GT 13
GT 5
Connections of the Various Units and Device Interiors
PO5G
GT 16
GT8 Series
GT 11
— High-Pressure Connectors —
GT 7
Features
GT 9
GT 8
GT 15 GT 18W GT 10
Crimp Terminals
U
se of an air-tight dimple construction at the contact portion serves to prevent oxidation of the contact
portion.
F Connector Housing
T
erminal number markings appear in a large size in consideration of insertion processing.
F
orm designed to prevent erroneous insertion.
M Connectors
D
esigned with escape holes for washing liquid to escape so that secondary soiling may be prevented when
the board has been washed.
T
he surrounding wall of the terminal has been constructed higher than the terminal so as to prevent terminal
bending.
The others
T
he F connector housing fits entirely inside of the M connector to prevent incomplete insertion and prevents
twisting and other problems. The F connector is guarded so that there is no slanting nor contact movement,
and the connector is resistant to vibration.
T
he color of the F connector housing and the M connector have been changed to prevent incomplete
insertion.
M Connectors (SMT Product)
I nstead of using screws for board fastening, a lead reflow type of reinforced fitting is used that permits
soldering at the time of reflow.
GT 25
GT 22
GT 6W
GT 3
GT 27
GT 26
GT 19
GT 17
200
Applications
Internal connections of mobile units and industrial equipments.
GT8 Series
F Connectors
1.5
1.7
GT 13
Terminals
GT 5
6.2
GT 16
PO5G
GT 11
Material
Phosphor bronze
Phosphor bronze
Phosphor bronze
Phosphor bronze
Finish
Tin plating
Tin plating
Tin plating
Tin plating
Packaging
10,000 pcs/reel
10,000 pcs/reel
10,000 pcs/reel
10,000 pcs/reel
Applicable housing
RoHS
GT8-*DS-2C, GT8A-*DS-2C, GT8Z-*DS-2C
YES
GT8E-*S-2C, GT8E-*DS-2C, GT8E-*S-HU, GT8E-*DS-HU
Note : GT8-2428SC(70) loose terminals for hand tools are also available. There are 100 pieces per package.
GT 26
A
GT 27
6.2
Housing (Without Flange)
8
GT 3
Housing (With Flange)
RoHS
YES
6.2
8.4
B
A
GT 10 GT 18W GT 15
Number of positions A dimension Specifications Packaging
14
15.8
1piece
1piece
24
25.8
1piece
1piece
Without lock
24
25.8
1piece
GT 7
HRS No.
Material
Color
758-0018-0
758-0003-3
758-0005-9
PBT
Dark Gray
758-0011-1
758-0012-4
3
GT 9
8
GT 8
Note : This product mates with GT8- or GT8A-*DP-2DSA(70).
14
15.8
24
25.8
B dimension
22
28
32
Packaging
1piece
1piece
1piece
RoHS
YES
GT 22
HRS No.
Material
Color
758-0009-0
758-0007-4
PBT
Dark Gray
758-0008-7
GT 25
Part Number
GT8Z-14DS-2C
GT8Z-20DS-2C
GT8Z-24DS-2C
201
Part Number
GT8-14DS-2C
GT8-20DS-2C
GT8-24DS-2C
GT8A-20DS-2C
GT8A-24DS-2C
Terminal No.
GT 6W
Lock
Lock
GT 19
HRS No.
758-0001-8-70
758-0026-9
758-0033-4
758-0055-7
GT 17
Part Number
GT8-2428SCF(70)
GT8-2022SCF
GT8E-2022SCF
GT8E-2428SCF
GT8E Series
F Connectors
Single low Housing
Part Number
GT8E-2S-2C
GT8E-8S-2C
Applicable
AWG #20-22
AWG #24-28
Applicable conductor
GT8E-2022SCF
GT8B-2428SCF
HRS No.
Material
Color
758-0030-6
PBT
Black
758-0029-7
Number of positions A dimension±0.15
2
7.1
8
16.6
Packaging
1piece
1piece
Note 1: Applicable terminal is GT8E-2022PCF.
Note 2: Use this in combination with GT8EW-4P-R, GT8EW-4P/S-BR, GT8EW-4P/S-BHS.
Note 3: Applicable housing is GT8E-W-4S-HU.
GT 15 GT 18W GT 10
GT 7
Single low Housing
GT 8
GT 9
GT 25
GT 22
Plug
GT8E *S-2C
GT 6W
GT 3
GT 27
GT 26
GT 19
GT 17
GT 11
PO5G
GT 16
GT 13
GT 5
GT8 Series
202
Plug
GT8E-8DS-2C
Applicable
AWG #20-22
AWG #24-28
Part Number
GT8E-8DS-2C
HRS No.
