Applicable standard
Operating
temperature range
-55C to + 105C (NOTE 1)
Operating
humidity range
Rating
20%
to 80%
(NOTE 2)
1000V AC/DC
Current(*1)
1
AWG10
40A
AWG12
31A
-10C to + 60C (NOTE 3)
40%
to 70%
(NOTE 3)
DF60(R)-*S-10.16C(##)
AWG 10-12
1
Rated voltage
Rated current
Overvoltage category
IP-Degree
UL
600V AC/DC
AWG10:55A/AWG12:45A
(At Ambient Temp.25℃)(Note 5)
C-UL
600V AC/DC
See above(*1)(Temp. rise up 30℃MAX)
600V AC/DC
See above(*1)
Ⅲ
IPOO
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
Voltage
Storage
temperature range
Storage
humidity range
Applicable
connector
Applicable
cable
TUV
Specifications
Item
Test method
REQUIREMENTS
QT
AT
X
X
X
X
X
X
Construction
General examination
Visually and by measuring instrument.
Marking
Confirmed visually.
According to drawing.
Electric characteristics
Contact resistance
millivolt level method
DC6V MAX, 1A
2m MAX.
Mechanical characteristics
Contact insertion and
extraction forces
Mechanical operation
1.0±0.002 by steel gauge.
Insertion force
Extraction force
12.0 N MAX.
2.0 N MIN.
30times insertions and extractions.
①Contact resistance: 2 m MAX.
②No damage, crack or looseness of parts.
X
Vibration
Frequency 10 to 500 Hz, total amplitude 1.5mm,
Acceleration 98m/s2, at 2h for 3 directions.
①No electrical discontinuity of 1μs.
X
Shock
490 m/s2 duration of pulse 11 ms at 3 times each for 3 both
axial directions.
X
Crimp tensile
strength
Apply wire tensile strength to caulking area axially until wire
become loosen or breakdown.
AWG10
AWG12
X
401N MIN
313N MIN
Environmental characteristics
Damp heat
(steady state)
Rapid change of
temperature
Exposed at 40 ± 2℃ , 90 to 95 %, 96 h.
X
Temperature -55℃→ +85℃
Time
30MIN→ 30MIN
Under 25 cycles.
(The transferring time of the tank is 2-3 MIN)
(After leaving the room temperature for 1-2h.)
X
Dry heat
Exposed at 105 ± 2℃, 250h
X
Remarks
Note1: Include the temperature rising by current.
Note2: No condensing.
Note3: Apply to the condition of long term storage for unused products before PCB on board .
After mounted on PCB board , operating temperature and humidity range is applied for interim storage during transportation.
Count
Description of revisions
8
DIS-H-00002440
Unless otherwise specifid , refer to IEC 60512.
1
Note QT:Qualification Test AT:Assurance Test X:Applicable Test
FORM HD0011-2-1
Designed
Checked
TS.KUMAZAWA
Approved
Part no.
Code no.
17.01.06
15.06.11
Checked
TS.FUKUSHIMA
15.06.10
Designed
TS.KUMAZAWA
15.06.10
Drawn
MI.SAKIMURA
15.06.09
Drawing no.
Specification sheet
TS.FUKUSHIMA
KI.AKIYAMA
Date
ELC-342869-00-00
DF60-1012SCA
CL680-3022-7-00
1
1/7
1
(Note 4)Derating curve takes manufacturing tolerances into consideration as well as uncertainties
in temperature measurement and the measuring set up and is derived from the basic curve
multiplied by 0.8 calculation.
(Note 5)The value of rated current differs depending on the ambient temperature.
It is recommended to use the product within the derating curve zone.
(Note 6) Measurement method of derating curve is shown below.
・Test specimen:Unused DF60-2P-10.16DS(27).
Unused DF60-2S-10.16C
Unused DF60-1012SCFA
・Test cable spec:AWG 10
・Test condition: Turn on electricity under the static state and measure.
(Test report # TR680E-20773)
[Reference]
Derating curve
Temperature rise curve
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC-342869-00-00
DF60-1012SCA
CL680-3022-7-00
1
2/7
1
(Note 7) Measurement method of derating curve is shown below.
・Test specimen:Unused DF60-3P-10.16DS(27).
Unused DF60-3S-10.16C
(Test report # TR680E-20802)
[Reference]
Derating curve
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC-342869-00-00
DF60-1012SCA
CL680-3022-7-00
1
3/7
1
(Note 8) Measurement method of derating curve is shown below.
・Test specimen:Unused DF60-6P-10.16DS(27).
Unused DF60-6S-10.16C
[Reference]
Derating curve
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC-342869-00-00
DF60-1012SCA
CL680-3022-7-00
1
4/7
1
(Note 9) Measurement method of derating curve is shown below.
・Test specimen:Unused DF60-1P-10.16DS(27).
Unused DF60-1S-10.16C
・Test cable spec:AWG 12
[Reference]
Derating curve
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC-342869-00-00
DF60-1012SCA
CL680-3022-7-00
1
5/7
1
(Note 10) Measurement method of derating curve is shown below.
[Reference]
Derating curve
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC-342869-00-00
DF60-1012SCA
CL680-3022-7-00
1
6/7
1
(Note 11) Measurement method of derating curve is shown below.
[Reference]
Derating curve
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC-342869-00-00
DF60-1012SCA
CL680-3022-7-00
1
7/7
很抱歉,暂时无法提供与“DF60-1012SCA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+7.39806100+0.89531
- 300+7.36349300+0.89113
- 500+7.36333500+0.89111
- 1000+7.363171000+0.89109
- 2000+7.363002000+0.89107
