The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS
products
have been discontinued,
or will be discontinued
soon. Please check theStandard
products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
PCN
Series●Product
Compliant
to DIN41612/IEC603-2
PCN10, 12, 13 Series (Product Compliant to DIN Standard: through hole,Wrapping Type)
Double-sided two point Contact System
PCN Series
■Features
Single-sided two point Contact System
1. Compliant with DIN Standard
Comply with IEC603-2/DIN41612 standard.
2. Variation in number of contacts
10, 16, 20, 24, 28, 30, 32, 44, 48, 50, 64, 90, 96, 100, 128, and
144 contacts are available.
3. Two point contact construction
PCN10 and 12 series are constructed with high reliable doublesided two point contacts.
PCN13 series pursues after cost performance, and constructed
with single sided two point contacts.
4. Broad applications
DIN standard types of B, C, R, and Q are available. The flux tight
product is available. The easy lock pin type to prefix the board is
available.
5. Stacking height variation
PCN10H series contains 25, 30, 35, 40 and 45mm stacking
height.
6. Circuit protection function available
PCN10MC series utilizes a sequence structure for circuit
protection function.
7. Cable connector
ID connector for ribbon cable is available.
The connector is prepared for crimping connection for AWC#26
to 30 cables.
■Application
Control equipment, exchange, measuring instruments etc.
A14
Stacking Connector
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose
website
representative.
PCN
Series●Product
Compliant to DIN41612/IEC603-2
Standard
■Product Specifications
Operating Temperature Range: -55 to +85ç (Note 1) Storage Temperature Range: -10 to +60ç (Note 2)
Operating Humidity Range: 85% max
Storage Humidity Range: 40 to 70% (Note 2)
Current rating: 2A
Voltage rating: 300V AC
Rating
Item
Specification
Condition
1.Insulation Resistance 106M ohms
100V DC
2.Withstanding Voltage No flashover or insulation breakdown.
1000V AC (insulation displacement, crimping type: 650V AC) /1 minute.
3.Contact Resistance
20m ohms max.
0.1A
4.Vibration
No electrical discontinuity of 10µs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5.Humidity(Steady state) Insulation resistance : 10 M ohms min.
96 hours at temperature of 40ç and humidity of 90% to 95%
6.Temperature Cycle
(-65ç : 30 minutes→15 to 35ç: 5 minutes max.→
125ç : 30 minutes→15 to 35ç: 5 minutes max.) 5 cycles
6
No damage, cracks, or parts looseness.
500 cycles
7.Durability (Mating/un-mating) Contact resistance : 20m ohms max.
8.Resistance to Soldering heat No deformation of components affecting performance. Manual soldering: 300ç for 3 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Material
Parts
Material
Finish
Remarks
Insulator
PBT
Gray
UL94V-0
Pin header
Brass
Contact area: Gold plated
Receptacle
Copper alloy
Remainer: Tin plated
Contact
■Ordering Information
●PCN 10 Series
PCN10
1
1
2
Series Name
Blank
A
B
C :
D :
EA :
H :
HA :
HB :
HC :
HD :
MC :
A – * P – 2.54 DS
2
3
4
5
6
3 Number of contacts: 2-row : 16, 20, 24, 32, 44, 50, 64, 90, 100
: PCN10
mold type (as listed below)
4 Connector type
Flux prevention type (DSA only)
Rack installation type
With Board prefixed lock pin
Stacking height 35mm type
Stacking height 30mm type
Stacking height 25mm type
Stacking height 45mm type
Stacking height 40mm type
Circuit Protection function type
5 Contact pitch
6 Contact type
DS
DSA
WA
WB
R
C
3-row : 48, 96, 144
4-row : 128
: P : Pin header
: S : Receptacle
: 2.54mm
: Right angle through hole type
: Straight through hole type
: Wrapping type (0.5tx0.7W)
: Wrapping type (0.5tx0.5W)
: Insulation displacement type
: Crimping type
A15
All non-RoHS
products
PCN
Series●Product
Compliant
●PCN 12 Series (Plug)
PCN12
A - * P - 2.54 DS
1
2
3
q Series name
: PCN12
w No symbol
: DIN standard type C (96 Contacts)
A
E-EA
4
5
6
e Number of contacts : 2-row: 10, 16, 20, 24, 28, 32, 44,
50, 64, 90, 100
3-row: 96
: Original type
: With board prefixed lock pin type r
P
: Plug
t Contact pitch
: 2.54mm
y Contact type
: DS: Right angle through hole type
●PCN 12E-*S-2.54 DSA(Socket)
PCN12
1
E - * S - 2.54 DSA
2
3
4
5
q Series name
: PCN12
r
w No symbol
: Standard type
t Contact pitch
E
S
: With board prefixed lock pin type y Contact type
6
: Socket
: 2.54mm
: DSA: Straight through hole type
e Number of contacts : 2-row: 10, 16, 20, 28, 32, 44, 50,
64, 90, 100
3-row: 96
●PCN 13E-*S-2.54 DSA (Socket)
PCN13
1
E - * S - 2.54 DSA
2
3
4
6
q Series name : PCN13
r
w No symbol
: Standard type
t Contact pitch
: 2.54mm
: With board prefixed easy pin type
y Contact style
E
e Number of contacts : 2-row: 10, 16, 20, 30, 32, 44, 50,
64, 90, 100
3-row: 48, 96
*PCN13 series are only socket type.
