DF1E-30PCF
DF1E-30PCF
    HRS(广濑)
    CONN PIN CRIMP 30AWG TIN
DF1E-30PCF 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. 2.5mm Pitch Connector for Full Lock and Discrete Wire Connection DF1E Series UL, C-CL Listed Full lock function added Inner-lock system full lock mechanism Mis-insertion prevention Photo 1 ■Features 1. Full Lock Function Added Double lock engaged The inner lock system adopts a full lock mechanism. This mechanism prevents disengagement to occur due to an unexpected external shock. (Refer to photo 1) Double lock engaged 2. Increase in Crimping Contact Fixation Force and Semi-insertion Prevention The double lock is activated for the use method to give a stress to the cable, to increase crimping contact fixation force, and to prevent the semi-insertion of the crimping contact. (Refer to photo 2) 3. Mold Lance Adopted Since the contact lance may be deformed involving in the contact after the crimping process, the mold lance has been adopted. 4. Mis-insertion Prevention Equipped with the mechanism to completely prevent reverse insertion and insertion between dissimilar contacts. 5. Means to Prevent Solder Crack The glass enforcement resin is adopted for the pin header to prevent a solder crack to occur due to heat compression. 6. Correspond to Potting Corresponding to potting, the pin header is provided for product variations. Corresponding to potting up to 8mm and mounting height 19.8mm (no retainer), the low profile is achieved. 7. Production Facility Cost Reduction The female crimping contact uses the DF1B series crimping contact, which has been conventionally marketed. Investment for new facilities isn't needed. However, if the retainer is installed in the cable with AWG#22 or more wire, use the DF1E crimping contact. The female crimping contact for in-line is used together with the DF1B applicator. Therefore, no investment is needed for new facilities. B146 Photo 2 8. Various Applications With the same series, various applications can be used for the board solder dip type and inline. 9. Listed by UL, C-UL ■Applications Electronic equipment, office machines, industrial equipment, and consumer equipment, and so on The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection ■Products Specifications Current rating Note 1. AWG#20 to 24 : 3A 26 : 2A 28 : 1A 30 : 0.5A Voltage rating 250VAC Rating Operating Temperature Range : -35 to +85ç Note 2. Operating Moisture Range : -40 to 80% Storage Temperature Range : -10 to +60ç Note 3. Storage Moisture Range : -40 to 70% Note 3. ■UL/C-UL File No. and Recognition No. UL :E52653 C-UL :E52653 C-UL Rating AWG#20 to #22 : 3A Current rating AWG#24 to #28 : 1A Rating AWG#30 Voltage rating : 0.5A 30V AC Item Specification Condition 1. Contact Resistance 30m ohms max. Measured at 20mV max. and 1mA 2. Insulation Resistance 1000M ohms min. 500V DC 3. Withstanding voltage No flashover or insulation breakdown. 