DF11A-2428SCF
DF11A-2428SCF
    HRS(广濑)
    CRIMP CONTACT
DF11A-2428SCF 数据手册
1 APPLICABLE STANDARD OPERATING TEMPERATURE RANGE OPERATING HUMIDITY RANGE VOLTAGE RATING Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. CURRENT -40C TO + 85C(NOTE 1) 40% TO + 80%(NOTE 2) 250V AC/DC AWG24 : 2.5A AWG26 : 2.0A AWG28 : 1.0A STORAGE TEMPERATURE RANGE STORAGE HUMIDITY RANGE APPLICABLE CONNECTOR -10C TO + 60C(NOTE 3) 40% TO + 70%(NOTE 3) DF11-**DS-2C(##) APPLICABLE CABLE AWG24 TO 28 SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT X X X X X - X - CONSTRUCTION GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT. MARKING CONFIRMED VISUALLY. ACCORDING TO DRAWING. ELECTRIC CHARACTERISTICS CONTACT RESISTANCE 100mA (DC OR 1000 Hz). 30m MAX. MECHANICAL CHARACTERISTICS MECHANICAL OPERATION ① CONTACT RESISTANCE: 30m MAX. ② NO DAMAGE, CRACK OR LOOSENESS OF PARTS. 30 TIMES INSERTIONS AND EXTRACTIONS. CONTACT INSERTION AND EXTRACTION FORCE □0.5±0.002 BY STEEL GAUGE. INSERTION FORCE EXTRACTION FORCE X - VIBRATION FREQUENCY 10 TO 55 Hz, SINGLE AMPLITUDE 0.75 mm, AT 2 h, FOR 3 DIRECTIONS. ① NO ELECTRICAL DISCONTINUITY OF 1s. ② NO DAMAGE, CRACK OR LOOSENESS OF PARTS. X - 490 m/s2 DURATION OF PULSE 11 ms AT 3 TIMES FOR 3 DIRECTIONS. ① NO ELECTRICAL DISCONTINUITY OF 1s. ② NO DAMAGE, CRACK OR LOOSENESS OF PARTS. X - SHOCK 4.4N MAX 0.3N MIN ENVIRONMENTAL CHARACTERISTICS RAPID CHANGE OF TEMPERATURE TEMPERATURE -55→ 5 TO 35→ 85→ 5 TO 35 C TIME 30→10 TO 15→30→10 TO 15 min UNDER 5 CYCLES. ① CONTACT RESISTANCE: 30m MAX. ② NO DAMAGE, CRACK OR LOOSENESS OF PARTS. X - DAMP HEAT (STEADY STATE) EXPOSED AT 40 ± 2 C, 90 TO 95 , 96 h. ① CONTACT RESISTANCE: 30m MAX. ② NO DAMAGE, CRACK OR LOOSENESS OF PARTS. X - REMARKS NOTE 1:INCLUDING THE TEMPERATURE RISE BY CURRENT NOTE 2:NO CONDENSING. NOTE 3:APPLY TO THE CONDITION OF LONG TERM STORAGE FOR UNUSED PRODUCTS BEFORE MOUNTED ON PCB, AFTER MOUNTED ON PCB, OPERATION TEMPERATURE AND HUMIDITY RANGE IS APPLIED FOR INTERIM STORAGE DURING TRANSPORTATION. 1 △ COUNT DESCRIPTION OF REVISIONS DESIGNED 1 DIS-H-00004374 TS.MIYAKI Unless otherwise specifid , refer to IEC 60512. Note QT:Qualification Test FORM HD0011-2-1 AT:Assurance Test X:Applicable Test PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. DATE SZ.ONO 20181102 APPROVED KJ.KATAYOSE 20050105 CHECKED TY.OMA 20050105 DESIGNED IO.DENPOUYA 20050105 DRAWN IO.DENPOUYA 20050105 DRAWING NO. SPECIFICATION SHEET CHECKED ELC-084373-00-00 DF11A-2428SCF CL543-0634-9-00 1 △ 1/1
DF11A-2428SCF 价格&库存
很抱歉,暂时无法提供与“DF11A-2428SCF”相匹配的价格&库存,您可以联系我们找货
DF11A-2428SCF
    DF11A-2428SCF