758-0027-1
GT8E-2022SCF
GT8B-2428SCF
Material
PBT
Color
Black
Note 1: Applicable terminal is GT8E-2022SCF, GT8B-2428SCF(70).
Note 2: Applicable housing is GT8E-*S-HU.
Number of positions
8
Packaging
1piece
RoHS
YES
RoHS
YES
GT8 Series
GT 5
Housing (3 to 10 pos./single row)
GT 13
GT 16
PO5G
GT 11
GT 17
Applicable Applicable conductor
AWG #20-22 GT8E-2022SCF
GT8E-*S-HU
AWG #24-28 GT8B-2428SCF
HRS No.
758-0061-0
758-0047-9
758-0062-2
758-0048-1
758-0063-5
758-0049-4
758-0050-3
Material
PBT
PBT
PBT
PBT
PBT
PBT
PBT
Color
Black
Black
Black
Black
Black
Black
Black
Note 1: Applicable terminal is GT8E-2022SCF, GT8B-2428SCF.
Note 2: This product mates with GT8E-*P-DS.
3
7.9 0.5
4
8.6 0.5
5
12 0.5
6
12.6 0.5
7
15.6 0.5
8
16.6 0.5
10
20.6 0.7
B dimension C dimension
7.9 0.5
4 0.15
8.6 0.5
6 0.15
7.1 0.5
8 0.15
7.1 0.5
10 0.15
7.1 0.5
12 0.15
7.1 0.5
14 0.15
7.1 0.5
18 0.15
12
16.6 0.5
16
21.85 0.7
24
28.6 0.7
B dimension
14 0.15
18 0.15
22 0.15
26 0.15
Packaging
1piece
1piece
1piece
1piece
1piece
1piece
1piece
RoHS
YES
GT 3
Part Number
GT8E-3S-HU
GT8E-4S-HU
GT8E-5S-HU
GT8E-6S-HU
GT8E-7S-HU
GT8E-8S-HU
GT8E-10S-HU
GT 27
GT 26
Plug
GT 19
GT 6W
Howsing (Double row)
GT 7
GT 10 GT 18W GT 15
GT 8
Plug
HRS No.
CL758-0051-6
CL758-0064-8
CL758-0052-9
CL758-0054-4
Material
PBT
PBT
PBT
PBT
Color
Black
Black
Black
Black
Note 2: This product mates with GT8E-*DP-DS.
Packaging
1piece
1piece
1piece
1piece
RoHS
YES
GT 22
Part Number
GT8E-12DS-HU
GT8E-16DS-HU
GT8E-20DS-HU
GT8E-24DS-HU
GT8E-2022SCF
GT8B-2428SCF
GT 25
Applicable
AWG #20-22
AWG #24-28
GT 9
GT8E-*DS-HU
203
M connector
Board type(Vertical Dip type)
BRecommended Board Mounting Pattern
GT 27
GT 26
GT 19
GT 17
GT 11
PO5G
GT 16
GT 13
GT 5
GT8 Series
GT 7
GT 15 GT 18W GT 10
GT 8
GT 9
GT 25
GT 22
GT 6W
GT 3
BFully Mated connector assemblies
204
Part Number
GT8E-4P-DSA
GT8E-7P-DSA
HRS No.
758-0065-0
758-0066-3
Number of positions
4
7
A dimension
11.98 0.2
18.98 0.2
B dimension
6 0.15
12 0.15
C dimension
14.4 0.3
21.4 0.3
D dimension E dimension
6 0.5
11.98 0.15
12 0.5
18.98 0.15
Packaging
1piece
1piece
GT8 Series
GT 5
Board type(S.M.T. 8pos)
GT 13
GT 16
PO5G
GT 11
GT 17
BRecommended Board
Mounting Pattern
Packaging
GT 19
400pcs/reel
GT 26
Color/Finish
Part Number
HRS No.
Material
PPS(Housing)
Black
GT8E-8DP-2H(70) 758-0028-4-70
Brass(Contact)
Tin plated
Brass(Reinforced fitting) Tin plated
Note 1: Applicable housing is GT8E-8DS-2C.
GT 27
GT 3
Board type(Small-size S.M.T.)
GT 6W
GT 7
GT 10 GT 18W GT 15
GT 8
Note 1: Applicable housing is GT8E-*S-HU.
Color/Finish
Black
Tin plated
Tin plated
Packaging RoHS
500pcs/reel
400pcs/reel YES
400pcs/reel
GT 22
Material
PBT(Housing)
Brass(Contact)
Brass(Metal fitting)
GT 25
GT 9
Number of positions A dimension B dimension C dimension D dimension E dimension F dimension
HRS No.
