S280W555-604
S280W555-604
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    Module
    4 INCH MOUNTING TRACK
S280W555-604 数据手册
DWG. NO. SA94843 SUPERSEDES: SE94843-5 U REVISED PER ECN 12047 T REVISED PER ECN 11710 S REVISED PER ECN 11271 R REVISED PER ECN 7622 REV DESCRIPTION RSK 10-09-13 RSK 05-02-12 VKP 11-15-10 JRD 09-20-02 SDH 10-09-13 SDH 05-02-12 SDH 11-15-10 SDH 09-20-02 BY DATE CHKD DATE DRAWING TITLE CAT NO. LINEAR MEASURE: RBGT__ & RBMT__ (SEE TABLE, SHT. 2) THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES ONE PLACE TRACKS, GROUNDING & MOUNTING CAGE NO.: 09922 SIZE: A CUSTOMER #.1 [ #3] TWO PLACES #.02 [ #0.5] #.010 [ #0.25] ANGLES #1 $ DRAWN: CHKD : DSGN : MFG : QC : VKP SDH JDA DH DK 11-15-10 11-15-10 10-13-92 11-15-10 11-15-10 DRAWING SCALE: 1:1 DRAWING NO. REV INCH [mm] THREE PLACES APPROVAL THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. PRO-E THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. RBGT GROUNDING & RBMT MOUNTING TRACKS INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. SA94843 www.souriau.com 1 OF 6 U DWG. NO. SA94843 1. GROUNDING TRACK ACCOMMODATES PIN CONTACTS PER MIL-C-39029/1-101. WITH A WIRE RANGE OF 24-22-20 AWG. USE INSERTION/REMOVAL TOOL PER MIL-I-81969/14C-11. MATERIAL: STRAIN RELIEF GROMMET: SILICONE RUBBER, COLOR RED GROMMET BONDING: EPOXY GROUNDING MODULE BODY: GLASS FORTIFIED THERMOPLASTIC UL94V-0. COLOR BLUE DESCRIPTION TABLE GROUNDING AND MOUNTING TRACKS: 6063-T6 ALUMINUM GROUNDING RIVETS: ALUMINUM ALLOY GROUNDING SOCKET CONTACTS: BERYLLIUM COPPER CONTACT RETENTION CLIPS: BERYLLIUM COPPER SOCKET CONTACT SLEEVES: THERMOPLASTIC, LIQUID CRYSTAL POLYMER TERMINAL IDENTIFICATION STRIP: THERMOPLASTIC, UL94V-0, COLOR WHITE PROTECTIVE COATING: PRO-E POLYURETHANE, COLOR OPTIONAL FINISH: GROUNDING AND MOUNTING TRACKS: CHROMATE CONVERSION COATING PER MIL-C-81706, CLASS 3, METHOD C, COLOR GOLD. (REF: ALODINE 1200) THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. GROUNDING SOCKET CONTACTS: 50 MICROINCHES [1,27 MICRONS] MIN. NICKEL ALL OVER. PIN CONTACT CURRENT BEARING SURFACE OVER-PLATED WITH 50 MICROINCHES [1,27 MICRONS] MIN. HARD GOLD. SOURIAU CATALOG NO. (O.A LENGTH) WEIGHT (g) RBGT2 RBGT4 RBGT6 RBGT8 RBGT10 RBGT14 RBGT16 RBGT18 RBGT20 RBGT22 RBGT26 RBGT28 RBGT34 RBGT38 RBMT2 RBMT4 RBMT6 RBMT8 RBMT10 RBMT14 RBMT16 RBMT18 RBMT20 RBMT22 RBMT26 RBMT28 RBMT34 RBMT38 2.000 [50,80] 4.000 [101,60] 6.000 [152,40] 8.000 [203,20] 10.000 [254,00] 14.000 [355,60] 16.000 [406,40] 18.000 [457,20] 20.000 [508] 22.000 [558,80] 26.000 [660,40] 28.000 [711,20] 34.000 [863.60] 38.000 [965,20] 2.000 [50,80] 4.000 [101,60] 6.000 [152,40] 8.000 [203,20] 10.000 [254,00] 14.000 [355,60] 16.000 [406,40] 18.000 [457,20] 20.000 [508] 22.000 [558,80] 26.000 [660,40] 28.000 [711,20] 34.000 [863.60] 38.000 [965,20] 17.5 35.0 52.5 70.0 87.5 122.5 140.0 157.5 175.0 192.5 227.5 245.0 297.5 332.5 6.25 12.5 18.75 25.0 31.25 43.75 50.0 56.25 62.5 68.75 81.25 87.5 106.25 118.75 --- ALL REV. RECORDED ON SHT. 1 --- --- REV BY