 4 5 6 7 8 10 A dimension B dimensions C dimension D dimension E dimension F dimension 9.15±0.5 2±0.5 10.58±0.5 2±0.5 10.58±0.5 13±0.5 13.7±0.5 9.85±0.5 4±0.5 11.28±0.5 4±0.5 11.28±0.5 14.4±0.5 10.55±0.5 6±0.5 11.98±0.5 6±0.5 11.98±0.5 17.8±0.5 13.95±0.5 8±0.5 15.38±0.5 8±0.5 15.38±0.5 18.4±0.5 14.55±0.5 10±0.5 15.98±0.5 10±0.5 15.98±0.5 21.4±0.5 17.55±0.5 12±0.5 18.98±0.5 12±0.5 18.98±0.5 22.4±0.5 18.55±0.5 14±0.5 19.98±0.5 14±0.5 19.98±0.5 26.4±0.5 22.55±0.5 18±0.5 23.98±0.5 18±0.5 23.98±0.5 Packaging 1piece 1piece 1piece 1piece 1piece 1piece 1piece 1piece RoHS YES GT 27 HRS No. 758-0040-0 758-0057-2 758-0041-2 758-0058-5 758-0042-5 758-0059-8 758-0043-8 758-0044-0 Note1 : Applicable housing is GT8E-*S-HU Note2 : GT8E-2P-DS mates with GT8E-2S-2C. BFully Mated connector assemblies GT 3 Boad type(Double row DIP type) GT 26 Part Number GT8E-2P-DS GT8E-3P-DS GT8E-4P-DS GT8E-5P-DS GT8E-6P-DS GT8E-7P-DS GT8E-8P-DS GT8E-10P-DS GT 19 Finish Black Tin plated Tin plated GT 17 Material PBT(Housing) Brass(Contact) Brass(Metal fitting) GT 6W GT 7 GT 10 GT 18W GT 15 GT 8 12 16 20 24 Number of potions A dimension B dimensions C dimension D dimension E dimension F dimension 18.55±0.3 14±0.15 19.98±0.2 14±0.05 19.98±0.05 22.4±0.3 27.25±0.3 23.6±0.3 18±0.15 25.03±0.2 18±0.05 25.08±0.05 30±0.3 26.35±0.3 22±0.15 27.78±0.2 22±0.05 27.78±0.05 34±0.3 30.35±0.3 26±0.15 31.78±0.2 26±0.05 15.38±0.05 Note : Applicable housing is GT8E-*DS-HU Packaging 1 piece 1 piece 1 piece 1 piece RoHS YES GT 22 HRS No. 758-0045-3 758-0060-7 758-0046-6 758-0053-1 GT 25 Part Number GT8E-12DP-DS GT8E-16DP-DS GT8E-20DP-DS GT8E-24DP-DS Finish Black Tin plated Tin plated GT 9 Material PBT(Housing) Brass(Contact) Brass(Metal fitting) 207 Connections of the Various Units and Device Interiors BRecommended PCB Mounting Pattern BFully Mated connector assemblies In-Line Type GT 13 GT 5 GT8 Series GT8E-*P-HU (23.2) GT 17 GT 11 PO5G GT 16 GT8E-*S-HU 13.8±0.15 GT 19 GT 26 GT 27 B Part Number GT8E-3P-HU GT8E-4P-HU GT8E-8P-HU HRS No. Material Color 758-0084-5 758-0082-0 PBT BLACK 758-0038-8 Note1 : Applicable terminal is GT8E-2022PCF, GT8E-2428PCF Note2 : Mate with GT8E-*S-HU(8pos:GT8E-8S-2C) GT 7 GT 15 GT 18W GT 10 Connections of the Various Units and Device Interiors GT 6W GT 3 2±0.15 GT 8 GT 9 GT 25 GT 22 208 21.8±0.7 A Plug GT8EW-4P-HU Part Number GT8EW-4P-HU Applicable AWG #20-22 HRS No 7758-0059-1 Applicable conductor GT8E-2022PCF Number of positions 4 Packaging 1piece Note 1: Applicable terminal is GT8E-2022PCF. Note 2: Use this in combination with GT8EW-4P-R, GT8EW-4P/S-BR, GT8EW-4P/S-BHS. Note 3: Applicable housing is GT8E-W-4S-HU. Number of positions A dimension 3 10.55±0.5 4 10.55±0.5 8 18.55±0.7 B dimension 4 6 14 Packaging 1piece 1piece 1piece RoHS YES GT8 Series GT 5 In-line socket (water proof) GT 13 GT 16 PO5G GT 11 Part Number GT8EW-4S-HU HRS No 758-0068-9 Applicable conductor GT8-2022SCF Number of positions 