DF60-1012PCFA
DF60-1012PCFA
    HRS(广濑)
    CONN PIN CRIMP 10-12AWG
DF60-1012PCFA 数据手册
65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply DF60 Series (UL, C-UL, TÜV certified product) Unique locking mechanism is contained inside the header Socket and header design avoids short-circuit between adjacent contacts. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Guide keys prevent incorrect insertion Molded pins give a temporary hold and assure proper orientation of the connector. ■Features ● Lock structure 1. High current capacity Capable of going to a max. of 65A when using 8 AWG with the single position connector. (Please refer to the chart for the rated current in other pin counts.) Fig.1 [A-A] Crimp contact A A Lock parts of the plug and header start to engage. 2. Secure lock mechanism ensures complete mating A secure lock mechanism with a clear tactile and audible click prevents insufficient mating. (Fig.2) No contact yet. 3. Highly reliable 5-point contact structure Three independent contact springs provide a secure contact with high contact reliability using 5-point of contact. (Fig.3) Header contact Fig.2 4. Molded lance design The lance is actually part of the housing instead of being part of the terminal. This prevents tangled wires during assembly. 5. Mis-insertion prevention for headers The addition of a molded pin on the header allows temporar y mounting retention and prevents reverse mounting on the PCB. (Fig.1). (Right angle pin header has a metal fitting for this purpose) 6. Prevention of solder cracks Three independent spring contacts provide a secure contact and a high contact reliability with 5-points of contact. Glass-reinforced resin is used on pin header to prevent solder cracks due to thermal contraction. Fig.3 7. Design Prevents short-circuits between contacts The wall structure between contacts isolates the contacts and prevents short circuits from occuring. (Fig.1) 8. Compliant to UL, C-UL and TÜV specifications 9. Glow Wire compliance(Compliant with IEC 60695-2-11) 10. Finger-safe (Electric shock prevention) type available In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2022.7 1 DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) ■Product Specifications Ratings 8 AWG 10 AWG 12 AWG 1 50A 40A 31A 45A 35A 28A 42A 33A 27A 2 3 4 5 6 Voltage Rating Current Rating See below table Voltage Rating AC/DC 600V C-UL See upper table (Δt=30ç) AC/DC 600V TÜV See upper table AC/DC 600V UL Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. AC/DC 1,000V Current rating of UL Standards (Ambient temperature : 25ç) (Note 1) Item 1.Insulation resistance 2. Withstand voltage 3.Contact resistance 4.Vibration Resistance 5.Shock Resistance 6.Moistureresistance 7.Temperature cycles No. of Contacts 1 2 3 4 10 AWG 65A 55A 12 AWG 45A 40A 50A 55A Storage Temperature Range -10~60ç (Note 3) Storage Humidity Range 40~70% UL/TÜV file No. and certification No. UL : E52653 C-UL : E52653 TÜV : R50244085 R5040864 (DF60F) 8 AWG (2 contacts) Derating Curve Basic Curve Derating Curve 120 100 8 AWG 5 6 Operating Temperature -55~105ç (Note 2) Operating Humidity Range 20~80% Current (A) Current Rating (Note 1) No. of Contacts 80 60 40 20 0 45A 35A 20 40 60 80 100 120 140 Ambient Temperature (℃) Note : The derating curve is derived from the basic curve multiplied by the derating factor of 0.8. Specifications Conditions No less than 1,000Mø