CC03M-2830-01-H
CC03M-2830-01-H
    SAMTEC(申泰)
    CC03M-2830-01-H
CC03M-2830-01-H 数据手册
CC03X-XXXX-01-XX REVISION V .038 ALL DIMENSIONS ARE REFERENCE (SEE C-203-XXXX-XX FOR CONTROLLING PRINT) DO NOT SCALE FROM THIS PRINT .035 SUPPLIED *L: LOOSE R: REEL M: MINI REEL (1K -5K CONTACTS) PLATING SPECIFICATION -GF: 3µ" GOLD FLASH IN CONTACT AREA, 3µ" GOLD ON TAIL -G: 10µ" LIGHT GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL ( * =FOR EXISTING CUSTOMERS ONLY) SECTION "B"-"B" SCALE 16 : 1 R.007 LEAD STYLE -2830: 28-30 AWG .015 .150 OPTION INSULATION THICKNESS: .113 .214 .203 .045 .260 .330 .025 .400 .530 "B" .605 "A" .025 "B" "A" "H" MAX (TAB LENGTH) (SEE TABLE 1, SHT 2) .040 "G" MAX (VESTIGE ALLOWANCE) (SEE TABLE 1, SHT 2) .0950 .150 .054 .0750 .0500 NOTES: 1. PLATED C-203 PARTS TO BE PULLED, PLATING OPTION CONFIRMED, POSITIONED AS SHOWN ON SAMTEC REEL WITH VIEWPORTS,LABELED CC03R WITH APPROPRIATE PLATING CALLOUT AND LABEL PLACED AS SHOWN. 2. MAXIMUM No OF SPLICES PER REEL: -R: 2 -M: 1 3. SPLICES ARE NOT TO BE CONNECTED. 4. NUMBER OF SPLICES TO BE MARKED ON EACH REEL. 5. REELED PARTS TO BE INTERLEAVED WITH PAPER BETWEEN EACH LAYER OF PARTS. 6. ALLOWABLE INTERLEAF SPLICES PER REEL: -R: 3 -M: 1 7. SECURELY CONNECT INTERLEAF SPLICE. 8. OUTER WRAP FOR PROTECTIVE REEL BAND AS BELOW: -R: RB-24-0.75-P -M: CRT-016-0.018 9. DUE TO PLATING REQUIREMENTS CONTACT SAMPLES MAY BE REMOVED INTERMITTINGLY FROM THE CARRIER RESULTING IN SMALL GAPS BUT DOES NOT AFFECT FINAL COUNT. 10. QTY PER REEL: -R: 35,000 +700/-0 PCS -M: 1,000 - 5,000 +300/-0 PCS .057 FIG 1 (CC03X-2830-01-X SHOWN) SECTION "A"-"A" SCALE 16 : 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 6:1 R.014 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050" C.L. DISCRETE WIRE CONTACT BeCu THICKNESS: .0050 DWG. NO. F:\DWG\MISC\MKTG\CC03X-XXXX-01-XX-MKT.SLDDRW BY: BRATCHER CC03X-XXXX-01-XX 3/8/2005 SHEET 1 OF 2 REVISION V "C" "A" "B" WIRE CRIIMP SCALE 16 : 1 INSULATION STRIP LENGTH FIG 2 RECOMENDED PROCESSING UNWINDING DIRECTION LABEL UP "E" HUB DIAMETER "D" "F" .50 * CARRIER TO BE ON LABEL SIDE FIG 3 REEL SPECIFICATIONS PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 6:1 F:\DWG\MISC\MKTG\CC03X-XXXX-01-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: DWG. NO. .050" C.L. DISCRETE WIRE CONTACT CC03X-XXXX-01-XX BY: BRATCHER 3/8/2005 SHEET 2 OF 2
CC03M-2830-01-H 价格&库存
很抱歉,暂时无法提供与“CC03M-2830-01-H”相匹配的价格&库存,您可以联系我们找货
CC03M-2830-01-H
  • 1000+1.538161000+0.19958
  • 2000+1.464652000+0.19004
  • 3000+1.423273000+0.18467
  • 5000+1.372895000+0.17814
  • 7000+1.340667000+0.17395
  • 10000+1.3073510000+0.16963
库存:5294
CC03M-2830-01-H
  • 1+2.853781+0.37028
  • 10+2.4108110+0.31280
  • 25+2.2638625+0.29374
  • 50+2.1554650+0.27967
  • 100+2.05153100+0.26619
  • 250+1.92255250+0.24945
  • 500+1.83070500+0.23754
库存:5294
