The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
QR/P4 SERIES
Small Rectangular Multi-electrode Solderless Connectors for Racks and Panels
Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
General
QR/P4 Series is a series of small connectors for rack
and panel application. This is a smaller-size version of
the QR/P and QR/P1 Series, whose rectangular multielectrode plug in connectors for racks and panels have
been well received in the market.
Six models with different numbers of contacts are
available: 8, 12, 16, 24 32 and 40. Wires are connected
to the connectors without solder for easier connection
and higher reliability.
Features
(1) The pins can be smoothly inserted into the receptacle, and give stable contact pressure bcause of their
point contact with the receptacle blades.Furthermore,
they have a larger allowance for the variation of connection length - a characteristic of plug-in connections.
(2) The connector size has been made smaller by separating the terminals for signals from those for voltage
supply.
(3) The pitch of the signal terminals inside the housing is
2.54mm. Tow pairs of diametrically opposed electrodes (four electrodes in total) on the two sides are
arranged with a pitch of 5.08mm so that they can
(4)
(5)
(6)
(7)
withstand high voltage, and can be used for power
supply. In addition, a nonflammable material (UL94V0) is used as the insulating housing of the connectors.
Guide pins and the housing body are molded as one
piece to achieve a smaller connector size.
Since the connectors are mounted on racks or panels with stepped screws, connection and disconnection can be done easily.
The contact for female terminals in the housing is
deeper than the fitting surface of the housing which
conforms to the finger test (UL Standard 1950).
The connectors of this series have passed UL, CSA
and TÜV standard.
Application
PPC, Transmission and reception equipment, Data Communication, Vending Machine, Measuring Instruments,
Automatic Equipment, Switchboards, etc.
151
04/2009
Specification
Item
Specifications
Contact Resistance
Insulation Resistance
Withstand Voltage
(for 1 minute)
Rated Current
Rated Voltage
Power
Max. 15mΩ at DC1A
Signal
Max. 15mΩ at DC1A
Min. 5000MΩ at DC500V
Power
AC 2000V
Signal
AC 500V
Power
3A
Signal
1A
Power
AC 300V
Signal
AC 250V
Item
Material
Finish
Insulator
PBT resin *:UL94V-0
Black
Contact
Phosphor Bronze
Selective Gold plating
over Nickel
Ratings authorized by QR/P4 safety standards
Safety standard
UL. CSA. TÜV
Operating temperature
−10∼+60℃
Rated
Voltage
Power supply
AC 30V
AC380V, DC450V
Signal unit
AC 250V
AC120V, DC150V
AWG#20
2.5A
3A
AWG#22
Rated
current
AWG#24
1A
2A
AWG#26
1A
AWG#28
Ordering Information
▲ Connector Unit
QR / P4 − 12 P − C − (01)
(1)
▲ Contact
152
(4)
(10)
QR / P1 − PC 2 A − 1 1 1
(1)
(1) Series name
(2) No.of contacts (8, 12, 16, 24, 32, 40)
(3) Type of Housing
P: Plug Housing
S: Socket Housing
(4) Type of termination
C: Criming
(5) Type of Contact
PC: Pin Contact
SC: Socket Contact
(2) (3)
(5) (6)
(7)(8)(9)
(6) Size of Barrel
2A: Thin Wire (UL1007 Type)
2B: Thin Wire (UL1007 Type) . . . For 4 contact holes at both ends
(7) Contact Type
1: Loose Contact
2: Chain Contact
(8) Applicable wire
1: Thin Wire AWG #24 - #28
2: Thick Wire AWG #20 - #24
(9) Finish
1: Selective Gold plated over Nickel
(10) UL, CSA, TÜV
Approved Spec
04/2009
Housing
Male Housing
Female Housing
Unit: mm
HRS No.
No. of Pin
Part No.
A
B
C
CL221-0159-5-01
8
QR/P4-08P-C(01)
34.68
26.68
CL221-0139-8-01
12
QR/P4-12P-C(01)
39.8
CL221-0155-4-01
16
QR/P4-16P-C(01)
44.84
CL221-0141-0-01
24
QR/P4-24P-C(01)
55
47
CL221-0153-9-01
32
QR/P4-32P-C(01)
67.7
CL221-0211-3-01
40
QR/P4-40P-C(01)
77.86
Unit: mm
RoHS
HRS No.
No. of Pin
Part No.
