CC79L-2830-01-L
CC79L-2830-01-L
    SAMTEC(申泰)
    CC79L-2830-01-L
CC79L-2830-01-L 数据手册
(2.54 mm) .100" PITCH • DISCRETE WIRE CABLE & COMPONENTS - SERIES MMSD - PINS PER ROW –02, –03, = Double Row PVC Cable MMSDT MMSS = Single Row PVC Cable –20C = Color Coded Cable (MMSD & MMSS only) –06, –08, –10, –12, - –S K - –K = Single Ended = Keyed Polarization –D LATCH OPTION (Metal latches for more rugged environments; –02, –05 & –10 positions only) –M = Single Ended, Metal Latches (Leave blank for plastic) = Double Ended (Latch Required) Double Ended (–D) Crossed requires MMSD/MMSDT –LUS –LDS = Plastic Latch down, straight MMSD, MMSDT, MMSS, MMSST = Color Coded Cable (MMSD & MMSS only) Board Mates: IPL1 (Does not mate with IPT1) –LUX –20C, –24C, –28C CABLE COLOR CODING –28C –30 No. of positions x (2.54) .100 + (1.40) .055 (8.97) .353 Teflon cable is intended for crimp only. Contact Samtec for solderable cable applications. = Assembly Length in Inches (82.55 mm) 03.25" min. END OPTION = Plastic Latch up, straight –26, –28 ® –“XX.XX” = 10 µ" (0.25 µm) Gold on contact, Tin on tail - –24C = Single Row Blue *Teflon® Cable (20, 24, 28, 30 AWG only) * Dupont™ Teflon® is a registered trademark of E.I. du Pont de Nemours and Company or its affiliates. ASSEMBLY LENGTH = Color Coded Cable (MMSD & MMSS only) (Standard sizes) Cable Mates: MMTD(T), MMTS(T) - –22, –24 –15, –16, –20, –25 MMSST PLATING OPTION –L –20 –04, –05, = Double Row Blue *Teflon® Cable (20, 24, 28, 30 AWG only) - WIRE GAUGE PIN COLOR 1 2 3 4 5 6 7 8 9 10 ETC BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GRAY WHITE BLACK REPEAT = Plastic Latch up, crossed –LDX Assembly Length ± (3.18) .125 = Plastic Latch down, crossed –MUS = Metal Latch up, straight –MDS = Metal Latch down, straight –MUX = Metal Latch up, crossed –MDX = Metal Latch down, crossed View complete specifications at: samtec.com?MMSD, samtec.com?MMSDT, samtec.com?MMSS & samtec.com?MMSST IPD1 - POSITIONS PER ROW –02, –03, –04, –05, –06, –08, –10, –12, –15, –16, –20, –25 (Standard sizes) - ROW OPTION –S = Single Row - - K –K = Keyed Polarization –D = Double Row LATCH OPTION SERIES –M CC79L = Metal Latch (Metal for more rugged environments) (–02, –05 & –10 positions only) = Contact, Loose CC79R = Contact, Full Reel (12,000 Parts per Reel) (Leave blank for plastic latch) - WIRE GAUGE 01 –2630 PLATING OPTION –L = 26 to 30 AWG = 10 µ" (0.25 µm) Gold on contact, Tin on tail –2024 = 20 to 24 AWG (17.93) .706 (12.83) .505 –S - - –D –M TOOLING Hand Tool: CAT-HT-179-2030-13 (20-30 AWG) Not: Some lengths, styles and options are non-standard, non-returnable. Mini Applicator: CAT-MC-179-2024-XX-01 (20-24 AWG) Mini Applicator: CAT-MC-179-2630 XX-01 (26-30 AWG) Extraction Tool: CAT-EX-179-01 View complete specifications at: samtec.com?IPD1, samtec.com?CC79L & samtec.com?CC79R samtec.com/minimate F-221 (Rev 21DEC21) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
CC79L-2830-01-L 价格&库存
很抱歉,暂时无法提供与“CC79L-2830-01-L”相匹配的价格&库存,您可以联系我们找货
CC79L-2830-01-L
  • 1+2.664151+0.34567
