PCN10F-24P-2.54DS(72) 数据手册
PCN Series●Product Compliant to DIN41612/IEC603-2 Standard
PCN10F Series (Product Compliant with DIN Standard: Coaxial and High Current Contact Composite Type)
■Features
1. Compliant with the DIN standard
The coaxial connector complies with DIN41612
standard.
2. Variation in number of contacts
Coaxial and high current contact insertion holes 2, 4,
6, and 8 contacts are available.
3. Reliable contact construction
PCN10F series is constructed with high reliable
double-sided 2 point contacts.
4. Broad applications
The receptacle is provided with solder type and
solderless connection type. The contact type is also
provided with straight, right angle and wrapping types.
The high current contact is provided with 10A and 20A
types.
5. High Conformity
High frequency characteristics are 1 GHz and
V.S.W.R1.2 maximum.
■Product Specifications
Current rating: 2A
Rating
Operating Temperature Range: -30 to +85ç (Note 1) Storage Temperature Range: -10 to +60ç (Note 2)
Voltage rating: 300V AC Operating Relative Humidity: 40 to 80%
Item
Operating Humidity Range: 40 to 70%
Specification
Condition
1.Insulation Resistance 10 M ohms
100V DC
2.Withstanding Voltage No flashover or insulation breakdown.
1000V AC/1 minute.
3.Contact Resistance
20m ohms max.
0.1A
4.Vibration
No electrical discontinuity of 10µs or more
6
(Note 2)
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5.Humidity(Steady state) Insulation resistance 10 M ohms min.
96 hours at temperature of 40ç and humidity of 90% to 95%
6.Temperature Cycle
(-65ç : 30 minutes→15 to 35ç: 5 minutes max.→
125ç : 30 minutes→15 to 35ç: 5 minutes max.) 5 cycles
6
No damage, cracks, or parts looseness.
7.Durability (Mating/un-mating) Contact resistance : 20m ohms max.
500 cycles
8.Resistance to Soldering heat No deformation of components affecting performance. Manual soldering: 350ç for 3 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Applications
Measurement instrument, control equipment, exchange, etc.
■Material
Contact
A56
Parts
Material
Finish
Remarks
Insulator
PBT
Gray
UL94V-0
Pin header
Brass
Contact area: Gold plated
________
Receptacle
Copper alloy
Remainder: Tin plated
■Ordering Information
●Plug
PCN10F
q
A – * P – 2.54 DS
w
e
r
t
y
q Series name : PCN10F
rP
: Plug
w Blank
: Board edge on mount type
t Contact pitch
: 2.54mm
: Board on mount type
y Contact type
: DS : Right angle type
A
e Number of contacts : 24(8), 42(6), 60(4), 78(2)
Values in parentheses indicates the number of coaxial
connector and high current contact mounting holes.
●Receptacle
PCN 10F A – * S – 2.54 DSA
q
w
e
q Series name : PCN
w Series No.
: 10F (Soldering type)
11F (Solderless connection type)
e Contact type: Straight
Blank
A
: Coaxial cable connection type
r
t
y
u
r Number of contacts : 24(8), 42(6), 60(4), 78(2)
tS
: Receptacle
y Contact pitch
: 2.54mm
: Coaxial connector through hole type u Contact type
Contact type: Right angle
PCN10F
DS
: right angle type
A
DSA : Straight type
B
WA
: Wrapping type (0.5tx0.7W)
WB
: Wrapping type (0.5tx0.5W)
PCN11F
PFB-2 : Short press fit type
WB-2 : Wrapping press fit type
BDIN Connector Mating Condition
Please be sure to utilize the DIN connector of Hirose within the range as shown below.