Measured at DC=1,000V No flashover or breakdown AC 3,000V applied for 1 minute. No more than 2mø Measured at 1A and not greater than 6V 2 No electrical discontinuity of 1μs or greater No electrical discontinuity of 1μs or greater Contact resistance : no more than 2mø ; insulation resistance : no less than 1,000Mø Contact resistance : no more than 2mø ; insulation resistance : no less than 1,000Mø Frequency 10 - 500Hz, accelerated velocity 98 m/s , 2 hours for each of the three axis directions 2 Accelerated velocity : 490m/s , for11 ms, half-sine wave form in 3 directions, 3 times for each of the three directions Temperature : 40±2ç; humidity : 90 to 95%, left for 96 hours -55ç : 30 minutes → 85ç : 30 minutes 25 cycles 8.Durability Contact resistance No more than 2mø 30 mating/unmating cycles 9. Solder heat resistance There should be no melting of the resin part which will influence the performance. Flow : 260ç, 10sec Hand soldering : temperature of soldering iron at 350ç±10ç for 5 seconds Note 1 : This is the maximum current rating while all pins are powered or used as all power lines. If you split the current over multiple lines, please factor in your own safety margin. Note 2 : Includes the temperature rise of power lines. Note 3 : The storage condition refers to long-term storage of the product on the shelf before assembly. Please use the operating temperature for temporary storage such as pre-assembly and during shipping. ■Materials / Finish Component Header 2 Part Material Finish UL Specification Insulator PBT (glass-reinforced) Black UL94V-0 Contact High conductivity copper alloy Gold plating − Metal fitting Brass Tin-plating Crimp socket In-line plug Insulator Insulator PBT (glass-reinforced) PBT (glass-reinforced) Black Black − UL94V-0 UL94V-0 Crimp contact Contact High conductivity copper alloy Gold plating − DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Header Connector DF 60 F R − * P − 10.16 DSA ❶ ❷ ❸ ❹ ❺ ❻ ❽ ❶ Series Name : DF ❺ Number of contacts : 1, 2, 3, 4, 5, 6 ❷ Series No. : 60 ❻ Connector type P : Pin header ❸ Form type ❼ Pitch : 10.16mm Blank : Standard F : Finger-safe ❽ Type of housing DSA : Straight pin header DS : Right angle pin header ❹ Guide key type Blank : Standard R : Another key shape Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❼ ●Socket Connector DF 60 F R − * S − 10.16 C ❶ ❷ ❸ ❶ Series Name : DF ❷ Series No. : 60 ❸ Form type A F ❹ ❺ ❻ ❼ ❽ ❺ Number of contacts : 1, 2, 3, 4, 5, 6 ❻ Connector type S : Socket ❼ Pitch : 10.16mm : Standard : Finger-safe ❽ Type of housing C : Crimp socket ❹ Guide key type Blank : Standard R : Another key shape ●In-line plug Connector DF 60 F R − * EP − 10.16 C ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❶ Series Name : DF ❺ Number of contacts : 1, 2, 3, 4, 5 ❷ Series No. : 60 ❻ Connector type EP : In-line plug ❸ Form type Blank : Standard A : No flange F : Finger-safe ❼ Pitch : 10.16mm ❹ Guide key type Blank : Standard R : Another key shape ❽ Type of housing C : Crimp socket ●Crimp Contact DF 60 A − ❶ ❶ Type of connection Blank : Standard A : Sequential ❷ Applicable wire size 8 : 8 AWG 1012 : 10 to 12 AWG 8 SCFA ❷ ❸ ❸ Packaging styles SCFA : Socket contact / reel SCA : Socket contact / loose PCFA : In-line plug contact / reel PCA : In-line plug contact / loose 3 DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) ■Diagram of Connector Mating