650V AC/1 minute 4. Single Insertor/Extraction Forth MIN 0.29N, MAX 4.41N Measured at the square steel pin with 0.635±0.002 5. Durability (Mating/un-mating) 30m ohms max 30 cycles 6. Vibration No electrical discontinuity of 1µs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 7. Shock No electrical discontinuity of 1µs or more Acceleration of 490 m/s2, 11 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis 8. Humidity (Steady state) 30m ohms max 96 hours at temperature of 40±2ç and humidity of 90% to 95% 9. Temperature Cycle 30m ohms max. (-55ç: 30 minutes-> 5 to 35ç: 5 minutes-> 85ç: 30 minutes-> 5 to 35ç: 5 minutes) 5 cicles 10. Resistance to Soldering heat No deformation of components affecting performance. Flow: 260ç for 10 seconds Manual soldering: 300ç for 3 seconds Note 1: Current rating of header is 3A. Note 2: Includes temperature rise caused by current flow. Note 3: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 4: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Product Part Material Treatment Remarks Socket Insulator Polyamide White UL94V-0 Insulator Polyamide Beige UL94V-0 Contact Brass Tin-lead plated ––––––– In-line Plug Insulator Polyamide White UL94V-0 retainer Insulator Polyamide Black UL94V-0 Crimping contact Contact Phosphor copper Tin plated ––––––– Header B147 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection ■Ordering Information ●Pin Header DF1E C - * P - 2.5 DSA q w e r t y q Series Name : DF1E w Hold Types (Note. 1) Standard Product Potting With Boss C Without Boss With Boss G Without Boss e Number of Contacts : 2 to 15 contacts (note. 2) r Connector Type P : Pin Header t Contact Pitch : 2.5mm y Form type DSA : Straight through hole DS : Right Angle Type Note 1 : The right angle pin header has no symbol. Note 2 : The potting header has 2 to 10 contacts. ●Socket q Series Name : DF1E DF1E - * S - 2.5 C q w e r w Number of Contacts : 2 to 15 contacts t e Connector type S: Socket r Contact Pitch : 2.5mm t Form Type C : Crimping socket ●In-line Plug DF1E A - * EP - 2.5 C q w e r t y q Series Name : DF1E e Number of Contacts : 2 to 10 contacts w In-line Plug type r EP : In-line plug Blank: With Panel mount Lock t Contact Pitch : 2.5mm A : Without Panel mount Lock y Form Type C : Crimping socket ●Crimping Contact q Series Name : DF1E - ** SCF q w w Applicable Cable Size Socket side : DF1B (Note 1) e DF1E (Note 1) Plug side : DF1E 2022 : AWG#20 to #22 2428 : WG#24 to #28 30 : AWG#30 e Packaging Type SCF : Female contact : Reel SC : Female contact : Bag PCF : Male contact : Reel PC : Male contact : Bag Note 1 : When the retainer is used, use DF1E-2022SC(F), DF1B2428SC(F), and DF1B-30SC(F) contacts. Note 1 : When no retainer is used, all DF1B-**SC(F) and DF1E2022SC(F) contacts can be used. ●Retainer DF1E - * RS/P - 2.5 q w e r q Series Name : DF1E w Number of Contacts : 2 to 10 contacts e Connector Type RS/P : Retainer Commonly used for socket and in-line plug r Contacts Pitch:2.5mm B148 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection ■Application Pattern Socket Retainer Photo : Contact Inserted Pin Header ●Straight Type In-line Plug ●In-line Plug (Panel Mount Lock Type) Photo: Contact Inserted ●Straight Potting Type ●In-line Plug Photo: Contact Inserted ●Right Angle Type B149 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection ■Right Angle Pin Header Contact No. mark 10 Mold Cavity No. mark 5.9 A 2.9 0.5 8 6.95 5.4 M 0.64 P=2.5 A Contact No.1 indicated 8.3 4.5 10.8 13.8 B 3.2 Note 2 Part Number CL No. Number of Contacts A B DF1E –02P–2.5DS(**) 541 – 0985– 0 –** 2 02.5 07.5 DF1E –03P–2.5DS(**) 541 – 0986– 3 –** 3 05.0 10.0 DF1E –04P–2.5DS(**) 541 – 0987– 6 –** 4 07.5 12.5 DF1E –05P–2.5DS(**) 541 – 0988– 9 –** 5 10.0 15.0 DF1E –06P–2.5DS(**) 541 – 0989– 1 –** 6 12.5 17.5 DF1E –07P–2.5DS(**) 541 – 0990– 0 –** 7 15.0 20.0 DF1E –08P–2.5DS(**) 541 – 0991– 3 –** 8 17.5 22.5 DF1E –09P–2.5DS(**) 541 – 0992– 6 –** 9 20.0 25.0 DF1E –10P–2.5DS(**) 541 – 0993– 9 –** 10 22.5 27.5 DF1E –11P–2.5DS(**) 541 – 0994– 1 –** 11 25.0 30.0 DF1E –12P–2.5DS(**) 541 – 0995– 4 –** 12 27.5 32.5 DF1E –13P–2.5DS(**) 541 – 0996– 7 –** 13 30.0 35.0 DF1E –14P–2.5DS(**) 541 – 0997– 0 –** 14 32.5 37.5 DF1E –15P–2.5DS(**) 541 – 0998– 2 –** 15 35.0 40.0 RoHS [Specific No.] –* *, (* *) (01): Gold plated (05): Tin plated Yes Note 1. : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the products per bag. However, the quantity for delivery will be changed according to the Specific No. Note 2. : The 2 to 4 contacts differ in two convex portions from those in above figures. The 2 and 3 contacts are not contained, but the 4 contact connector is contained in the center at one point. Note 3. : Styles of 2 to 4 contact connectors partially differ from those in above figures. BPCB mounting pattern (Board Thickness t = 1.6 ± 0.1) A±0.1 P = 2.5±0.05 * – Ø1 .1 + 0 B150 0. 1 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection ■Straight Pin Header Contact No. mark 10 Mold Cavity No. mark 5.9 A 0.5 8 6.95 5.4 P=2.5 A Contact No.1 indicated 3.6 10.8 8.3 4.5 B M 0.64 3.2 Note 2 Part Number CL No. Number of Contacts A B DF1EC–02P–2.5DSA(**) 541– 0867– 4 –** 2 02.5 07.5 DF1EC–03P–2.5DSA(**) 541– 0868– 7 –** 3 05.0 10.0 DF1EC–04P–2.5DSA(**) 541– 0869– 0 –** 4 07.5 12.5 DF1EC–05P–2.5DSA(**) 541– 0870– 9 –** 5 10.0 15.0 DF1EC–06P–2.5DSA(**) 541– 0871– 1 –** 6 12.5 17.5 DF1EC–07P–2.5DSA(**) 541– 0872– 4 –** 7 15.0 20.0 DF1EC–08P–2.5DSA(**) 541– 0873– 7 –** 8 17.5 22.5 DF1EC–09P–2.5DSA(**) 541– 0874– 0 –** 9 20.0 25.0 DF1EC–10P–2.5DSA(**) 541– 0875– 2 –** 10 22.5 27.5 DF1EC–11P–2.5DSA(**) 541– 0876– 5 –** 11 25.0 30.0 DF1EC–12P–2.5DSA(**) 541– 0877– 8 –** 12 27.5 32.5 DF1EC–13P–2.5DSA(**) 541– 0878– 0 –** 13 30.0 35.0 DF1EC–14P–2.5DSA(**) 541– 0879– 3 –** 14 32.5 37.5 DF1EC–15P–2.5DSA(**) 541– 0880– 2 –** 15 35.0 40.0 RoHS [Specific No.] –* *, (* *) (01): Gold plated (05): Tin plated Yes Note 1. : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the products per bag. However, the quantity for delivery will be changed according to the Specific No. Note 2. : The 2 to 4 contacts differ in two convex portions from those in above figures. The 2 and 3 contacts are not contained, but the 2 and 3 contacts are not contained, and 4 contact is in the center at one point. Note 3. : Styles of 2 to 4 contacts partially differ from those in above figures. BPCB mounting pattern (Board Thickness t = 1.6 ± 0.1) A±0.1 P = 2.5±0.05 * – Ø1 .1 + 0 0. 