DATE CHKD DATE DRAWING TITLE CAT NO. LINEAR MEASURE: TRACKS, GROUNDING & MOUNTING RBGT__ & RBMT__ (SEE TABLE, SHT. 2) THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES ONE PLACE CAGE NO.: 09922 SIZE: A CUSTOMER #.1 [ #3] TWO PLACES #.02 [ #0.5] #.010 [ #0.25] ANGLES #1 $ DRAWN: CHKD : DSGN : MFG : QC : VKP SDH JDA DH DK 11-15-10 11-15-10 10-13-92 11-15-10 11-15-10 DRAWING SCALE: 1:1 DRAWING NO. REV INCH [mm] THREE PLACES APPROVAL THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. NOTES: INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. SA94843 www.souriau.com 2 OF 6 U DWG. NO. SA94843 PERFORMANCE CHARACTERISTICS THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. ELECTRICAL: IN ACCORDANCE WITH MIL-T-81714. PARA. 4.6.16. REF: MIL-STD-1344. METHOD 3004. SIZE 16-20: 45 MILLIVOLTS MAX. AT 7.5A WITH 20 AWG SILVER PLATED WIRE. LOW LEVEL CONTACT RESISTANCE: IN ACCORDANCE WITH MIL-T-81714. PARA. 4.6.17. REF: MIL-STD-1344. METHOD 3002. SIZE 16-20: .009 OHMS MAX. WITH 20 AWG SILVER PLATED WIRE. VOLTAGE STABILITY: 4 MILLIVOLT MAX. DIFFERENCE BETWEEN RECORDED HIGHEST AND LOWEST POTENTIAL DROP VALUES IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.18. ENVIRONMENTAL: PRO-E FLUID IMMERSION: ALL MATERIALS ARE RESISTANT TO BMS3-11 (SKYDROLLD-4) AND MIL-H-5606 HYDRAULIC FLUIDS, AND MIL-L-7808 AND MIL-L-23699 LUBRICATING OILS. HUMIDITY: IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.10. REF: MIL-STD-1344, METHOD 1002, TYPE II, (EXCEPT WITHOUT STEP 7b) SALT SPRAY: 500 HOURS IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.12. REF: MIL-STD-1344, METHOD 1001, TEST CONDITION C. VIBRATION (SINUSOIDAL): IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.8.1. REF: MIL-STD-202, METHOD 204, TEST CONDITION G. VIBRATION (RANDOM): IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.8.2. REF: MIL-STD-1344, METHOD 2005, TEST CONDITION VI,LETTER J. MECHANICAL (IMPACT) SHOCK: IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.9. REF: MIL-STD-1344, METHOD 2004, TEST CONDITION D. THERMAL SHOCK: IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.5. REF: MIL-STD-1344, METHOD 1003, TEST CONDITION A, (EXCEPT TEMPERATURE EXTREMES ARE -65 C $ TO +150 C $ [-85 F $ TO +302 F $]). TEMPERATURE LIFE: 150C $ [302 F $] FOR 1000 HOURS IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.13. OZONE: IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.14. REF: MIL-STD-1344, METHOD 1007. --- ALL REV. RECORDED ON SHT. 1 --- --- REV BY DATE CHKD DATE DESCRIPTION DRAWING TITLE CAT NO. LINEAR MEASURE: TRACKS, GROUNDING & MOUNTING RBGT__ & RBMT__ (SEE TABLE, SHT. 2) THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES ONE PLACE CAGE NO.: 09922 SIZE: A CUSTOMER #.1 [ #3] TWO PLACES #.02 [ #0.5] #.010 [ #0.25] ANGLES #1 $ DRAWN: CHKD : DSGN : MFG : QC : VKP SDH JDA DH DK 11-15-10 11-15-10 10-13-92 11-15-10 11-15-10 DRAWING SCALE: 1:1 DRAWING NO. REV INCH [mm] THREE PLACES APPROVAL THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. CONTACT RESISTANCE: INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. SA94843 www.souriau.com 3 OF 6 U DWG. NO. SA94843 PERFORMANCE CHARACTERISTICS THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. MECHANICAL: MAGNETIC PERMEABILITY: ALL MATERIALS DO NOT EXHIBIT A RELATIVE MAGNETIC PERMEABILITY OF GREATER THAN 2 IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.15. REF: MIL-STD-1344, METHOD 3006. MAINTENANCE AGING: IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.3. CONTACT INSERTION/REMOVAL FORCE: 10 LBS [44,4N] MAX. IN ACCORDANCE WITH MIL-T-81714, PARA.4.6.3 CONTACT RETENTION: 20 LBS [88,9N] MIN. IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.4. AXIALDISPLACEMENT DOES NOT EXCEED .012 [0,30]. REF: MIL-STD-1344, METHOD 2007. PROBE DAMAGE: IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.2. PRO-E RETENTION SYSTEM FLUID IMMERSION: IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.23. INTERNAL CONTACT DURABILITY: 100 CYCLES OF MATING AND UNMATING TO DEPTH OF MECHANICAL AND ELECTRICAL ENGAGEMENT IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.19. OVERSIZE PIN CONTACT PROTECTION: GROUNDING MODULE DESIGNED TO PREVENT ENTRANCE OF AN OVERSIZE TEST PIN OF .070 [1,78] IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.20. CONTACT WALKOUT: IN ACCORDANCE WITH MIL-T-81714, PARA. 4.6.22. REF: MIL-STD-1549. FEEDBACK MODULE INSTALLED IN GROUNDING AND MOUNTING TRACKS SCALE 1:1 --- ALL REV. RECORDED ON SHT. 1 --- --- REV BY DATE CHKD DATE DESCRIPTION DRAWING TITLE CAT NO. LINEAR MEASURE: TRACKS, GROUNDING & MOUNTING RBGT__ & RBMT__ (SEE TABLE, SHT. 2) THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES ONE PLACE CAGE NO.: 09922 SIZE: A CUSTOMER #.1 [ #3] TWO PLACES #.02 [ #0.5] #.010 [ #0.25] ANGLES #1 $ DRAWN: CHKD : DSGN : MFG : QC : VKP SDH JDA DH DK 11-15-10 11-15-10 10-13-92 11-15-10 11-15-10 DRAWING SCALE: 1:1 DRAWING NO. REV INCH [mm] THREE PLACES APPROVAL THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. SEE DRAWING SE94834 FOR FEEDBACK MODULE INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. SA94843 www.souriau.com 4 OF 6 U DWG. NO. SA94843 .29 #.03 [7.4 #0.7] .095 [2.41] 1.27 #.03 [32.2 #0.7] CX .098 [2.49] ID NUMERALS INK STAMPED IN SEQUENCE ON BOTH SIDES. COLOR BLACK .260 #.030 [6.6 #0.76] .310 #.010 [7.87 #0.25] .54 #.030 13.72 #0.76 .060 [1.52] .648 #.010 [16.46 #0.25] TYP GROUNDING RIVET WITH PROTECTIVE COATING TYP 1.000 [25.4] TYP (.23 ) [5.7] (.17 ) [4.3] SOURIAU CATALOG NO., CAGE NO., DATE CODE. AND LOGO.INK STAMPED, COLOR WHITE. FIRST LEFT HAND BODY ONLY CUSTOMER PART NO. INK STAMPED. COLOR WHITE. FIRST LEFT HAND BODY ONLY. TYP (.31 ) [7.8] .25 #.03 [6.4 #0.7] .13 #.03 [3.3 #0.7] TYP 1.990 #.010 [50.55 #0.25] CENTRELINE OF ALIGNMENT KEYWAY RBGT4 09922 - ZZYRWK TERMINAL IDENTIFICATION STRIP IS REMOVABLE AND REVERSIBLE BX .132 #.010 [3.35 #0.25] ALIGNMENT KEYWAY A GROUNDING TRACK - CATALOG NO. RBGT4 SHOWN C X GROUNDING CONTACT SOCKET .012/1.000 [0.30/25.40] TYP .50 #.03 [12.7 #0.7] .50 #.30 [12.7 #7.6] --- ALL