PCN10 and 12 series are mating connectors.
A16
5
S : Socket
website
representative.
PCN
Series●Product
Standard
BDIN Connector Mating Condition
DIN connectors of Hirose should be used under conditions as illustrated below.
A17
All non-RoHS
products
PCN
Series●Product
Compliant
BContact numbers
According to the inter-combination with DIN standard type C (type B) and type R (type Q), the contact numbers
and row numbers represent contact No. (No.1 to 32) and row No. (a, b, c).
●DIN standard type C and type R represent the 3-row 96 contacts type, including 32 contacts in single-row.
●DIN standard type B and type Q represent the 2-row 64 contacts type, including 32 contacts in single-row.
1 Receptacle straight type
Type C (Type B)
3 Pin header straight type
Type R (Type Q)
2 Pin header right angle type
Type C (Type B)
4 Receptacle right angle type
Type R (Type Q)
Note: The DIN connector is basically standardized in combination with straight and right angle types. As shown
above in illustrationss;
The contact numbers is matched in combination with (1)-(2) and (3)-(4), while the contact numbers are
inverted in combination with (1)-(2) and (3)-(4).
A18
website
representative.
PCN
Series●Product
Standard
PCN10 Series
■Pin Header: 2-row Right Angle Type (DIN standard type B)
Unit:mm
PCN10-*P-2.54DS(72)
Part Number
BPCB mounting pattern
CL No.
Number of Contacts
A
B
C
D
RoHS
PCN10- 16P-2.54DS(72) CL583-0230-9-72
16
33.04 24.39 17.78 27.94
PCN10- 20P-2.54DS(72) CL583-0077-3-72
38.12 29.47 22.86 33.02
PCN10- 32P-2.54DS(72) CL583-0015-6-72
32
53.36 44.71 38.10 48.26
PCN10- 44P-2.54DS(72) CL583-0038-1-72
44
68.60 59.95 53.34 63.50
PCN10- 50P-2.54DS(72) CL583-0016-9-72
50
76.22 67.57 60.96 71.12
PCN10- 64P-2.54DS(72) CL583-0017-1-72
64
94.00 85.35 78.74 88.90
PCN10- 90P-2.54DS(72) CL583-0018-4-72
90
127.02 118.37 111.76 121.92
PCN10-100P-2.54DS(72) CL583-0113-5-72
100
139.72 131.07 124.46 134.62
YES
PCN10A-*P-2.54DS(72)
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
D
PCN10A-116P-2.54DS(72) CL583-0231-1-72
16
PCN10A-120P-2.54DS(72) CL583-0078-6-72
PCN10A-132P-2.54DS(72) CL583-0011-5-72
32
PCN10A-144P-2.54DS(72) CL583-0039-4-72
44
PCN10A-150P-2.54DS(72) CL583-0012-8-72
50
PCN10A-164P-2.54DS(72) CL583-0013-0-72
64
PCN10A-190P-2.54DS(72) CL583-0014-3-72
90
PCN10A-100P-2.54DS(72) CL583-0114-8-72
100
RoHS
YES
A19
All non-RoHS
products
PCN
Series●Product
Compliant
●With Board prefixed lock pin
Unit:mm
PCN10EA*P-2.54DS(72)
●The PCB mounting pattern is
equivalent to PCN10A-*P-2.54DS.
(Refer to page A19.)
Part Number
CL No.