1 B151 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection 5.4 Contact No. mark Mold Cavity No. mark A 10 5.9 C 6.95 ■Straight Pin Header for Potting P=2.5 A B 8.3 16.3 M 0.64 3.2 3 4.5 Contact No.1 indicated Note 2 Note 2 Part Number CL No. Number of Contacts A B C DF1EG –02P–2.5DSA(**) 541 – 0923 – 3** 2 02.5 07.5 8.0 DF1EG –03P–2.5DSA(**) 541 – 0924 – 6** 3 05.0 10.0 8.0 DF1EG –04P–2.5DSA(**) 541 – 0925 – 9** 4 07.5 12.5 8.0 DF1EG –05P–2.5DSA(**) 541 – 0926 – 1** 5 10.0 15.0 7.8 DF1EG –06P–2.5DSA(**) 541 – 0927 – 4** 6 12.5 17.5 7.8 DF1EG –07P–2.5DSA(**) 541 – 0928 – 7** 7 15.0 20.0 7.8 DF1EG –08P–2.5DSA(**) 541 – 0929 – 0** 8 17.5 22.5 7.8 DF1EG –09P–2.5DSA(**) 541 – 0930 – 9** 9 20.0 25.0 7.8 DF1EG –10P–2.5DSA(**) 541 – 0931 – 1** 10 22.5 27.5 7.8 DF1EG –11P–2.5DSA(**) 541 – 0932 – 4** 11 25.0 30.0 7.8 RoHS [Specific No.] –* *, (* *) (05): Tin plated Yes Note 1. : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. However, the quantity for delivery will be changed according to spec number. Note 2. : The 2 to 6 and 9 to 10 contact connectors differ in two convex portions from those in above figures. The 2 to 5 and 9 to 10 contacts are not contained, but the 6 contact is bonded to the convex portion at both ends. Note 3. : Styles of 2 to 4 contact may partially differ from the above figures. BPCB mounting pattern (Board Thickness t = 1.6 ± 0.1) A±0.1 P = 2.5±0.05 * – Ø1 .1 + 0 B152 0. 1 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection ■In-line Plug (Panel Mount Lock Type) 2.8 A 0.9 10 A 6.9 8.1 2.8 B P=2.5 Mold Cavity No. mark Contact No. mark Contact No.1 indicated 12 18.8 C 10 Contact No. mark 9 7 5 3 1 Contact No. mark Note 2 Photo: Contact Inserted. Note 3 Part Number CL No. Number of Contacts A B C DF1E–02EP–2.5C 541– 0943– 0 DF1E–03EP–2.5C 541– 0944– 3 DF1E–04EP–2.5C DF1E–05EP–2.5C D E 2 8.0 2.5 3 10.5 5.0 15.0 8.4 11.9 17.5 10.9 14.4 541– 0945– 6 4 13.0 541– 0946– 9 5 15.5 7.5 20.0 13.4 16.9 10.0 22.5 15.9 19.4 DF1E–06EP–2.5C 541– 0947– 1 6 18.0 DF1E–07EP–2.5C 541– 0948– 4 7 20.5 12.5 25.0 18.4 21.9 15.0 27.5 20.9 24.4 DF1E–08EP–2.5C 541– 0949– 7 8 DF1E–09EP–2.5C 541– 0950– 6 9 23.0 17.5 30.0 23.4 26.9 25.5 20.0 32.5 25.9 29.4 DF1E–10EP–2.5C 541– 0951– 9 10 28.0 22.5 35.0 28.4 31.9 RoHS Yes Note 1. : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the products per bag. However, the quantity for delivery will be changed according to the Specific No. Note 2. : In regard to 2 to 5 contacts, the retainer fixed convex portions are located at both ends. Note 3. In regard to 2 to 7 contacts, 2 convex portions are different from those in the above figures. Note 4. Use the no radius side at the panel edge in the looking area. Note 5. : Panel fixation is loosened. (May be enlarged according to the panel board thickness.) Note 6. : Styles of 2 to 4 contact partially differ from those in the above figures. * Refer to page B156 for the retainer. BPanel Cutout (E+X) Panel Thickness X 1.7 to 2.0 1.5 1.3 to 1.6 1.0 0.9 to 1.2 0.5 0.7 to 0.8 0.0 5.8 +0.2 0 1.1 +0.1 0 D +0.1 0 +0.1 0 Note 4 4.2±0.05 3.5 +0.1 0 +0.1 8.4 0 Panel B153 