Combinations ●Standard Type Crimp socket Socket contact Straight pin header DF60A(R)-*S-10.16C (Note) DF60-*SC(F)A DF60(R)-*P-10.16DSA Note : R type (Another key shape) socket mates with R type plug / pin header. Right angle pin header Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF60(R)-*P-10.16DS In-line plug In-line plug contact DF60(A)(R)-*EP-10.16C DF60(A)-*PC(F)A ●Finger-safe Type Crimp socket DF60F(R)-*S-10.16C (Note) Socket contact Straight pin header DF60-*SC(F)A DF60F(R)-*P-10.16DSA Note : R type (Another key shape) socket mates with R type plug / pin header. 4 In-line plug In-line plug contact DF60F(R)-*EP-10.16C DF60(A)-*PC(F)A DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) ■Straight pin header 3 pos. 5 pos. PCB layout 2±0.05 D±0.05 4- R1 E±0.05 ±0 .05 5 5.8±0.05 0.0 .8± Ø1 Connector outline 2.54±0.05 P=10.16±0.05 A±0.05 Headers with 5 to 6 pos. B±0.4 12.2±0.4 B±0.4 A±0.3 A Cavity.No 2.95±0.3 15.7±0.4 2.95±0.3 P=10.16±0.2 1.45±0.2 1.45±0.2 12.2±0.4 Headers with 1 to 4 pos. 15.7±0.4 A±0.3 P=10.16±0.2 A Cavity.No Contact No. 3 2 3 4 2 1±0.2 t=1±0.1 5.8±0.3 2.54±0.3 3.8±0.2 5 1 Ø2±0.2 1±0.2 21.5±0.3 23.1±0.4 3.8±0.2 23.1±0.4 Contact No. 21.5±0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Recommended thickness of PCB: t=1.6±0.1mm) 1 Ø2±0.2 t=1±0.1 5.8±0.3 2.54±0.3 C±0.3 C±0.3 gold plating, tray packaging Unit : mm Standard Type Part No. DF60-1P-10.16DSA(27) DF60-2P-10.16DSA(27) DF60-3P-10.16DSA(27) DF60-4P-10.16DSA(27) DF60-5P-10.16DSA(27) DF60-6P-10.16DSA(27) HRS No. No. of Contacts 680-3004-5 27 1 680-3005-8 27 2 680-3001-7 27 3 680-3006-0 27 4 680-3007-3 27 5 680-3008-6 27 6 A —— 10.16 20.32 30.48 40.64 50.8 B 15.2 22.36 32.52 42.68 52.84 63 C 9.55 19.71 29.87 40.03 50.19 60.35 D 12.2 22.36 32.52 42.68 52.84 63 E Quantity per package Guide key 7.78 160 17.94 96 28.1 64 Standard 38.26 48 48.42 32 58.58 Color HRS No. No. of Contacts A 680-3005-8 45 2 10.16 680-3001-7 45 3 20.32 B 22.36 32.52 C 19.71 29.87 D 22.36 32.52 E Quantity per package Guide key 17.94 96 Standard 28.1 64 Color HRS No. No. of Contacts A 680-3038-7 27 3 20.32 B 32.52 C 29.87 D 32.52 E 28.1 Color Gray Black Standard Type [Color : Red] Part No. DF60-2P-10.16DSA(45) DF60-3P-10.16DSA(45) Red R Type Part No. DF60R-3P-10.16DSA(27) Quantity per package Guide key Another key shape 64 Note : Please place orders in full lot quantities. 5 DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) ■Right angle pin header 3 pos. 5 pos. PCB Layout 25±0.3 (2) 17.2±0.05 6-Ø 1.8 2.54±0.05 P=10.16±0.05 .05 ±0 A±0.05 Headers with 1 to 4 pos. Headers with 5 to 6 pos. B±0.4 B±0.4 5 4 2 3 17.2±0.4 1 3.6±0.5 t=0.47±0.1 t=0.47±0.1 t=1±0.1 2 17.35±0.3 A Cavity.No 17.2±0.4 25±0.3 Cavity.No 3 3.6±0.5 25±0.3 17.35±0.3 A t=1±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Recommended thickness of PCB: t=1.6±0.1mm) B±0.4 2Ø3 Connector outline C±0.05 ±0 .05 1 Contact No. 3.8 +0.8 -0.3 3.8 1±0.2 2.54±0.3 P=10.16±0.2 1±0.2 2.54±0.3 P=10.16±0.2 A±0.3 C±0.3 Standard Type Part No. DF60-1P-10.16DS(27) DF60-2P-10.16DS(27) DF60-3P-10.16DS(27) DF60-4P-10.16DS(27) DF60-5P-10.16DS(27) DF60-6P-10.16DS(27) gold plating, tray packaging A±0.3 C±0.3 No. of Contacts HRS No. 680-3015-1 27 1 680-3016-4 27 2 680-3017-7 27 3 680-3018-0 27 4 680-3019-2 27 5 680-3020-1 27 6 A —— 10.16 20.32 30.48 40.64 50.8 B 15.2 22.36 32.52 42.68 52.84 63 C 8.35 15.51 25.67 35.83 45.99 56.15 Quantity per package 120 72 48 36 Guide key HRS No. No. of Contacts 680-3016-4 45 2 A 10.16 B 22.36 C 15.51 Quantity per package 72 HRS No. No. of Contacts 680-3043-7 27 2 680-3044-0 27 3 A 10.16 20.32 B 22.36 32.52 C 15.51 25.67 Quantity per package Guide key 72 Another key shape 48 Unit:mm Color Standard Black Guide key Standard Color Red 24 Standard Type [Color : Red] Part No. DF60-2P-10.16DS(45) R Type Part No. DF60R-2P-10.16DS(27) DF60R-3P-10.16DS(27) Note : Please place orders in full lot quantities. 