MSG
High performance
Low profile
rectangular MSG
connectors
Description
MSG Series connectors is a 50 and 59
position low profile, compact design
rectangular I/O connector.
MSG has been developed for industrial and
railway control equipments which require a
easy handling and high density connector.
In addition to its panel mount version, a
PCB mount version has been especially
designed to fit 19 inch Euro-rack system.
Features and benefits
Performance characteristics
Construction
• Connectors supplied pre-assembled.
• Available in 50 and 59 contact versions.
• PCB mount version fully equipped with
male contacts. Selective contact loading
optional.
• Accessories : polarizing screws
(receptacle)
polarizing plate (plug)
dust cap (plug)
Operating
temperature:
Insulation
resistance:
Test potential:
Current
rating:
Creepage
distance:
Durability:
Connector Material : Glass filled
thermoplast
Flammability rating : UL94-V0
Hoods, skirts :
Steel, nickel plated
Cable clamps:
Guiding hardware:
Stainless steel
Contacts receptacle : Copper alloy
(Au over Ni)
Vibration
Salt Spray:
-55°C to +125°C
5000 MΩ min.
2000 VAC
7.5A - cable to PCB
13A - cable to cable
2.5mm (50 positions)
2.2mm (59 positions)
500 matings and
unmatings.
Per JIS-C STD 0040
Per JIS-C STD 0023
Contact accommodation
• “MSG” Rectangular connectors accept
TRIM TRIO size 16 crimp-type removable
contacts (see contact section)
• For the plug connector and the panel
mount receptacle, contacts have to be
ordered separately.
How to order
Number of
contacts
59
50
Part number
Description
MSG59P-L11
Plug for cable up
MSG59P-L21
Plug for cable down
MSG59R-PL110
Panel mount receptacle
MSG59R-RL111
Right angle PCB mount receptacle without flange
MSG59R-FL111
Right angle PCB mount receptacle with flange
MSG50P-L11
Cable plug
MSG50RG-L111
73
MSG
Plug connector with metal hood (MSG59P-L11)
Panel mount receptacle (MSG59RP-L110)
74
MSG
Right angle PCB mount receptacle without flange (MSG59RR-L111)
Right angle PCB mount receptacle with flange (MSG59RF-L111)
75
MSG
MSG59 recommended drilling hole pattern (for PCB) (MSG59RR-L111, MSG59RF-L111)
MSG59 recommended panel cut-out (front mount) (MSG59RR-L110)
MSG59 recommended for front mount (MSG59RR-L111, MSG59RF-L111)
Polarizing hardware
Receptacle side
Plug side
76
MSG
(MSG50P-L11)
(MSG50RF-L111)
77
MSG
(MSG50RF-L111)
(MSG50RF-L111)
78
MB
Robust lever locking
connector
Description
• 52 contact, rectangular, one action lever
locking connector
• Same receptacle can be front or rear
mounted
• 2 cable clamp orientations available:
perpendicular or parallel to mating face
• Anti Jack knife system, guide plate on
plug and wide entry docket contact for a
smooth and reliable mating
• Adapted to shielded cable
• Easy assembly
Application
• Signalling
Mechanical
Electrical
Environmental
• Temperature range: -55°C + 125°C
• Flammability rating: UL94V0
Hood: Steel, Nickel plated
Lever: stainless steel
Grip and insulator: glass filled PBT
Contact body: copper
Contact plating: consult us
Endurance: 500 mating/unmating
operations
• Vibration: per JIS C 0040
Withstanding voltage 2000 Veff
Insulation resistance: 5000M
Current rating: 13A
Contact accommodation: standard TRIM
TRIO size 16 contacts
How to order
Receptacle
Basic series
Number of contacts
MB
52
R
-L
1
1
MB
52
P
-L
1
1
Receptacle:
Lever type:
Contact type:
1: TRIM TRIO contact
Cable clamp:
1: Lever down; 2: Lever up
Variation:
0: contacts to be ordered separately
Plug
Basic series
Number of contacts
52
Plug
Lever
Cable clamp:
Cable direction
1: Parallel; 2: Perpendicular to mating face
Variation
MB
Dimensions
Plug MB52P-L120
Receptacle MB52R-L110
31 ± 0,2
20 ± 0,2
Panel cut
80
85 ± 0,2
88,1 ± 0,2
95,5 ± 0,2
Rear mount
Front mount
很抱歉,暂时无法提供与“MSG5ARR-2FPK”相匹配的价格&库存,您可以联系我们找货