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection ■In-line Plug A B 0.9 P=2.5 Mold Cavity No. mark Contact No. mark A 6.9 8.1 10 Contact No.1 indicated 18.8 Photo: Contact Inserted 10 9 7 5 1 3 Contact No. mark Note 2 Contact No. mark Note 3 Part Number CL No. Number of Contacts A B DF1EA –02EP–2.5C 541 – 0957 – 5 2 08.0 02.5 DF1EA –03EP–2.5C 541 – 0958 – 8 3 10.5 05.0 DF1EA –04EP–2.5C 541 – 0959 – 0 4 13.0 07.5 DF1EA –05EP–2.5C 541 – 0960 – 0 5 15.5 10.0 DF1EA –06EP–2.5C 541 – 0961 – 2 6 18.0 12.5 DF1EA –07EP–2.5C 541 – 0962 – 5 7 20.5 15.0 DF1EA –08EP–2.5C 541 – 0963 – 8 8 23.0 17.5 DF1EA –09EP–2.5C 541 – 0964 – 0 9 25.5 20.0 DF1EA –10EP–2.5C 541 – 0965 – 3 10 28.0 22.5 RoHS Yes Note 1. : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the products per bag. However, the quantity for delivery will be changed according to the Specific No. Note 2. : In regard to 2 to 5 contacts, the retainer fixed convex portions are located at both ends. Note 3. : 2 to 7 contacts do not contain two convex portions, which is different from the above figure. Note 4. : Styles of 2 to 4 contacts partially differ from the above figures. * Refer to page B156 for retainer. B154 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection 4.55 ■Socket P=2.5 A B C 8.5 11.8 Note 2 Photo: Contact Inserted 10 1 Contact No.1 indicated Contact No. mark 7.55 A Mold Cavity No. mark Note 3 Note 3 Note 4 Note 4 Part Number CL No. Number of Contacts A B C DF1E –02S–2.5C 541 – 0811 – 0 2 02.5 08.0 05.4 DF1E –03S–2.5C 541 – 0812 – 2 3 05.0 10.5 07.9 DF1E –04S–2.5C 541 – 0813 – 5 4 07.5 13.0 10.4 DF1E –05S–2.5C 541 – 0814 – 8 5 10.0 15.5 12.9 DF1E –06S–2.5C 541 – 0815 – 0 6 12.5 18.0 15.4 DF1E –07S–2.5C 541 – 0816 – 3 7 15.0 20.5 17.9 DF1E –08S–2.5C 541 – 0817 – 6 8 17.5 23.0 20.4 22.9 DF1E –09S–2.5C 541 – 0818 – 9 9 20.0 25.5 DF1E –10S–2.5C 541 – 0819 – 1 10 22.5 28.0 25.4 DF1E –11S–2.5C 541 – 0820 – 0 11 25.0 30.5 27.9 DF1E –12S–2.5C 541 – 0821 – 3 12 27.5 33.0 30.4 DF1E –13S–2.5C 541 – 0822 – 6 13 30.0 35.5 32.9 DF1E –14S–2.5C 541 – 0823 – 9 14 32.5 38.0 35.4 DF1E –15S–2.5C 541 – 0824 – 1 15 35.0 40.5 37.9 RoHS Yes Note 1. : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the products per bag. However, the quantity for delivery will be changed according to spec number. Note 2. : The 2 contact connector is equipped with the convex portion to prevent false-insertion. Note 3. : The 2 consult Has no wall on the locking side Note 4. : The 2 to 5 contacts contain the retainer fixed convex portions at both ends. * Refer to page B156 for the retainer. B155 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection ■Retainer A 1.9 B 1.7 P = 2.5 1.5 3.3 5.9 0.7 Note2 Note2 Contact No. mark A1 0 Mold Cavity No. mark Part Number CL No. Number of Contacts A B DF1E –02RS/P–2.5 541 – 0971 – 6 2 08.0 02.5 DF1E –03RS/P–2.5 541 – 0972 – 9 3 10.5 05.0 DF1E –04RS/P–2.5 541 – 0973 – 1 4 13.0 07.5 DF1E –05RS/P–2.5 541 – 0974 – 4 5 15.5 10.0 DF1E –06RS/P–2.5 541 – 0975 – 7 6 18.0 12.5 DF1E –07RS/P–2.5 541 – 0976 – 0 7 20.5 15.0 DF1E –08RS/P–2.5 541 – 0977 – 2 8 23.0 17.5 DF1E –09RS/P–2.5 541 – 0978 – 5 9 25.5 20.0 DF1E –10RS/P–2.5 541 – 0979 – 8 10 28.0 22.5 RoHS Yes Note 1. : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the products per bag. However, the quantity for delivery will be changed according to spec number. Note 2. : The 2 to 4 contacts contain socket and plug fixed holes at both ends. * This retainer can be used together with the socket and relay plug. B156 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection ■Plug Crimping Contact 0.68 2 1.2 2.4 18.9 13.9 0.64 ●Applicable Cable (Tin plating annealed copper wire) ●Recommended Cable UL1061, UL1007 Conductor Size (Wire construction) ●Strip Length AWG # 20 (21 cores./0.18mm) 3.0 to 3.7mm Note : If other cables are used instead of the applicable cable, contact Hirose sales department. AWG # 22 (17 cores./0.16mm) AWG # 24 (11 cores./0.16mm) AWG # 26 (07 cores./0.16mm) AWG # 28 (07 cores./0.127mm) AWG # 30 (07 cores./0.1mm) Part Number CL No. DF1E – 2022PCF 541 – 0937 – 8 DF1E – 2022PC 541 – 0938 – 0 DF1E – 2428PCF 541 – 0939 – 3 DF1E – 2428PC 541 – 0940 – 2 DF1E – 30PCF 541 – 0941 – 5 DF1E – 30PC 541 – 0942 – 8 Applicable Cable Applicable Cable Indication AWG Jacket Diameter 20 22 AWG # 20 AWG # 22 1.2 to 1.9mm 24 28 AWG # 24 AWG # 28 0.9 to 1.5mm 30 AWG # 30 0.6 to 1.2mm Packaging Type Quantity Reel 10,000 Bag 100 Reel 10,000 Bag 100 Reel 10,000 Bag 100 RoHS Yes ● Crimping Contact Extraction Tool DF-C-PO(B) B157 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection ■Socket Crimping Contact ●DF1E-2022SCF ●DF1B - * * * * SCF 1.75 1.75 0.975 1.95 1.4 Applicable cable indicated 0.83 1.95 2.5 9.5 14 9.4 3.35 2.55 Applicable cable indicated 1.6 1.4 1.4 2.4 1 6.1 12.9 1.6 0.55 ●Applicable Cable (Tin plating annealed copper wire) ●Recommended Cable UL1061, UL1007 Conductor Size (Wire construction) ●Strip Length AWG # 20 (21 cores./0.18mm) 2.0mm to 2.5mm Note : If other cables are used instead of the applicable cable, consult Hirose sales department. AWG # 22 (17 cores./0.16mm) AWG # 24 (11 cores./0.16mm) AWG # 26 (07 cores./0.16mm) AWG # 28 (07 cores./0.127mm) AWG # 30 (07 cores./0.1mm) Part Number CL No. DF1E – 2022SCF 541 – 0999 – 5 DF1E – 2022SC 541 – 1000 – 2 DF1B – 2022SCF 541 – 0223 – 1 DF1B – 2022SC 541 – 0224 – 4 DF1B – 2428SCF 541 – 0678 – 1 DF1B – 2428SC 541 – 0679 – 4 DF1B – 30SCF 541 – 0682 – 9 DF1B – 30SC 541 – 0683 – 1 AWG Jacket Diameter 20 22 AWG # 20 AWG # 22 1.2 to 1.9mm 20 22 AWG # 20 AWG # 22 1.2 to 1.9mm 24 28 AWG # 24 AWG # 28 0.9 to 1.5mm 30 AWG # 30 0.6 to 1.2mm ● Crimping Contact Extraction Tool DF-C-PO(B) B158 Applicable Cable Applicable Cable Indication Packaging Type Quantity Reel 10,000 Bag 100 Reel 10,000 Bag 100 Reel 10,000 Bag 100 Reel 10,000 Bag 100 RoHS Yes The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection BCrimping Tools Item Part Number CL No. 901 – 4561 – 0 DF1E – 2022SCF AP105 – DF1B – 2022S K K 901 – 4510 – 9 DF1B – 2022SCF AP105 – DF1B – 2428S K K 901 – 4518 – 0 DF1B – 2428SCF AP105 – DF1B – 30S K K 901 – 4517 – 8 DF1B – 30SCF AP105 – DF1B – 2022P K K 901 – 4509 – 0 DF1E – 2022PCF AP105 – DF1B – 2428P K K 901 – 4521 – 5 DF1E – 2428PCF AP105 – DF1B – 30P K K 901 – 