6 +0.8 -0.3 Color Gray DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) ■ In-line plug  Standard Type No Flange Type 3 pos. 4 pos. The torque value for attaching screws is 49N Panel cutout C±0.2 13.5±0.3 .1 ±0 6 3. Ø .5M 8.45±0.3 13.4±0.3 R0 17.9±0.3 AX In-line plugs with 1 to 5 pos. Inline plug with 4 pos. D±0.3 C±0.2 B±0.3 A±0.3 42.68±0.2 30.48±0.3 P=10.16±0.2 P=10.16±0. P=10.16±0.2 A A 15.9±0.4 Cavity.No 12.4±0.3 38 6±0 4 6.8±0.3 11.2±0.3 Contact No. 3 2 38.6±0.4 15.9±0.4 12.4±0.3 Cavity.No 38.6±0.4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (B+1)±0.3 Contact No. 4 1 3 2 1 41.08±0.3 1 package = 100 pcs E±0.3 Standard Type Part No. HRS No. No. of Contacts A B C DF60-1EP-10.16C 680-3050-2 1 —— 15.2 23.7 DF60-2EP-10.16C 680-3025-5 2 —— 22.36 30.86 DF60-3EP-10.16C 680-3026-8 3 20.32 32.52 41.02 DF60-4EP-10.16C 680-3027-0 4 30.48 42.68 51.18 DF60-5EP-10.16C 680-3028-3 5 40.64 52.84 61.34 Standard Type [Color : Red] Part No. HRS No. No. of Contacts A B C DF60-1EP-10.16C(15) 680-3050-2 15 1 —— 15.2 23.7 DF60-2EP-10.16C(15) 680-3025-5 15 2 —— 22.36 30.86 DF60-3EP-10.16C(15) 680-3026-8 15 3 20.32 32.52 41.02 R Type Part No. HRS No. No. of Contacts A B C DF60R-2EP-10.16C 680-3053-0 2 —— 22.36 30.86 DF60R-3EP-10.16C 680-3054-0 3 20.32 32.52 41.02 No Flange Type Part No. HRS No. No. of Contacts Guide key Color DF60A-4EP-10.16C 680-3069-0 4 Standard Black Note : Bag packaging (100pcs/pack). Order by number of packs. D 32.2 39.36 49.52 59.68 69.84 E 10.6 20.76 30.92 41.08 51.24 Guide key Unit : mm Color Standard Black D 32.2 39.36 49.52 E 10.6 20.76 30.92 Guide key Color Standard Red D 39.36 49.52 E 20.76 30.92 Guide key Color Another key shape Gray 7 DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) ■ Crimp socket Crimp socket with 1 to 4 pos. Crimp socket with 5 to 6 pos. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A±0.3 A±0.3 P=10.16±0.2 P=10.16±0.2 1 1 Cavity No. Cavity No. B±0.4 B±0.4 18±0.4 24.4±0.3 24.4±0.3 18±0.4 3 2 5 1 4 3 2 1 Contact No. Contact No. 1 package = 100 pcs Standard Type Part No. DF60A-1S-10.16C DF60A-2S-10.16C DF60A-3S-10.16C DF60A-4S-10.16C DF60A-5S-10.16C DF60A-6S-10.16C HRS No. 680-3058-0 680-3059-0 680-3060-0 680-3061-0 680-3076-0 680-3077-0 Standard Type [Color : Red] Part No. HRS No. DF60A-1S-10.16C(15) 680-3058-0 15 DF60A-2S-10.16C(15) 680-3059-0 15 DF60A-3S-10.16C(15) 680-3060-0 15 No. of Contacts 1 2 3 4 5 6 A —— 10.16 20.32 30.48 40.64 50.8 B 15.8 22.36 32.52 42.68 52.84 63.0 Guide key Unit : mm Color Standard Black No. of Contacts 1 2 3 A —— 10.16 20.32 B 15.8 22.36 32.52 Guide key Color Standard Red No. of Contacts 2 3 A 10.16 20.32 B 22.36 32.52 Guide key Color Another key shape Gray R Type Part No. DF60AR-2S-10.16C DF60AR-3S-10.16C HRS No. 680-3063-0 680-3064-0 Note : Bag packaging (100pcs/pack). Order by number of packs. 