Number of Contacts
A
B
C
D
RoHS
PCN10EA-116P-2.54DS(72) CL583-0256-2-72
16
PCN10EA-120P-2.54DS(72) CL583-0181-5-72
PCN10EA-132P-2.54DS(72) CL583-0182-8-72
32
PCN10EA-144P-2.54DS(72) CL583-0183-0-72
44
PCN10EA-150P-2.54DS(72) CL583-0184-3-72
50
PCN10EA-164P-2.54DS(72) CL583-0185-6-72
64
PCN10EA-190P-2.54DS(72) CL583-0186-9-72
90
PCN10EA-100P-2.54DS(72) CL583-0187-1-72
100
YES
■Pin Header: 2-row Straight Type
PCN10-*P-2.54DSA(72)
A20
*Type Q differs in the outer dimensions and PCB mounting pattern.
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
D
RoHS
PCN10-120P-2.54DSA(72) CL583-0139-9-72
43.30 38.10 29.47 22.86
PCN10-132P-2.54DSA(72) CL583-0007-8-72
32
58.54 53.34 44.71 38.10
PCN10-144P-2.54DSA(72) CL583-0488-8-72
44
73.78 68.58 59.95 53.54
PCN10-150P-2.54DSA(72) CL583-0008-0-72
50
81.40 76.20 67.57 60.96 YES
PCN10-164P-2.54DSA(72) CL583-0009-3-72
64
99.18 93.98 85.35 78.74
PCN10-190P-2.54DSA(72) CL583-0010-2-72
90
132.20 127.00 118.37 111.76
PCN10-100P-2.54DSA(72) CL583-0251-9-72
100
144.90 139.70 131.07 124.46
website
representative.
PCN
Series●Product
Standard
■Receptacle: 2-row Right Angle Type
PCN10C-*S-2.54DS(72)
*Type Q differs in the external size and PCB mounting pattern.
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
D
RoHS
PCN10C-120S-2.54DS(72) CL583-0201-0-72
43.10 29.12 22.86 38.10
PCN10C-132S-2.54DS(72) CL583-0202-3-72
32
58.34 44.36 38.10 53.34
PCN10C-144S-2.54DS(72) CL583-0052-2-72
44
73.58 59.60 53.34 68.58
PCN10C-150S-2.54DS(72) CL583-0168-7-72
50
81.20 67.22 60.96 76.20
PCN10C-160S-2.54DS(72) CL583-0174-0-72
60
93.90 79.92 73.66 88.90
Note PCN10C-164S-2.54DS(72) CL583-0203-6-72
64
98.98 85.00 78.74 93.98
PCN10C-190S-2.54DS(72) CL583-0204-9-72
90
132.00 118.02 111.76 127.00
PCN10C-100S-2.54DS(72) CL583-0178-0-72
100
144.70 130.72 124.46 139.70
YES
Note: DIN standard type Q (Reverse type of type B) indicates PCN10B-64S-2.54DS(72).
■Receptacle: 2-row Straight Type (DIN standard type B)
PCN10-*S-2.54DSA(72)
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
D
RoHS
PCN10-32S-2.54DSA(72) CL583-0019-7-72
32
54.36 49.36 44.36 38.10
PCN10-50S-2.54DSA(72) CL583-0020-6-72
50
77.22 72.22 67.22 60.96 YES
PCN10-64S-2.54DSA(72) CL583-0021-9-72
64
95.00 90.00 85.00 78.74
A21
All non-RoHS
products
PCN
Series●Product
Compliant
■Receptacle: 2-row Wrapping Type (DIN standard type B)
PCN10-*S-2.54
WA(72)
WB(72)
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
D
RoHS
PCN10-32S-2.54WA(72) CL583-0107-2-72
32
PCN10-32S-2.54WB(72) CL583-0067-0-72
32
PCN10-50S-2.54WA(72) CL583-0108-5-72
50
PCN10-50S-2.54WB(72) CL583-0068-2-72
50
PCN10-64S-2.54WA(72) CL583-0109-8-72
64
PCN10-64S-2.54WB(72) CL583-0069-5-72
64
YES
■Flux Prevention Type (DIN standard type B)
PCN10C-*S-2.54DSA(72)
A22
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
D
PCN10C-116S-2.54DSA(72) CL583-0226-1-72
16
34.04 29.04 24.04 17.78
PCN10C-120S-2.54DSA(72) CL583-0079-9-72
39.12 34.12 29.12 22.86
PCN10C-132S-2.54DSA(72) CL583-0033-8-72
32
PCN10C-144S-2.54DSA(72) CL583-0034-0-72
44
69.60 64.60 59.60 53.34
PCN10C-150S-2.54DSA(72) CL583-0035-3-72
50
PCN10C-164S-2.54DSA(72) CL583-0036-6-72
64
PCN10C-190S-2.54DSA(72) CL583-0037-9-72
90
128.02 123.02 118.02 111.76
PCN10C-100S-2.54DSA(72) CL583-0112-2-72
100
140.72 135.72 130.72 124.46
RoHS
YES
website
representative.