A
B
C
17.68
CL221-0160-4-01
8
QR/P4-08S-C(01)
34.68
26.68
17.68
31.8
22.8
CL221-0140-7-01
12
QR/P4-12S-C(01)
39.8
31.8
22.8
36.84
27.84
CL221-0156-7-01
16
QR/P4-16S-C(01)
44.84
36.84
27.84
38
CL221-0142-2-01
24
QR/P4-24S-C(01)
55
47
38
59.7
50.7
CL221-0154-1-01
32
QR/P4-32S-C(01)
67.7
59.7
50.7
69.86
60.86
CL221-0212-6-01
40
QR/P4-40S-C(01)
77.86
69.86
60.86
RoHS
Note: Determine the combinations with the panel so that the mating clearance between the P side and S side is 1.5mm or less.
Contact
Power Male Contact
Power Female Contact
Selective gold plated with nickel under plating
Applicable
Wire
AWG#20∼24
HRS No.
Part No.
Type Packing RoHS
Loose
CL221-0115-0-12 QR/P1-PC2B-121(12) contact
100pin
Chain 5,000pin
CL221-0119-0-12 QR/P1-PC2B-221(12) contact
Applicable
Wire
AWG#20∼24
HRS No.
Part No.
Type Packing RoHS
Loose
CL221-0117-2-12 QR/P1-SC2B-121(12) contact
100pin
Chain 5,000pin
CL221-0121-2-12 QR/P1-SC2B-221(12) contact
153
04/2009
Contact
Signal Male Contact
Signal Female Contact
Partly gold plated over nickel plating
Applicable
Wire
AWG#20∼24
HRS No.
Part No.
Type Packing RoHS
Loose
CL221-0103-0-12 QR/P1-PC2A-111(12) contact
100pin
Chain 5,000pin
CL221-0107-1-12 QR/P1-PC2A-211(12) contact
Applicable
Wire
AWG#24∼28
HRS No.
Part No.
Type Packing RoHS
Loose
CL221-0105-6-12 QR/P1-SC2A-111(12) contact
100pin
Chain 5,000pin
CL221-0109-7-12 QR/P1-SC2A-211(12) contact
Panel Cutout
No. of pin
Rear
Mounting
Front
Mounting
8pin 12pin 16pin 24pin 32pin 40pin
A 15.87 18.45 20.97 26.05 32.4
37.48
B 19.18 24.3
29.34 39.5
52.2
62.36
C 20.18 25.3
30.34 40.5
53.2
63.36
D 26.68 31.8
36.84 47
59.7
69.86
E 18.18 23.3
28.34 38.5
51.2
61.36
F 21.68 26.8
31.84 42
54.7
64.86
G 26.68 31.8
36.84 47
59.7
69.86
No. of pin
A 16.87 18.95 21.49 26.57 32.9
Rear
Mounting
Front
Mounting
29.84 40
52.7
62.86
C 20.18 25.3
30.34 40.5
53.2
63.36
D 26.68 31.8
36.84 47
59.7
69.86
E 26.68 31.8
38.84 47
59.7
69.86
F 19.18 24.3
29.34 39.5
52.2
62.36
G 22.68 27.8
32.84 43
55.7
65.68
Tooling
Kind
Hand Crimp
Tool
HRS No.
37.98
B 19.68 24.8
Part No.
Applicator Contact
CL250-0021-3
TC-QR/P1-PC2B
QR/P1-PC2B-121
CL250-0016-3
TC-QR/P1-PC2A
QR/P1-PC2A-111
CL250-0023-9
TC-QR/P1-SC2B
QR/P1-SC2B-121
CL250-0018-9
TC-QR/P1-SC2A
QR/P1-SC2A-111
CL901-2530-5
AP105-QR/P1-2B-2
QR/P1-PC2B-221
Auto Crimp
Machine
Applicator
Hand Crimp Tool
154
Auto Crimp Machine
CM-105
CL901-0005-4
QR/P1-SC2B-221
QR/P1-PC2A-211
CL901-2528-3
AP105-QR/P1-2A-1
QR/P1-SC2A-211
Extraction Tool
CL250-0029-5
TC-QR/P4-21
QR/P1-SC2, PC2
04/2009
Contacts for thick wire Contact Configuration
Male Housing (Viewed from Wiring Side)
■: indicates a contact hole for thick wire
QR/P4-8P-C (01)
QR/P4-12P-C (01)
QR/P4-16P-C (01)
QR/P4-24P-C (01)
QR/P4-32P-C (01)
QR/P4-40P-C (01)
155
04/2009
