CC83L-2426-F
CC83L-2426-F
    SAMTEC(申泰)
    CC83L-2426-F
CC83L-2426-F 数据手册
REVISION H CC83X-XXXX-X ALL DIMENSIONS ARE REFERENCE (SEE C-383-XXXX-X FOR CONTROLLING PRINT) DO NOT SCALE FROM THIS PRINT PLATING -F: 3µ" GOLD IN THE CONTACT AREA, MATTE TIN TAIL -L: 10µ" GOLD IN THE CONTACT AREA, MATTE TIN TAIL OPTION L: LOOSE R: FULL REELS .085 LEAD STYLE -2426: FOR 24, 26 AWG .086 R.020 SECTION 'C'-'C' SCALE 10 : 1 .055 .080 .160 .1148 .255 .340 'B' 'C' 'B' .373 .433 .780 'C' .058 .136 .150 .075 .051 .300 .0625±.0010 (TYP) NOTES: 1. REPRESENTS A CRITICAL DIMENSION. 2. PLATED C-383 PARTS TO BE PULLED, PLATING OPTION CONFIRMED, POSITIONED AS SHOWN ON SAMTEC REEL WITH VIEWPORTS,LABELED CC83R WITH APPROPRIATE PLATING CALLOUT AND LABEL PLACED AS SHOWN. 3. MAXIMUM No OF SPLICES PER REEL: 2 3. SPLICES ARE NOT TO BE CONNECTED. 4. NUMBER OF SPLICES TO BE MARKED ON EACH REEL. 5. REELED PARTS TO BE INTERLEAVED WITH PAPER BETWEEN EACH LAYER OF PARTS. 6. ALLOWABLE INTERLEAF SPLICES PER REEL: 3 7. SECURELY CONNECT INTERLEAF SPLICE. 8. OUTER WRAP SHALL RECEIVE HMS1015C-16MM PROTECTIVE REEL BAND. 9. DUE TO PLATING REQUIREMENTS CONTACT SAMPLES MAY BE REMOVED INTERMITTINGLY FROM THE CARRIER RESULTING IN SMALL GAPS BUT DOES NOT AFFECT FINAL COUNT. 10. QTY PER REEL: 7,000 +700/-0 PCS FIG 1 (CC83X-2426-X SHOWN) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: MATERIAL: * R.014 PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING PHOSPHOR BRONZE THICKNESS: .0080 F:\DWG\MISC\MKTG\CC83X-XXXX-X-MKT.SLDDRW SHEET SCALE: 6:1 SECTION 'B'-'B' SCALE 10 : 1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .100 SMSX CONTACT CC83X-XXXX-X BY: VICKY Z 09/15/2011 SHEET 1 OF 2 REVISION H "C" "B" "A" "E" MAX (TAB LENGTH) WIRE CRIMP "D" MAX (VESTIGE ALLOWANCE) INSULATION STRIP LENGTH CARRIER TAB SPECIFCATION REEL SPECIFICATIONS (PLATED PARTS TO BE POSITIONED ON HARD BOARD REELS AS SHOWN) (REELS TO HAVE VIEWPORTS) (7,000 PARTS PER REEL) LABEL UP 24.00 1.125±.062 10.00±.13 * 5.50 .500 UNWINDING DIRECTION PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\CC83X-XXXX-X-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .100 SMSX CONTACT CC83X-XXXX-X BY: VICKY Z 09/15/2011 SHEET 2 OF 2
CC83L-2426-F 价格&库存
很抱歉,暂时无法提供与“CC83L-2426-F”相匹配的价格&库存,您可以联系我们找货
CC83L-2426-F
    • 1+3.19184
    • 200+1.27365
    • 500+1.23099
    • 1000+1.21004