PCN
Series●Product
Standard
■Board Prefixed Lock Pin Type (DIN standard type B)
●Flux prevention type
PCN10EA*S-2.54DSA(72)
●The PCB mounting pattern is equivalent to
PCN10-*P-2.54DSA and PCN10C-*P-2.54DSA.
(Refer to catalog page A21 and A22.)
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
D
RoHS
PCN10EA-120S-2.54DSA(72) CL583-0188-4-72
PCN10EA-132S-2.54DSA(72) CL583-0189-7-72
32
PCN10EA-144S-2.54DSA(72) CL583-0190-6-72
44
PCN10EA-150S-2.54DSA(72) CL583-0191-9-72
50
PCN10EA-164S-2.54DSA(72) CL583-0192-1-72
64
PCN10EA-190S-2.54DSA(72) CL583-0193-4-72
90
PCN10EA-100S-2.54DSA(72) CL583-0194-7-72
100
■Receptacle: 2-row Straight Type (Rack installation type)
PCN10D*S-2.54DSA(72)
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
D
RoHS
PCN10D-50S-2.54DSA(72) CL583-0055-0-72
50
PCN10D-64S-2.54DSA(72) CL583-0056-3-72
64
95.00 90.22 85.00 78.74 YES
PCN10D-90S-2.54DSA(72) CL583-0057-6-72
90
A23
All non-RoHS
products
PCN
Series●Product
Compliant
■Pin Header: 3-row Right Angle Type (DIN standard type C)
PCN10-*P-2.54DS(72)
The 48 contact type contains guide key grooves at 8 points.
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
D
E
PCN10-48P-2.54DS(72) CL583-0063-9-72
48
53.36 47.36 44.61 38.10 48.26
PCN10-96P-2.54DS(72) CL583-0001-1-72
96
94.00 88.00 85.25 78.74 88.90
RoHS
YES
Unit:mm
Part Number
A24
CL No.
Number of Contacts
A
B
C
D
E
PCN10A-48P-2.54DS(72) CL583-0064-1-72
48
PCN10A-96P-2.54DS(72) CL583-0006-5-72
96
RoHS
YES
website
representative.
PCN
Series●Product
Standard
■Pin Header: Right Angle Type
PCN10-64ACP-2.54DS(72)
CL583-0046-0-72
RoHS Compliant
PCN10A-64ACP-2.54DS(72)
CL583-0032-5-72
RoHS Compliant
A25
All non-RoHS
products
PCN
Series●Product
Compliant
■Pin Header: 3-row Straight Type (DIN standard type R)
PCN10-96P-2.54DSA(72)
CL583-0002-4-72
RoHS Compliant
PCN10-48P-2.54DSA(72)
CL583-0104-4-72
RoHS Compliant
A26
website
representative.
PCN
Series●Product
Standard
■Receptacle: 3-row Right Angle Type
PCN10A-96S-2.54DS(72)
CL583-0027-5-72
RoHS Compliant
■Receptacle: 3-row Right Angle Type(DIN standard type R)
PCN10B-96S-2.54DS(72)
CL583-0004-0-72
RoHS Compliant
A27
All non-RoHS
products
PCN
Series●Product
Compliant
■Receptacle: 3-row Straight Type(DIN standard type C)
PCN10*S-2.54DSA(72)
Unit:mm
Part Number
A28
Number of Contacts
A
B
PCN10-48S-2.54DSA(72) CL583-0065-4-72
CL No.
48
54.36
50
44.36 38.10
C
D
PCN10-96S-2.54DSA(72) CL583-0003-7-72
96
95.00
90
85.00 78.74
PCN10-96S-2.54WA(72) CL583-0085-1-72
96
95.00
90
85.00 78.74
PCN10-96S-2.54WB(72) CL583-0071-7-72
96
95.00
90
85.00 78.74
RoHS
YES
website
representative.
