YHLZG8-1
YHLZG8-1
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    Connector Ground Block
YHLZG8-1 数据手册
DWG. NO. SA83900 U REVISED PER ECN 11727 T REVISED PER ECN 10510 S REVISED PER ECN 10338 R REVISED PER ECN 9725 P REVISED PER ECN 8187 13 REVISED PER ECN 4594 RSK 05-25-12 RKO 04-16-08 FLR 11-21-07 SDH 01-04-06 SDH 12-18-03 SAF 07-28-00 SAF 07-09-99 SDH 05-25-12 SDH 04-16-08 SDH 11-21-07 SDH 01-04-06 SDH 12-18-03 SDH 07-28-00 TMN 07-09-99 12 REVISED PER ECN 4401 11 SHT 2: MATERIAL FOR GROUND BUS BODY, ALUMINUM ALLOY QQA591 HAS BEEN SUPERSEDED BY ASTM B85 ALLOY SC84B (ECN 3685) NLL 03-25-97 JDA 03-25-97 10 REVISED AND REDRAWN. DWG SIZE WAS 'E' SUPERSEDES DWGS SE83900 AND SE83907. SHT 7 ADDED ISOMETRIC SEALING TAPE VIEWS. SEE REV. REF. PRINT (ECN 3634) FDH 01-28-97 JDA 01-28-97 REV DESCRIPTION BY DATE CHKD DATE DRAWING TITLE YHLZG TERMINAL GROUND BLOCK MODULE ASSEMBLY CAT NO. LINEAR MEASURE: YHLZG__-_ (SEE TABLE) THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES INCH [mm] ONE PLACE #.1 [ #3] TWO PLACES # 0.02 [ #.5] THREE PLACES # 0.005 [ #.13] ANGLES #1 $ CAGE NO.: 09922 SIZE: A CUSTOMER APPROVAL THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. PRO-E THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. YHLZG GROUNDING TERMINAL BLOCKS DRAWN: CHKD : DSGN : MFG : QC : RKO SDH LAS 04-16-08 04-16-08 04-25-08 DRAWING SCALE: 1:1 DRAWING NO. REV INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. SA83900 www.souriau.com 1 OF 6 U DWG. NO. SA83900 NOTES: UNLESS OTHERWISE SPECIFIED. TERMINAL GROUND BLOCKS ACCOMODATE SOURIAU 'YHMM' TYPE CONTACTS. SEE DRAWING SE66466, USE INSERTION/ REMOVAL TOOL 'J1276-_' SEE DRAWINGS SC58867, SC65988, SC66580 AND SC69488. MATERIAL: THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. 1 GROUND BUS BODY MODULE CONTACT PROTECTIVE COATING PLATING: GROUND BUS BODY : CHROMATE CONVERSION COATING/ ALODINE IZOD OR IRRIDITE 14-2 PER MIL-C-5541. CLASS 3 AND MIL-C-81706. CLASS 3.METHOD C COLOR GOLD TO OLIVE DRAB MODULE CONTACT : GOLD OVER COPPER. PERFORMANCE CHARACTERISTICS: CURRENT RATING : 70 AMPS MAX PER MODULE 20 AMPS MAX PER CONTACT CONTACT RESISTANCE : 1.75 MILLIOHMS (MOUNTING FLANGE HOLE TO WIRE AT END OF CONTACT) PRO-E CONTACT RETENTION : 25 LBS (111.2 NEWTONS) THERMAL SHOCK : MIL-STD 202, METHOD 107D, CONDITION 'B' 5 CYCLES VIBRATION : MIL-STD 202, METHOD 214. 8 HOURS EACH AXIS. ENVELOPE PER FIG 6 OF EACH BOEING SPEC D6-81926 SALT SPRAY : MIL-STD MOISTURE RESISTANCE : MIL-STD 202, METHOD 106D (OMIT VIBRATION STEP 7b) DURABILITY : 100 CYCLES. 