QR/P17A-SCA-211
QR/P17A-SCA-211
    HRS(广濑)
    CONNCRIMPTERMFEMALE16-18AWG
QR/P17A-SCA-211 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. QR/P SERIES PLUG-IN CRIMP CONNECTORS General QR/P series connectors have been developed for Plugin Connection Power and Signal Circuits in copier machine or other equipments which impose the connectors repeated insertion and extraction for maintenence work of them Available number of pins are 4, 8, 12, 16, and 24. Wire termination is done by crimping which offers higher reliability, Especially, the unique sexless contact assures soft and smooth coupling operation which is the most appropriate for Plug-in connection by machine itself. Features (1) The selective plating sexless contact is commonly used for plug and receptacle housings. (2) As QR/P series are crimp type connectors their housing and contacts are supplied separately. The sexless feature of the contact offers customers higer utilization and easier inventory control. (3) The two pairs of contacts at both ends are sequenced for power circuits. They are longer than the others. The molding material is UL94V-0 glass-reinforced polyester. (4) The Guide Pin is made of steel nickel plated to be strong enough against accidental coupling shock. (5) The mount of a receptacle housing is done through Floating Bushes. Thus, they may help to give smoother coupling of connectors by a self-adjusting function. Applications Main applications are PPC, Data Communications, Vending Machines, Instrument, Automatic Equipment, etc. 139 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Material and Finish QR/P Main Rating Material Contact resistance 10 Ω or less at DC1A Insulation resistance 5000M Ω or less at DC 500V Withstand voltage ( 1 min. ) Power AC 3000V Signal AC 1000V Power 13A Max (AWG#14 use) Current rating Voltage rating Insulator Contact PBT* Blue Phosphor bronze Selective gold over Nickel Plating ※UL94V-0 Signal 7A Max (AWG#14 use) Power AC 600V Signal AC 250V Ratings authorized by QR/P safety standards Standard safety UL operating temperature Rated voltage −10∼+60℃ Power AC120V AC125V Signal AC250V, DC300V AC125V, DC150V ― AWG#14 10A Rated current TÜV CSA 10A AWG#16 5A AWG#18 3A 5A 2A 2.5A 1A 1A AWG#20 3A AWG#22 AWG#24 Ordering Information ▲ Connector Unit QR / P − 8 P − C (01) (1) ▲ Contact (2) (3) (4) (9) QR / P − X C − 1 1 1 (1) (5) (4) (6)(7)(8) (1) Series Name (2) No.of Pin 4, 8, 12, 16, 24 (3) Type of Housing P: Plug Housing S: Receptacle Housing (4) Type of Termination C: Crimping (5) Sexless Contact (6) Contact Type 1: Loose Contact 2: Chain Contact (7) Applicable Wire 1: AWG # 14 - # 16 2: AWG # 18 - # 24 (8) Finish 1: Selective Gold over Nickel plating (9) UL, CSA, TÜV Approved Spec. 140 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Plug Housing Unit: mm HRS No. No. of Pin Part No. L P H E CL221-0013-0-01 4 QR/P-04P-C(01) 41 31 5 18.5 CL221-0001-0-01 8 QR/P-08P-C(01) 52 42 5 18.5 CL221-0002-3-01 12 QR/P-12P-C(01) 61 51 5 18.5 CL221-0003-6-01 16 QR/P-16P-C(01) 70 60 5 18.5 CL221-0004-9-01 24 QR/P-24P-C(01) 86.5 77 5.5 18 HRS No. No. of Pin Part No. L P CL221-0014-2-51 4 QR/P-04S-C(51) 41 31 CL221-0005-1-51 8 QR/P-08S-C(51) 52 42 CL221-0006-4-51 12 QR/P-12S-C(51) 61 51 CL221-0007-7-51 16 QR/P-16S-C(51) 70 60 CL221-0008-0-51 