PCN
Series●Product
Standard
Note: The PCB mounting pattern is equivalent to
PCN10-*S-2.54DSA(72).
Unit:mm
(Refer to catalog page A21.)
Part Number
CL No.
Number of Contacts
A
B
C
D
PCN10EA-48S-2.54DSA(72) CL583-0195-0-72
48
54.36
50
44.36 38.10
Note PCN10EA-96S-2.54DSA(72) CL583-0180-2-72
96
95.00
90
85.00 78.74
RoHS
YES
Note: Flux prevention type
■Receptacle: Straight Type
PCN10-64ACS-2.54DSA(72)
CL583-0044-4-72
RoHS Compliant
A29
All non-RoHS
products
PCN
Series●Product
Compliant
PCN10MA-144P-2.54DS(72)
CL583-0131-7-72
RoHS Compliant
●Board prefixed lock pin attached
PCN10MA-144S-2.54DSA(72)
CL583-0130-4-72
RoHS Compliant
A30
Sequential contacts are located at 27 points up to contact
No.30~38 in both rows b and c.
website
representative.
PCN
Series●Product
Standard
■Pin Header: 4-row Right Angle Type
PCN10-128P-2.54DS(72)
CL583-0087-7-72
RoHS Compliant
PCN10A-128P-2.54DS(72)
CL583-0088-0-72
RoHS Compliant
A31
All non-RoHS
products
PCN
Series●Product
Compliant
■Pin Header: 4-row Straight Type
PCN10-128P-2.54DSA(72)
CL583-0215-5-72
RoHS Compliant
■Receptacle: 4-row Straight Type
PCN10-128S-2.54DSA(72)
Unit:mm
Part Number
A32
CL No.
Number of Contacts RoHS
PCN10-128S-2.54DSA(72) CL583-0089-2-72
128
PCN10-128S-2.54WA(72) CL583-0090-1-72
128
PCN10-128S-2.54WB(72) CL583-0091-4-72
128
YES
website
representative.
PCN
Series●Product
Standard
■Receptacle: 4-row Right Angle Type
PCN10B-128S-2.54DS(72)
CL583-0333-1-72
RoHS Compliant
A33
All non-RoHS
products
PCN
Series●Product
Compliant
■Polarizing Key
Part Number
CL No.
Material
RoHS
PCN10-GK(A)
583-0269-4
PBT, black
YES
Note: Using the polarizing key prevents connector mis-insertion in the board.
Insert the polarizing key in both connectors on the receptacle side and header side.
Insert the polarizing key so as to hit the mold bottom.
A34
website
representative.
PCN
Series●Product
Standard
Ribbon Cable Connector Compliant with DIN Standard
■Cable Insulation displacement Connector
PCN10-64S-2.54R(52)
CL583-0030-0-52
RoHS Compliant
■Insulation displacement Tool
●Guide plate for insulation
displacement + pressing block
●Hi-Flex connection press
PCN10-GPB64
CL550-0168-6
Part Number
CL No.
Hi-Flex connection press HHP502
550-0082-2
Height
Width
Depth
440mm 160mm 350mm
Weight
13kg
A35
All non-RoHS
products
PCN
Series●Product
Compliant
Crimping Connector Compliant with DIN Standard
■3-row Type
PCN10-96S-2.54C
CL583-0100-3
Current rated
Voltage rated
2A
ID type
1A
Crimping type AWG#26
2A
AWG#28·30 1A
300V AC (Crimping type 200V AC)
RoHS Compliant
■2-row Type
PCN10-*S-2.54C
Unit:mm
A36
Part Number
CL No.
Number of Contacts
PCN10-20S-2.54C
CL583-0241-5
A
B
C
D
PCN10-64S-2.54C
CL583-0243-0
64
RoHS
YES
website
representative.
PCN
Series●Product
Standard
■Manual Crimping Tool
●Crimping Contact
●PCN10-2630SC (Full Gold plated)
CL583-0102-9 (RoHS Compliant)
●PCN10-2226SC (Selective Gold plated)
CL583-0216-8 (RoHS Compliant)
●Crimping tool
●PCN10-TA2630HC (PCN10-2230SC)
CL550-0163-2
●PCN10-TA2226HC (PCN10-2226SC)
CL550-0218-2
Applicable Cable
●PCN10-2630SC: AWG#26 to #30
100pcs per bag
●PCN10-2226SC: AWG#22 to #26
100pcs per bag
■Automatic Crimping Tool
Item
Part Number
CL No.
