MSG29RR-2FPFK
MSG29RR-2FPFK
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    MSG3URECEPTACLES
MSG29RR-2FPFK 数据手册
MSG High performance Low profile rectangular MSG connectors Description MSG Series connectors is a 50 and 59 position low profile, compact design rectangular I/O connector. MSG has been developed for industrial and railway control equipments which require a easy handling and high density connector. In addition to its panel mount version, a PCB mount version has been especially designed to fit 19 inch Euro-rack system. Features and benefits Performance characteristics Construction • Connectors supplied pre-assembled. • Available in 50 and 59 contact versions. • PCB mount version fully equipped with male contacts. Selective contact loading optional. • Accessories : polarizing screws (receptacle) polarizing plate (plug) dust cap (plug) Operating temperature: Insulation resistance: Test potential: Current rating: Creepage distance: Durability: Connector Material : Glass filled thermoplast Flammability rating : UL94-V0 Hoods, skirts : Steel, nickel plated Cable clamps: Steel, nickel plated Guiding hardware: Stainless steel Contacts receptacle : Copper alloy (Au over Ni) Vibration Salt Spray: -55°C to +125°C 5000 MΩ min. 2000 VAC 7.5A - cable to PCB 13A - cable to cable 2.5mm (50 positions) 2.2mm (59 positions) 500 matings and unmatings. Per JIS-C STD 0040 Per JIS-C STD 0023 Contact accommodation • “MSG” Rectangular connectors accept TRIM TRIO size 16 crimp-type removable contacts (see contact section) • For the plug connector and the panel mount receptacle, contacts have to be ordered separately. How to order Number of contacts 59 50 Part number Description MSG59P-L11 Plug for cable up MSG59P-L21 Plug for cable down MSG59R-PL110 Panel mount receptacle MSG59R-RL111 Right angle PCB mount receptacle without flange MSG59R-FL111 Right angle PCB mount receptacle with flange MSG50P-L11 Cable plug MSG50RG-L111 Right angle PCB mount receptacle with flange 73 MSG Plug connector with metal hood (MSG59P-L11) Panel mount receptacle (MSG59RP-L110) 74 MSG Right angle PCB mount receptacle without flange (MSG59RR-L111) Right angle PCB mount receptacle with flange (MSG59RF-L111) 75 MSG MSG59 recommended drilling hole pattern (for PCB) (MSG59RR-L111, MSG59RF-L111) MSG59 recommended panel cut-out (front mount) (MSG59RR-L110) MSG59 recommended for front mount (MSG59RR-L111, MSG59RF-L111) Polarizing hardware Receptacle side Plug side 76 MSG (MSG50P-L11) (MSG50RF-L111) 77 MSG (MSG50RF-L111) (MSG50RF-L111) 78 MB Robust lever locking connector Description • 52 contact, rectangular, one action lever locking connector • Same receptacle can be front or rear mounted • 2 cable clamp orientations available: perpendicular or parallel to mating face • Anti Jack knife system, guide plate on plug and wide entry docket contact for a smooth and reliable mating • Adapted to shielded cable • Easy assembly Application • Signalling Mechanical Electrical Environmental • • • • • • • • • • • Temperature range: -55°C + 125°C • Flammability rating: UL94V0 Hood: Steel, Nickel plated Lever: stainless steel Grip and insulator: glass filled PBT Contact body: copper Contact plating: consult us Endurance: 500 mating/unmating operations • Vibration: per JIS C 0040 Withstanding voltage 2000 Veff Insulation resistance: 5000M Current rating: 13A Contact accommodation: standard TRIM TRIO size 16 contacts How to order Receptacle Basic series Number of contacts MB 52 R -L 1 1 0 MB 52 P -L 1 1 0 52 Receptacle: Lever type: Contact type: 1: TRIM TRIO contact Cable clamp: 1: Lever down; 2: Lever up Variation: 0: contacts to be ordered separately Plug Basic series Number of contacts 52 Plug Lever Cable clamp: 1: Lever down; 2: Lever up Cable direction 1: Parallel; 2: Perpendicular to mating face Variation 0 79 MB Dimensions Plug MB52P-L120 Receptacle MB52R-L110 31 ± 0,2 20 ± 0,2 Panel cut 80 85 ± 0,2 88,1 ± 0,2 95,5 ± 0,2 Rear mount Front mount
MSG29RR-2FPFK 价格&库存
很抱歉,暂时无法提供与“MSG29RR-2FPFK”相匹配的价格&库存,您可以联系我们找货
