PCN10FA-30P-2.54DS(72)
    HRS(广濑)
    CONNDINHEADER30POS
PCN10FA-30P-2.54DS(72) 数据手册
PCN Series●Product Compliant to DIN41612/IEC603-2 Standard PCN10F Series (Product Compliant with DIN Standard: Coaxial and High Current Contact Composite Type) ■Features 1. Compliant with the DIN standard The coaxial connector complies with DIN41612 standard. 2. Variation in number of contacts Coaxial and high current contact insertion holes 2, 4, 6, and 8 contacts are available. 3. Reliable contact construction PCN10F series is constructed with high reliable double-sided 2 point contacts. 4. Broad applications The receptacle is provided with solder type and solderless connection type. The contact type is also provided with straight, right angle and wrapping types. The high current contact is provided with 10A and 20A types. 5. High Conformity High frequency characteristics are 1 GHz and V.S.W.R1.2 maximum. ■Product Specifications Current rating: 2A Rating Operating Temperature Range: -30 to +85ç (Note 1) Storage Temperature Range: -10 to +60ç (Note 2) Voltage rating: 300V AC Operating Relative Humidity: 40 to 80% Item Operating Humidity Range: 40 to 70% Specification Condition 1.Insulation Resistance 10 M ohms 100V DC 2.Withstanding Voltage No flashover or insulation breakdown. 1000V AC/1 minute. 3.Contact Resistance 20m ohms max. 0.1A 4.Vibration No electrical discontinuity of 10µs or more 6 (Note 2) Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5.Humidity(Steady state) Insulation resistance 10 M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95% 6.Temperature Cycle (-65ç : 30 minutes→15 to 35ç: 5 minutes max.→ 125ç : 30 minutes→15 to 35ç: 5 minutes max.) 5 cycles 6 No damage, cracks, or parts looseness. 7.Durability (Mating/un-mating) Contact resistance : 20m ohms max. 500 cycles 8.Resistance to Soldering heat No deformation of components affecting performance. Manual soldering: 350ç for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Applications Measurement instrument, control equipment, exchange, etc. ■Material Contact A56 Parts Material Finish Remarks Insulator PBT Gray UL94V-0 Pin header Brass Contact area: Gold plated ________ Receptacle Copper alloy Remainder: Tin plated PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Ordering Information ●Plug PCN10F q A – * P – 2.54 DS w e r t y q Series name : PCN10F rP : Plug w Blank : Board edge on mount type t Contact pitch : 2.54mm : Board on mount type y Contact type : DS : Right angle type A e Number of contacts : 24(8), 42(6), 60(4), 78(2) Values in parentheses indicates the number of coaxial connector and high current contact mounting holes. ●Receptacle PCN 10F A – * S – 2.54 DSA q w e q Series name : PCN w Series No. : 10F (Soldering type) 11F (Solderless connection type) e Contact type: Straight Blank A : Coaxial cable connection type r t y u r Number of contacts : 24(8), 42(6), 60(4), 78(2) Values in parentheses indicates the number of coaxial connector and high current contact mounting holes. tS : Receptacle y Contact pitch : 2.54mm : Coaxial connector through hole type u Contact type Contact type: Right angle PCN10F DS : right angle type A : Board on mount type DSA : Straight type B : Board edge on mount type WA : Wrapping type (0.5tx0.7W) WB : Wrapping type (0.5tx0.5W) PCN11F PFB-2 : Short press fit type WB-2 : Wrapping press fit type BDIN Connector Mating Condition Please be sure to utilize the DIN connector of Hirose within the range as shown below. A57 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Plug Right Angle Type (Board edge on mount type) PCN10F-24P-2.54DS(72) CL583-0341-0-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-LR-PC-1(40)) ●High current contact (Power contact PC(72), PCA(72)) PCN10F-42P-2.54DS(72) CL583-0145-1-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-LR-PC-1(40)) ●High current contact (Power contact PC(72), PCA(72)) A58 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard PCN10F-60P-2.54DS(72) CL583-0303-0-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-LR-PC-1(40)) ●High current contact (Power contact PC(72), PCA(72)) PCN10F-78P-2.54DS(72) CL583-0321-2-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-LR-PC-1(40)) ●High current contact (Power contact PC(72), PCA(72)) A59 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Plug