A57
■Plug Right Angle Type
(Board edge on mount type)
CL583-0341-0-72
RoHS Compliant
BPCB mounting pattern
BArea A dimensions
●Coaxial connector (PO51-LR-PC-1(40)) ●High current contact
(Power contact PC(72), PCA(72))
PCN10F-42P-2.54DS(72)
CL583-0145-1-72
RoHS Compliant
BArea A dimensions
A58
PCN10F-60P-2.54DS(72)
CL583-0303-0-72
RoHS Compliant
BArea A dimensions
PCN10F-78P-2.54DS(72)
CL583-0321-2-72
RoHS Compliant
BArea A dimensions
A59
(Board on mount type)
PCN10FA-42P-2.54DS(72)
CL583-0148-0-72
RoHS Compliant
BArea A dimensions
●Coaxial connector (PO51-LR-PC-A(40)) ●High current contact
PCN10FA-60P-2.54DS(72)
CL583-0304-3-72
RoHS Compliant
BArea A dimensions
A60
PCN10FA-78P-2.54DS(72)
CL583-0322-5-72
RoHS Compliant
BArea A dimensions
A61
■Receptacle Right Angle Type
PCN10FB-42S-2.54DS(72)
CL583-0334-4-72
RoHS Compliant
PCN10FA-60S-2.54DS(72)
CL583-0337-2-72
RoHS Compliant
A62
■ Receptacle Straight Type
(Coaxial connector/high current cable)
PCN10F-24S-2.54DSA(72)
CL583-0343-5-72
RoHS Compliant
BArea A dimensions
●Coaxial connector (PO51-P-1.5-1A(40)) ●Coaxial connector
(PO51-LP-1.5-A(40))
(Power contact 10S, 20S)
PCN10F-42S-2.54DSA(72)
CL583-0142-3-72
RoHS Compliant
BArea A dimensions
(PO51-LP-1.5-A(40))
A63
PCN10F-60S-2.54DSA(72)
CL583-0305-6-72
RoHS Compliant
BArea A dimensions
(PO51-LP-1.5-A(40))
PCN10F-78S-2.54DSA(72)
CL583-0323-8-72
RoHS Compliant
BArea A dimensions
(PO51-LP-1.5-A(40))
A64
■ Receptacle Wrapping Type
PCN10F-24S-2.54WB(72)
CL583-0345-0-72
RoHS Compliant
BArea A dimensions
(PO51-LP-1.5-A(40))
PCN10F-42S-2.54WA(72)
CL583-0151-4-72
PCN10F-42S-2.54WB(72)
CL583-0271-6-72
RoHS Compliant
BArea A dimensions
(PO51-LP-1.5-A(40))
A65
PCN10F-60S-2.54WB(72)
CL583-0307-1-72
RoHS Compliant
BArea A dimensions
(PO51-LP-1.5-A(40))
A66
■ Receptacle Solderless Connection Type
PCN11F-42S-2.54PFB-2(72)
CL583-1185-1-72
RoHS Compliant
BArea A dimensions
(PO51-LP-1.5-A(40))
PCN11F-60S-2.54PFB-2(72)
CL583-1187-7-72
RoHS Compliant
BArea A dimensions
(PO51-LP-1.5-A(40))
A67
PCN11F-42S-2.54WB-2
CL583-1186-4
RoHS Compliant
BArea A dimensions
(PO51-LP-1.5-A(40))
A68
■ High Current Contact
Material: Brass
Finish: Gold plated
Part Number
CL No.
Operating Current
A
B
POWERCONTACT-20P(72) CL583-0369-9-72
20A(70ç)
Ø3.70
Ø2.8
POWERCONTACT-10P(72) CL583-0449-6-72
10A(85ç)
Ø2.55
Ø1.7
RoHS
YES
Material: Brass
Finish: Gold plated
Note: Power contact -P is for PCN10F-*P-2.54DS(72).
Power contact -PCA is for PCN10FA-*P-2.54DS(72).
Material: Copper alloy
Finish: Gold plated
Part Number
CL No.
Operating Current
A
POWERCONTACT-PC(72)
CL583-0370-8-72
20A(70ç)
10.10
POWERCONTACT-PCA(72) CL583-0371-0-72
20A(70ç)
11.75
RoHS
YES
Part Number
CL No.
Operating Current
A
B
RoHS
Power Contact -20S
583-0374-9
20A (70ç)
Ø3.7
Ø2.8
YES
A69
■ Application
: Mounting hole center
C.L. : Center line
A70
PCN10F-24P-2.54DS(72) 价格&库存
很抱歉,暂时无法提供与“PCN10F-24P-2.54DS(72)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+25.78749
- 10+16.45823
