High Current Connector
PS3 Series
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
1U
Flexible wire
Flexible wire
Fig.1
■Features
Y
1. Power contact supports up to 150 Amps
(210A/1pin Derating curve, ambient temp
25˚C) with 50mm sq. O/I AWG wire.
2. The unique blade contacts help to
create a slim design and allows it to
be utilized in a standard 1U rack size
(44.5mm × 482.6mm). (Fig.1)
X
Shoulder Portion
Thread Portion
System Side Panel
Shoulder Screw
Fig.2
3. Sp e cial s cr ew s a r e us e d in t h e
receptacle to allow the floating (±2.0
mm) in X Y axial directions.
Connector floating is allowed by using flexible
wire without missing flexibility in short distant
wiring between 1U connection. (Fig.1, 2)
Test Finger
4. The cable connection to the power
contact is made by means of a screw
to a JIS round crimp contact.
Fig.3
5. For added safety, the plug side
(battery side) is designed to prevent
shock hazard and provides for more
user safety and security. (Fig.3)
6. A special dust cap is available and
can be used with both the plug and
receptacle.
7. The plug and receptacle have been
UL, C-UL and TÜV certified.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2017.2②
1
PS3 Series●High Current Connector
■Product Specifications
Rated Current
Power
Signal
150A/1pin(*1)
210A/1pin (Derating curve, ambient temp 25°C)
1A/1pin
Ratings
Rated Voltage
AC、DC 1000V(*1)
-40 to +105°C
(including temperature rise due
to electric current)
Stor. Temp. Range
−40℃∼ +60℃
*1 : UL, C-UL and TÜV certifications have been obtained while changing conditions such as rated current and voltage multiple times.
For details, see the "Conditions on Safety Standards (UL, C-UL, TÜV)" on page 6.
*2 : Select your cables based on the current capacity needed for your application.
Flexible wires are recommended to provide flexibility to the receptacles (system side).
*3 : Used 50sq (1/0 AWG) cable.
5 to 1/0 AWG
14 to 50sq
(WL1、WL2 *1 *2)
Applicable
Cable
20 to 22 AWG
Op. Temp. Range
■Materials / Finish
●Receptacle
Parts
Insulator
Contact
Contact Retention plate A
Contact Retention plate B
Floating screw
Signal male contact
Signal Retention plate (12)
Signal Retention plate (16)
Materials
PBT
Copper alloy
PBT
PBT
Steel
Copper allay
PBT
PBT
Color/Finish
Black
Silver plated
Black
Black
Nickel plated
Gold plated
Black
Black
Remarks
UL94V-0
UL94V-0
UL94V-0
UL94V-0
UL94V-0
Materials
PBT resin
Copper alloy
PBT resin
Copper allay
PBT
PBT
Color/Finish
Black
Silver plated
Black
Gold plated
Black
Black
Remarks
UL94V-0
UL94V-0
UL94V-0
UL94V-0
Materials
Silicon rubber
Color/Finish
Blue
Remarks
UL94HB
●Plug
Parts
Insulator
Contact
Contact Retention plate C
Signal female contact
●Dust Cap
Parts
Insulator
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
1. Connector product name
PS3 - 2 U S / 12 S / 16 S
❶
❷ ❸ ❹
❺
❻
❺
❻
PS3 - 2 U - DC
❷ ❸
❺ No. of signal contacts
❷ No. of power contacts
❻ Signal contact shapes
P : Male contact
S : Female contact
❸ Current capacity of power contact
U : 150A
2. Dust cap product name
❶
❶ Series name symbol
❹ Power contact shapes
P : Male contact
S : Female contact
❼
❼ Dust cap
■ Combination List
Signal part for Power/signal hybrid type is GT8E series (sell separately).
PS3-2UP/12P/16P
PS3-2US/12S/16S
GT8E-12DS-HU + GT8E-2022SCF (Gold plated)
GT8E-16DS-HU + GT8E-2022SCF (Gold plated)
(Example) PS3-2UP/12P/16P
2
■Receptacle
5
15
39.7
(12.75)
14.75
●PS3-2UP (Power type)
131.7
(119.5)
(42.45)
(23.8)
PS3
A
A
23
(41.8)
M6×1
A
(6)
HRS No.
236-1042-2 00
236-1042-2 01
8.2
Packaging
1box (40pcs.)
1pcs.
M6×1
(5.5)
(10)
Part No.
PS3-2UP
PS3-2UP(01)
BDiagram of recommended PCB layout dimensions
Corner radius : 2mm max.
Panel thickness:3mm max.
119.5
119.5
2-M6×1
.5
32.45
.5
R8
R8
36.7
44
43
49.8
31
46.2
2-M6×1
27.2
48.5
7
44.5
7
■Plug
●PS3-2US (Power type)
HRS No.
236-1041-0 00
236-1041-0 01
BDistance between panels
PS3
A
PS3
A
Packaging
1box (40pcs.)
1pcs.
BRecommended panel
(24.2∼26.2)
2-M6×1
112.3
93.6
23.7
Part No.