REV. RECORDED ON SHT. 1 --- --- REV BY DATE CHKD DATE DESCRIPTION DRAWING TITLE CAT NO. LINEAR MEASURE: TRACKS, GROUNDING & MOUNTING RBGT__ & RBMT__ (SEE TABLE, SHT. 2) THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES ONE PLACE CAGE NO.: 09922 SIZE: A CUSTOMER #.1 [ #3] TWO PLACES #.02 [ #0.5] #.010 [ #0.25] ANGLES #1 $ DRAWN: CHKD : DSGN : MFG : QC : VKP SDH JDA DH DK 11-15-10 11-15-10 10-13-92 11-15-10 11-15-10 DRAWING SCALE: 1:1 DRAWING NO. REV INCH [mm] THREE PLACES APPROVAL THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. .738 #.007 [18.73 #0.17] CONTACT AND WIRE SHOWN FOR ILLUSTRATION .006/1.000 [0.15/25.40] "G" FOR GROUND IDENTIFICATION INK STAMPED. COLOR WHITE PRO-E THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. PIN CONTACT CURRENT BEARING SURFACE INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. SA94843 www.souriau.com 5 OF 6 U (A) LINEAR MEASURE: CAT NO. THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES ONE PLACE TWO PLACES #.02 [ #0.5] THREE PLACES #.010 [ #0.25] ANGLES #1 $ RBGT__ & RBMT__ (SEE TABLE, SHT. 2) CAGE NO.: 09922 INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. REV BOEING PART NO. S280W555-502 S280W555-504 S280W555-506 S280W555-508 S280W555-510 S280W555-514 S280W555-516 S280W555-518 S280W555-520 S280W555-522 S280W555-526 S280W555-528 S280W555-534 S280W555-538 RBGT2 RBGT4 RBGT6 RBGT8 RBGT10 RBGT14 RBGT16 RBGT18 RBGT20 RBGT22 RBGT26 RBGT28 RBGT34 RBGT38 RBMT2 RBMT4 RBMT6 RBMT8 RBMT10 RBMT14 RBMT16 RBMT18 RBMT20 RBMT22 RBMT26 RBMT28 RBMT34 RBMT38 SOURIAU CATALOG NO. S280W555-602 S280W555-604 S280W555-606 S280W555-608 S280W555-610 S280W555-614 S280W555-616 S280W555-618 S280W555-620 S280W555-622 S280W555-626 S280W555-628 S280W555-634 S280W555-638 BOEING PART NO. 2.000 [50,80] 4.000 [101,60] 6.000 [152,40] 8.000 [203,20] 10.000 [254,00] 14.000 [355,60] 16.000 [406,40] 18.000 [457,20] 20.000 [508] 22.000 [558,80] 26.000 [660,40] 28.000 [711,20] 34.000 [863.60] 38.000 [965,20] A . #010 [0,25] .050 [1.27] SOURIAU CATALOG NO. MOUNTING TRACK DIMENSIONS, INK STAMPING, AND OTHER FEATURES ARE THE SAME AS THE GROUNDING TRACK EXCEPT AS SHOWN. MOUNTING TRACK - CATALOG NO. RBMT4 SHOWN 2 4 6 8 10 14 16 18 20 22 26 28 34 38 B 16 32 48 64 80 112 128 144 160 176 208 224 272 304 C THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. .175 #.010 [4.45 #0.25] SIZE: A INCH [mm] CUSTOMER #.1 [ #3] www.souriau.com 10 14 16 18 20 22 26 28 34 38 8 2 4 6 FEEDBACK MODULES ACCOMMODATED SEE DWG. SE94834 1.020 MAX. [25.91] APPROVAL PRO-E .704 #.007 [17.88 #0.17] GROUNDING TRACK RBMT4 09922 - ZZYRWK THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. DWG. NO. SA94843 TYP .400 #.030 [10.16 #0.76] --- ALL REV. RECORDED ON SHT. 1 ECN NUMBER DRAWN: CHKD : DSGN : MFG : QC : ----- BY DATE CHKD DATE DRAWING TITLE TRACKS, GROUNDING & MOUNTING VKP SDH JDA DH DK SA94843 6 OF 6 11-15-10 11-15-10 10-13-92 11-15-10 11-15-10 DRAWING SCALE: 1:1 DRAWING NO. REV U
S280W555-604 价格&库存
很抱歉,暂时无法提供与“S280W555-604”相匹配的价格&库存,您可以联系我们找货
