DWR-T600S-V212-90
DWR-T600S-V212-90
    ARDUINO
    CONNHEADER6POSSTRGTSLDRCP
DWR-T600S-V212-90 数据手册
A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. DATE A PROPOSAL DWG (EAR 13867) MAY06/11 B UPDATED POWER CONTACTS MAY11/12 84.28 3.318 APP'D S.M 1 1 45.72 1.800 9.14 .360 TYP. 10.80 .425 SOCKET HOUSING 3.25 .128 MOUNTING HOLE A6 A5 A4 A3 A2 A1 2 2 SLOT ACCEPTS PIN CONNECTOR HOUSING BLADE LOCATED OFF CENTRE TO PREVENT IMPROPER MATING RECESSED SIZE CB8 COOLBAND POWER CONTACT 60.55 2.384 8.40 .331 3 3 AMPHENOL PART NUMBER: DWR-T600S-V212-90 9.02 .355 15.37 .605 REF 6.35 .250 7.20 .283 4 5.49 .216 POWER CONTACT SIZE #8 AWG SOLDER CUP (6 PLCS) ORIENTATION PEG PREVENTS ASSEMBLY ERRORS NOTES: 73.10 2.878 5 4 54.86 2.160 1. MATERIALS: ALL MATERIALS ARE RoHS COMPLIANT PER EU DIRECTIVE 2002/95/EC AND AMENDMENTS. • HOUSING: HIGH TEMPERATURE RESISTANT NYLON, UL FLAMMABILITY RATING 94V-0, COLOUR BLACK • POWER CONTACTS: BERYLLIUM COPPER MATING GRID, TELLURIUM COPPER ALLOY BALANCE. MATING AREA PLATED WITH 0.38µm (15µ”) GOLD OVER 1.27µm (50µ”) NICKEL, SILVER BALANCE 2. WHEN MATED WITH PIN CONNECTOR P/N DWR-T600P-V212-90, THE ORDER OF MECHANICAL AND ELECTRICAL ENGAGEMENT IS A) HOUSING BLADES, B) HOUSING SHROUD, C) TWO EXTENDED "FIRST MAKE" POWER CONTACTS IN POSITIONS A1 AND A6 AND D) FOUR STANDARD POWER CONTACTS IN POSITIONS A2, A3, A4 AND A5. 3. RATINGS SUBJECT TO DESIGN QUALIFICATION TESTING • CURRENT RATING: 55A • DIELECTRIC WITHSTANDING VOLTAGE: 1500VDC • INSULATION RESISTANCE: 5000 MEGAOHMS OPERATING TEMPERATURE: -55C TO +105 • UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D DRAWN REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. 1 DECIMAL PLACE ENG. REL. NO. 2 DECIMAL PLACES REF. 3 DECIMAL PLACES THIRD ANGLE PROJECTION ANGULAR DEGREES E S.CAELERS MAY06/11 MILLIMETERS CHECKED INCHES M.E. APP'D EAR 13867 Amphenol Canada Corp. DWR SERIES SLIM DRAWER 6 SOCKET CONNECTOR, SPECIAL RECESSED SIZE CB8 COOL POWER, SOLDER CUP TAILS (#8 AWG), RoHS COMPLIANT DWG. NO. REV B P-DWR-T600S-V212-90 DO NOT SCALE DRAWING CODE ID NO. F 5 03554 DWG SIZE: X G SCALE: 2:1 SHEET 1 OF 2 H 6 A B C D E G F H REVISIONS REV DESCRIPTION, ECN, EAR NO. DATE APP'D A PROPOSAL DWG (EAR 13867) UPDATED POWER CONTACTS MAY06/11 MAY11/12 S.M B 1 1 2 2 MATING PIN P/N DWR-T600P-V212-90 3 3 4 4 SOCKET CONNECTOR P/N DWR-T600S-V212-90 MATED ASSEMBLY SIDE VIEW SCALE 3:1 5 5 UNLESS SPECIFIED OTHERWISE PRIMARY UNITS SECONDARY 6 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE OR USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN PERMISSION FROM AMPHENOL CANADA CORP. A B C D DRAWN REFERENCE IN PARENTHESES Q.A. APP'D GENERAL TOLERANCES DWG APPR. 1 DECIMAL PLACE ENG. REL. NO. 2 DECIMAL PLACES REF. 3 DECIMAL PLACES THIRD ANGLE PROJECTION ANGULAR DEGREES E S.CAELERS MAY06/11 MILLIMETERS CHECKED INCHES M.E. APP'D EAR 13867 Amphenol Canada Corp. DWR SERIES SLIM DRAWER 6 SOCKET CONNECTOR, SPECIAL RECESSED SIZE CB8 COOL POWER, SOLDER CUP TAILS (#8 AWG), RoHS COMPLIANT DWG. NO. REV F B P-DWR-T600S-V212-90 DO NOT SCALE DRAWING CODE ID NO. 03554 DWG SIZE: X G SCALE: 2:1 SHEET 2 OF 2 H 6
DWR-T600S-V212-90 价格&库存
很抱歉,暂时无法提供与“DWR-T600S-V212-90”相匹配的价格&库存,您可以联系我们找货
