EL CONNECTOR
4.5 mm pitch/Disconnectable Crimp style Wire-to-wire connectors
Specifications
• Current rating: 10 A AC/DC
• Voltage rating: 300 V AC/DC
• Temperature range: -25℃ to +90℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 7 mΩ max.
After environmental tests/ 10 mΩ max.
• Insulation resistance: 1,000 M Ω min.
• Withstanding voltage: 1,500 VAC/minute
• Applicable wire: AWG #26 to #16
0.13 to 1.25 mm2
• Applicable panel thickness: 0.8 to 2.0 mm
EL CONNECTOR
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
ELコネクタ表1
The contacts for the compact EL connector
can be easily inserted into the connector
housings. The plug housing and the receptacle
housing can be smoothly mated even if they
are mechanically distorted.
Note: The current rating varies depending on the number of circuits and the
wire size used in each connector. The table below lists the current
rating as a function of the number of circuits and the wire size.
No. of
circuits
2
3
4
6
9
12
15
#16
10
10
10
8
6
6
6
#18
6
6
6
5
4
4
4
●E
asy insertion and secure installation of
contacts
● A smooth connection even when pried
during mating
Standards
● Durable arm lock mechanism
Recognized E60389
● Two contact styles
Certified LR20812
R75052
● Interchangeability with ML connector
ELコネクタ表4
Wire size (AWG)
#20
#22
5
4
5
4
5
4
4
3
3
3
3
3
3
3
Current unit : A
#24
4
4
4
3
2
2
2
#26
3
3
3
3
2
2
2
Panel layout and Assembly layout
A
39.2
ELコネクタ表3
B
C
D
A
No. of circuits
Dimensions A (mm)
2~4
(Single-line arrangement)
10.4
4
(Double-line arrangement)
15.0
6
14.9
9~15
19.4
No. of Receptacle housing Panel hole dimensions (mm) General tolerance ±0.13 Applicable panel
circuits
Model No.
thickness (mm)
A
B
C
D
2
15.0
6.0
6.85
5.2
ELR-02V
3
19.7
6.0
6.85
5.2
ELR-03V
24.2
6.0
6.85
5.2
ELR-04V
4
15.6
10.6
11.6
5.2
ELR-04NV
0.8~2.0
6
19.7
10.2
11.1
5.2
ELR-06V
9
19.7
14.8
15.7
5.2
ELR-09V
12
24.2
14.8
15.7
5.2
ELR-12V
15
28.7
14.8
15.7
5.2
ELR-15V
Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed.
2. The strength of the panel must be considered when punching two or more holes.
3. The connector must be inserted from the same side as the hole is punched.
1
EL CONNECTOR
ELコネクタ表2
Contact
Applicable wire
Model No.
1.3
Pin contact
17.7
7.5
4.3
2.0
3.8
Insulation O.D. Q’ty/reel
(mm)
Pin contact
Socket contact
mm2
AWG #
SLM-01T-P1.3E
SLF-01T-P1.3E
0.13~0.5
26~20
1.3~2.7
SLM-41T-P1.3E
SLF-41T-P1.3E
0.5~1.25
20~16
1.9~3.4
*SLM-42T-P1.3E *SLF-42T-P1.3E
0.3+0.3~
0.5+0.5
22+22~
20+20
1.7+1.7~
2.0+2.0
6,000
4,000
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
RoHS2 compliance
Note: 1 . Contact denoted by * is used for two wires.
2. Contact JST for special products.
3. Contact JST for brass products.
Socket contact
SLM-01T-P1.3E
11.3
2.0
SLM-42T-P1.3E
4.3
SLF-42T-P1.3E
Dies
Crimp applicator with dies
MK/SLF/M-01-13E APLMK SLF/M01-13E
SLF-01T-P1.3E
17.7
Applicator
Crimping
machine Crimp applicator
Contact
AP-K2N
MK/SLF/M-42-13E APLMK SLF/M42-13E
MKS-L
SLM-41T-P1.3E
MK/SLF/M-41-13E APLMK SLF/M41-13E
SLF-41T-P1.3E
Note: Contact JST for fully automatic crimping applicator.