24 QR/P-24S-C(51) 86.5 77 RoHS ○ Receptacle Housing Floating Bush MIN Float 0.4mm Unit: mm RoHS ○ Sexless Crimp Contact Unit: mm Applicable Wire AWG#14−16 AWG#18−24 HRS No. Part No. Type Plating CL221-0009-2-12 QR/P-XC-111(12) Loose CL221-0011-4-12 QR/P-XC-211(12) Chain Selective gold CL221-0010-1-12 QR/P-XC-121(12) Loose over Nickel Plating CL221-0012-7-12 QR/P-XC-221(12) Chain RoHS ○ Note* Loose-piece terminals are available in packs. Each pack contains 100 terminals. Strip terminals are available in reels. Each reel contains QR/P-XC-221 Pin 3,500. QR/P-XC-221 Pin 5,000 terminals. 141 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. How To Use Connectors QR/P series connectors are primarily used in Plug-in Connection and the use is shown below. Mount Panel QR/P−CX「 」 QR/P−  」P−C Floating Bush (MIN. Float 0.4mm) QR/P−「 」S−C Note: Determine the combinations with the panel so that the mating clearance between the P side and S side is 2 mm or less. Recommended Mounting Hole (for S Insulation Case) No. of pin Max Rear Mounting Front Mounting 4 pin 8 pin 12 pin 16 pin 24 pin A 31 42 51 60 70 B 26.5 37.5 46.5 55.5 73.5 C 23 34 43 52 70 D 18.5 29.5 38.5 47.5 65.5 E 31 42 51 60 77 F 15.5 26.5 35.5 44.5 62.5 Note: Panel mounting dimensins for the P insulation case are symmetrical with request to the vertical axis, in relation to the S insulation case. Tools HRS No. Item Applicable Contact Applicable Cable CL250-0027-0 TC-2100-111 QR/P-XC-111 AWG#14−#16 CL250-0028-2 TC-2100-121 QR/P-XC-121 AWG#18−#24 Applicator CL901-2531-8 AP105-QR/P-XC-221 QR/P-XC-221 AWG#18−#24 Contact Extraction Tool CL250-0009-8 TC-2100-21 ―― ―― Hand Crimp Tool Hand Crimp Tool 142 Part No. Contact Extraction Tool Auto Crimp Tool CM-105 04/2009 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. Assembling Procedure m .5m ut 3 abo Crimped After assembling, please make sure if the contact is installed as shown in the left by pulling the cable slightly. Procedure for Contact Extraction In case of extracting a contact from the housing in insertion error or in circuit change, follow the steps as shown below. Contact Extrator Spring (Pull the wire) Fig. 1 1. Hold the Contact Extractor, placing the tip of the Extractor on the tip of a contact, then insert it between the contact and the housing, following to the Fig. 1. 2. When the tip of the Extractor comes into contact with a stepped part in the housing, the spring will come off from the stepped part with a snap which is felt. Then, extract the contact by pulling the wire. Fig. 2 3. Above Fig. 1 and Fig. 2 show how to extract a contact from socket housing. The same procedure can be employed to extract a contact from pin housing. 4. When the extracted contact is installed again in the housing, do not forget to raise up the contact spring to the original position. 143 04/2009 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hirose Electric: QR/P-XC-121(07) WI Crimper 105-QR/P-XC-2 QR/P10-12P-C QR/P10-12S-C QR/P10-32P-C QR/P10-32S-C QR/P10-14P-C QR/P10-14S-C QR/P14-14P-C QR/P14-14S-C QR/P14-18S-C QR/P14-18P-C QR/P17-10P4SCA(51) QR/P17-10S4PC-B(51) QR/P17-14P-A(51) QR/P17-14S-B(51) QR/P17-18S-B(50) QR/P17-18S-B1(50) QR/P11-8S-C(09) QR/P17A-SCA-211
QR/P17A-SCA-211 价格&库存
很抱歉,暂时无法提供与“QR/P17A-SCA-211”相匹配的价格&库存,您可以联系我们找货
