Interface Connectors for Portable Terminal Devices
ST Series
Strong locking mechanism
Right
Mating axial direction
Left
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Top
49N max.
Overview
The ST Series interface connectors are specifically
designed for use as Input/Output (I/O) connectors on
portable information devices. They feature a unique
structure with high strength which resists deformation
and helps to prevent improper mating.
3.0 mm height and 0.5 mm contact pitch connector
prevents EMI as well.
The ST Series can be used in wide range of applications
such as DSC, PDA, laptop PCs, cellular phones, etc.
Bottom
Fig.1
Prevention against reversed or angle insertion
Polarization keys
Contacts are not damaged!
Features
1. Strong locking mechanism
To assure continuous reliability of the connection in
an unpredictable consumer environment, mated
connectors will withstand pull force of 49N max.
applied in any direction. (Fig.1)
2. Prevention against reversed or angle
insertion
Multiple polarization keys will not allow incorrect
insertion of the mating plug.
In addition, contacts will not be damaged when the user
attempts to insert only the corner of the mating plug. (Fig.2)
3. Optimal I/F for Small Devices
Plugs are 8 mm in height and 20 mm long (including
covers), which is appropriate for small devices.
Receptacles feature the low height of 3 mm and the
contact pitch of 0.5 mm. Their small size saves
valuable space and contributes to a smaller device set.
Fig.2
Plug variations
Identification surface
Reverse plug
4. Multiple Variations
A wide variations is available for supporting different
types of peripheral devices. Examples include shielded
plugs for data communication, non-shielded plugs for
power charge, reversed plug types as shown in Fig.3
and cradle type connectors.
Standard plug
Fig.3
5. Cable Options
This connector uses a solder type termination,
which allows you to apply flexible cable types.
Applications
Digital Still Cameras, Personal Digital Assistance,
Notebook computers, Cellular phones, Smart
phones and other portable devices requiring high
reliability small size input/output connection.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2016.9④
1
ST Series●Interface Connectors for Portable Terminal Devices
Product Specifications
Rating
Current rating 0.5A (1 A max. can be carried via 4 random contacts)
Operating temperature range
: -30ç to +80ç
Voltage rating
Storage temperature range
: -40ç to +85ç (Note)
100V AC
Characteristic
Specification
11. Contact resistance
12. Insulation resistance
13. Dielectric withstanding voltage
14. Mating/un-mating forces
15. Durability
(mating/un-mating)
16. Shock
Conditions
60mø max.
1,000Mø min.
No flashover or insulation breakdown.
Mating : 29.4N max.
100mA DC
250V DC
350V AC/ 1 minute
With corresponding connector.
Contact resistance : 100mø max.
10,000 cycles
Acceleration of 490 m/s2, 11 ms duration, sine half-wave
waveform, 3 cycles in each of the 3 axis.
Temperature : -55ç ➝ +5ç to +35ç ➝ +85ç ➝ +5ç to +35ç
Time (Minutes) : -30 ➝ +5
➝ +30 ➝ +5
5 cycles
5±1% salt water solution at 35±3ç for 48 hours, after
washing without salt, leave for 24 hours at room temperature
No electrical discontinuity of 10µ sec. max.
17. Temperature cycle
Insulation resistance : 1,000Mø min.
18. Salt spray
No corrosions
19. Lock strength
Fully inserted and locked corresponding connector.
Pull force : 49N max. applied in each of the 4 axis.
No physical damage or electrical failure.
Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2
hours, 3 axis.
10. Vibration
Note: Includes temperature rise caused by current flow.
Materials / Finish
● Receptacles and cradles
Component
Material
Finish
Remarks
Insulator
Thermoplastic compound, glass reinforced
Color: Black
UL94V-0
Contacts
Copper alloy
Contact area: Gold plated
Shield
Stainless steel
Tin alloy plating
● Plugs
Component
Material
Finish
Remarks
Insulator
Color: Black
UL94V-0
Contacts
Copper alloy
Shield
Stainless steel
Cover
UL94V-0
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
● Receptacles
q Series name
w Termination type
ST 60 - 18 P (30)
q
w
r
t
u
● Plugs
e
ST 40 X - 18 S - CVR (30)
q
w
e
r
t
y
u
r
t
● Plug - Cradle type
ST 80 X - 18 S (30)
q
w
e
r
t
y
u
u
2
60
40
80
Shield
X
Blank
Number of contacts
Contact type
P
S
Plug type
CV
CVR
CV1
RoHS compliant
: ST
: Right angle SMT
: Solder type
: Cradle, vertical, SMT
: With shield
: Without shield
: Male contact (Receptacle)
: Female contact (Plug)
: Standard type, for top PCB mount
: Reverse type, for bottom PCB mount
: For larger diameter cables
: (30)
Recommended PCB
mounting pattern
Receptacle
10 pos.
10.5
4.5
0.5
E2%#*
(#&b^c
6.4
7
No.10
ST60
0.3
0.75
RoHS
(4)
3
Packaging
1,500pcs/reel
G%
1.5
(4.4)
10.1
18 pos.
