ITS-P-13029Q
PS3F Series
Signal Hybrid 100 Amps Power Supply,
Front Access Plug-in Connector
Features
1. ”Front Access” on system rack side allows cable assembly from mating side.
2. Front access is best suited to the systems with no space at the back side for maintenance.
3. For signal lines, GT8E connector with a good track record in automotive market is applied.
4. Floating screw allows ± 2.5 mm floating mate
5. Finger protection meeting IP2X requirements contributes to operators’ safety.
(Female power contact side only)
6. UL, C-UL certified*, will be TÜV approved
*Except signal lines (Conditions for safety standards vary depending on submitted applications of current and voltage ratings.
Contact Hirose for details.
220
PS3F-2R/8P/10P
All the operations can be done
from the battery side
No maintenance space
26.6
PS3F allows power/signal cables attachment/
detachment from the plug-in side (front side). Optimum
for systems installed closely to the container wall etc.
with no maintenance space at the back face.
44.2
Dimensions
170
198.2
*:Separately available
PS3F-RPC(22)*
198
41
23
Inaccessible from the
system back side
(71.4)
“Front Access”
” Type
PS3F-PC-HOLDER*
PS3F-2RS/8S/10S
Specifications
Power Line
Signal Line
Operating
Temperature Range
-40 °C to +105 °C
(includes temperature rise by current carrying)
Rated Current/pin
100 Amps
1 Amp
Rated Voltage
AC/DC 1000 V
AC/DC 250 V
Contact Resistance
0.3 mΩ Max. (DC 1A)
60 mΩ Max (100 mA)
Insulation Resistance
5000 MΩ Min. (DC 250V)
100 MΩ Min. (DC 500V)
Withstanding Voltage
AC 2000V, 1 minute
AC 650V, 1 minute
Durability
100 times (Durability of GT8E: 30 times)
183
8 pos.
: GT8E-8S-HU
10 pos.
: GT8E-10S-HU
System rack side contact : GT8E-2022SCF(01)
(Gold plated)
Battery module side contact: GT8E-2022SCF
(Tin plated)
・ Applicable wire: 22sq (WL1, WL2, UL3832AWM)
・ RoHS, Halogen free (900 ppm maximum chlorine, 900 ppm maximum bromine, and 1500 ppm maximum total of chlorine and bromine)
Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities.
Issued: Nov. 29, 2013
很抱歉,暂时无法提供与“PS3F-2R/8P/10P(01)”相匹配的价格&库存,您可以联系我们找货