PS3-2US
PS3-2US(01)
PS3
A
2-Ø6.4
(12.4)
5
9.2
124.6
112.3
(42.45)
43.5
(42.45)
26.6
(35.85)
M6×1
22.7
(62.45)
102.6
3
■Receptacle
5
(12.75)
15
39.7 15
●PS3-2UP/12P/16P (Signal hybrid type)
205.7
(193.5)
(117.2)
(42.45)
M6×1
A
PS3
23
(41.8)
Packaging
1box (40pcs.)
1pcs.
(62.45)
Corner radius : 1mm max.
50.05
82.4
10.4
15.5
49.8
52.05
75.9
9.15
14.5
52.05
75.9
193.5
92.45
32.45
2×M6×1
15.5 14.5
29
45.8
2×M6×1
10.4
193.5
88.45
36.45
9.15
50.05
82.4
■Plug
M6×1
PS3
A
PS3
A
A
PS3
(12.4)
198.6
186.3
(117.2)
(42.45)
5
9.2 26.6
(35.85)
43.5
(42.45)
22.7
2ר6.4
Part No.
HRS No.
Packaging
PS3-2US/12S/16S
PS3-2US/12S/16S(01)
236-1043-5 00
236-1043-5 01
1box (40pcs.)
1pcs.
BRecommended panel
(24.7 to 28.7)
2×M6×1
186.3
167
x
ma
R2
4×
23.7
HRS No.
236-1044-8 00
236-1044-8 01
L
A
(23.8)
M6×1
A
L
Part No.
PS3-2UP/12P/16P
PS3-2UP/12P/16P(01)
(5.5)
(10) (6)
Ø8.2
176
4
■Dust cap
Part No.
HRS No.
Packaging
PS3-2U-DC
236-1054-1
1box (40pcs.)
This dust cap can be used on both the receptacle and plug.
(16)
4X
R2
32.7
●PS3-2U-DC
(10)
75.6
(4)
A
(1)
5
BUsage Precautions
• M6 screws are used to attach to the panels. The recommended amount of torque used to tighten the screws should be 2.5
to 5.2 Nm.
• The recommended amount of torque used to tighten the screws to the power contacts should be 2.5 to 5.2 Nm.
• Power contacts are silver plated and may react with the sulfide in the atmosphere.
This might cause the color to change to a dark brown.
The power contacts do not support hot-pluggable, so it cannot be used to shut off the power.
BSafety Standards Certifications (UL, C-UL, TÜV)
The PS3 series has received safety certifications from the UL, C-UL, and TÜV under the conditions provided in Table 1 and Table 2.
Conditions for safety standards vary depending on submitted applications of current and voltage ratings. See Table 1 and Table 2.
Table 1. Conditions for UL and C-UL
Condition ①
Rated Voltage
(AC/DC)
Rated Current
Condition ②
600V
100A
14 to 22sq (*1)
5 to 3 AWG
Cable
Creepage Distance
(*2)
Clearance (*2)
150A
38 to 50sq (*1)
1 to 1/0 AWG
MIN : 3.2mm
MIN : 3.2mm
Table 2. Conditions for TÜV
Rated Voltage (AC/DC)
Rated Current
Overvoltage Category
Contamination Level
Creepage Distance (*2)
Clearance (*2)
Insulation System
Recommended Panel for
PS3-2UP Side
PS3-2US Side
Condition I
800V
Condition II
Condition III
600V
1000V
100 A (cable 14 to 22sq, 5 to 3 AWG *1)
125 A (cable 38sq, 1 AWG *1)
150 A (cable 50sq, 1/0 AWG *1)
II
III
3
MIN : 12.6mm
MIN : 12.6mm
MIN : 16mm
MIN : 6mm
MIN : 6mm
MIN : 8mm
Basic insulation (Panel should be grounded)
Recommended Panel 1
Recommended Panel 1
Recommended Panel 2 (*3)
Recommended Panel 3
*1 : Use the screw and crimp contact combination recommended below. The use of other screws and crimp contacts can
affect clearance and creepage distance.
If you choose to use a different screw/contact combination, be sure to check the measurements for clearance and
creepage. Make sure that these conditions will meet the UL, C-UL and TÜV.
• Recommended screw: JIS B 1188 spring lock washer + cross recessed head screw with captive flat washer M6×12
• Recommended crimp contacts
Cable 14 sq: JIS C 2805 R14-6
Cable 22 sq: JIS C 2805 R22-6
Cable 38 sq: NICHIFU R38-6S
Cable 50 sq: NICHIFU R60-6S
*2 : Subjects of clearance and creepage distance are as follows.
• Between crimp contacts
• Between power contact and panel
• Between crimp contact and panel
• Between screw (attached to power contact) and panel
*3 : In case of recommended panel 2, reverse attachment of receptacle is possible. Please be careful in panel attachment.
6
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 02/2017. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“PS3-2US(01)”相匹配的价格&库存,您可以联系我们找货