8 DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) ■ Straight pin header (Finger-safe Type) 4.4±0.4 32.52±0.35 20.32±0.2 P=10.16±0.2 12.2±0.3 15.7±0.3 Another Key Shape A Cavity.No 23.42±0.35 Contact No. 3 2 1 3.8±0.4 1.6±0.3 21.5±0.3 1±0.2 t=1±0.1 2.54±0.3 30.31±0.2 Ø1 .7 ±0 (Recommended thickness of PCB : t=1.6±0.1mm) 4- 5.8±0.05 2±0.05 .2 PCB layout 5.8±0.4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Standard Key Shape 32.52±0.05 R 1± 28.1±0.05 0. 05 5 0.0 .8± 1 Ø 2.54±0.05 Connector outline 10.16±0.05 20.32±0.05 Part No. DF60F-3P-10.16DSA(50) DF60FR-3P-10.16DSA(50) HRS No. 680-4001-0 50 680-4004-0 50 No. of Contacts 3 3 Quantity per package Guide key 64 Standard Another key shape 64 Color Black Red Note : Please place orders in full lot quantities. 9 DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) ■ In-line plug (Finger-safe Type) Standard Key Shape Another Key Shape Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 49.72±0.3 41.02±0.3 32.52±0.3 20.32±0.3 P=10.16±0.2 A Cavity No. 23.42±0.3 6.8±0.3 39.6±0.4 11.2±0.3 16.65±0.4 15.7±0.3 12.2±0.3 Contact No. 3 2 1 32.52±0.3 Pabel Cutout AX .5M X R0 5MA . R0 X MA 5 . R0 0.1 .4± φ3 17.7±0.3 13.2±0.3 7.875±0.3 41.02±0.2 33.52±0.3 25.42±0.3 R 0. 5M AX Part No. DF60F-3EP-10.16C DF60FR-3EP-10.16C HRS No. 680-4003-0 680-4006-0 No. of Contacts 3 3 Quantity per package 100 100 Guide key Standard Another key shape Note 1 : Bag packaging (100pcs/pack). Order by number of packs. Note 2 : For better finger-safe function, heat shrink tube shall be installed to Crimp contact of in-line plug. (Recommended heat shrink tube : Sumitomo Electric Industries, Ltd. F2(Z)8∞0.25) For the details, please see DF60 Cable Assembly procedure. (ETAD-H0653) 10 Color Black Red DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) ■ Crimp socket (Finger-safe Type) Another Key Shape 7.1±0.6 11.5±0.4 20.32±0.3 P=10.16±0.2 A Cavity No. 32.52±0.4 Contact No. 2 1 26.1±0.3 3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Standard Key Shape Part No. DF60F-3S-10.16C DF60FR-3S-10.16C HRS No. 680-4002-0 680-4005-0 No. of Contacts 3 3 Quantity per package 100 100 Guide key Standard Another Key shape Color Black Red Note 1 : Bag packaging (100pcs/pack). Order by number of packs. Note 2 : For better finger-safe function, heat shrink tube shall be installed to Crimp contact of socket. (Recommended heat shrink tube : Sumitomo Electric Industries, Ltd. F2(Z)8∞0.25) For the details, please see DF60 Cable Assembly procedure. (ETAD-H0653) 11 DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) ■Socket crimp contact 4.05±0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ø2 t=0.5±0.1 HRS No. Jacket Diameter 4.9 to 7.8 7.54 UL 8 8 2.1±0.3 2±0.3 ±0 .3 14.7±0.3 20±0.4 25.5±0.4 4±0.3 27±0.3 Part No. Applicable wire gauge mark 5±0.3 7.7±0.3 DF60-8SCFA DF60-8SCA 680-3003-2 680-3021-4 UL1283 DF60-1012SCFA 680-3014-9 UL1015 4 to 5.2 DF60-1012SCA 680-3022-7 UL1015 4.69 4.04 Strip length : 6.5 - 7.5mm Applicable wires Wire size Core structure Package style Reel 8 AWG 7/24/0.26 Loose 10 AWG 104/0.26 Reel 12 AWG 65/0.26 10 AWG 104/0.26 Loose 12 AWG 65/0.26 Quantity 700 100 900 100 Note 1 : The applicable wires are tin-plated and annealed. Note 2 : Please contact our Sales Department when using wires other than those listed. ■Crimp contact for in-line plugs 14.7±0.3 .3 ±0 Ø2 27±0.3 Part No. HRS No. A B DF60A-8PCFA (Note 3) DF60-8PCFA(07) DF60-8PCA(07) 680-3057-0 680-3023-0 07 680-3048-0 07 