202. METHOD 101D (48 HOURS) CATALOG NUMBER TABLE SOURIAU CAT. NO. NO. OF CONTACT POSITIONS MTG. FLANGE ORIENTATION YHLZG8-1 RIGHT ANGLE 8 YHLZG8-2 YHLZG16-1 STRAIGHT RIGHT ANGLE 16 YHLZG16-2 STRAIGHT DRAWING TITLE YHLZG TERMINAL GROUND BLOCK MODULE ASSEMBLY CAT NO. LINEAR MEASURE: YHLZG__-_ (SEE TABLE) THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES INCH [mm] ONE PLACE #.1 [ #3] TWO PLACES # 0.02 [ #.5] THREE PLACES # 0.005 [ #.13] ANGLES #1 $ CAGE NO.: 09922 SIZE: A CUSTOMER APPROVAL THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. : DIE CAST ALUMINUM ALLOY : BERYLLIUM COPPER ALLOY : POLYURETHANE DRAWN: CHKD : DSGN : MFG : QC : RKO SDH LAS 04-16-08 04-16-08 04-25-08 DRAWING SCALE: 1:1 DRAWING NO. REV INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. SA83900 www.souriau.com 2 OF 6 U DWG. NO. SA83900 TYP TYP .064 [1.63] .11 [2.7] THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. .65 [16.51 ] GROUND BUS BODY MODULE CONTACTS .90 [22.86] .385 #.010 [9.79 #0.25] 4X .283 #.003 [7.19 #0.07] .06 [1.57] VARIATION NO. NO. OF POSITIONS DATE CODE YHLZG__-__ 2.33 [59.16] 1.821 #.010 [46.25 #0.25] 1.214 #.010 [30.84 #0.25] THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. .607 #.010 [15.42 #0.25] SEE VIEW A FOR TYPICAL LETTERING TYP .257 #.010 [6.53 #0.25] .255 #.020 [6.477 #0.508] .250 #.020 [6.35 #0.508] TYPICAL LETTERING FOR ALL SIZES YHLZG8-1 SHOWN 9X STAKE YHLZG8-1 WEIGHT 30 GRAMS DRAWING TITLE YHLZG TERMINAL GROUND BLOCK MODULE ASSEMBLY CAT NO. LINEAR MEASURE: YHLZG__-_ (SEE TABLE) THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES INCH [mm] ONE PLACE #.1 [ #3] TWO PLACES # 0.02 [ #.5] THREE PLACES # 0.005 [ #.13] ANGLES #1 $ CAGE NO.: 09922 SIZE: A CUSTOMER APPROVAL PRO-E .096 [2.44] DRAWN: CHKD : DSGN : MFG : QC : RKO SDH LAS 04-16-08 04-16-08 04-25-08 DRAWING SCALE: 1:1 DRAWING NO. REV INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. SA83900 www.souriau.com 3 OF 6 U DWG. NO. SA83900 THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. TYP .257 #.010 [6.53 #0.25] .283 #.003 [7.19 #0.07] 9X STAKE .270 #.005 [6.85 #0.12] GROUND BUS BODY 4X SEE VIEW A FOR TYPICAL LETTERING .06 [1.57] .17 [4.39] 1.03 [26.04] .253 #.010 [6.44 #0.25] PRO-E .385 #.010 [9.78 #0.25] MODULE CONTACTS 2.33 [59.15] .607 #.010 [15.42 #0.25] .38 [9.5] .11 [2.7] 1.214 #.010 [30.84 #0.25] TYP TYP .070 [1.78] .096 [2.44] YHLZG8-2 WEIGHT 30 GRAMS DRAWING TITLE YHLZG TERMINAL GROUND BLOCK MODULE ASSEMBLY CAT NO. LINEAR MEASURE: YHLZG__-_ (SEE TABLE) THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES INCH [mm] ONE PLACE #.1 [ #3] TWO PLACES # 0.02 [ #.5] THREE PLACES # 0.005 [ #.13] ANGLES #1 $ CAGE NO.: 09922 SIZE: A CUSTOMER APPROVAL THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. 