Recommended PCB
mounting pattern
RoHS
14.1
2
2.8 3.6
PCB edge
0.6(Through hole)
1.9(Land)
14.1
0.3
0.75
Packaging
1,500pcs/reel
0.9
.3 2.7
R0.
85
No.18
ST60
Part No.
HRS No.
ST60-18P(30) 241-0011-9 30
1
6.6(Land)
R0
13.2
No.1
0.3(Land)
3.1
6.9
7.5
(0.58)
15.5
8.5
0.5
1.6
1.9
14.5
8.5
0.5 0.18
(4)
3
1.5
4.4
24 pos.
Recommended PCB
mounting pattern
0.18
(18.5)
16.2
No.1
RoHS
17.1
2
2.8 3.6
9.6(Land)
17.1
PCB edge
0.6(Through hole)
1.9(Land)
0.3
1.5
4.4
0.75
Packaging
1,500pcs/reel
1
No.24
ST60
Part No.
HRS No.
ST60-24P(30) 241-0003-0 30
11.5
0.5 0.3(Land)
3.1
R
R0 0.3 2.71.6
.85
1.9
(0.58)
6.9
7.5
0.5
0.9
17.5
11.5
(4)
3
36 pos.
Packaging
1,500pcs/reel
RoHS
1.8
2.35
R0
.3
R1 5
2.45(Land)
9.25
24.6
1.45
3.05
PCB edge
0.7(Through hole)
2(Land)
No.36
No.1
ST60
0.3
24.6
1.5
5
0.75
HRS No.
ST60-36P(30) 241-0033-1 30
19
2 0.35(Land)
(0.58)
(26)
23.5
Part No.
0.5
3.65
3.25
0.18
7
7.5
0.5
25
19
2
1.7
2.1
Recommended PCB
mounting pattern
(4.06)
3
Part No.
HRS No.
ST60-10P(30) 241-0022-5 30
dj\
]g
#(I
G%
9.2
No.1
Z
]da
(0.58)
(11.5)
0.18
3
36 pos. reverse type
Recommended PCB
mounting pattern
No.1
No.36
ST60
Plug – cradle type(Horizontal)
1.5
5
0.3
24.6
0.75
RoHS
(4.06)
3
Packaging
1,500pcs/reel
1.45
(0.58)
(26)
23.5
Part No.
HRS No.
ST60-36PR(30) 241-0036-0 30
PCB edge
0.7(Through hole)
2(Land)
1.8
2.35
2.45(Land)
9.25
24.6
3.05
1.7
2.1
0.18
7
7.5
0.5
3.65
R0
.35 3.25
R1
25
19
2
19
2 0.35(Land)
0.5
13.78
18 pos.
Recommended PCB
mounting pattern
5)
3.575
3.85(max)
0.9
P=0.5
PCB edge
Ø1
Connector positioning
14.5
.5
11.6
1.45(Land)
.72
(R0
1.475
0.75 2.95
1.7
3.1
2.5
ole
(h
1.5
7.95(min)
0.85(Through hole)
15.55
14.5
25
4
0.
(R 8.5
0.32(Land)
1.75
RoHS
0.05 1.8
1.5(hole)
Packaging
900pcs/reel
0.25
3.575
0.9
1.35
Part No.
HRS No.
ST60X-18S(30) 241-0028-1 30
0.15 0.5
8.5
1.5
3.05
9.05
(13.65)
0.25
Ø1
.3
1.25
2.25
11.6
15.55
1.375
1.475
17
15.8
No.1
No.18
RoHS
0.15
19
24.95
0.5
Recommended PCB
mounting pattern
26
24.95
1.5
2.1
le) 0.05
0.5
19
2 0.32(Land)
3.1
2.5
Connector
positioning
4
22.05
1.25
3.55(max)
Ø1
.7
(ho
PCB edge
7.75(min)
0.85(Through hole)
1.45(Land)
Packaging
900pcs/reel
0.25
4.475
0.9
4.475
Part No.
HRS No.
ST60X-36S(30) 241-0035-7 30
Ø1
.3
0.9
1.4 9.05
(13.65)
0.25
22.05
26
1.475
0.75
No.1
1.375
No.36
1.475
24.25
27.5
(2.95)
36 pos.
Plug – cradle type(Vertical)
11.3
11.3
4
1.5
No.10
0.15
2.6 2.6
4
2.62.6
7.8
5.5
No.2
1
1.75
RoHS
1
1.75
R0.5
R0.3
1.15
9.6
2.1
2.5
10.3
11.2
0.25
6
4
1.5
10.3
Recommended PCB
mounting pattern
18 pos.
14.9
1.5
14.9
8
1.6
8.8
2.875
0.9(Land)
0.5(Through hole)
Ø1.3
0.15
2.825
0.25
2.875
.1
R2
No.17
2
2.4
45
le)
1.1
9.6
1.5
R0.
1
4.25
8
13.6
14.2
25.7
ho
7.8
6
Ø1
.5(
RoHS
5.5
55
25
No.1 1
4.25
8
ho
R0.
2
Packaging
400 pcs/reel
1.1
le
3.75
1
Ø4
(18)
27.6
25.7
8
3.75
1 0.2 No.18
No.18
No.2
No.1
Part No.