34.2 28.7 32.7 27.2 DF60-1012PCFA(07) DF60-1012PCA(07) 680-3024-2 07 680-3049-3 07 32.7 32.7 27.2 27.2 2.1±0.3 8 5±0.3 2±0.3 Applicable wire gauge mark B±0.4 4±0.3 A±0.4 7.4±0.3 6.2±0.3 t=0.5±0.1 UL UL1283 Jacket Diameter 4.9 to 7.8 Strip length : 6.5 - 7.5mm Applicable wires Wire size Core structure Package style Quantity 8 AWG 7/24/0.26 10 AWG 12 AWG 10 AWG 12 AWG 104/0.26 65/0.26 104/0.26 65/0.26 7.54 UL1015 4 to 5.2 UL1015 4.69 4.04 Reel 700 Loose 100 Reel 900 Loose 100 Note 1 : The applicable wires are tin-plated and annealed. Note 2 : Please contact our Sales Department when using wires other than those listed. Note 3 : Not conforming to finger-safe type. BApplicable crimping tool Item Applicator Part No. HRS No. AP105-DF60-8 901-4623-5 QHS895700H-UP – AP105-DF60-1012 901-4624-8 QHS888000K-UP – HT306/DF60-8 Hand tool HT306/DF60-1012 Applrcable contact Remarks DF60-8SCFA(##)/PCFA(##) DF60A-8PCFA (Note 4) manufaftured by Japan Automatic Machine Co., Ltd. DF60-1012SCFA(##)/ PCFA(##) (Note 4) manufaftured by Japan Automatic Machine Co., Ltd. DF60-8SCA/PCA 550-0301-4 *Exclusive for UL1283 8AWG DF60-1012SCA/PCA 550-0307-0 *Exclusive for UL1015 10 to 12AWG Note 1 : The Hirose Press Unit CM-105C (HRS No.901-0001-0) has a capacity of 1.5 tons and cannot be used. Please use a press unit which can mount offical Hirose's applicators and has a capacity of 3 tons or more. Note 2 : Please contact our Sales Department when you are using crimp tools made by other manufacturers. Note 3 : Please do the crimping operations according to the "Crimping work standards" and "Crimping condition table". Note 4 : Please contact Japan Automatic Machine Co., Ltd. (hereinafter J.A.M.) through their website regarding crimping issues when using applicators manufactured by J.A.M. URL http://www.jam-net.co.jp 12 DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) BMated dimensions ● Wire-to-Board Connection using the straight pin header DF60F (Finger-safe) (18.6) &- DF60F-3S-10.16C 9;+%6"H"&%#&+8 (31.5)  (% DF60F-3P-10.16DSA(50) ● Wire-to-Board Connection using the right angle pin header. (&-#-) (((#*) 9;+%6"H"&%#&+8 9;+%"E"&%#&+9H', ● In-line or Wire-to-Wire Connection DF60F (Finger-safe) (49.6) (),#&) (18.6) DF60F-3EP-10.16C (&-) DF60F-3S-10.16C 9;+%6"H"&%#&+8 9;+%":E"&%#&+8 BUsage example of sequential contacts 3 4 2 1 DF60-****PCFA(##) Standard contact as a connect-sensing pin. 3 2 1 DF60A-8PCFA Sequential contact as a ground pin. 4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 9;+%"E"&%#&+9H6', DF60-****PCFA(##) DF60A-8PCFA 13 DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) BRemoving Contacts ●Contact extraction tool: precision screwdriver (flathead screwdriver with 1.4mm in width across flats) ●For Crimp contacts: DF60-8SC(F)A, DF60-1012SC(F)A, DF60-8PC(F)A, DF60-1012PC(F)A ●Procedure  Sectioned drawing of the housing BdaYZYaVcXZ Precision screwdriver 1. After unmating the parts, position the screwdriver to raise the lance as shown in the illustration. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Before attempting to remove any contacts, make sure that the power is switched off and the system is de-energized. 