T1M44-R-2830-01-H
T1M44-R-2830-01-H
    SAMTEC(申泰)
    T1M44-R-2830-01-H
T1M44-R-2830-01-H 数据手册
REVISION J T1M44-X-XXXX-01-XX ALL DIMENSIONS ARE REFERENCE PLATING SPECIFICATION -GF: 3µ" GOLD FLASH IN CONTACT AREA, 3µ" GOLD ON TAIL -G: 10µ" LIGHT GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL SUPPLIED *-L: LOOSE -R: REEL -M: MINI REEL (SEE T-1M44-XXXX-XX FOR CONTROL PRINT) DO NOT SCALE FROM THIS PRINT LEAD STYLE -2830: 28-30 AWG CARRIER SPECIFICATIONS (*= FOR EXISTING CUSTOMERS ONLY) .030 .383 .523 .618 .693 .584 "B" "A" .334 .483 .130 "B" .034 .070 "A" .025 .095 .150 .0500 (TYP) .150 .0150 .054 .038 FIG 1 (T-1M44-2830-01-XX SHOWN) .057 .035 NOTES: 1. PLATED T-1MM PARTS ARE TO BE UNWOUND THEN REWOUND AND COUNTED, POSITIONED AS SHOWN ON SAMTEC REEL WITH VIEWPORTS, LABELED T1M44 WITH APPROPRIATE PLATE CALL OUT AND LABEL PLACED AS SHOWN. 2. MAXIMUM ALLOWABLE SPLICES PER REEL: -R: 2 -M: 1 3. SPLICES ARE NOT TO BE CONNECTED. 4. NUMBER OF SPLICES TO BE MARKED ON EACH REEL. 5. REELED PARTS TO BE INTERLEAVED WITH PAPER BETWEEN EACH LAYER OF PARTS. 6. ALLOWABLE INTERLEAF SPLICES PER REEL: -R: 3 -M: 1 7. SECURELY CONNECT INTERLEAF SPLICE. 8. OUTER WRAP SHALL RECEIVE RB-24-1.00-P PROTECTIVE REEL BAND. 9. DUE TO PLATING REQUIREMENTS CONTACT SAMPLES MAY BE REMOVED INTERMITTINGLY FROM THE BANDOLIER RESULTING IN SMALL GAPS BUT DOES NOT AFFECT FINAL COUNT. 10.QTY PER REEL: -R: 35,000 +100/-0 PCS -M: 5,000 +300/-0 PCS R.008 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES MATERIAL: R.014 SECTION "B"-"B" SCALE 16 : 1 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 8:1 SECTION "A"-"A" SCALE 16 : 1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: BeCu THICKNESS: .0050 DWG. NO. F:\DWG\MISC\MKTG\T1M44-X-XXXX-01-XX-MKT.SLDDRW BY: .050" C.L. DISCRETE WIRE TERMINAL T1M44-X-XXXX-01-XX G. PURVIS 12/21/2007 SHEET 1 OF 2 REVISION J "C" "A" "B" WIRE CRIMP INSULATION STRIP LENGTH FIG 2 RECOMMENDED PROCESSING UNWINDING DIRECTION "D" .500 "E" "F" LABEL DOWN FIG 3 REEL SPECIFICATIONS F:\DWG\MISC\MKTG\T1M44-X-XXXX-01-XX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 8:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: DWG. NO. BY: .050" C.L. DISCRETE WIRE TERMINAL T1M44-X-XXXX-01-XX G. PURVIS 12/21/2007 SHEET 2 OF 2
T1M44-R-2830-01-H 价格&库存
很抱歉,暂时无法提供与“T1M44-R-2830-01-H”相匹配的价格&库存,您可以联系我们找货
T1M44-R-2830-01-H
    • 35000+1.6185035000+0.21000