Applicable Contact
Crimping tool unit
CM-105
901-0005-4
AP105-PCN10-2226S
901-3506-6
PCN10-2226SCF
AP105-PCN10-2630S
901-3508-1
PCN10-2630SCF
Applicator
■Contact Extraction Tool
Part Number
CL No.
PCN10-PO
550-0282-1
A37
All non-RoHS
products
PCN
Series●Product
Compliant
Circuit Protection Function Type
PCN10MC-96P-2.54DS(72)
CL583-0120-0-72
RoHS Compliant
PCN10MC-96S-2.54DSA(72)
CL583-0169-0-72
RoHS Compliant
A38
website
representative.
PCN
Series●Product
Standard
■Receptacle: 3-row Wrapping Type
PCN10MC-96S-2.54WB(72)
CL583-0119-1-72
RoHS Compliant
PCN10MC-*P-2.54DS(72)
Unit:mm
Part Number
CL No.
Number of Contacts
PCN10MC-064P-2.54DS(72) CL583-0211-4-72
64
PCN10MC-100P-2.54DS(72) CL583-0212-7-72
100
A
94.0
B
C
D
85.35 78.74 88.9
RoHS
YES
A39
All non-RoHS
products
PCN
Series●Product
Compliant
PCN10MC-*S-2.54DSA(72)
(64 contacts): The sequential contacts are located at 27 points
of 1 to 4 and 26 to 32 in both rows a and b.
(100 contacts): The sequential contacts are located at 22 points
of 1 to 4 and 44 to 50 in both rows a and b.
Unit:mm
Part Number
A40
Number of Contacts
A
B
C
D
PCN10MC-064S-2.54DSA(72) CL583-0213-0-72
CL No.
64
95.0
90.0
85.0
78.74
PCN10MC-100S-2.54DSA(72) CL583-0214-2-72
100
RoHS
YES
website
representative.
PCN
Series●Product
Standard
Stacking Connector
■Stacking Plug
BApplication Pattern
Unit: mm
Part Number
CL No.
Number of Contacts
A
37.92
43.00
48.08
58.24
73.48
81.10
37.92
43.00
48.08
58.24
73.48
81.10
37.92
43.00
48.08
58.24
73.48
81.10
37.92
73.48
81.10
37.92
48.08
73.48
81.10
16
PCN10H- 16P-2.54DSA(72) CL583-0227-4-72
PCN10H- 20P-2.54DSA(72) CL583-0157-0-72
24
PCN10H- 24P-2.54DSA(72) CL583-0425-8-72
32
PCN10H- 32P-2.54DSA(72) CL583-0161-8-72
44
PCN10H- 44P-2.54DSA(72) CL583-0164-6-72
50
PCN10H- 50P-2.54DSA(72) CL583-0401-0-72
16
PCN10HA-16P-2.54DSA(72) CL583-0228-7-72
PCN10HA-20P-2.54DSA(72) CL583-0158-3-72
24
PCN10HA-24P-2.54DSA(72) CL583-0426-0-72
32
PCN10HA-32P-2.54DSA(72) CL583-0162-0-72
44
PCN10HA-44P-2.54DSA(72) CL583-0165-9-72
50
PCN10HA-50P-2.54DSA(72) CL583-0402-2-72
16
PCN10HB-16P-2.54DSA(72) CL583-0229-0-72
PCN10HB-20P-2.54DSA(72) CL583-0159-6-72
24
PCN10HB-24P-2.54DSA(72) CL583-0427-3-72
32
PCN10HB-32P-2.54DSA(72) CL583-0163-3-72
44
PCN10HB-44P-2.54DSA(72) CL583-0166-1-72
50
PCN10HB-50P-2.54DSA(72) CL583-0403-5-72
16
PCN10HC-16P-2.54DSA(72) CL583-0397-4-72
44
PCN10HC-44P-2.54DSA(72) CL583-0399-0-72
50
PCN10HC-50P-2.54DSA(72) CL583-0404-8-72
16
PCN10HD-16P-2.54DSA(72) CL583-0398-7-72
24
PCN10HD-24P-2.54DSA(72) CL583-0429-9-72
44
PCN10HD-44P-2.54DSA(72) CL583-0400-7-72
50
PCN10HD-50P-2.54DSA(72) CL583-0405-0-72
Note: Please note that the above series can not mate with PCN10EA series.
