1520-2
1520-2
    KEYSTONE
1520-2 数据手册
TURRET TERMINALS STYLES • Single, double and triple turrets • Double-ended (feed-thru) • Split-type (fork) • Tubular (hollow) • Swage and thread mounting types available • Bright Tin plated for extended shelf life and excellent solderability • Wide variety of sizes to suit space and wire size requirements ORDERING INFORMATION Keystone standardized terminals are available for various board thicknesses. To specify a terminal, select the “CAT. NO.” and “DASHED NUMBER” that corresponds with the board thickness to be used. DASH NUMBERS (Board Thicknesses) -1 for .032 (.81) thick Board -2 for .062 (1.57) thick Board -3 for .093 (2.36) thick Board -4 for .125 (3.2) thick Board Example: 1503-1 for .032 (.81) thick Board 1503-2 for .062 (1.57) thick Board STAKING TOOLS SPECIFICATIONS MATERIAL: Brass - Per ASTM-B16, Bright Electro-Tin per MIL-T-10727 Type 1. For easy mounting of terminals to insulators and PC boards. Standard and “special order” staking tools are available. Cat. No. “TL” designates a tool consisting of a TOP STAKING PUNCH and a BOTTOM ANVIL. Manufactured from steel with zinc plate. Punch and anvil are precision machined and hardened to insure long life. Refer to page 135. Other platings available upon request. SPECIAL TERMINALS Custom terminals can be manufactured to your specifications. Complete facilities available to meet your production requirements. Quotations on special terminals furnished promptly upon receipt of sample, sketch or print. CUSTOM BUILT STAKING TOOLS Custom prototype and production staking tools can be furnished for Single-End, Double-End, Fork Terminals, Extruded Lugs, Eyelets, Rivets, etc. Contact our Engineering Department for details. CUSTOM BUILT TERMINAL BOARDS TURRET TERMINALS We are specialists in the assembly of terminals, eyelets, clips and special hardware. Quotations on special terminal boards furnished promptly upon receipt of sample, sketch or print. Assembly service using customer supplied materials also available. (Refer to pages 130-132 for standard terminal boards.) SINGLE, DOUBLE & TRIPLE TURRET 1528 1508 .104 [2.7] L Staking Tool No. TL-2 CAT. NO. L .078 (1.98) 1520-1 1520-2 .109 (2.8) 1520-3 .141 (3.5) 1520-4 .172 (4.4) Staking Tool No. TL-8 CAT. NO. L .078 (1.98) 1532-1 1532-2 .109 (2.8) 1532-3 .141 (3.5) 1532-4 .172 (4.4) 1502 1514 1503 .093 [2.36] .050 [1.27] .186 [4.7] .093 [2.36] L .090 [2.29] Staking Tool No. TL-2 CAT. NO. L .078 (1.98) 1502-1 1502-2 .109 (2.8) 1502-3 .141 (3.5) 1502-4 .172 (4.4) .112 [2.9] Staking Tool No. TL-5 CAT. NO. L .078 (1.98) 1514-1 1514-2 .109 (2.8) 1514-3 .141 (3.5) 1514-4 .172 (4.4) Staking Tool No. TL-8 CAT. NO. L .078 (1.98) 1503-1 1503-2 .109 (2.8) 1503-3 .141 (3.5) 1503-4 .172 (4.4) THREADED TURRETS 1527 1563 1595 1587 .145 [3.7] .093 [2.36] .484 [12.3] .301 [7.7] .125 [3.2] .043 [1.09] DIA. THRU .187 [4.8] L .090 [2.29] Staking Tool No. TL-2 CAT. NO. L 1598-1 .062 (1.57) 1598-2 .094 (2.39) 1598-3 .125 (3.2) 1598-4 .156 (3.9) 142 .360 [9.2] .187 [4.8] L L Staking Tool No. TL-1 CAT. NO. L .051 (1.30) 1573-1 1573-2 .082 (2.08) 1573-3 .113 (2.8) 1573-4 .145 (3.6) 1598 .281 [7.2] .156 [4.0] .090 [2.29] .072 [1.83] Staking Tool No. TL-1 CAT. NO. L .054 (1.37) 1593-1 1593-2 .084 (2.13) 1593-3 .115 (2.9) 1593-4 .147 (3.7) .219 [5.6] .125 [3.2] L L .062 [1.57] .145 [3.7] .109 [2.8] .094 [2.39] .156 [4.0] .112 [2.9] Staking Tool No.TL-1 CAT. NO. L .051 (1.30) 1572-1 1572-2 .082 (2.08) 1572-3 .113 (2.8) 1572-4 .145 (3.6) 1573 .062 [1.57] L .078 [1.98] .072 [1.83] Staking Tool No. TL-1 CAT. NO. L .053 (1.35) 1508-1 1508-2 .084 (2.13) 1508-3 .115 (2.9) 1508-4 .147 (3.7) .234 [6.0] .187 [4.8] L L .062 [1.57] 1593 .187 [4.8] .125 [3.2] .093 [2.36 L Staking Tool 1528-TL CAT. NO. L .051 (1.30) 1528-1 1528-2 .082 (2.08) 1528-3 .113 (2.8) 1528-4 .145 (3.6) .145 [3.7] .093 [2.36] .094 [2.39] .093 [2.36] .047 [1.19] 1532 .075 [1.90] .050 [1.27] .063 [1.60] .040 [1.02] .062 [1.57] 1520 1572 L .112 [2.9] Staking Tool No. TL-8 CAT. NO. L 1527-1 .078 (1.98) 1527-2 .109 (2.8) 1527-3 .141 (3.5) 1527-4 .172 (4.4) Tel (718) 956-8900 • Fax (718) 956-9040 (800) 221-5510 • kec@keyelco.com .075 [1.9] DIA. .093 [2.4] DIA. .187 [4.8] .125 [3.2] HEX. .156 [4.0] 4-40 THREAD .125 [3.2] CAT. NO. 1563 ® RoHS COMPLIANT ~ ISO 9001 CERTIFIED 2-56 THREAD CAT. NO. 1595-1 1595-2 1595-3 L L .093 (2.36) .125 (3.2) .188 (4.8) .145 [3.7] DIA. .187 [4.8] HEX. 4-40 THREAD CAT. NO. 1587-1 1587-2 www.keyelco.com 31-07 20th Road – Astoria, NY 11105-2017 .360 [9.2] L L .125 (3.2) .188 (4.8)
1520-2 价格&库存
很抱歉,暂时无法提供与“1520-2”相匹配的价格&库存,您可以联系我们找货
