SMM-003T-P0.5
SMM-003T-P0.5
    JST
    特性:紧凑型设计。外壳到端子的锁定。可使用压接式和绝缘位移插座。全屏蔽插头在配对时可抵抗“晃动”
SMM-003T-P0.5 数据手册
ZM CONNECTOR 1.5mm pitch/Crimp style Wire-to-wire connectors Matable with ZH and ZR receptacles Specifications ––––––––––––––––––– 1 T 3 2 JS • Current rating: 0.7A AC, DC max. (AWG #28) • Voltage rating: 50V AC, DC max. (See Note below.) • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20m Ω max. After environmental testing/ 30m Ω max. • Insulation resistance: 500M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: AWG #30 to #28 Note: Contacts are exposed at the housing lances. Care should be taken so that these parts do not touch the metal section of the chasis. 3 ZM connector ST Crimp style ZH connector T JS Insulation displacement ZR connector 1.5mm pitch connectors allow higher densities. * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. • Compact design • Housing-to-terminal locks • Both crimp style and insulation displacement receptacles can be used • Fully shrouded header resists "rocking" during mating Standards––––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 ZM/ZH connector ZM/ZR connector (9.2) 3.6 3.6 (9.1) Plug / ZM connector 3.6 B Housing 8.1 4.1 1.05 Contact 7 2.8 2.2 1 2 1 1.5 A Applicable wire Model No. mm SMM-003T-P0.5 Insulation O.D. (mm) AWG # 2 0.05∼0.08 30∼28 0.7∼0.9 Q´ty / reel 16,000 Material and Finish 2.85 1.5 Dimensions (mm) A B Q´ty / bag ZMR-02 1.5 5.5 2,000 ZMR-03 3.0 7.0 2,000 9 ZMR-09 12.0 16.0 1,000 13 ZMR-13 18.0 22.0 1,000 Circuits Model No. 2 3 Phosphor bronze, tin-plated (reflow treatment) Material RoHS compliance Glass-filled PA 66, UL94V-0 Contact Crimping machine Crimp applicator SMM-003T-P0.5 AP-K2N Note: *Strip-crimp applicator 1 Applicator Dies RoHS compliance Crimp applicator with dies MKS-L MK/SMM-003-05 APLMK SMM003-05 *MKS-SC SC/SMM-003-05 APLSC SMM003-05 0.3 φ0.5 3 ZM CONNECTOR Receptacle / ZH connector (Crimp style) Contact Housing B 1.5 3.4 A 0.3 1.5 4 2.2 1.4 1.1 2 1 0.3 0.3 1.5 4.2 3 1 0.5 Dimensions (mm) mm2 AWG # Insulation (mm) Q´ty / reel 0.032∼0.08 32∼28 0.5∼0.9 16,000 Model No. SZH-003T-P0.5 Material and Finish B Q´ty / bag ZHR-2 1.5 4.5 1,000 ZHR-3 3.0 6.0 1,000 ZHR-9 12.0 15.0 1,000 ZHR-13 18.0 21.0 1,000 Model No. 2 3 9 13 Dimensions (mm) A Circuits Phosphor bronze, tin-plated (reflow treatment) Material RoHS compliance PA 66, UL94V-0 Crimping machine Crimp applicator Contact SZH-003T-P0.5 AP-K2N Applicator RoHS compliance Dies Crimp applicator with dies MKS-L MK/SZH-003-05 APLMK SZH003-05 *MKS-SC SC/SZH-003-05 APLSC SZH003-05 Note: *Strip-crimp applicator Receptacle / ZR connector (IDC) Receptacle Circuits A 1.5 4.4 2.7 3.1 1.5 Model No. Dimensions (mm) A B Q´ty / bag 02ZR-8M-P 1.5 4.5 2,000 03ZR-8M-P 3.0 6.0 2,000 09ZR-3H-P 09ZR-8M-P 12.0 15.0 2,000 13ZR-3H-P 13ZR-8M-P 18.0 21.0 2,000 AWG #30 AWG #28 2 02ZR-3H-P 3 03ZR-3H-P 9 13 Material JST B 4.1 Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: Glass-filled PA 66, UL94V-0 RoHS compliance 2
SMM-003T-P0.5
- 物料型号:ZM 连接器有多种型号,例如用于线对线连接的 SMM-003T-P0.5,适用于 0.05~0.08 mm² 的电线,绝缘外径为 30~28 AWG#。 - 器件简介:ZM 连接器采用 1.5mm 间距,有紧凑设计,防“摇摆”的全罩式插座,以及可用于更高密度的接触设计。 - 引脚分配:ZM/ZH 连接器的接触点为 2.8mm 直径的圆,适用于 AWG# 30 到 AWG# 28 的电线。 - 参数特性:电流额定值为 0.7A AC/DC 最大(AWG #28),电压额定值为 50V AC/DC 最大,工作温度范围为 -25°C 至 +85°C。 - 功能详解:ZM 连接器包括压接式 ZH 连接器和绝缘位移 ZR 连接器,均符合 RoHS 标准。 - 应用信息:适用于需要高密度连接的场合,如电子设备内部连接。 - 封装信息:提供了不同电路数的型号,如 ZMR-02(2 电路)、ZMR-03(3 电路)等,以及它们的尺寸和每包数量。
SMM-003T-P0.5 价格&库存
很抱歉,暂时无法提供与“SMM-003T-P0.5”相匹配的价格&库存,您可以联系我们找货
SMM-003T-P0.5
    • 16000+0.05720
    库存:112000
    SMM-003T-P0.5
    • 128+0.40410128+0.05253
    • 500+0.39961500+0.05195
    • 1000+0.239091000+0.03108
    库存:6848
    SMM-003T-P0.5
      库存:5668
      SMM-003T-P0.5
        • 1+0.304241+0.03955
        • 10+0.2520910+0.03277
        • 50+0.1999350+0.02599
        • 100+0.17385100+0.02260
        • 500+0.15647500+0.02034
        • 1000+0.156471000+0.02034
        • 2000+0.147782000+0.01921
        库存:2063