2. T h e l a n c e n e e d s t o b e raised sufficiently to allow the terminated wire to slip past it. The lance needs to be held up while at the same time pulling on the wire. Due to any previous repairs, the strength of the lance could have been compromised. Hirose recommends the use of a new crimp housing to assure proper performance. Caution Please be very careful when removing the contact work so that you don’t become injured by the protruding part of the crimp contact. BRated values Please avoid using the device above the rated values. Also, do not insert or pull out energized or “ live” wires. BOperating environment Please contact us if you are designing this connector into environmental conditions where high and low temperatures are repeated. 14 DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) BPrecautionary notes 1.Recommended soldering conditions Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. Cleaning Conditions 3. Important notes 4. Handling instructions 5. Right angle pin header  Precautions for use ■ Soldering profile when using an automatic soldering device Soldering temperature: 260℃ ; Soldering time: no more than 10 seconds ■ Hand soldering conditions Temperature of soldering iron: 350±10℃ , soldering time: no more than 3 seconds Please refer to the "Wire-to-Board Connector Guide". Cleaning with IPA is allowed. (Other cleaning agents are not recommended due to the fact that it may change the push/pull feeling. Please contact us when you use other cleaning agents. ) 1. Caution is required for mating and un-mating the connector without it being mounting on a PCB. Doing so can damage or deform the contacts. 2. During hand soldering, do not apply excess amounts flux which can migrate on to the connector. 3. This product may have a slight differences in color depending on the production lot. This difference does not have any influence on the performance. 4. The connector could be damaged if it is pulled out forcibly. When it is hard to pull out, push it in slightly first and then depress the lock and un- mate. Please refer to “DF60 Series mating and unmating Procedure Document (ETAD-H0654-00)” for points in handling regarding mating operations. 5. When thick, short sections of wire are used, the connector could be deformed due to the force of the wires’ position. Route cables in such a way that they do not twist when being installed. 6. Make sure to turn off the power when mating or un-mating the connector. 7. Please do not touch any area around the contact part with your hand when the power is on; it could be very dangerous. 8. Please refer to “Harness procedure manual (ETAD-H0653-00)” for points in harness operations. Please refer to the "Wire-to-Board Connector Guide”. Since the lead mounting part has some exposed parts, please insure sufficient clearance when mounting other parts near this connector. Lead part 6. In-line connector Panel fixing operation ① Insert a M3 nut from the lateral direction. ②Push the nut in the direction of the arrow. ③Nut insertion is then complete. ④Panel mounting is completed by installing a connector on the panel cutout hole and tightening wit a M3 screw. Torque value is 49N·cm max. 15 DF60 Series●65A 10.16mm pitch Wire-to-Board Connectors for Internal Power Supply(UL, C-UL, TÜV certified product) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO: 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ 16 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2022. Contents are subject to change without notice for the purpose of improvements.
DF60-1012PCFA 价格&库存
很抱歉,暂时无法提供与“DF60-1012PCFA”相匹配的价格&库存,您可以联系我们找货