Contact position location numbers
Contact position numbers are stamped
Receptacle housing
Plug housing
15
4
3
2 4
1 3
5
2
1
4
4
3
2
1
1
1
3
2
1
3
3
1
3
1
2
1
2
2
1
1
3
4 2
3 1
2
2
4
4
3
2
1
4
2
1
3
2
1
3
2
2
1
Plug housing
2
Receptacle housing
12
14
4
4
8
9
3
6
10
3
10
5
15
4
9
11
6
3
4
14
13
5
9
3
7
8
5
3
13
2
12
2
6
7
1
1
4
8
2
9
4
2
12
1
5
7
1
9
4
11
6
1
1
10
5
7
7
2
10
8
7
11
8
1
8
12
9
2
4
6
3
5
3
6
6
1
11
5
6
6 3
5 2
4 1
2
9 6 3
8 5 2
7 4 1
12
11
10
9
8
7
6
5
4
3
2
1
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
3 6
2 5
1 4
3 6 9
2 5 8
1 4 7
4
3
2
1
8
7
6
5
12
11
10
9
5
4
3
2
1
10
9
8
7
6
15
14
13
12
11
EL CONNECTOR
P272
Housing
No. of
circuits
Voltage
rating
Material: PA 6, UL94V-0, white
Current
rating
Receptacle housing (for pin contact)
Plug housing (for socket contact)
Q’ty/
bag
ELP-02V
Q’ty/
bag
10.3
ELR-02V
500
300 V
10 A
ELR-02VF
Q’ty/
bag
10.3
2
5.6
10.3
24.6
24.6
5.8
ELR-03V
10 A
500
500
Q’ty/
bag
ELP-03V
Q’ty/
bag
14.8
300 V
14.6
24.6
14.8
3
5.8
500
24.6
24.6
5.6
ELR-04V
500
14.6
5.8
ELP-04V
Q’ty/
bag
19.3
19.3
Q’ty/
bag
500
24.6
JST-L
10 A
24.6
Q’ty/
bag
ELP-04NV
Q’ty/
bag
10.3
300 V
14.6
5.6
ELR-04NV
4
500
5.8
10.3
10.3
24.6
ELR-04NVF
10.3
500
14.6
500
10.3
24.6
24.6
10.3
ELR-06V
8A
Q’ty/
bag
14.8
300 V
ELP-06V
14.8
6
Q’ty/
bag
500
24.6
9.9
10.3
14.6
500
24.6
RoHS2 compliance
3
EL CONNECTOR
P274
Housing
No. of
circuits
Voltage
rating
Current
rating
ELR-09V
6A
500
24.6
24.6
Q’ty/
bag
ELP-12V
500
24.6
24.6
Q’ty/
bag
ELP-15V
Q’ty/
bag
500
500
14.8
24.6
14.4
14.6
24.6
RoHS2 compliance
Note: 1
. ELR-02VF and ELR-04NVF are exclusively for free hanging. The other circuits can be used either for panel mounted or free hanging.
See "Panel layout" for the panel hole dimensions.
4
500
14.6
23.8
6A
14.8
23.8
300 V
Q’ty/
bag
14.4
ELR-15V
15
500
14.6
19.3
6A
14.8
19.3
300 V
Q’ty/
bag
14.4
ELR-12V
12
ELP-09V
14.8
300 V
Q’ty/
bag
14.8
9
P2
很抱歉,暂时无法提供与“SLM-41T-P1.3E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.22513
- 400+0.17751
- 1600+0.15107
- 4000+0.13523
- 国内价格 香港价格
- 1+0.312931+0.04068
- 10+0.2520910+0.03277
- 50+0.1999350+0.02599
- 100+0.17385100+0.02260
- 500+0.15647500+0.02034
- 1000+0.156471000+0.02034
- 2000+0.156472000+0.02034