Part Number
GT8E-2P-2H(70) 758-0032-1-70
2
13 0.15
9.15 0.15
2
10.58
2
10.58
GT8E-3P-2H 758-0096-4
3
13.7 0.3
9.85 0.3
4
11.28
4
11.28
GT8E-4P-2H 758-0079-5
4
14.4 0.3
10.55 0.3
6
11.98
6
11.98
205
Board type(Small-size 8/2pos)
GT 17
GT 11
PO5G
GT 16
GT 13
GT 5
GT8 Series
GT 27
GT 26
GT 19
Finish
Black
Tin plated
Tin plated
Packaging
RoHS
500pcs/reel
YES
Note 1: Applicable housing is GT8E-8S-2C.
Board type(8/5pos)
GT 7
GT 8
GT 15 GT 18W GT 10
Material
PPS(Housing)
Brass(Contact)
GT 9
GT 25
GT 22
GT 6W
GT 3
Part Number
HRS No.
GT8E-8/2P-2H(70) 758-0031-9-70
206
Part Number
GT8E-8/5P-2H
HRS No.
758-0073-9
Material
PPS(Housing)
Brass(Contact)
Note 1: Applicable housing is GT8E-5S-HU, GT8E-8S-2C.
Finish
Black
Tin plated
Tin plated
Packaging
500pcs/reel
GT8 Series
GT 5
Board type(Single raw DIP type)
GT 13
GT 16
PO5G
BRecommended PCB
Mounting Pattern
GT 11
Number of
potions
2
3
4
5
6
7
8
10
A dimension B dimensions C dimension D dimension E dimension F dimension
9.15±0.5
2±0.5
10.58±0.5
2±0.5
10.58±0.5
13±0.5
13.7±0.5
9.85±0.5
4±0.5
11.28±0.5
4±0.5
11.28±0.5
14.4±0.5
10.55±0.5
6±0.5
11.98±0.5
6±0.5
11.98±0.5
17.8±0.5
13.95±0.5
8±0.5
15.38±0.5
8±0.5
15.38±0.5
18.4±0.5
14.55±0.5
10±0.5
15.98±0.5
10±0.5
15.98±0.5
21.4±0.5
17.55±0.5
12±0.5
18.98±0.5
12±0.5
18.98±0.5
22.4±0.5
18.55±0.5
14±0.5
19.98±0.5
14±0.5
19.98±0.5
26.4±0.5
22.55±0.5
18±0.5
23.98±0.5
18±0.5
23.98±0.5
Packaging
1piece
1piece
1piece
1piece
1piece
1piece
1piece
1piece
RoHS
YES
GT 27
HRS No.
758-0040-0
758-0057-2
758-0041-2
758-0058-5
758-0042-5
758-0059-8
758-0043-8
758-0044-0
Note1 : Applicable housing is GT8E-*S-HU
Note2 : GT8E-2P-DS mates with GT8E-2S-2C.
GT 3
Boad type(Double row DIP type)
GT 26
Part Number
GT8E-2P-DS
GT8E-3P-DS
GT8E-4P-DS
GT8E-5P-DS
GT8E-6P-DS
GT8E-7P-DS
GT8E-8P-DS
GT8E-10P-DS
GT 19
Finish
Black
Tin plated
Tin plated
GT 17
Material
PBT(Housing)
Brass(Contact)
GT 6W
GT 7
GT 10 GT 18W GT 15
GT 8
12
16
Number of
potions
18.55±0.3
14±0.15
19.98±0.2
14±0.05
19.98±0.05
22.4±0.3
27.25±0.3
23.6±0.3
18±0.15
25.03±0.2
18±0.05
25.08±0.05
30±0.3
26.35±0.3
22±0.15
27.78±0.2
22±0.05
27.78±0.05
34±0.3
30.35±0.3
26±0.15
31.78±0.2
26±0.05
15.38±0.05
Note : Applicable housing is GT8E-*DS-HU
Packaging
1 piece
1 piece
1 piece
1 piece
RoHS
YES
GT 22
HRS No.
758-0045-3
758-0060-7
758-0046-6
758-0053-1
GT 25
Part Number
GT8E-12DP-DS
GT8E-16DP-DS
GT8E-20DP-DS
GT8E-24DP-DS
Finish
Black
Tin plated
Tin plated
GT 9
Material
PBT(Housing)
Brass(Contact)
207
BRecommended PCB Mounting Pattern
In-Line Type
GT 13
GT 5
GT8 Series
GT8E-*P-HU
(23.2)
GT 17
GT 11
PO5G
GT 16
GT8E-*S-HU
13.8±0.15
GT 19
GT 26
GT 27
B
Part Number
GT8E-3P-HU
GT8E-4P-HU
GT8E-8P-HU
HRS No.
