SWT120-UPEG-S01-UU-UU
    SULLINS
    CONN SOCKET 28-32AWG TIN
SWT120-UPEG-S01-UU-UU 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2002 INITIAL RELEASE 7/17/2009 JH F F 0.150 .0059 1.40±0.25[.055 .010] E E 1.70±0.25[.067 .010] 0.61±0.20[.024 .008] SEC:A-A D A 0.71±0.20[.028 .008] A D 3.30±0.25[.130 .010] B B 1.05±0.25 .041±.010 1.00±0.10[.039 .004] 0.75±0.15[.030 .006] 0.05±0.05[.002 .002] 0.00 1.00±0.25 .039±.010 SEC:B-B +.000 0.35 - 0.10 .014 - .004 C C 1.40±0.10[.055 .004] 0.45±0.10[.018 .004] 0.90±0.10[.035 .004] B A B NOTES: 1. MATERIAL: PHOSPHOR BRONZE. 2. PLATING: SEE PART NUMBER CODING. 3. WIRE RANGE: AWG #28 - #32. 4. INSULATION O.D.: 1.00mm MAX. 5. QUANTITY PER REEL = 15,000 PIECES. 6. USED IN SWH120 SERIES HOUSING. 8 7 UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN IN MM[INCH] TOLERANCES: ANGULAR: 30' .X= .3 [.01] .XX= .15 [.006] .XXX= .050 [.0020] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 6 5 4 DRAWN NAME 7/17/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. CRIMP TERMINAL - SWH120 SWT120-UP_G-S01-UU-UU SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 11290 A SCALE: 20:1 2 SHEET 1 OF 1 1 FILE NAME: Z:\ECO PENDING\2002, wafer 120 series\11290, SWT120-UP_G-S01-UU-UU PRINT: 9/23/2009 A
SWT120-UPEG-S01-UU-UU 价格&库存
很抱歉,暂时无法提供与“SWT120-UPEG-S01-UU-UU”相匹配的价格&库存,您可以联系我们找货