Right Angle Type (Board on mount type) PCN10FA-42P-2.54DS(72) CL583-0148-0-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-LR-PC-A(40)) ●High current contact (Power contact PC(72), PCA(72)) PCN10FA-60P-2.54DS(72) CL583-0304-3-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-LR-PC-A(40)) ●High current contact (Power contact PC(72), PCA(72)) A60 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard PCN10FA-78P-2.54DS(72) CL583-0322-5-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-LR-PC-1(40)) ●High current contact (Power contact PC(72), PCA(72)) A61 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■Receptacle Right Angle Type (Board edge on mount type) PCN10FB-42S-2.54DS(72) CL583-0334-4-72 RoHS Compliant BPCB mounting pattern ■Receptacle Right Angle Type (Board on mount type) PCN10FA-60S-2.54DS(72) CL583-0337-2-72 RoHS Compliant BPCB mounting pattern A62 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■ Receptacle Straight Type (Coaxial connector/high current cable) PCN10F-24S-2.54DSA(72) CL583-0343-5-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-P-1.5-1A(40)) ●Coaxial connector High current contact (PO51-LP-1.5-A(40)) (Power contact 10S, 20S) PCN10F-42S-2.54DSA(72) CL583-0142-3-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-P-1.5-1A(40)) ●Coaxial connector High current contact (PO51-LP-1.5-A(40)) (Power contact 10S, 20S) A63 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard PCN10F-60S-2.54DSA(72) CL583-0305-6-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-P-1.5-1A(40)) ●Coaxial connector High current contact (PO51-LP-1.5-A(40)) (Power contact 10S, 20S) PCN10F-78S-2.54DSA(72) CL583-0323-8-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-P-1.5-1A(40)) ●Coaxial connector High current contact (PO51-LP-1.5-A(40)) (Power contact 10S, 20S) A64 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■ Receptacle Wrapping Type (Coaxial connector/high current cable) PCN10F-24S-2.54WB(72) CL583-0345-0-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-P-1.5-1A(40)) ●Coaxial connector High current contact (PO51-LP-1.5-A(40)) (Power contact 10S, 20S) PCN10F-42S-2.54WA(72) CL583-0151-4-72 PCN10F-42S-2.54WB(72) CL583-0271-6-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-P-1.5-1A(40)) ●Coaxial connector High current contact (PO51-LP-1.5-A(40)) (Power contact 10S, 20S) A65 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard PCN10F-60S-2.54WB(72) CL583-0307-1-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-P-1.5-1A(40)) ●Coaxial connector High current contact (PO51-LP-1.5-A(40)) (Power contact 10S, 20S) A66 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■ Receptacle Solderless Connection Type PCN11F-42S-2.54PFB-2(72) CL583-1185-1-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-P-1.5-1A(40)) ●Coaxial connector High current contact (PO51-LP-1.5-A(40)) (Power contact 10S, 20S) PCN11F-60S-2.54PFB-2(72) CL583-1187-7-72 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-P-1.5-1A(40)) ●Coaxial connector High current contact (PO51-LP-1.5-A(40)) (Power contact 10S, 20S) A67 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard PCN11F-42S-2.54WB-2 CL583-1186-4 RoHS Compliant BPCB mounting pattern BArea A dimensions ●Coaxial connector (PO51-P-1.5-1A(40)) ●Coaxial connector High current contact (PO51-LP-1.5-A(40)) (Power contact 10S, 20S) A68 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■ High Current Contact Material: Brass Finish: Gold plated Part Number CL No. Operating Current A B POWERCONTACT-20P(72) CL583-0369-9-72 20A(70ç) Ø3.70 Ø2.8 POWERCONTACT-10P(72) CL583-0449-6-72 10A(85ç) Ø2.55 Ø1.7 RoHS YES Material: Brass Finish: Gold plated Note: Power contact -P is for PCN10F-*P-2.54DS(72). Power contact -PCA is for PCN10FA-*P-2.54DS(72). Material: Copper alloy Finish: Gold plated Part Number CL No. Operating Current A POWERCONTACT-PC(72) CL583-0370-8-72 20A(70ç) 10.10 POWERCONTACT-PCA(72) CL583-0371-0-72 20A(70ç) 11.75 RoHS YES Part Number CL No. Operating Current A B RoHS Power Contact -20S 583-0374-9 20A (70ç) Ø3.7 Ø2.8 YES A69 PCN Series●Product Compliant to DIN41612/IEC603-2 Standard ■ Application ' : Mounting hole center C.L. : Center line A70
PCN10FA-30P-2.54DS(72) 价格&库存
很抱歉,暂时无法提供与“PCN10FA-30P-2.54DS(72)”相匹配的价格&库存,您可以联系我们找货