4519 – 3 DF1E – 30PCF CM – 105 K K 901 – 0005 – 4 AP105 – DF1E – 2022S Applicator Main Press Unit HT102/DF1E – 2022S Manual Crimping Tool Contact Extraction Tool Applicable Contact –––––– 550 – 0277 – 1 DF1E – 2022SC DF1B – TA2022SHC K K 550 – 0182 – 7 DF1B – 2022SC DF1B – TA2428SHC K K 550 – 0209 – 1 DF1B – 2428SC DF1B – TA30SHC K K 550 – 0211 – 3 DF1B – 30SC HT102/DF1BE – 2022P 550 – 0278 – 4 DF1E – 2022PC HT102/DF1BE – 2428P 550 – 0279 – 7 DF1E – 2428PC HT102/DF1BE – 30P 550 – 0280 – 6 DF1E – 30PCF DF – C – PO (B) 550 – 0179 – 2 DF1E – 2022SC (F) DF1B – * * * * SC (F) DF1E – * * * * PC (F) K " to the last number of the product, in order to use DF1B series tools, which have been conventionally merchandized. Note 1. : Add "K Note 2. : If any trouble has occurred due to other tools, which are not designated by Hirose, Hirose won't guarantee any products. B159 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection BApplication Pattern ●Standard Header 8.5 DF1E _ * S _ 2.5 C DF1E _ * RS / P _ 2.5 DF1E# _ * P _ 2.5 DSA 18.8 17.3 DF1E _ * P _ 2.5 DS (**) 8.5 14.3 15.8 DF1E _ * RS / P _ 2.5 DF1E _ * S _ 2.5 C 3.7 10.8 3 14.3 ●Header for Potting 8 DF1E _ * S _ 2.5 C DF1E _ * RS / P _ 2.5 11.7 8 MAX 19.8 21.3 Potting Resin DF1E# _ * P _ 2.5 DSA 3.2 ●Panel Mounting Lock In-line Plug ●In-line Plug 25.3 25.3 17 DF1E _ * RS / P _ 2.5 DF1E _ * RS / P _ 2.5 DF1E _ * S _ 2.5 C DF1E _ * RS / P _ 2.5 DF1E _ * S _ 2.5 C DF1EA _ * EP _ 2.5 C DF1E _ * EP _ 2.5 C 15.5 22.3 B160 9 9 8.1 Panel DF1E _ * RS / P _ 2.5 22.3 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF1E Series●2.5mm Pitch Connector for Full Lock and Discrete Wire Connection BPrecautions 1. Recommended Soldering Condition Flow: 260ç for 10 seconds Manual soldering: 300ç for 3 seconds 2. Cleaning Condition Refer to Nylon Connector Use Hand book. However, if the connector is cleaned by the potting header, the detergent remains within the connector, which will cause malfunction. 3. Connection Condition Refer to Nylon Connector Use Hand book. 4. Cautions ● To remove the connector, if the connector is forcedly removed, it will cause connector damage. If the connector is hardly removed, slightly push the connector once, and then remove it using the lock. ● In some method for laying the cable within equipment, a tension may be applied to the cable so as to remove the contact. In this case, it is recommended to use the retainer. ● Incomplete insertion of the contact can be prevented by mounting a retainer; however, mounting of a retainer might not be possible when the contact protrudes beyond the socket. Insert the contact securely and then mount the retainer. ● If the potting process is implemented, it is desirable to fill the connector with resin, considering the resin surface tensile force. ● The color phase of this product may be slightly different from that of the forming product according to the manufacturing lot and future storage conditions, however the difference doesn't affect the performance. 5. Precautions Refer to Nylon Connector Use Hand book. B161
DF1E-30PCF 价格&库存
很抱歉,暂时无法提供与“DF1E-30PCF”相匹配的价格&库存,您可以联系我们找货
