CC81R-2830-01-S
CC81R-2830-01-S
    SAMTEC(申泰)
    CC81R-2830-01-S
CC81R-2830-01-S 数据手册
(2.00 mm) .0787" PITCH • CABLE ASSEMBLY/COMPONENTS SERIES S2SD = Double Row PVC Cable - - PINS PER ROW –05, –07, –10, –15, –20, –25, –30 (Standard sizes) S2SDT = Double Row Blue *Teflon ® Cable (24, 28, 30 Gauge only) - WIRE GAUGE PLATING OPTION –24 –24C –L = 10 µ" (0.25 µm) Gold on contact = Color Coded Cable (S2SD only) - ASSEMBLED LENGTH - –“XX.XX” –S = Wire Length in Inches (69.85 mm) 02.75" min. Board Mates: T2M Specify “S” for single ended and “D” for double ended. –(X)R = Retention Latch (–SR mates with T2M-WT) –(X)S –24C CABLE COLOR CODING SPECIFICATIONS Insulator Material: Black LCP Contact Material: BeCu Plating: Au over 50 µ" (1.27 µm) Ni Wire: 24, 26, 28 or 30 AWG Operating Temp Range: -10 °C to +105 °C (PVC) -40 °C to +125 °C (*Teflon®) Current Rating (S2SD-24/T2M): 3.8 A per pin (2 pins powered) Voltage Rating: 250 VAC PIN COLOR 1 2 3 4 5 6 7 8 9 10 ETC BROWN RED ORANGE YELLOW GREEN VIOLET GRAY WHITE BLACK BLUE REPEAT –NUS –D = Double End = Screw Down (10 positions minimum) (mates with T2M-DS) No. of positions x (2.00) .0787 + (3.50) .138 - - POSITIONS PER ROW –05, –07, –10, –15, –20, –25, –30 (Standard sizes) ROW OPTION –D = Double Row (11.38) .448 - LATCH OPTION –M = Metal Retention Latch (2.00) .079 DIA SERIES CC81L = Contact, Loose CC81R = Contact, Full Reel (17,000 Parts per Reel) –NDX = Notch down, crossed (Pin 1 to Pin 1) *DuPont™ Teflon® is a registered trademark of the E.I. du Pont de Nemours and Company or its affiliates. Assembly Length ± (3.18) .125 For wiring option information refer to drawings on web. - WIRE GAUGE - 01 - –2426 = 24 to 26 AWG –2830 L –L = 10 µ" (0.25 µm) Gold on contact = 28 to 30 AWG (3.68) .145 (1.78) .070 –M –NUX = Notch up, crossed (Pin 1 to Pin N) Notes: Teflon® cable is intended for crimp only. Contact Samtec for solderable cable applications. = Screw Down (2.03) .080 (2.64) .104 –NDS = Notch down, straight (Pin 1 to Pin 2) (5.15) .203 –S (2.07) .081 = Notch up, straight (Pin 1 to Pin N-1) (7.52) .296 View complete specifications at: samtec.com?S2SD and samtec.com?S2SDT ISD2 END 2 OPTIONS (Only available with –D, –DR & –DS) = Single End –26 –28 –30 S2SD(T) - END OPTIONS (12.35) .486 (3.17) .125 –S TOOLING Note: Some lengths, styles and options are non-standard, non-returnable. Hand Tool: CAT-HT-281-2430-13 Mini Applicator: CAT-MC-281-2426-XX-01 (24-26 AWG) Extraction Tool: CAT-EX-169-01 Mini Applicator: CAT-MC-281-2830-XX-01 (28-30 AWG) View complete specifications at: samtec.com?ISD2, samtec.com?CC81R & samtec.com?CC81L samtec.com/2mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
CC81R-2830-01-S 价格&库存
很抱歉,暂时无法提供与“CC81R-2830-01-S”相匹配的价格&库存,您可以联系我们找货