Material
Color
758-0084-5
758-0082-0
PBT
BLACK
758-0038-8
Note1 : Applicable terminal is GT8E-2022PCF, GT8E-2428PCF
Note2 : Mate with GT8E-*S-HU(8pos:GT8E-8S-2C)
GT 7
GT 15 GT 18W GT 10
GT 6W
GT 3
2±0.15
GT 8
GT 9
GT 25
GT 22
208
21.8±0.7
A
Plug
GT8EW-4P-HU
Part Number
GT8EW-4P-HU
Applicable
AWG #20-22
HRS No
7758-0059-1
GT8E-2022PCF
Number of positions
4
Packaging
1piece
GT8EW-4P/S-BHS.
3
10.55±0.5
4
10.55±0.5
8
18.55±0.7
B dimension
4
6
14
Packaging
1piece
1piece
1piece
RoHS
YES
GT8 Series
GT 5
In-line socket (water proof)
GT 13
GT 16
PO5G
GT 11
Part Number
GT8EW-4S-HU
HRS No
758-0068-9
GT8-2022SCF
Number of positions
4
Packaging
1piece
GT 27
Retainer (Only for GT8EW-4P-HU)
GT 26
Note 1: Applicable terminal is GT8E-2022SCF.
GT8EW-4P/S-BHS.
Note 3: Applicable housing is GT8E-W-4P-HU.
GT 19
Applicable
AWG #20-22
GT 17
Plug
GT8EW-4S-HU
GT 3
GT 6W
Packaging
1piece
Retainer (Only for GT8EW-4S-HU)
GT 10 GT 18W GT 15
Note : Use this in combination with GT8EW-4P-HU.
GT 7
HRS No
758-0077-0
GT 8
GT 9
Packaging
1piece
Note : Use this in combination with GT8EW-4S-HU.
GT 22
HRS No
758-0076-7
GT 25
Part Number
GT8EW-4S-R
209
Part Number
GT8EW-4P-R
Retainer (Used with GT8EW-4P-HU, GT8EW-4S-HU)
GT 11
PO5G
GT 16
GT 13
GT 5
GT8 Series
Part Number
GT8EW-4P/S-BR
HRS No
758-0070-0
Packaging
1piece
Bushing (Used with GT8EW-4P-HU, GT8EW-4S-HU)
Part Number
GT8EW-4P/S-BHS
HRS No
758-0071-3
Packaging
1piece
B In line waterproof connector use hand book
GT 25
GT 9
GT 8
GT 15 GT 18W GT 10
GT 7
Note : Use this in combination with GT8EW-4P-HU, GT8EW-4S-HU.
GT 22
GT 6W
GT 3
GT 27
GT 26
GT 19
GT 17
210
1Climp the terminal and insert it into the in-line plug/socket. And mount the retainer.
2Fit the parts to the in-line plug/socket in following order:Bushing and Retainer.
GT8 Series
GT 5
B Termination Tools
GT 13
User's manuals are available. Please contact a Hirose Electric account representative.
Automatic Crimping Machine
Specification
1.5ton
30mm
200 spm (50 Hz)
Wight
75 kg
Motor
0.2kw
Crimping speed
2,000 to 4,000 pcs. per Hour
240 spm (60 Hz)
AC100V
GT 11
Stroke length
Number of strokes
Remarks
PO5G
The photograph shows
just one example.
The product is subject to
change.
Item
Specification
GT 16
Specifications
GT 17
GT 19
GT 26
Part number CM-105
Applicator Product Number
AP105-GT8-2428S
GT 27
Hand Tool
GT 3
HRS No.
780-0019-4
780-0042-6
GT 7
* C rimp height setting tables are available for each cable type. Please contact your nearest Hirose Electric account
representative. Different cables will requires different crimp height settings.
GT 10 GT 18W GT 15
GT 8
GT 9
GT 25
GT 22
211
HT102/GT8E-2428S
HT304/GT8E-2022S
GT 6W
Product Number
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Hirose Electric:
GT8-2428SCF(70) GT8-14DS-2C GT8B-2428SCF GT8Z-20DS-2C GT8Z-24DS-2C GT8A-14DP-2DSA(71) GT8B2428SCF(01) GT8-2428SC(70) GT8B-14DS-2C GT8Z-14DS-2C GT8-2022SCF
很抱歉,暂时无法提供与“GT8B-2428SCF”相匹配的价格&库存,您可以联系我们找货