1.821 #.010 [46.25 #0.25] DRAWN: CHKD : DSGN : MFG : QC : RKO SDH LAS 04-16-08 04-16-08 04-25-08 DRAWING SCALE: 1:1 DRAWING NO. REV INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. SA83900 www.souriau.com 4 OF 6 U DWG. NO. SA83900 TYP .091 [2.31] THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. TYP .064 [1.63] .650 #.020 [16.51 #0.5] .105 #.020 [2.67 #0.5] GROUND BUS BODY 1.22 [30.98] MODULE CONTACTS .708 #.010 [17.99 #0.25] TYP .283 #.003 [7.19 #0.07] PRO-E 4X .06 [1.57] TYPICAL GROUNDING RIVET WITH PROTECTIVE COATING .326 #.010 [8.28 #0.25] 1.821 #.010 [46.25 #0.25] 2.33 [59.16] 1.214 #.010 [30.84 #0.25] SEE VIEW A FOR TYPICAL LETTERING .255 #.020 [6.477 #0.508] .250 #.020 [6.35 #0.508] TYP .257 #.010 [6.53 #0.25] 18X STAKE YHLZG16-1 WEIGHT 50 GRAMS DRAWING TITLE YHLZG TERMINAL GROUND BLOCK MODULE ASSEMBLY CAT NO. LINEAR MEASURE: YHLZG__-_ (SEE TABLE) THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES INCH [mm] ONE PLACE #.1 [ #3] TWO PLACES # 0.02 [ #.5] THREE PLACES # 0.005 [ #.13] ANGLES #1 $ CAGE NO.: 09922 SIZE: A CUSTOMER APPROVAL THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. .607 #.010 [15.42 #0.25] DRAWN: CHKD : DSGN : MFG : QC : RKO SDH LAS 04-16-08 04-16-08 04-25-08 DRAWING SCALE: 1:1 DRAWING NO. REV INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. SA83900 www.souriau.com 5 OF 6 U DWG. NO. TYP .257 #.010 [6.53 #0.25] .326 #.010 [8.28 #0.25] TYP .283 #.003 [7.19 #0.07] TYPICAL GROUNDING RIVET WITH PROTECTIVE COATING 18X STAKE 2.33 [59.18] 4X .06 [1.57] .17 [4.32] 1.03 [26.16] MODULE CONTACTS .38 [9.65] .254 #.010 [6.45 #0.25] 1.214 #.010 [30.84 #0.25] GROUND BUS BODY .607 #.010 [15.42 #0.25] .105 #.020 [2.67 #0.50] 1.821 #.010 [46.25 #0.25] TYP .064 [1.63] TYP .091 [2.31] YHLZG16-2 WEIGHT 50 GRAMS DRAWING TITLE YHLZG TERMINAL GROUND BLOCK MODULE ASSEMBLY CAT NO. LINEAR MEASURE: YHLZG__-_ (SEE TABLE) THIRD ANGLE PROJECTION TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES INCH [mm] ONE PLACE #.1 [ #3] TWO PLACES # 0.02 [ #.5] THREE PLACES # 0.005 [ #.13] ANGLES #1 $ CAGE NO.: 09922 SIZE: A CUSTOMER APPROVAL THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. SEE VIEW A FOR TYPICAL LETTERING .708 #.015 [17.98 #0.38] PRO-E THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. SA83900 DRAWN: CHKD : DSGN : MFG : QC : RKO SDH LAS 04-16-08 04-16-08 04-25-08 DRAWING SCALE: 1:1 DRAWING NO. REV INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. SA83900 www.souriau.com 6 OF 6 U
YHLZG8-1 价格&库存
很抱歉,暂时无法提供与“YHLZG8-1”相匹配的价格&库存,您可以联系我们找货