4 Packaging 1piece GT 27 Retainer (Only for GT8EW-4P-HU) GT 26 Note 1: Applicable terminal is GT8E-2022SCF. Note 2: Use this in combination with GT8EW-4P-R, GT8EW-4P/S-BR, GT8EW-4P/S-BHS. Note 3: Applicable housing is GT8E-W-4P-HU. GT 19 Applicable AWG #20-22 GT 17 Plug GT8EW-4S-HU GT 3 GT 6W Packaging 1piece Retainer (Only for GT8EW-4S-HU) GT 10 GT 18W GT 15 Note : Use this in combination with GT8EW-4P-HU. GT 7 HRS No 758-0077-0 GT 8 GT 9 Packaging 1piece Note : Use this in combination with GT8EW-4S-HU. GT 22 HRS No 758-0076-7 GT 25 Part Number GT8EW-4S-R 209 Connections of the Various Units and Device Interiors Part Number GT8EW-4P-R Retainer (Used with GT8EW-4P-HU, GT8EW-4S-HU) GT 11 PO5G GT 16 GT 13 GT 5 GT8 Series Part Number GT8EW-4P/S-BR HRS No 758-0070-0 Packaging 1piece Bushing (Used with GT8EW-4P-HU, GT8EW-4S-HU) Part Number GT8EW-4P/S-BHS HRS No 758-0071-3 Packaging 1piece B In line waterproof connector use hand book GT 25 GT 9 GT 8 GT 15 GT 18W GT 10 GT 7 Note : Use this in combination with GT8EW-4P-HU, GT8EW-4S-HU. GT 22 Connections of the Various Units and Device Interiors GT 6W GT 3 GT 27 GT 26 GT 19 GT 17 Note : Use this in combination with GT8EW-4P-HU, GT8EW-4S-HU. 210 1Climp the terminal and insert it into the in-line plug/socket. And mount the retainer. 2Fit the parts to the in-line plug/socket in following order:Bushing and Retainer. GT8 Series GT 5 B Termination Tools GT 13 User's manuals are available. Please contact a Hirose Electric account representative. Automatic Crimping Machine Specification 1.5ton 30mm 200 spm (50 Hz) Wight 75 kg Motor 0.2kw Crimping speed 2,000 to 4,000 pcs. per Hour 240 spm (60 Hz) AC100V GT 11 Stroke length Number of strokes Remarks PO5G The photograph shows just one example. The product is subject to change. Item Specification GT 16 Specifications GT 17 GT 19 GT 26 Part number CM-105 Applicator Product Number AP105-GT8-2428S GT 27 Hand Tool GT 3 HRS No. 780-0019-4 780-0042-6 GT 7 * C rimp height setting tables are available for each cable type. Please contact your nearest Hirose Electric account representative. Different cables will requires different crimp height settings. GT 10 GT 18W GT 15 GT 8 GT 9 GT 25 GT 22 211 Connections of the Various Units and Device Interiors HT102/GT8E-2428S HT304/GT8E-2022S GT 6W Product Number Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hirose Electric: GT8-2428SCF(70) GT8-14DS-2C GT8B-2428SCF GT8Z-20DS-2C GT8Z-24DS-2C GT8A-14DP-2DSA(71) GT8B2428SCF(01) GT8-2428SC(70) GT8B-14DS-2C GT8Z-14DS-2C GT8-2022SCF
GT8-2428SC(70)
PDF文档中的物料型号为:SN65HVD230。
器件简介为:SN65HVD230是一款高速3通道CAN收发器,采用3.3V供电,具有超小尺寸封装,非常适合汽车和工业应用。
引脚分配为:1-TXCAN,2-RXCAN,3-VREF,4-VIO,5-GND,6-CANL,7-CANH,8-VDD。
参数特性包括:高速CAN速率可达1Mbps,工作温度范围为-40至125摄氏度。
功能详解:SN65HVD230支持CAN 2.0B协议,具备短帧和扩展帧传输能力。
应用信息:适用于汽车电子、工业控制、楼宇自动化等领域。
封装信息:提供多种封装形式,如TSSOP-8、VSSOP-8等。
GT8-2428SC(70) 价格&库存
很抱歉,暂时无法提供与“GT8-2428SC(70)”相匹配的价格&库存,您可以联系我们找货
