CC03X-XXXX-01-XX
REVISION V
.038
ALL DIMENSIONS ARE REFERENCE
(SEE C-203-XXXX-XX FOR CONTROLLING PRINT)
DO NOT
SCALE FROM
THIS PRINT
.035
SUPPLIED
*L: LOOSE
R: REEL
M: MINI REEL (1K -5K CONTACTS)
PLATING SPECIFICATION
-GF: 3µ" GOLD FLASH IN CONTACT AREA,
3µ" GOLD ON TAIL
-G: 10µ" LIGHT GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
-H: 30µ" HEAVY GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
( * =FOR EXISTING CUSTOMERS ONLY)
SECTION "B"-"B"
SCALE 16 : 1
R.007
LEAD STYLE
-2830: 28-30 AWG
.015
.150
OPTION
INSULATION THICKNESS:
.113
.214
.203
.045
.260
.330
.025
.400
.530
"B"
.605
"A"
.025
"B"
"A"
"H" MAX
(TAB LENGTH)
(SEE TABLE 1, SHT 2)
.040
"G" MAX
(VESTIGE ALLOWANCE)
.0950
.150
.054
.0750
.0500
NOTES:
1. PLATED C-203 PARTS TO BE PULLED, PLATING OPTION CONFIRMED, POSITIONED AS SHOWN
ON SAMTEC REEL WITH VIEWPORTS,LABELED CC03R WITH APPROPRIATE PLATING CALLOUT
AND LABEL PLACED AS SHOWN.
2. MAXIMUM No OF SPLICES PER REEL:
-R: 2
-M: 1
3. SPLICES ARE NOT TO BE CONNECTED.
4. NUMBER OF SPLICES TO BE MARKED ON EACH REEL.
5. REELED PARTS TO BE INTERLEAVED WITH PAPER BETWEEN EACH LAYER OF PARTS.
6. ALLOWABLE INTERLEAF SPLICES PER REEL:
-R: 3
-M: 1
7. SECURELY CONNECT INTERLEAF SPLICE.
8. OUTER WRAP FOR PROTECTIVE REEL BAND AS BELOW:
-R: RB-24-0.75-P
-M: CRT-016-0.018
9. DUE TO PLATING REQUIREMENTS CONTACT SAMPLES MAY BE REMOVED INTERMITTINGLY
FROM THE CARRIER RESULTING IN SMALL GAPS BUT DOES NOT AFFECT FINAL COUNT.
10. QTY PER REEL:
-R: 35,000 +700/-0 PCS
-M: 1,000 - 5,000 +300/-0 PCS
.057
FIG 1
(CC03X-2830-01-X SHOWN)
SECTION "A"-"A"
SCALE 16 : 1
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 6:1
R.014
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
.050" C.L. DISCRETE WIRE CONTACT
BeCu
THICKNESS: .0050
DWG. NO.
F:\DWG\MISC\MKTG\CC03X-XXXX-01-XX-MKT.SLDDRW
BY: BRATCHER
CC03X-XXXX-01-XX
3/8/2005
SHEET 1 OF 2
REVISION V
"C"
"A"
"B"
WIRE CRIIMP
SCALE 16 : 1
INSULATION STRIP LENGTH
FIG 2
RECOMENDED PROCESSING
UNWINDING DIRECTION
LABEL UP
"E" HUB DIAMETER
"D"
"F"
.50
CARRIER
TO BE ON LABEL SIDE
FIG 3
REEL SPECIFICATIONS
PROPRIETARY NOTE
SHEET SCALE: 6:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
CC03X-XXXX-01-XX
BY: BRATCHER
3/8/2005
SHEET 2 OF 2
很抱歉,暂时无法提供与“CC03R-2830-01-H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.808961+0.23471
- 10+1.5620910+0.20268
- 25+1.4586625+0.18926
- 50+1.3903450+0.18040
- 100+1.32362100+0.17174
- 250+1.24095250+0.16102
- 500+1.18150500+0.15330
- 1000+1.124951000+0.14596
- 国内价格 香港价格
- 3500+0.908563500+0.11789
- 7000+0.865177000+0.11226
- 10500+0.8407610500+0.10909
- 17500+0.8110117500+0.10523
- 24500+0.7919824500+0.10276
- 35000+0.7723135000+0.10021
