PS3F-PC-HOLDER
PS3F-PC-HOLDER
    HRS(广濑)
    CONN PS3F HOLDER
PS3F-PC-HOLDER 数据手册
ITS-P-13029Q PS3F Series Signal Hybrid 100 Amps Power Supply, Front Access Plug-in Connector Features 1. ”Front Access” on system rack side allows cable assembly from mating side. 2. Front access is best suited to the systems with no space at the back side for maintenance. 3. For signal lines, GT8E connector with a good track record in automotive market is applied. 4. Floating screw allows ± 2.5 mm floating mate 5. Finger protection meeting IP2X requirements contributes to operators’ safety. (Female power contact side only) 6. UL, C-UL certified*, will be TÜV approved *Except signal lines (Conditions for safety standards vary depending on submitted applications of current and voltage ratings. Contact Hirose for details. 220 PS3F-2R/8P/10P All the operations can be done from the battery side No maintenance space 26.6 PS3F allows power/signal cables attachment/ detachment from the plug-in side (front side). Optimum for systems installed closely to the container wall etc. with no maintenance space at the back face. 44.2 Dimensions 170 198.2 *:Separately available PS3F-RPC(22)* 198 41 23 Inaccessible from the system back side (71.4) “Front Access” ” Type PS3F-PC-HOLDER* PS3F-2RS/8S/10S Specifications Power Line Signal Line Operating Temperature Range -40 °C to +105 °C (includes temperature rise by current carrying) Rated Current/pin 100 Amps 1 Amp Rated Voltage AC/DC 1000 V AC/DC 250 V Contact Resistance 0.3 mΩ Max. (DC 1A) 60 mΩ Max (100 mA) Insulation Resistance 5000 MΩ Min. (DC 250V) 100 MΩ Min. (DC 500V) Withstanding Voltage AC 2000V, 1 minute AC 650V, 1 minute Durability 100 times (Durability of GT8E: 30 times) 183 8 pos. : GT8E-8S-HU 10 pos. : GT8E-10S-HU System rack side contact : GT8E-2022SCF(01) (Gold plated) Battery module side contact: GT8E-2022SCF (Tin plated) ・ Applicable wire: 22sq (WL1, WL2, UL3832AWM) ・ RoHS, Halogen free (900 ppm maximum chlorine, 900 ppm maximum bromine, and 1500 ppm maximum total of chlorine and bromine) Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities. Issued: Nov. 29, 2013
PS3F-PC-HOLDER 价格&库存
很抱歉,暂时无法提供与“PS3F-PC-HOLDER”相匹配的价格&库存,您可以联系我们找货
