DF6A-1822PCF(05)
DF6A-1822PCF(05)
    HRS(广濑)
    CRIMP CONTACT
DF6A-1822PCF(05) 数据手册
3.96mm Pitch Connector Directly Mounted on Board Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF6 Series ■Features 1. Service Efficiency Up Conventional thick cables are directly mounted on the board piece by piece, but connecterization has achieved soldering services in a batch. This product enhances soldering service efficiency. 2. Miniaturization This product achieves miniaturization for thick cables. Mounting height on board : 7.5mm Width : 5.0mm 3. Board Prefixed Mechanism Since the connector is softly press-fitted to the board for insertion, it can be prefixed to the board. Height: 7.5mm ■Applications Secondary power supply units for various equipment width: 4.6mm Prefixed mechanism B129 DF6 Series●3.96mm Pitch Connector Directly Mounted on Board ■Product Specifications Current rating Rating (Note 1) Cable size Voltage rating Item Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5A Operating Temperature Range -35 to +85ç (Note 1) AWG 20 : 4A Operating Moisture Range 40 to 80% AWG 22 : 3A Storage Temperature Range -10 to +60ç (Note 2) Storage Humidity Range 40 to 70% (Note 2) AWG 18 : 300V AC Specification Condition 1.Insulation Resistance 1000M ohms min. 500V DC 2.Withstanding voltage No flashover or insulation breakdown. 1500V AC/1 minute 3.Contact Resistance 15m ohms max. 100mA 4.Vibration No damage, cracks, or parts looseness. Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5.Humidity (Steady state) No damage, cracks, or parts looseness. 96 hours at temperature of 40ç and humidity of 90% to 95% 6.Temperature Cycle (-55ç: 30 minutes ➝15 to 35ç: 10 minutes➝85ç: 30 minutes➝ 5 to 35ç: 10 minutes ) 5 cycles No damage, cracks, or parts looseness. Flow: 250ç for 10 seconds 7. Resistance to Soldering heat No deformation of components affecting performance. Manual soldering: 300ç for 3 seconds Note 1: The rated current will be changed according to cable sizes for use. Note 2: Includes temperature rise caused by current flow. Note 3: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 4: Information contained in this catalog represents general requirements for this Series.Contact us for the drawings and specifications for a specific part number shown. ■Material Product Part Crimping Plug Insulator Crimping Contact for Plug Brass Material Finish Remarks Polyamide White Copper Alley Tin plated UL94V-0 ________ ■Ordering Information ●Crimping Plug DF6 - * P - 3.96 C q q Series Name w : DF 6 w Number of contacts: 1~8, 10 e r t r Contact pitch: 3.96mm t C: Crimping plug e Connector type P: Plug ●Crimping Contact DF6A - 1822 PCF q q Applicable cable type None : Jacket dia. 1.5mm to 2.2mm UL 1007 A : Jacket dia. 2.2mm to 2.9mm UL 1015 w Applicable cable size 1822 : AWG#18~#22 B130 w e e Packaging type PCF: Plug contact, reel packaging SC: Plug contact, bag packaging DF6 Series●3.96mm Pitch Connector Directly Mounted on Board ■Precrimping Plug Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Photo: Contact Inserted Part Number DF6- 1P-3.96C DF6- 2P-3.96C DF6- 3P-3.96C DF6- 4P-3.96C DF6- 5P-3.96C DF6- 6P-3.96C DF6- 7P-3.96C DF6- 8P-3.96C DF6-10P-3.96C