CC79R-2024-01-S
CC79R-2024-01-S
    SAMTEC(申泰)
    CC79R-2024-01-S
CC79R-2024-01-S 数据手册
REVISION Y CC79X-XXXX-XX-X ALL DIMENSIONS ARE REFERENCE (SEE XC-179-XX-X-XX FOR CONTROLLING PRINT) DO NOT SCALE FROM THIS PRINT PLATING -F: 3µ" GOLD ON CONTACT, BRIGHT ACID TIN ON TAIL -L: 10µ" GOLD ON CONTACT, BRIGHT ACID TIN ON TAIL -S: 30µ" GOLD ON CONTACT, BRIGHT ACID TIN ON TAIL SUPPLIED -L: LOOSE -R: REEL LEAD STYLE -2630 (26-30 AWG) -2024 (20-24 AWG) -2830 (28-30 AWG)(PTFE) OPTION (INSULATION THICKNESS) -01 "A" .016 .020 .064 .130 .155 "B" "C" .190 .060 .1198 "B" .435 "C" .090 "N" MAX (TAB LENGTH) (SEE TABLE 1, SHT 2) .1060 .150 .075 .1250 "A" "D" SECTION "A"-"A" FIG 1 "A" (CC79R-XXXX-01-X SHOWN) "B" "E" R "F" R "C" SECTION "B"-"B" SCALE 6 : 1 "P" MAX (VESTIGE ALLOWANCE) (SEE TABLE 1, SHT 2) .0620 (TYP) SECTION "C"-"C" SCALE 6 : 1 NOTES: 1. PLATED C-179 PARTS TO BE PULLED, PLATING OPTION CONFIRMED, POSITIONED AS SHOWN ON SAMTEC REEL WITH VIEWPORTS, LABELED CC79R WITH APPROPRIATE PLATING CALLOUT AND LABEL PLACED AS SHOWN. 2. MAXIMUM No OF SPLICES PER REEL: 2 3. SPLICES ARE NOT TO BE CONNECTED. 4. NUMBER OF SPLICES TO BE MARKED ON EACH REEL. 5. REELED PARTS TO BE INTERLEAVED WITH PAPER BETWEEN EACH LAYER OF PARTS. 6. ALLOWABLE INTERLEAF SPLICES PER REEL: 3 7. SECURELY CONNECT INTERLEAF SPLICE. 8. OUTER WRAP SHALL RECEIVE HMS1015C-16MM PROTECTIVE REEL BAND. 9. DUE TO PLATING REQUIREMENTS CONTACT SAMPLES MAY BE REMOVED INTERMITTINGLY FROM THE CARRIER RESULTING IN SMALL GAPS BUT DOES NOT AFFECT FINAL COUNT. 10. QTY PER REEL: 12,000 ± 15 PCS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. MATERIAL: DO NOT SCALE DRAWING SHEET SCALE: 3:1 DESCRIPTION: PHOS BRONZE THICKNESS: .0080 F:\DWG\MISC\MKTG\CC79X-XXXX-XX-X-MKT.SLDDRW DWG. NO. BY: .100 IPD1 CONTACT CC79X-XXXX-XX-X DEAN P 8/12/2004 SHEET 1 OF 2 REVISION Y "J" "G" "H" WIRE CRIMP INSULATION STRIP LENGTH FIG 2 RECOMMENDED PROCESSING .50 "K" "L" "M" UNWINDING DIRECTION LABEL DOWN, LOGO DOWN F:\DWG\MISC\MKTG\CC79X-XXXX-XX-X-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS CARRIER TO BE ON LABEL SIDE AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING FIG 3 REEL SPECIFICATIONS SHEET SCALE: 5:1 DESCRIPTION: DWG. NO. BY: .100 IPD1 CONTACT CC79X-XXXX-XX-X DEAN P 8/12/2004 SHEET 2 OF 2
CC79R-2024-01-S 价格&库存
很抱歉,暂时无法提供与“CC79R-2024-01-S”相匹配的价格&库存,您可以联系我们找货
CC79R-2024-01-S
  • 1+2.483581+0.32192
  • 10+2.1083810+0.27329
  • 25+1.9800425+0.25665
  • 50+1.8847550+0.24430
  • 100+1.79414100+0.23256
  • 250+1.68184250+0.21800
  • 500+1.60151500+0.20759
  • 1000+1.524921000+0.19766
  • 2500+1.429332500+0.18527
库存:224504
