(1.27 mm) .050" PITCH • DISCRETE WIRE ASSEMBLY/COMPONENTS
SERIES
POSITIONS
PER ROW
SFSS
–03, –04, –05,
–07, –10, –15,
–20, –25, –40, –50
= Single Row
PVC Cable
SFSST
–28
–28C
= Color
Coded Cable
(SFSS only)
Board Mates:
TFM, TFC
(–SR & –DR requires
–WT option)
SPECIFICATIONS
Insulator Material:
Black LCP
Contact Material:
BeCu
Plating:
Au over 50 µ" (1.27 µm) Ni
Current Rating:
2.9 A per pin (2 pins powered)
Operating Temp Range:
-10 °C to +80 °C (PVC)
-40 °C to +125 °C (*Teflon®)
Voltage Rating:
275 VAC (PVC)
235 VAC (*Teflon®)
Wire:
28 or 30 AWG
PIN
COLOR
1
2
3
4
5
6
7
8
9
10
ETC
BROWN
RED
ORANGE
YELLOW
GREEN
VIOLET
GRAY
WHITE
BLACK
BLUE
REPEAT
ASSEMBLED
LENGTH
–S
= Assembled
Length in Inches
(76.20 mm)
03.00" min. for
–S end option
(82.60 mm)
03.25" min. for
–D end option
–30
= Single Ended
–D
= Double Ended
–SR
= Single Ended
Retention Latch
(TFM-WT option
required for mating)
No. of Positions
x (1.27) .050
+ (0.53) .021
–DR
End 1 Notch
(Always Up)
(5.08)
.200
Assembled
Length
± (3.18)
.125
–03, –04, –05,
–07, –10, –15,
–20, –25, –40, –50
–NUS
= Notch up,
straight
(Pin 1 to Pin N)
–NDS
= Notch down,
straight
(Pin 1 to Pin 1)
*DuPont™ Teflon® is a
registered trademark of the
E.I. du Pont de Nemours
and Company or its affiliates.
End 2
notch
location
determined
by part
number
POSITIONS
PER ROW
Requires
–D or –DR
(End 1 Notch Up)
= Double Ended
Retention Latch
(TFM-WT option
–D–NUS
Notes:
Teflon® cable is intended
for crimp only. Contact
Samtec for solderable cable
applications.
SFSS OR SFSST
For wiring option information
refer to drawings on web.
View complete specifications at: samtec.com?SFSS & samtec.com?SFSST
END 2
OPTION
(11.18)
.440
–SR
ISDF
END
OPTION
–“XX.XX”
= 10 µ"
(0.25 µm)
Gold on
contact,
Gold Flash
on balance
= 30 AWG
–28C CABLE
COLOR CODING
SFSS(T)
PLATING
OPTION
–G
= 28 AWG
(Standard sizes)
= Single Row
Blue *Teflon® Cable
WIRE
GAUGE
ROW
OPTION
–S
–M
= Single
Row
= Metal
Retention
Latch
(Standard sizes)
SERIES
OPTION
CC03R
= Contact, Full Reel
(35,000 Parts per Reel)
WIRE
GAUGE
- 01 -
–2830
–GF
= 28 to 30
AWG
CC03M
= Gold flash
contact
–G
= Contact, Mini Reel
(1,000 - 5,000 Parts
per Reel)
No. of Positions
x (1.27) .050
+ (0.53) .021
PLATING
= 10 µ" (0.25 µm)
Gold on contact
(5.08)
.200
(15.37)
.605
(11.18)
.440
(3.81)
.150
(6.32)
.249
–S
–M
TOOLING
Hand Tool: CAT-HT-203-2830-12
Mini Applicator: CAT-MC-203-2830-XX-01
Clamp for mounting hand tool: CAT-HT-MNT-01
Extraction Tool: CAT-EX-169-01
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-221
View complete specifications at: samtec.com?ISDF, samtec.com?CC03R & samtec.com?CC03M
samtec.com/127mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SERIES
POSITIONS
PER ROW
SFSD
–03, –04, –05,
–07, –10, –15,
–20, –25, –40, –50
= Double Row
PVC Cable
SFSDT
–28
Board Mates:
TFM, TFC
(–SR & –DR requires
–WT option)
SPECIFICATIONS
Insulator Material:
Black LCP
Contact Material:
BeCu
Plating:
Current Rating:
2.9 A per pin
(2 pins powered)
Voltage Rating:
275 VAC (PVC)
235 VAC (*Teflon®)
Wire:
28 or 30 AWG
–G
–28C
PIN
COLOR
1
2
3
4
5
6
7
8
9
10
ETC
BROWN
RED
ORANGE
YELLOW
GREEN
VIOLET
GRAY
WHITE
BLACK
BLUE
REPEAT
No. of Positions
x (1.27) .050
+ (0.38) .015
END
OPTION
= Single Ended
–D
= Double Ended
For –(X) specify
“S” for single ended
and “D” for
double ended.
Assembled
Length
± (3.18)
.125
POSITIONS
PER ROW
–03, –04, –05,
–07, –10, –15,
–20, –25, –40, –50
ROW
OPTION
–D
–M
= Double
Row
= Metal
Retention
Latch
(Standard sizes)
–S
No. of Positions
x (1.27) .050
+ (0.38) .015
= Screw
Down
–NDX
= Notch down,
crossed
(Pin 1 to Pin 1)
Notes:
applications.
SFSD OR SFSDT
SERIES
OPTION
–NUX
End 2
notch
location
determined
by part
number
–D–NUS
–NDS
= Notch up,
crossed
(Pin 1 to Pin N)
(11.18)
.440
–SR
–NUS
= Notch up,
straight
(Pin 1 to Pin N-1)
–(X)S
= Screw Down
(Not available in -03,
-04 & -50 positions)
(Mates with
TFM-DS option)
(6.35)
.250
Requires
–D, –DS, –DR
(End 1 Notch Up)
= Notch down,
straight
(Pin 1 to Pin 2)
= Retention Latch
(TFM-WT option
End 1 Notch
(Always Up)
END 2
OPTION
–(X)R
View complete specifications at: samtec.com?SFSD & samtec.com?SFSDT
ISDF
–S
= Assembled
Length in
Inches
(76.20 mm)
03.00" min. for
–S end option
(82.60 mm)
03.25" min. for
–D end option
–30
= 30 AWG
ASSEMBLED
LENGTH
–“XX.XX”
= 10 µ"
(0.25 µm)
Gold on
contact,
Gold Flash
on balance
= Color
Coded Cable
(SFSD only)
–28C CABLE
COLOR CODING
SFSD(T)
PLATING
OPTION
= 28 AWG
(Standard sizes)
= Double Row
Blue *Teflon® Cable
WIRE
GAUGE
CC03R
WIRE
GAUGE
- 01 -
PLATING
–2830
–GF
= 28 to 30
AWG
CC03M
= Gold flash
contact
–G
per Reel)
= 10 µ" (0.25 µm)
Gold on contact
(6.35)
.250
(11.18)
.440
(15.37)
.605
(6.32)
.249
(3.81)
.150
–D
–M
–S
TOOLING
Note:
non-returnable.
F-221