CL No. 546-0001-1 546-0002-4 546-0003-7 546-0004-0 546-0005-2 546-0006-5 546-0007-8 546-0008-0 546-0011-5 Number of Contacts 1 2 3 4 5 6 7 8 10 A 4.92 8.88 12.84 16.80 20.76 24.72 28.68 32.64 40.56 B _____ 3.96 7.92 11.88 15.84 19.80 23.76 27.72 35.64 RoHS YES Contact View for Insertion Note: A packaging quantity is delivered by the bag unit (100 pcs.). ■Crimping Contact ●Slip length DF6-1822PC (F): 2.1mm to 2.6mm DF6A-1822PC (F): 2.3mm to 2.8mm ●Applicable through-hole: 1.8 +0.15 0 Part Number CL No. DF6 -1822PCF(05) DF6 -1822PC(05) DF6A-1822PCF(05) DF6A-1822PC(05) 546-0009-3-05 546-0010-2-05 546-0013-0-05 546-0014-3-05 UL style 1007 1015 Applicable Cable Packaging Type Jacket dia. AWG size Contact Construct Reel 1.5 to 2.2mm AWG 18 34 cores/0.18mm Bag AWG 20 21 cores/0.18mm Reel 2.2 to 2.9mm AWG 22 17 cores/0.16mm Bag Quantity 5,000 100 3,000 100 A B C 10.2 1.5 1.2 10.5 1.7 1.4 RoHS YES Note 1. The applicable cable conductor is a tin plated and annealed copper wire. Note 2. If other cables are used instead of the applicable cable, contact the Hirose Sales Department. BApplicable Crimping Tools TypeItem Applicator Press unit Manual crimping tool Extraction tool Part Number AP105-DF6-1822P AP105-DF6A-1822P CM-105 DF6 -TA1822HC DF6A-TA1822HC DF-C-PO(A) CL No. 901-4505-9 901-4520-2 901-0005-4 550-0174-9 550-0222-0 550-0170-8 Applicable Contact DF6 -1822PCF(05) DF6A-1822PCF(05) ________ DF6 -1822PC(05) DF6A-1822PC(05) DF6/DF6A-1822PC(F)(05) Note: If any trouble has been caused due to other tools, which are not designated by Hirose, Hirose never guarantee any products. B131 DF6 Series●3.96mm Pitch Connector Directly Mounted on Board BPrecautions 1.Recommended soldering condition 2.Cleaning condition Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.Connecting condition 4.Precations B132 Powered by TCPDF (www.tcpdf.org) Flow: 250ç for 3 seconds Manual soldering: 290ç for 2 seconds ■After soldering, if a load is given to the cable where connector and cable contain heat, the jacket holding member will be loosened. After soldering, the operation should be performed, after connector returns to room temperature. Refer to the "Nylon Connector Use Hand book". Don't use solvent to degrade the cable jacket like trichloroethane. In addition, avoid heat cleaning with solvent. Refer to the "Nylon Connector Use Hand book". Slight discoloration on the insulating materials will not affect form, fit or function of the connectors. Refer to "Nylon Connector Use Handbook"
DF6A-1822PCF(05)
物料型号:DF6系列
器件简介: - 提供了服务效率,通过连接器化实现批量焊接服务。 - 实现了粗电缆的小型化,板载高度为7.5mm,宽度为5.0mm。 - 板前固定机制,连接器软性地压配到板上进行插入,可以固定到板上。
引脚分配:1~10个接触点,接触点间距为3.96mm。
参数特性: - 电流额定值:AWG18为5A,AWG20为4A,AWG22为3A。 - 操作温度范围:-35至+85°C。 - 存储温度范围:-10至+60°C。 - 绝缘电阻:最小1000M欧姆。 - 耐电压:1500V AC/1分钟无闪络或绝缘击穿。 - 接触电阻:最大15毫欧姆。
功能详解: - 振动测试:在10Hz至55Hz频率下,0.75mm单振幅,每个方向2小时,无损伤、裂纹或零件松动。 - 稳态湿热测试:在40°C温度和90%至95%湿度下96小时,无损伤、裂纹或零件松动。 - 温度循环测试:经历-55°C至+35°C至+85°C的温度循环,无损伤、裂纹或零件松动。
应用信息:适用于各种设备的二次电源单元。
封装信息: - 绝缘体材料:聚酰胺,白色,UL94V-0。 - 插针接触材料:黄铜,铜合金,锡镀层。
订购信息: - 压接插头型号示例:DF6/0-/P/3.96C/θ。 - 压接接触型号示例:DF6A/0-1822/PCF/θ。
注意事项: - 推荐的焊接条件、清洁条件、连接条件以及对材料的注意事项。
DF6A-1822PCF(05) 价格&库存
很抱歉,暂时无法提供与“DF6A-1822PCF(05)”相匹配的价格&库存,您可以联系我们找货
