REVISION Y
CC79X-XXXX-XX-X
ALL DIMENSIONS ARE REFERENCE
(SEE XC-179-XX-X-XX FOR CONTROLLING PRINT)
DO NOT
SCALE FROM
THIS PRINT
PLATING
-F: 3µ" GOLD ON CONTACT,
BRIGHT ACID TIN ON TAIL
-L: 10µ" GOLD ON CONTACT,
-S: 30µ" GOLD ON CONTACT,
SUPPLIED
-L: LOOSE
-R: REEL
LEAD STYLE
-2630 (26-30 AWG)
-2024 (20-24 AWG)
-2830 (28-30 AWG)(PTFE)
OPTION
(INSULATION THICKNESS)
-01
"A"
.016
.020
.064
.130
.155
"B"
"C"
.190
.060
.1198
"B"
.435
"C"
.090
"N" MAX
(TAB LENGTH)
(SEE TABLE 1, SHT 2)
.1060
.150
.075
.1250
"A"
"D"
SECTION "A"-"A"
FIG 1
"A"
(CC79R-XXXX-01-X SHOWN)
"B"
"E"
R "F"
R "C"
SECTION "B"-"B"
SCALE 6 : 1
"P" MAX
(VESTIGE ALLOWANCE)
.0620 (TYP)
SECTION "C"-"C"
SCALE 6 : 1
NOTES:
1. PLATED C-179 PARTS TO BE PULLED, PLATING OPTION CONFIRMED, POSITIONED AS SHOWN
ON SAMTEC REEL WITH VIEWPORTS, LABELED CC79R WITH APPROPRIATE PLATING CALLOUT
AND LABEL PLACED AS SHOWN.
2. MAXIMUM No OF SPLICES PER REEL: 2
3. SPLICES ARE NOT TO BE CONNECTED.
4. NUMBER OF SPLICES TO BE MARKED ON EACH REEL.
5. REELED PARTS TO BE INTERLEAVED WITH PAPER BETWEEN EACH LAYER OF PARTS.
6. ALLOWABLE INTERLEAF SPLICES PER REEL: 3
7. SECURELY CONNECT INTERLEAF SPLICE.
8. OUTER WRAP SHALL RECEIVE HMS1015C-16MM PROTECTIVE REEL BAND.
9. DUE TO PLATING REQUIREMENTS CONTACT SAMPLES MAY BE REMOVED INTERMITTINGLY
FROM THE CARRIER RESULTING IN SMALL GAPS BUT DOES NOT AFFECT FINAL COUNT.
10. QTY PER REEL: 12,000 ± 15 PCS
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
MATERIAL:
DO NOT SCALE DRAWING
SHEET SCALE: 3:1
DESCRIPTION:
PHOS BRONZE
THICKNESS: .0080
F:\DWG\MISC\MKTG\CC79X-XXXX-XX-X-MKT.SLDDRW
DWG. NO.
BY:
.100 IPD1 CONTACT
CC79X-XXXX-XX-X
DEAN P
8/12/2004
SHEET 1 OF 2
REVISION Y
"J"
"G"
"H"
WIRE CRIMP
INSULATION STRIP LENGTH
FIG 2
RECOMMENDED PROCESSING
.50
"K"
"L"
"M"
UNWINDING DIRECTION
LABEL DOWN,
LOGO DOWN
PROPRIETARY NOTE
CARRIER
TO BE ON LABEL SIDE
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
FIG 3
REEL SPECIFICATIONS
SHEET SCALE: 5:1
DESCRIPTION:
DWG. NO.
BY:
.100 IPD1 CONTACT
CC79X-XXXX-XX-X
DEAN P
8/12/2004
SHEET 2 OF 2
很抱歉,暂时无法提供与“CC79R-2024-01-L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 12000+0.6315212000+0.08209
- 24000+0.6013724000+0.07817
- 36000+0.5844136000+0.07596
- 60000+0.5637360000+0.07327
- 84000+0.5505184000+0.07156
- 120000+0.53685120000+0.06978