B
33.02
38.10
43.18
53.34
68.58
76.20
33.02
38.10
43.18
53.34
68.58
76.20
33.02
38.10
43.18
53.34
68.58
76.20
33.02
68.58
76.20
33.02
43.18
68.58
76.20
C
24.39
29.47
34.55
44.71
59.95
67.57
24.39
29.47
34.55
44.71
59.95
67.57
24.39
29.47
34.55
44.71
59.95
67.57
24.39
59.95
67.57
24.39
34.55
59.95
67.57
D
17.78
22.86
27.94
38.10
53.34
60.96
17.78
22.86
27.94
38.10
53.34
60.96
17.78
22.86
27.94
38.10
53.34
60.96
17.78
53.34
60.96
17.78
27.94
53.34
60.96
E
F
G
29.8
3.44
35
24.8
3.36
30
RoHS
YES
19.8
3.28
25
39.8
3.30
45
34.8
4.42
40
A41
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
Product Compliant to DIN41612/IEC603-2 Standard
PCN Series
Pin Header Side
●Straight through hole type
Receptacle Side
PCN10EA-* *S-2.54DSA
PCN10CA-* *S-2.54DSA
PCN10DA-* *S-2.54DSA
PCN12EA-* *S-2.54DSA
PCN13EA-* *S-2.54DSA
PCN10EA- * *P-2.54DSA
●Stacking through hole type
PCN10H* - * *P-2.54DSA
●Wrapping type
PCN10EA-* *S-2.54W*
●Right angle through hole type (mounted on the board edge)
PCN10EA-* *P-2.54DS
PCN12EA-* *P-2.54DS
PCN12EA-* *P-2.54DS
PCN10BA-* *S-2.54DS
●Right angle through hole type (mounted on the board)
PCN10AE-* *P-2.54DS
PCN10EA-* *P-2.54DS
PCN12AE-* *P-2.54DS
PCN12EA-* *P-2.54DS
PCN10AE-* *S-2.54DS
PCN10CA-* *S-2.54DS
PCN13EA-* *S-2.54DS
●Press fit type
●Press fit short pin type
PCN11-* *S-2.54PFB-2
PCN11-* *P-2.54W* -2+PCN11-* *P-2.54H-2
●Press fit long pin type
PCN11-* *S-2.54WB-2
●Cable type
PCN10-* *S-2.54C+PCN10-* * * *SC*
PCN10-* *S-2.54R
A12
website
representative.
PCN
Series●Product
Standard
■Coaxial Connector and High Current Contact Composite Type
Pin Header Side
Receptacle Side
PCN10F-* *P-2.54DS
PCN10FA-* *S-2.54DSA
●Wrapping type
PCN10FA-* *S-2.54W*
PCN10FA-* *P-2.54DS
PCN10FB-* *S-2.54DS
PCN10FA-* *S-2.54DS
PCN11F-* *S-2.54PFB-2
PCN11F-* *S-2.54WB-2
Pin Header Side
Receptacle Side
PCN10MC*-* *S-2.54DSA
PCN10MC*-* *P-2.54DS
●Wrapping type
PCN10MC*-* *S-2.54W*
A13
website
representative.
PCN
Series●Product
Standard
●Vertical Connection
●2-row type
: Mounting hole center
C.L. :Center line
A49
All non-RoHS
products
PCN
Series●Product
Compliant
●3-row type
A50
48 contacts: 19.09
48 contacts: 19.09
48 contacts: 17.9
C.L. :Center line
website
representative.
PCN
Series●Product
Standard
C.L. :Center line
48 contacts: 19.09
●3-row 144 Contact type
●4-row type
A51
All non-RoHS
products
PCN
Series●Product
Compliant
●Horizontal Connection
●2-row type
●4-row type
A52
C.L. :Center line
website
representative.
PCN
Series●Product
Standard
●3-row type
48 contacts: 19.09
C.L. :Center line
A53
All non-RoHS
products
PCN
Series●Product
Compliant
●2-row type
C.L. :Center line
●4-row type
A54
48 contacts: 17.9
48 contacts: 17.9
●3-row type
website
representative.
PCN
Series●Product
Standard
■Circuit Protection Function Type
●2-row type
C.L. :Center line
●3-row type
64 contacts :
are indicated at 22
points to contact No.1 to
rows a and b.
100 contacts :
located at 22 points to a1
and a32.
is indicated at 22 points
to contact No.1 to 4 and
and b.