HRS No.
ST80X-18S(30) 241-0020-0 30
2.825
0.5(Land)
ST80
1.5
13.6
14.2
A
4.15
5.6
1
5.75
11
R1.8
No.23
5
.4
R0.2
R0
5.25
1
4.8
8.8
1.15
2.6
0.15
1.25
4.15
Ø1.3
6
9.6
1
5.75
11
9.6
16.2
17.2
27
2.1
2.5
0.25
No.1
No.24
No.24
6
7.8
e)
ol
(h
6
Ø1 0.5(Land)
le)
(ho
Ø4 .5
3
R0
R0.
RoHS
ST80
Packaging
400 pcs/reel
(20.7)
29.9
27
11
5.25
No.2 1 0.2
No.1
1(Land)
A
Part No.
HRS No.
ST80X-24S(30) 241-0037-2 30
2.4
2
0.75
2.6 2.6
1.5
0.5(Through hole)
0.9(Land)
17.2
0.6(Through hole)
0.75
17.2
11
5
Recommended PCB
mounting pattern
24 pos.
9.6
1.6
No.9
No.10
ST80
Packaging
400pcs/reel
0.2
Ø1.3
2.25
1
No.1
No.1
Part No.
HRS No.
ST80X-10S(30) 241-0030-3 30
8.8
4.8
16
11.2
4
2.4
2
2
2.25
1
R0.45 0.5
R0.25 (Land)
Ø1.6(hole)
0.5(Through hole)
0.9(Land)
Recommended PCB
mounting pattern
0.6(Through hole)
1(Land)
10 pos.
A
1.25
1.5
16.2
17.2
5
Plug
10 pos. (Non-shielded type)
7
6
19.5
16
16
Part No.
HRS No.
Packaging RoHS
ST40-10S-CV(30) 241-0021-2 30
1
No.1
No.10
10 pos. (Reverse, non-shielded type)
7
6
19.5
16
16
Part No.
HRS No.
Packaging RoHS
ST40-10S-CVR(30) 241-0040-7 30
1
No.1
No.10
10 pos. (Shielded type)
7
6
19.5
16
16
Part No.
HRS No.
Packaging RoHS
ST40X-10S-CV(30) 241-0041-0 30
1
No.1
No.10
10 pos. (Reverse, shielded type)
7
6
19.5
16
16
Part No.
HRS No.
Packaging RoHS
ST40X-10S-CVR(30) 241-0029-4 30
1
No.10
6
No.1
18 pos. (Shielded type)
7
5.5
18
Part No.
HRS No.
Packaging RoHS
ST40X-18S-CV(30) 241-0012-1 30
1
No.1
18 pos. (Reverse, shielded type)
7
5.5
18
Part No.
HRS No.
Packaging RoHS
ST40X-18S-CVR(30) 241-0016-2 30
1
No.1
No.18
24 pos. (Shielded type)
7
5.5
21
Part No.
HRS No.
Packaging RoHS
ST40X-24S-CV(30) 241-0004-3 30
1
No.1
No.24
(10)
9
20.1
(10)
21
5.5
No.18
21
Part No.
HRS No.
Packaging RoHS
ST40X-24S-CV1(30) 241-0023-8 30
1
No.24
No.1
7
36 pos. (Shielded type)
11.4
6.7
29
30.6
32.5
Part No.
HRS No.
Packaging RoHS
ST40X-36S-CV(30) 241-0034-4 30
1
7.6
No.1
No.36
Note: Plug assemblies will require additional components. Contact Hirose Electric representative for detailed descriptions and installation instructions.
Packaging Specification
Embossed Carrier Tape Dimensions
Reel Dimensions
Part No.
ST60-10P(30)
ST60-18P(30)
ST60-24P(30)
ST60-36P(30)
ST60-36PR(30)
ST80X-10S(30)
ST80X-18S(30)
ST80X-24S(30)
ST60X-18S(30)
ST60X-36S(30)
A
24
24
32
44
44
24
44
44
32
44
B
--------28.4
40.4
40.4
----40.4
40.4
28.4
40.4
C
11.5
11.5
14.2
20.2
20.2
11.5
20.2
20.2
14.2
20.2
D
12
12
12
12
12
16
16
16
E
00.5
00.5
00.5
00.5
00.5
12.2
12.7
12.7
4.95
4.85
pcs. / reel
1,500
1,500
1,500
1,500
1,500
0400
0400
0400
0900
0900
E
B
A
C
.5
Ø1
1.75
Unreeling direction
D
4
2
Recommended Temperature Profile
(Lead-free soldering compound)
Reel Dimensions
This measurement is performed on
Unreeling direction
(ç)
the contact lead section.
240ç
230ç min
250
(13)
Pocket
(Ø
38
2)
The temperature profile may vary
200
180ç
due to external conditions such as
150
150ç
the type of cream solder,
manufacturer, and board size.
100
60S
50
30S
Please contact the solder
manufacturer for their
specifications.
8
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 09/2016. Contents are subject to change without notice for the purpose of improvements.