■Stacking Connector
C.L. :Center line
*G : 35, 30, 25, 45, 40
A55
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Hirose Electric:
PCN10B-96S-2.54DS(73) PCN10B-96S-2.54DS(77) PCN10B-96S-2.54DS(82) PCN10A-96P-2.54DS(71) PCN1064P-2.54DSA(77) PCN10A-90P-2.54DS(77) PCN10-90P-2.54DS(71) PCN10-90P-2.54DS(77) PCN10-32S2.54DSA(70) PCN10-32S-2.54DSA(75) PCN10-32S-2.54DS(77) PCN10-64S-2.54DS(77) PCN10C-32S-2.54DSA(75)
PCN10-44P-2.54DS(77) PCN10M-90P-2.54DS(72) PCN10B-64ACS-2.54DS(72) PCN10-64ACP-2.54DS(77)
PCN10D-32S-2.54DSA(72) PCN10D-50S-2.54DSA(72) PCN10D-90S-2.54DSA(72) PCN10D-50S-2.54DS(72)
PCN10D-64S-2.54DS(72) PCN10A-48S-2.54DSA(72) PCN10-32S-2.54WB(72) PCN10-96S-2.54WB(71) PCN10M128P-2.54DS(72) PCN10M-128S-2.54DSA(72) PCN10M-128S-2.54WB(72) PCN10-20P-2.54DS(77) PCN10C-20S2.54DSA(75) PCN10MA-64P-2.54DS(72) PCN10-128P-2.54DS(71) PCN10-128P-2.54DS(77) PCN10-128S2.54DSA(88) PCN10E-64S-2.54DSA(72) PCN10E-50P-2.54DS(72) PCN10E-64P-2.54DS(72) PCN10E-90P2.54DS(72) PCN10MA-50P-2.54DS(72) PCN10-100P-2.54DS(77) PCN10MC-96S-2.54WB(71) PCN10MC-96S2.54WC(71) PCN10MC-96S-2.54DS(71) PCN10A-96S-2.54DSA(72) PCN10-20P-2.54DSA(88) PCN10C-32P2.54DSA(72) PCN10C-96S-2.54DSA(77) PCN10H-44P-2.54DSA(77) PCN10E-100S-2.54DS(72) PCN10EA-96S2.54DSA(87) PCN10EA-32P-2.54DS(77) PCN10EA-44P-2.54DS(77) PCN10EA-32S-2.54DSA(86) PCN10EA-32S2.54DSA(87) PCN10EA-44S-2.54DSA(77) PCN10EA-50S-2.54DSA(75) PCN10EA-64S-2.54DSA(75) PCN10EA-90S2.54DSA(86) PCN10EA-128S-2.54DSA(77) PCN10E-32S-2.54DS(72) PCN10-128P-2.54DSA(77) PCN10-128P2.54DSA(88) PCN10MC-90S-2.54DSA(72) PCN10MC-90P-2.54DS(72) PCN10-128P-2.54DSB(72) PCN10Q-20P2.54DSA(72) PCN10A-64S-2.54DS(72) PCN10B-64S-2.54DS(72) PCN10C-100S-2.54WA(72) PCN10EB-20P2.54DS(72) PCN10EB-32P-2.54DS(72) PCN10EB-44P-2.54DS(72) PCN10EB-64P-2.54DS(72) PCN10EB-100P2.54DS(72) PCN10EB-96P-2.54DS(82) PCN10EB-64ACP-2.54DS(72) PCN10EA-96S-2.54DS(77) PCN10EA-48P2.54DSA(72) PCN10EA-32S-2.54DS(77) PCN10EA-32S-2.54DS(82) PCN10EA-44S-2.54DS(72) PCN10EA-50S2.54DS(77) PCN10EA-64S-2.54DS(77) PCN10EA-100S-2.54DS(72) PCN10EA-32P-2.54DSA(77) PCN10EA-32P2.54DSA(87) PCN10EA-50P-2.54DSA(77) PCN10EA-64P-2.54DSA(77) PCN10EA-90P-2.54DSA(72) PCN10M-96S2.54DS(72) PCN10EA-64ACP-2.54DS(72) PCN10B-128S-2.54DS(92) PCN10B-128S-2.54DS(93) PCN10MCB-64S2.54DSA(72) PCN10MA-48P-2.54DS(72) PCN10-48S-2.54WA(72) PCN10MCA-96P-2.54DS(72) PCN10MCB-96P2.54DS(72) PCN10MCB-64ACP-2.54DS(72) PCN10MCC-64ACP-2.54DS(72)
